  2. Announcements
  3. 💬 Building a Orange Pi Gateway
110 Posts 24 Posters 66.3k Views 21 Watching
  • R Reza
    @Tag thank you. but i can not setup this . very complicated :) perhaps @marceloaqno can setup this.
    thank you
    Tag
    @Reza
    Can imagine that it is complicated, assuming you used the OPI zero pinout, try the configure example from my previous post. might work.
    Another option you have is get an arduino with the radio attached and just plug it into usb, your messages will appear on i.e /dev/ttyUSB0
    • R Reza
      @Tag
      GPIO3 is pin 15? so change wiring? CE to pin15 ?
      Tag
      wrote on last edited by Tag
      #40
      @Reza
      try this:
      ./configure --spi-spidev-device=/dev/spidev0.0 --my-transport=nrf24 --my-rf24-ce-pin=2 --my-rf24-cs-pin=3
      See this page for your header pinout: http://linux-sunxi.org/Orange_Pi_One#Orientation_of_the_GPIO_header
      the --my-rf24-cs-pin= is key to have it right on your system
      R 1 Reply Last reply
        SdeWeb
        Look here :
        https://linux-sunxi.org/Xunlong_Orange_Pi_One_%26_Lite
        Best.
        • T Tag
          @Reza
          try this:
          R
          R
          Reza
          @Tag my-rf24-cs-pin=3 . 3 is pin15 ? i do it. cs is connect to pin15 (GPIO3) and configre again .but dont work
          S T 2 Replies Last reply
          • R Reza
            SdeWeb
            wrote on last edited by SdeWeb
            #43
            @Reza Try to connect like mine, look above in this thread, then use my own ./configure setup.
            If it's not work, try to use the .fex file for your Orange PI download it here :
            http://linux-sunxi.org/Orange_Pi_One#Sunxi.2FLegacy_Kernel
            • S SdeWeb
              R
              R
              Reza
              @SdeWeb said in 💬 Building a Orange Pi Gateway:
              sorry i cannot understand what is say in this link. thank you .perhaps other friend can found this for orange pi one or lite . i cannot understand really.
              • R Reza
                Tag
                #45
                @Reza
                Did you also change the SPI channel?
                if you use the OPIzero pinout, SPI1 will be SPI0 on the OPI one......
                Your other option will be using a serial gateway: https://www.mysensors.org/build/serial_gateway
                This works for sure on the OPI One
                • T Tag
                  @Reza
                  R
                  R
                  Reza
                  @Tag i change this but dont work, i am useing serial gateway now.but i want use a orangepi gateway:(
                  S 1 Reply Last reply
                  • R Reza
                    SdeWeb
                    @Reza
                    Tell us how you connect your NRF24 module on your Orange PI.
                    On this guide https://www.mysensors.org/build/orange do you followed the section "configure spidev" ?
                    The main things are :
                    1 - install sunxy-tools
                    2 - install MySensors.git
                    But the pinout of the GPIO on your Orange PI is different of the Orange PI zero explained here : https://www.mysensors.org/build/orange
                    So you need to modify the script.bin file, with the command "bin2fex / fex2bin" as explained in the "configure spidev" chapter, if you fail to find the right configuration, try to use the .fex file that you can download here :
                    If you have a Orange PI lite :
                    https://github.com/igorpecovnik/lib/blob/master/config/fex/orangepilite.fex
                    Or if you have a Orange PI One :
                    https://github.com/igorpecovnik/lib/blob/master/config/fex/orangepione.fex
                    then "fex2bin" the file you downloaded, to replace your own script.bin as described in the tuto at the chapter "configure spidev".
                    I think that the pinout of your Orange PI is the same than mine, i got a Orange PI Plus 2E, so look my setup as explained above in this forum, then connect your NRF24 module like mine and use my "./configure" setup.
                    If you succes your gateway setup, dont forget than the next step it's to install a controler to drive it, so you'll need to read guide about setup a controler : https://www.mysensors.org/controller
                    Regards.
                    • S SdeWeb
                      @Reza
                      Regards.
                      R
                      R
                      Reza
                      wrote on last edited by Reza
                      #48
                      @SdeWeb
                      this is my levels:
                      sudo apt-get update
                      sudo apt-get install sunxi-tools
                      bin2fex /boot/script.bin /tmp/orange.fex
                      nano /tmp/orange.fex
                      and replace
                      and save .
                      so:
                      sudo fex2bin /tmp/orange.fex /boot/script.bin
                      sudo reboot
                      root@orangepione:~# ls -l /dev/spidev*
                      crw------- 1 root root 153, 0 Mar 16 12:00 /dev/spidev0.0
                      sudo modprobe gpio-sunxi
                      echo "gpio-sunxi" >> /etc/modules
                      cd MySensors
                      ./configure --spi-spidev-device=/dev/spidev0.0 --my-transport=nrf24 --my-rf24-ce-pin=2 --my-rf24-cs-pin=13
                      ./configure --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyUSB020
                      make
                      sudo ./bin/mysgw -d
                      so i see :
                      mysgw: Starting gateway...
                      mysgw: TSM:INIT
                      mysgw: TSF:WUR:MS=0
                      mysgw: !TSM:INIT:TSP FAIL
                      mysgw: TSM:FAIL:CNT=1
                      mysgw: TSM:FAIL:PDT
                      wiring is similar to zero...
                      • R Reza
                        @SdeWeb
                        this is my levels:
                        sudo apt-get update
                        and replace
                        and save .
                        so:
                        sudo reboot
                        cd MySensors
                        make
                        sudo ./bin/mysgw -d
                        so i see :
                        mysgw: TSM:INIT
                        mysgw: TSF:WUR:MS=0
                        mysgw: TSM:FAIL:PDT
                        SdeWeb
                        @Reza
                        Try to wire like mine and apply my configure setup, here is the copy/paste of the famous previous post from me :
                        I connected my NRF24L01 on OPI P2E like this :
                        NRF24L01 Port Name / (Pin N°) ----- OPI Port (Pin N°) / Name
                                              GND (1)  <-----------> (20) / GND
                                              VCC (2)  <-----------> (17) / 3.3V PWR
                                              CE (3)   <-----------> (22) / (PA2 / GPIO2)
                                              CSN (4)  <-----------> (24) / (PC3 / GPIO67)
                                              SCK (5)  <-----------> (23)
                                              MOSI (6) <-----------> (19) MOSI
                                              MISO (7) <-----------> (21) MISO
                                              IRQ (8)  <-----------> NC
                        So "MySensors" setup is :
                        ./configure --spi-spidev-device=/dev/spidev0.0 --my-transport=nrf24 --my-rf24-ce-pin=2 --my-rf24-cs-pin=67
                        Then
                        ./bin/mysgw -d
                        Return :
                        root@orangepiplus2e:~/MySensors# ./bin/mysgw -d
                        mysgw: TSM:INIT
                        mysgw: TSF:WUR:MS=0
                        mysgw: TSM:INIT:TSP OK
                        mysgw: TSM:INIT:GW MODE
                        mysgw: MCO:REG:NOT NEEDED
                        mysgw: MCO:BGN:STP
                        mysgw: MCO:BGN:INIT OK,TSP=1
                        Best.
                        Seb.
                        • S SdeWeb
                          @Reza
                          Then
                          ./bin/mysgw -d
                          Return :
                          mysgw: TSM:INIT
                          mysgw: TSF:WUR:MS=0
                          mysgw: MCO:BGN:STP
                          Best.
                          Seb.
                          R
                          R
                          Reza
                          @SdeWeb
                          i do wiring true and do your levels... but there is same problem...
                          root@orangepione:~/MySensors# ./configure --spi-spidev-device=/dev/spidev0.0 --my-transport=nrf24 --my-rf24-ce-pin=2 --my-rf24-cs-pin=67
                          [OK] Finished.
                          root@orangepione:~/MySensors# ./configure --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyUSB020
                          [OK] Finished.
                          root@orangepione:~/MySensors# make
                          gcc -MT build/drivers/Linux/log.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/log.c -o build/drivers/Linux/log.o
                          g++ -MT build/drivers/Linux/noniso.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/noniso.cpp -o build/drivers/Linux/noniso.o
                          g++ -MT build/drivers/Linux/GPIO.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/GPIO.cpp -o build/drivers/Linux/GPIO.o
                          g++ -MT build/drivers/Linux/Print.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/Print.cpp -o build/drivers/Linux/Print.o
                          g++ -MT build/drivers/Linux/EthernetClient.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/EthernetClient.cpp -o build/drivers/Linux/EthernetClient.o
                          g++ -MT build/drivers/Linux/SerialPort.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/SerialPort.cpp -o build/drivers/Linux/SerialPort.o
                          g++ -MT build/drivers/Linux/Stream.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/Stream.cpp -o build/drivers/Linux/Stream.o
                          g++ -MT build/drivers/Linux/IPAddress.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/IPAddress.cpp -o build/drivers/Linux/IPAddress.o
                          g++ -MT build/drivers/Linux/compatibility.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/compatibility.cpp -o build/drivers/Linux/compatibility.o
                          g++ -MT build/drivers/Linux/interrupt.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/interrupt.cpp -o build/drivers/Linux/interrupt.o
                          g++ -MT build/drivers/Linux/SerialSimulator.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/SerialSimulator.cpp -o build/drivers/Linux/SerialSimulator.o
                          g++ -MT build/drivers/Linux/SoftEeprom.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/SoftEeprom.cpp -o build/drivers/Linux/SoftEeprom.o
                          g++ -MT build/drivers/Linux/EthernetServer.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/EthernetServer.cpp -o build/drivers/Linux/EthernetServer.o
                          g++ -MT build/examples_linux/mysgw.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c examples_linux/mysgw.cpp -o build/examples_linux/mysgw.o
                          examples_linux/mysgw.cpp:31:0: warning: "MY_RADIO_NRF24" redefined
                          <command-line>:0:0: note: this is the location of the previous definition
                          g++ -MT build/drivers/SPIDEV/SPI.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/SPIDEV/SPI.cpp -o build/drivers/SPIDEV/SPI.o
                          g++ -pthread  -o bin/mysgw build/drivers/Linux/log.o build/drivers/Linux/noniso.o build/drivers/Linux/GPIO.o build/drivers/Linux/Print.o build/drivers/Linux/EthernetClient.o build/drivers/Linux/SerialPort.o build/drivers/Linux/Stream.o build/drivers/Linux/IPAddress.o build/drivers/Linux/compatibility.o build/drivers/Linux/interrupt.o build/drivers/Linux/SerialSimulator.o build/drivers/Linux/SoftEeprom.o build/drivers/Linux/EthernetServer.o build/examples_linux/mysgw.o  build/drivers/SPIDEV/SPI.o
                          root@orangepione:~/MySensors# sudo ./bin/mysgw -d
                          mysgw: TSM:INIT
                          mysgw: TSF:WUR:MS=0
                          mysgw: TSM:FAIL:PDT
                          mysgw: TSM:FAIL:RE-INIT
                          mysgw: TSM:INIT
                          mysgw: TSM:FAIL:CNT=2
                          mysgw: TSM:FAIL:PDT
                          • R
                            R
                            Reza
                            this is all my steps
                            root@orangepione:~# sudo apt-get update
                            Hit:1 http://ports.ubuntu.com xenial InRelease
                            Hit:2 http://apt.armbian.com xenial InRelease
                            Hit:3 http://ports.ubuntu.com xenial-security InRelease
                            Hit:4 http://ports.ubuntu.com xenial-updates InRelease
                            Hit:5 http://ports.ubuntu.com xenial-backports InRelease
                            Reading package lists... Done
                            root@orangepione:~# bin2fex /boot/script.bin /tmp/orange.fex
                            fexc-bin: /boot/script.bin: version: 1.2
                            fexc-bin: /boot/script.bin: size: 34704 (81 sections), header value: 34704
                            root@orangepione:~# nano /tmp/orange.fex
                            crw------- 1 root root 153, 0 Mar 19 11:17 /dev/spidev0.0
                            root@orangepione:~# sudo modprobe gpio-sunxi
                            root@orangepione:~# echo "gpio-sunxi" >> /etc/modules
                            root@orangepione:~# vncserver
                            New 'X' desktop is orangepione:1
                            Starting applications specified in /root/.vnc/xstartup
                            Log file is /root/.vnc/orangepione:1.log
                            root@orangepione:~# *** Error in `pasystray': corrupted double-linked list (not small): 0x01cdb908 ***
                            Cloning into 'MySensors'...
                            remote: Counting objects: 13985, done.
                            remote: Compressing objects: 100% (45/45), done.
                            remote: Total 13985 (delta 8), reused 0 (delta 0), pack-reused 13940
                            Receiving objects: 100% (13985/13985), 9.70 MiB | 181.00 KiB/s, done.
                            Resolving deltas: 100% (8436/8436), done.
                            Checking connectivity... done.
                            root@orangepione:~# cd MySensors
                            [OK] Finished.
                            [OK] Finished.
                            mysgw: MCO:BGN:INIT GW,CP=RNNG----,VER=2.2.0-beta
                            mysgw: TSM:INIT
                            mysgw: TSF:WUR:MS=0
                            mysgw: TSM:FAIL:PDT
                            mysgw: TSM:INIT
                            mysgw: TSM:FAIL:PDT
                            mysgw: TSM:INIT
                            mysgw: TSM:FAIL:CNT=3
                            mysgw: TSM:FAIL:PDT
                            • pansenP
                              pansenP
                              pansen
                              Can you post a picture of your wiring?
                              Orange Pi Plus 2e connected to nrf24 PA via SPI running git-development MySensors gateway, OpenHAB2, mosquitto and MySQL persistence.
                              • R Reza
                                [OK] Finished.
                                [OK] Finished.
                                mysgw: TSM:INIT
                                mysgw: TSF:WUR:MS=0
                                mysgw: TSM:FAIL:PDT
                                mysgw: TSM:INIT
                                mysgw: TSM:FAIL:PDT
                                mysgw: TSM:INIT
                                mysgw: TSM:FAIL:PDT
                                SdeWeb
                                @Reza Hello,
                                Did you modifying the .Fex file before applying the 'configure' setup ?
                                What did you do with nano ?
                                Regards.
                                • pansenP pansen
                                  R
                                  R
                                  Reza
                                  #54
                                  @pansen
                                  red is 3.3
                                  brown is GND
                                  green is CE
                                  orange is SCK
                                  yellow is MISO
                                  violet is CS
                                  blue is MOSI
                                  IRQ is empty
                                  • S SdeWeb
                                    @Reza Hello,
                                    Regards.
                                    R
                                    R
                                    Reza
                                    #55
                                    @SdeWeb
                                    yes. use:
                                    sudo nano /tmp/orange.fex
                                    and remove all line and copy , paste your link and save this.
                                    now orange.fex is:
                                    [product]
                                    version = "100"
                                    machine = "Xunlong Orange Pi One"
                                    [platform]
                                    debug_mode = 1
                                    eraseflag = 1
                                    next_work = 2
                                    [target]
                                    boot_clock = 1008
                                    storage_type = -1
                                    [key_detect_en]
                                    keyen_flag = 0
                                    [fel_key]
                                    fel_key_max = 7
                                    fel_key_min = 2
                                    [card_boot]
                                    logical_start = 40960
                                    sprite_work_delay = 500
                                    sprite_err_delay = 200
                                    sprite_gpio0 = port:PL10<1><default><default><default>
                                    next_work = 3
                                    [box_start_os]
                                    used = 1
                                    start_type = 1
                                    irkey_used = 1
                                    pmukey_used = 1
                                    pmukey_num = 3
                                    led_power = 0
                                    led_state = 0
                                    [boot_init_gpio]
                                    used = 1
                                    gpio0 = port:PL10<1><default><default><1>
                                    gpio1 = port:PG11<1><default><default><1>
                                    [recovery_para]
                                    used = 1
                                    mode = 2
                                    recovery_key = port:PL04<0><default><default><default>
                                    [pm_para]
                                    standby_mode = 1
                                    [card0_boot_para]
                                    card_ctrl = 0
                                    card_high_speed = 1
                                    card_line = 4
                                    sdc_d1 = port:PF00<2><1><2><default>
                                    sdc_d0 = port:PF01<2><1><2><default>
                                    sdc_clk = port:PF02<2><1><2><default>
                                    sdc_cmd = port:PF03<2><1><2><default>
                                    sdc_d3 = port:PF04<2><1><2><default>
                                    sdc_d2 = port:PF05<2><1><2><default>
                                    [card2_boot_para]
                                    card_ctrl = 2
                                    card_high_speed = 1
                                    card_line = 8
                                    sdc_cmd = port:PC06<3><1><2><default>
                                    sdc_clk = port:PC05<3><1><2><default>
                                    sdc_d0 = port:PC08<3><1><2><default>
                                    sdc_d1 = port:PC09<3><1><2><default>
                                    sdc_d2 = port:PC10<3><1><2><default>
                                    sdc_d3 = port:PC11<3><1><2><default>
                                    sdc_d4 = port:PC12<3><1><2><default>
                                    sdc_d5 = port:PC13<3><1><2><default>
                                    sdc_d6 = port:PC14<3><1><2><default>
                                    sdc_d7 = port:PC15<3><1><2><default>
                                    sdc_2xmode = 1
                                    sdc_ddrmode = 1
                                    [twi_para]
                                    twi_port = 0
                                    twi_scl = port:PA11<2><default><default><default>
                                    twi_sda = port:PA12<2><default><default><default>
                                    [uart_para]
                                    uart_debug_port = 0
                                    uart_debug_tx = port:PA04<2><1><default><default>
                                    uart_debug_rx = port:PA05<2><1><default><default>
                                    [force_uart_para]
                                    force_uart_port = 0
                                    force_uart_tx = port:PF02<3><1><default><default>
                                    force_uart_rx = port:PF04<3><1><default><default>
                                    [jtag_para]
                                    jtag_enable = 0
                                    jtag_ms = port:PA00<3><default><default><default>
                                    jtag_ck = port:PA01<3><default><default><default>
                                    jtag_do = port:PA02<3><default><default><default>
                                    jtag_di = port:PA03<3><default><default><default>
                                    [clock]
                                    pll_video = 297
                                    pll_ve = 402
                                    pll_periph0 = 600
                                    pll_gpu = 576
                                    pll_periph1 = 600
                                    pll_de = 864
                                    [dram_para]
                                    dram_clk = 624
                                    dram_type = 3
                                    dram_zq = 0x3b3bfb
                                    dram_odt_en = 1
                                    dram_para1 = 283377664
                                    dram_para2 = 0
                                    dram_mr0 = 6208
                                    dram_mr1 = 64
                                    dram_mr2 = 24
                                    dram_mr3 = 2
                                    dram_tpr0 = 0x48a192
                                    dram_tpr1 = 0x1c2418d
                                    dram_tpr2 = 0x76051
                                    dram_tpr3 = 0x0
                                    dram_tpr4 = 0x0
                                    dram_tpr5 = 0x0
                                    dram_tpr6 = 0x64
                                    dram_tpr7 = 0x0
                                    dram_tpr8 = 0x0
                                    dram_tpr9 = 0x0
                                    dram_tpr10 = 0x0
                                    dram_tpr11 = 0x6aaa0000
                                    dram_tpr12 = 0x7979
                                    dram_tpr13 = 0x800800
                                    [wakeup_src_para]
                                    cpu_en = 0
                                    cpu_freq = 48
                                    pll_ratio = 273
                                    dram_selfresh_en = 1
                                    dram_freq = 36
                                    wakeup_src0 =
                                    wakeup_src_wl = port:PG10<4><default><default><0>
                                    wakeup_src_bt = port:PL03<6><default><default><0>
                                    [twi0]
                                    twi_used = 1
                                    [twi1]
                                    twi_used = 1
                                    twi_scl = port:PA18<3><default><default><default>
                                    twi_sda = port:PA19<3><default><default><default>
                                    [twi2]
                                    twi_used = 0
                                    twi_scl = port:PE12<3><default><default><default>
                                    twi_sda = port:PE13<3><default><default><default>
                                    [uart0]
                                    uart_used = 1
                                    uart_port = 0
                                    uart_type = 2
                                    uart_tx = port:PA04<2><1><default><default>
                                    uart_rx = port:PA05<2><1><default><default>
                                    [uart1]
                                    uart_used = 0
                                    uart_port = 1
                                    uart_type = 4
                                    uart_tx = port:PG06<2><1><default><default>
                                    uart_rx = port:PG07<2><1><default><default>
                                    uart_rts = port:PG08<2><1><default><default>
                                    uart_cts = port:PG09<2><1><default><default>
                                    [uart2]
                                    uart_used = 0
                                    uart_port = 2
                                    uart_type = 4
                                    uart_tx = port:PA00<2><1><default><default>
                                    uart_rx = port:PA01<2><1><default><default>
                                    uart_rts = port:PA02<2><1><default><default>
                                    uart_cts = port:PA03<2><1><default><default>
                                    [uart3]
                                    uart_used = 0
                                    uart_port = 3
                                    uart_type = 4
                                    uart_tx = port:PA13<3><1><default><default>
                                    uart_rx = port:PA14<3><1><default><default>
                                    uart_rts = port:PA15<3><1><default><default>
                                    uart_cts = port:PA16<3><1><default><default>
                                    [spi0]
                                    spi_used = 1
                                    spi_cs_bitmap = 1
                                    spi_mosi = port:PC00<3><default><default><default>
                                    spi_miso = port:PC01<3><default><default><default>
                                    spi_sclk = port:PC02<3><default><default><default>
                                    spi_cs0 = port:PC03<3><1><default><default>
                                    [spi1]
                                    spi_used = 0
                                    spi_cs_bitmap = 1
                                    spi_cs0 = port:PA13<2><1><default><default>
                                    spi_sclk = port:PA14<2><default><default><default>
                                    spi_mosi = port:PA15<2><default><default><default>
                                    spi_miso = port:PA16<2><default><default><default>
                                    [spi_devices]
                                    spi_dev_num = 1
                                    [spi_board0]
                                    modalias = "spidev"
                                    max_speed_hz = 33000000
                                    bus_num = 0
                                    chip_select = 0
                                    mode = 0
                                    full_duplex = 1
                                    manual_cs = 0
                                    ; NOTE: This section is necessary only for "gpio_sunxi" driver
                                    ; which is obsolete for H3 boards
                                    [gpio_para]
                                    gpio_used = 0
                                    gpio_num = 0
                                    ;[led_assign]
                                    ;normal_led = "gpio_pin_2"
                                    ;standby_led = "gpio_pin_1"
                                    [leds_para]
                                    leds_used = 1
                                    green_led = port:PL10<1><default><default><1>
                                    green_led_active_low = 0
                                    red_led = port:PA15<1><default><default><0>
                                    red_led_active_low = 0
                                    [ths_para]
                                    ths_used = 1
                                    ths_trip1_count = 6
                                    ths_trip1_0 = 75
                                    ths_trip1_1 = 80
                                    ths_trip1_2 = 85
                                    ths_trip1_3 = 90
                                    ths_trip1_4 = 95
                                    ths_trip1_5 = 105
                                    ths_trip1_6 = 0
                                    ths_trip1_7 = 0
                                    ths_trip1_0_min = 0
                                    ths_trip1_0_max = 1
                                    ths_trip1_1_min = 1
                                    ths_trip1_1_max = 2
                                    ths_trip1_2_min = 2
                                    ths_trip1_2_max = 3
                                    ths_trip1_3_min = 3
                                    ths_trip1_3_max = 4
                                    ths_trip1_4_min = 4
                                    ths_trip1_4_max = 5
                                    ths_trip1_5_min = 5
                                    ths_trip1_5_max = 7
                                    ths_trip1_6_min = 0
                                    ths_trip1_6_max = 0
                                    ths_trip2_count = 1
                                    ths_trip2_0 = 105
                                    [cooler_table]
                                    cooler_count = 8
                                    cooler0 = "1200000 4 4294967295 0"
                                    cooler1 = "912000 4 4294967295 0"
                                    cooler2 = "768000 4 4294967295 0"
                                    cooler3 = "648000 4 4294967295 0"
                                    cooler4 = "480000 4 4294967295 0"
                                    cooler5 = "480000 3 4294967295 0"
                                    cooler6 = "480000 2 4294967295 0"
                                    cooler7 = "480000 1 4294967295 0"
                                    [nand0_para]
                                    nand_support_2ch = 0
                                    nand0_used = 0
                                    nand0_we = port:PC00<2><default><default><default>
                                    nand0_ale = port:PC01<2><default><default><default>
                                    nand0_cle = port:PC02<2><default><default><default>
                                    nand0_ce1 = port:PC03<2><default><default><default>
                                    nand0_ce0 = port:PC04<2><default><default><default>
                                    nand0_nre = port:PC05<2><default><default><default>
                                    nand0_rb0 = port:PC06<2><default><default><default>
                                    nand0_rb1 = port:PC07<2><default><default><default>
                                    nand0_d0 = port:PC08<2><default><default><default>
                                    nand0_d1 = port:PC09<2><default><default><default>
                                    nand0_d2 = port:PC10<2><default><default><default>
                                    nand0_d3 = port:PC11<2><default><default><default>
                                    nand0_d4 = port:PC12<2><default><default><default>
                                    nand0_d5 = port:PC13<2><default><default><default>
                                    nand0_d6 = port:PC14<2><default><default><default>
                                    nand0_d7 = port:PC15<2><default><default><default>
                                    nand0_ndqs = port:PC16<2><default><default><default>
                                    [boot_disp]
                                    advert_disp = 0
                                    auto_hpd = 1
                                    output_type = 4
                                    hdmi_channel = 0
                                    hdmi_mode = 4
                                    cvbs_channel = 1
                                    cvbs_mode = 11
                                    output_full = 1
                                    hdmi_mode_check = 1
                                    [disp_init]
                                    disp_init_enable = 1
                                    disp_mode = 0
                                    screen0_output_type = 3
                                    screen0_output_mode = 5
                                    screen1_output_type = 3
                                    screen1_output_mode = 5
                                    fb0_format = 0
                                    fb0_width = 0
                                    fb0_height = 0
                                    fb1_format = 0
                                    fb1_width = 0
                                    fb1_height = 0
                                    [hdmi_para]
                                    hdmi_used = 1
                                    hdmi_power = "vcc-hdmi-18"
                                    [tv_para]
                                    tv_used = 0
                                    tv_dac_used = 1
                                    tv_dac_src0 = 0
                                    [pwm0_para]
                                    pwm_used = 0
                                    pwm_positive = port:PA05<3><0><default><default>
                                    ;       If set gamc_phy to use = 2
                                    [gmac0]
                                    gmac_used = 2
                                    gmac_power1 =
                                    [csi0]
                                    vip_used = 1
                                    vip_mode = 0
                                    vip_dev_qty = 1
                                    vip_define_sensor_list = 0
                                    vip_csi_pck = port:PE00<2><default><default><default>
                                    vip_csi_mck = port:PE01<2><default><default><default>
                                    vip_csi_hsync = port:PE02<2><default><default><default>
                                    vip_csi_vsync = port:PE03<2><default><default><default>
                                    vip_csi_d0 = port:PE04<2><default><default><default>
                                    vip_csi_d1 = port:PE05<2><default><default><default>
                                    vip_csi_d2 = port:PE06<2><default><default><default>
                                    vip_csi_d3 = port:PE07<2><default><default><default>
                                    vip_csi_d4 = port:PE08<2><default><default><default>
                                    vip_csi_d5 = port:PE09<2><default><default><default>
                                    vip_csi_d6 = port:PE10<2><default><default><default>
                                    vip_csi_d7 = port:PE11<2><default><default><default>
                                    vip_csi_sck = port:PE12<2><default><default><default>
                                    vip_csi_sda = port:PE13<2><default><default><default>
                                    vip_dev0_mname = "gc2035"
                                    vip_dev0_pos = "front"
                                    vip_dev0_lane = 1
                                    vip_dev0_twi_id = 2
                                    vip_dev0_twi_addr = 120
                                    vip_dev0_isp_used = 0
                                    vip_dev0_fmt = 0
                                    vip_dev0_stby_mode = 0
                                    vip_dev0_vflip = 1
                                    vip_dev0_hflip = 1
                                    vip_dev0_iovdd = ""
                                    vip_dev0_iovdd_vol = 2800000
                                    vip_dev0_avdd = ""
                                    vip_dev0_avdd_vol = 2800000
                                    vip_dev0_dvdd = ""
                                    vip_dev0_dvdd_vol = 1800000
                                    vip_dev0_afvdd = ""
                                    vip_dev0_afvdd_vol = 2800000
                                    vip_dev0_power_en = port:PA17<1><default><default><1>
                                    vip_dev0_reset = port:PE14<1><default><default><1>
                                    vip_dev0_pwdn = port:PE15<1><default><default><0>
                                    vip_dev0_flash_en =
                                    vip_dev0_flash_mode =
                                    vip_dev0_af_pwdn =
                                    vip_dev0_act_used = 0
                                    vip_dev0_act_name = "ad5820_act"
                                    vip_dev0_act_slave = 24
                                    vip_dev1_mname = ""
                                    vip_dev1_pos = "rear"
                                    vip_dev1_lane = 1
                                    vip_dev1_twi_id = 0
                                    vip_dev1_twi_addr =
                                    vip_dev1_isp_used = 0
                                    vip_dev1_fmt = 1
                                    vip_dev1_stby_mode = 0
                                    vip_dev1_vflip = 0
                                    vip_dev1_hflip = 0
                                    vip_dev1_iovdd = ""
                                    vip_dev1_iovdd_vol = 2800000
                                    vip_dev1_avdd = ""
                                    vip_dev1_avdd_vol = 2800000
                                    vip_dev1_dvdd = ""
                                    vip_dev1_dvdd_vol = 1500000
                                    vip_dev1_afvdd = ""
                                    vip_dev1_afvdd_vol = 2800000
                                    vip_dev1_power_en =
                                    vip_dev1_reset =
                                    vip_dev1_pwdn =
                                    vip_dev1_flash_en =
                                    vip_dev1_flash_mode =
                                    vip_dev1_af_pwdn =
                                    [tvout_para]
                                    tvout_used = 0
                                    tvout_channel_num =
                                    tv_en = 0
                                    [tvin_para]
                                    tvin_used = 0
                                    tvin_channel_num =
                                    [di_para]
                                    di_used = 1
                                    [mmc0_para]
                                    sdc_used = 1
                                    sdc_detmode = 3
                                    sdc_buswidth = 4
                                    sdc_det = port:PF06<0><1><2><default>
                                    sdc_use_wp = 0
                                    sdc_wp =
                                    sdc_isio = 0
                                    sdc_regulator = "none"
                                    sdc_power_supply = "none"
                                    [mmc1_para]
                                    sdc_used = 1
                                    sdc_detmode = 4
                                    sdc_buswidth = 4
                                    sdc_clk = port:PG00<2><1><3><default>
                                    sdc_cmd = port:PG01<2><1><3><default>
                                    sdc_d0 = port:PG02<2><1><3><default>
                                    sdc_d1 = port:PG03<2><1><3><default>
                                    sdc_d2 = port:PG04<2><1><3><default>
                                    sdc_d3 = port:PG05<2><1><3><default>
                                    sdc_det =
                                    sdc_use_wp = 0
                                    sdc_wp =
                                    sdc_isio = 1
                                    sdc_2xmode = 1
                                    sdc_ddrmode = 1
                                    [mmc2_para]
                                    sdc_used = 0
                                    sdc_detmode = 3
                                    sdc_buswidth = 8
                                    emmc_rst = port:PC16<3><1><2><default>
                                    sdc_det =
                                    sdc_use_wp = 0
                                    sdc_wp =
                                    sdc_isio = 0
                                    sdc_2xmode = 1
                                    sdc_ddrmode = 1
                                    [smc_para]
                                    smc_used = 0
                                    smc_rst = port:PA09<2><default><default><default>
                                    smc_vppen = port:PA20<3><default><default><default>
                                    smc_vppp = port:PA21<3><default><default><default>
                                    smc_det = port:PA10<2><default><default><default>
                                    smc_vccen = port:PA06<2><default><default><default>
                                    smc_sck = port:PA07<2><default><default><default>
                                    smc_sda = port:PA08<2><default><default><default>
                                    [usbc0]
                                    usb_used = 1
                                    usb_port_type = 2
                                    usb_detect_type = 0
                                    usb_id_gpio = port:PG12<0><1><default><default>
                                    usb_det_vbus_gpio = port:PG12<0><1><default><default>
                                    usb_drv_vbus_gpio = port:PL02<1><0><default><0>
                                    usb_host_init_state = 1
                                    usb_restrict_gpio =
                                    usb_restric_flag = 0
                                    usb_restric_voltage = 3550000
                                    usb_restric_capacity = 5
                                    usb_regulator_io = "nocare"
                                    usb_regulator_vol = 0
                                    usb_not_suspend = 0
                                    [usbc1]
                                    usb_used = 1
                                    usb_drv_vbus_gpio =
                                    usb_restrict_gpio =
                                    usb_not_suspend = 0
                                    [usbc2]
                                    usb_used = 1
                                    usb_drv_vbus_gpio =
                                    usb_restrict_gpio =
                                    usb_not_suspend = 0
                                    [usbc3]
                                    usb_used = 1
                                    usb_drv_vbus_gpio =
                                    usb_restrict_gpio =
                                    usb_not_suspend = 0
                                    [usb_feature]
                                    vendor_id = 6353
                                    mass_storage_id = 1
                                    adb_id = 2
                                    manufacturer_name = "USB Developer"
                                    product_name = "Android"
                                    serial_number = "20080411"
                                    [msc_feature]
                                    vendor_name = "USB 2.0"
                                    product_name = "USB Flash Driver"
                                    release = 100
                                    luns = 3
                                    [serial_feature]
                                    serial_unique = 0
                                    [module_para]
                                    module_num = 7
                                    module_power0 = "vcc-wifi-33"
                                    module_power0_vol = 0
                                    module_power1 =
                                    module_power1_vol =
                                    module_power2 =
                                    module_power2_vol =
                                    module_power3 =
                                    module_power3_vol =
                                    chip_en =
                                    lpo_use_apclk =
                                    [wifi_para]
                                    wifi_used = 0
                                    wifi_sdc_id = 1
                                    wifi_usbc_id = 5
                                    wifi_usbc_type = 1
                                    wl_reg_on = port:PL07<1><default><default><0>
                                    wl_host_wake = port:PG10<0><default><default><0>
                                    wl_host_wake_invert = 0
                                    [bt_para]
                                    bt_used = 0
                                    bt_uart_id = 1
                                    bt_rst_n =
                                    bt_wake =
                                    bt_host_wake =
                                    bt_host_wake_invert = 0
                                    [pcm0]
                                    daudio_used = 0
                                    daudio_master = 4
                                    daudio_select = 1
                                    audio_format = 1
                                    signal_inversion = 1
                                    mclk_fs = 128
                                    sample_resolution = 16
                                    slot_width_select = 32
                                    pcm_lrck_period = 32
                                    pcm_lrckr_period = 1
                                    msb_lsb_first = 0
                                    sign_extend = 0
                                    slot_index = 0
                                    slot_width = 32
                                    frame_width = 0
                                    tx_data_mode = 0
                                    rx_data_mode = 0
                                    i2s_mclk = port:PA18<2><1><default><default>
                                    i2s_bclk = port:PA19<2><1><default><default>
                                    i2s_dout0 = port:PA20<2><1><default><default>
                                    i2s_din = port:PA21<2><1><default><default>
                                    [pcm1]
                                    daudio_used = 0
                                    daudio_master = 4
                                    daudio_select = 1
                                    audio_format = 1
                                    mclk_fs = 128
                                    msb_lsb_first = 0
                                    sign_extend = 0
                                    slot_index = 0
                                    slot_width = 32
                                    frame_width = 0
                                    tx_data_mode = 0
                                    rx_data_mode = 0
                                    i2s_mclk = port:PG10<2><1><default><default>
                                    i2s_bclk = port:PG11<2><1><default><default>
                                    i2s_dout0 = port:PG12<2><1><default><default>
                                    i2s_din = port:PG13<2><1><default><default>
                                    [audio0]
                                    audio_used = 1
                                    lineout_vol = 31
                                    cap_vol = 5
                                    audio_hp_ldo = "none"
                                    adcagc_used = 0
                                    adcdrc_used = 0
                                    dacdrc_used = 0
                                    adchpf_used = 0
                                    dachpf_used = 0
                                    audio_pa_ctrl = port:PA16<1><default><default><0>
                                    [spdif0]
                                    spdif_used = 0
                                    spdif_dout = port:PA17<2><1><default><default>
                                    [audiohub]
                                    hub_used = 0
                                    codec_used = 1
                                    spdif_used = 1
                                    hdmi_used = 1
                                    [s_cir0]
                                    ir_used = 0
                                    ir_rx = port:PL11<2><1><default><default>
                                    ir_power_key_code0 = 87
                                    ir_addr_code0 = 40704
                                    ir_power_key_code1 = 26
                                    ir_addr_code1 = 64260
                                    ir_power_key_code2 = 20
                                    ir_addr_code2 = 32640
                                    ir_power_key_code3 = 21
                                    ir_addr_code3 = 32640
                                    ir_power_key_code4 = 11
                                    ir_addr_code4 = 63240
                                    ir_power_key_code5 = 3
                                    ir_addr_code5 = 239
                                    ir_power_key_code6 = 159
                                    ir_addr_code6 = 19635
                                    ir_power_key_code7 = 10
                                    ir_addr_code7 = 30536
                                    ir_power_key_code8 = 69
                                    ir_addr_code8 = 48386
                                    ir_power_key_code9 = 77
                                    ir_addr_code9 = 56865
                                    ir_power_key_code10 = 24
                                    ir_addr_code10 = 65025
                                    ir_power_key_code11 = 87
                                    ir_addr_code11 = 65280
                                    ir_power_key_code12 = 77
                                    ir_addr_code12 = 65344
                                    [cir]
                                    ir_used = 1
                                    ir_tx = port:PH07<2><default><default><default>
                                    ; dvfs voltage-frequency table configuration
                                    ; pmuic_type:0:none, 1:gpio, 2:i2c
                                    ; pmu_gpio0: gpio config.
                                    ; pmu_levelx: 0~9999: voltage(mV), 10000~90000:gpio0 state. voltage form high to low.
                                    ; extremity_freq(Hz): cpu extremity frequency when run benckmark or demo apk
                                    ;                     1536MHz@1500mV with radiator, 1296MHz@1340mV without radiator
                                    ; max_freq: cpu maximum frequency, based on Hz, can not be more than 1200MHz
                                    ; min_freq: cpu minimum frequency, based on Hz, can not be less than 60MHz
                                    ; LV_count: count of LV_freq/LV_volt, must be < 16
                                    ; LV1: core vdd is 1.50v if cpu frequency is (1296Mhz,  1536Mhz]
                                    ; LV2: core vdd is 1.34v if cpu frequency is (1200Mhz,  1296Mhz]
                                    ; LV3: core vdd is 1.32v if cpu frequency is (1008Mhz,  1200Mhz]
                                    ; LV4: core vdd is 1.20v if cpu frequency is (816Mhz,   1008Mhz]
                                    ; LV5: core vdd is 1.10v if cpu frequency is (648Mhz,    816Mhz]
                                    ; LV6: core vdd is 1.04v if cpu frequency is (0Mhz,      648Mhz]
                                    ; LV7: core vdd is 1.04v if cpu frequency is (0Mhz,      648Mhz]
                                    ; LV8: core vdd is 1.04v if cpu frequency is (0Mhz,      648Mhz]
                                    [dvfs_table]
                                    pmuic_type = 1
                                    pmu_gpio0 = port:PL06<1><1><2><1>
                                    pmu_level0 = 11300
                                    pmu_level1 = 1100
                                    max_freq = 1200000000
                                    min_freq = 480000000
                                    LV_count = 5
                                    LV1_freq = 1200000000
                                    LV1_volt = 1300
                                    LV2_freq = 1008000000
                                    LV2_volt = 1300
                                    LV3_freq = 912000000
                                    LV3_volt = 1100
                                    LV4_freq = 648000000
                                    LV4_volt = 1100
                                    LV5_freq = 480000000
                                    LV5_volt = 1100
                                    [gpu_dvfs_table]
                                    G_LV_count = 3
                                    G_LV0_freq = 312000000
                                    G_LV0_volt = 1200000
                                    G_LV1_freq = 384000000
                                    G_LV1_volt = 1200000
                                    G_LV2_freq = 456000000
                                    G_LV2_volt = 1200000
                                    [Vdevice]
                                    Vdevice_used = 0
                                    Vdevice_0 = port:PH10<5><1><2><default>
                                    Vdevice_1 = port:PH11<5><1><2><default>
                                    [s_uart0]
                                    s_uart_used = 0
                                    s_uart_tx = port:PL02<2><default><default><default>
                                    s_uart_rx = port:PL03<2><default><default><default>
                                    [s_rsb0]
                                    s_rsb_used = 1
                                    s_rsb_sck = port:PL00<2><1><2><default>
                                    s_rsb_sda = port:PL01<2><1><2><default>
                                    [s_jtag0]
                                    s_jtag_used = 0
                                    s_jtag_tms = port:PL04<2><1><2><default>
                                    s_jtag_tck = port:PL05<2><1><2><default>
                                    s_jtag_tdo = port:PL06<2><1><2><default>
                                    s_jtag_tdi = port:PL07<2><1><2><default>
                                    [s_powchk]
                                    s_powchk_used = -2147483648
                                    s_power_reg = 0
                                    s_system_power = 50
                                    [sim0]
                                    scr_used = 0
                                    scr_vccen = port:PA06<2><default><default><default>
                                    scr_slk = port:PA07<2><default><default><default>
                                    scr_sda = port:PA08<2><default><default><default>
                                    scr_rst = port:PA09<2><default><default><default>
                                    scr_det = port:PA10<2><default><default><default>
                                    [ts0]
                                    tsc_used = 0
                                    tsc_clk = port:PE00<3><default><default><default>
                                    tsc_err = port:PE01<3><default><default><default>
                                    tsc_sync = port:PE02<3><default><default><default>
                                    tsc_dvld = port:PE03<3><default><default><default>
                                    tsc_d0 = port:PE04<3><default><default><default>
                                    tsc_d1 = port:PE05<3><default><default><default>
                                    tsc_d2 = port:PE06<3><default><default><default>
                                    tsc_d3 = port:PE07<3><default><default><default>
                                    tsc_d4 = port:PE08<3><default><default><default>
                                    tsc_d5 = port:PE09<3><default><default><default>
                                    tsc_d6 = port:PE10<3><default><default><default>
                                    tsc_d7 = port:PE11<3><default><default><default>
                                    [gpio_power_key]
                                    key_used = 1
                                    key_io = port:PL03<6><default><default><0>
                                    [key_para]
                                    key_used = 0
                                    key_cnt = 5
                                    key1_vol = 222
                                    key2_vol = 444
                                    key3_vol = 666
                                    key4_vol = 857
                                    key5_vol = 2000
                                    [d7s_para]
                                    d7s_used = 0
                                    din_gpio = port:PD00<1><default><default><1>
                                    clk_gpio = port:PD01<1><default><default><1>
                                    stb_gpio = port:PD02<1><default><default><1>
                                    ;mali parameters
                                    [mali_para]
                                    mali_used = 1
                                    mali_clkdiv = 1
                                    mali_extreme_freq = 600
                                    mali_extreme_vol = 1400
                                    ;1wire parameters (default - PA20)
                                    [w1_para]
                                    w1_used = 1
                                    gpio = 20
                                    [corekeeper]
                                    corekeeper_enabled = 1
                                    • R Reza
                                      @SdeWeb
                                      yes. use:
                                      now orange.fex is:
                                      [product]
                                      version = "100"
                                      [platform]
                                      debug_mode = 1
                                      eraseflag = 1
                                      next_work = 2
                                      [target]
                                      boot_clock = 1008
                                      storage_type = -1
                                      [key_detect_en]
                                      keyen_flag = 0
                                      [fel_key]
                                      fel_key_max = 7
                                      fel_key_min = 2
                                      [card_boot]
                                      next_work = 3
                                      [box_start_os]
                                      used = 1
                                      start_type = 1
                                      irkey_used = 1
                                      pmukey_used = 1
                                      pmukey_num = 3
                                      led_power = 0
                                      led_state = 0
                                      [boot_init_gpio]
                                      used = 1
                                      [recovery_para]
                                      used = 1
                                      mode = 2
                                      [pm_para]
                                      standby_mode = 1
                                      [card0_boot_para]
                                      card_ctrl = 0
                                      card_high_speed = 1
                                      card_line = 4
                                      [card2_boot_para]
                                      card_ctrl = 2
                                      card_high_speed = 1
                                      card_line = 8
                                      sdc_2xmode = 1
                                      sdc_ddrmode = 1
                                      [twi_para]
                                      twi_port = 0
                                      [uart_para]
                                      uart_debug_port = 0
                                      [force_uart_para]
                                      force_uart_port = 0
                                      [jtag_para]
                                      jtag_enable = 0
                                      [clock]
                                      pll_video = 297
                                      pll_ve = 402
                                      pll_periph0 = 600
                                      pll_gpu = 576
                                      pll_periph1 = 600
                                      pll_de = 864
                                      [dram_para]
                                      dram_clk = 624
                                      dram_type = 3
                                      dram_zq = 0x3b3bfb
                                      dram_odt_en = 1
                                      dram_para2 = 0
                                      dram_mr0 = 6208
                                      dram_mr1 = 64
                                      dram_mr2 = 24
                                      dram_mr3 = 2
                                      dram_tpr2 = 0x76051
                                      dram_tpr3 = 0x0
                                      dram_tpr4 = 0x0
                                      dram_tpr5 = 0x0
                                      dram_tpr6 = 0x64
                                      dram_tpr7 = 0x0
                                      dram_tpr8 = 0x0
                                      dram_tpr9 = 0x0
                                      dram_tpr10 = 0x0
                                      dram_tpr12 = 0x7979
                                      [wakeup_src_para]
                                      cpu_en = 0
                                      cpu_freq = 48
                                      pll_ratio = 273
                                      dram_freq = 36
                                      wakeup_src0 =
                                      [twi0]
                                      twi_used = 1
                                      [twi1]
                                      twi_used = 1
                                      [twi2]
                                      twi_used = 0
                                      [uart0]
                                      uart_used = 1
                                      uart_port = 0
                                      uart_type = 2
                                      [uart1]
                                      uart_used = 0
                                      uart_port = 1
                                      uart_type = 4
                                      [uart2]
                                      uart_used = 0
                                      uart_port = 2
                                      uart_type = 4
                                      [uart3]
                                      uart_used = 0
                                      uart_port = 3
                                      uart_type = 4
                                      [spi0]
                                      spi_used = 1
                                      spi_cs_bitmap = 1
                                      [spi1]
                                      spi_used = 0
                                      spi_cs_bitmap = 1
                                      [spi_devices]
                                      spi_dev_num = 1
                                      [spi_board0]
                                      modalias = "spidev"
                                      bus_num = 0
                                      chip_select = 0
                                      mode = 0
                                      full_duplex = 1
                                      manual_cs = 0
                                      [gpio_para]
                                      gpio_used = 0
                                      gpio_num = 0
                                      ;[led_assign]
                                      [leds_para]
                                      leds_used = 1
                                      [ths_para]
                                      ths_used = 1
                                      ths_trip1_count = 6
                                      ths_trip1_0 = 75
                                      ths_trip1_1 = 80
                                      ths_trip1_2 = 85
                                      ths_trip1_3 = 90
                                      ths_trip1_4 = 95
                                      ths_trip1_5 = 105
                                      ths_trip1_6 = 0
                                      ths_trip1_7 = 0
                                      ths_trip1_0_min = 0
                                      ths_trip1_0_max = 1
                                      ths_trip1_1_min = 1
                                      ths_trip1_1_max = 2
                                      ths_trip1_2_min = 2
                                      ths_trip1_2_max = 3
                                      ths_trip1_3_min = 3
                                      ths_trip1_3_max = 4
                                      ths_trip1_4_min = 4
                                      ths_trip1_4_max = 5
                                      ths_trip1_5_min = 5
                                      ths_trip1_5_max = 7
                                      ths_trip1_6_min = 0
                                      ths_trip1_6_max = 0
                                      ths_trip2_count = 1
                                      ths_trip2_0 = 105
                                      [cooler_table]
                                      cooler_count = 8
                                      [nand0_para]
                                      nand0_used = 0
                                      [boot_disp]
                                      advert_disp = 0
                                      auto_hpd = 1
                                      output_type = 4
                                      hdmi_channel = 0
                                      hdmi_mode = 4
                                      cvbs_channel = 1
                                      cvbs_mode = 11
                                      output_full = 1
                                      hdmi_mode_check = 1
                                      [disp_init]
                                      disp_mode = 0
                                      fb0_format = 0
                                      fb0_width = 0
                                      fb0_height = 0
                                      fb1_format = 0
                                      fb1_width = 0
                                      fb1_height = 0
                                      [hdmi_para]
                                      hdmi_used = 1
                                      [tv_para]
                                      tv_used = 0
                                      tv_dac_used = 1
                                      tv_dac_src0 = 0
                                      [pwm0_para]
                                      pwm_used = 0
                                      [gmac0]
                                      gmac_used = 2
                                      gmac_power1 =
                                      [csi0]
                                      vip_used = 1
                                      vip_mode = 0
                                      vip_dev_qty = 1
                                      vip_dev0_lane = 1
                                      vip_dev0_twi_id = 2
                                      vip_dev0_fmt = 0
                                      vip_dev0_vflip = 1
                                      vip_dev0_hflip = 1
                                      vip_dev0_iovdd = ""
                                      vip_dev0_avdd = ""
                                      vip_dev0_dvdd = ""
                                      vip_dev0_afvdd = ""
                                      vip_dev0_flash_en =
                                      vip_dev0_af_pwdn =
                                      vip_dev1_mname = ""
                                      vip_dev1_lane = 1
                                      vip_dev1_twi_id = 0
                                      vip_dev1_twi_addr =
                                      vip_dev1_fmt = 1
                                      vip_dev1_vflip = 0
                                      vip_dev1_hflip = 0
                                      vip_dev1_iovdd = ""
                                      vip_dev1_avdd = ""
                                      vip_dev1_dvdd = ""
                                      vip_dev1_afvdd = ""
                                      vip_dev1_power_en =
                                      vip_dev1_reset =
                                      vip_dev1_pwdn =
                                      vip_dev1_flash_en =
                                      vip_dev1_af_pwdn =
                                      [tvout_para]
                                      tvout_used = 0
                                      tvout_channel_num =
                                      tv_en = 0
                                      [tvin_para]
                                      tvin_used = 0
                                      tvin_channel_num =
                                      [di_para]
                                      di_used = 1
                                      [mmc0_para]
                                      sdc_used = 1
                                      sdc_detmode = 3
                                      sdc_buswidth = 4
                                      sdc_use_wp = 0
                                      sdc_wp =
                                      sdc_isio = 0
                                      [mmc1_para]
                                      sdc_used = 1
                                      sdc_detmode = 4
                                      sdc_buswidth = 4
                                      sdc_det =
                                      sdc_use_wp = 0
                                      sdc_wp =
                                      sdc_isio = 1
                                      sdc_2xmode = 1
                                      sdc_ddrmode = 1
                                      [mmc2_para]
                                      sdc_used = 0
                                      sdc_detmode = 3
                                      sdc_buswidth = 8
                                      sdc_det =
                                      sdc_use_wp = 0
                                      sdc_wp =
                                      sdc_isio = 0
                                      sdc_2xmode = 1
                                      sdc_ddrmode = 1
                                      [smc_para]
                                      smc_used = 0
                                      [usbc0]
                                      usb_used = 1
                                      usb_port_type = 2
                                      usb_detect_type = 0
                                      usb_restrict_gpio =
                                      usb_not_suspend = 0
                                      [usbc1]
                                      usb_used = 1
                                      usb_drv_vbus_gpio =
                                      usb_restrict_gpio =
                                      usb_not_suspend = 0
                                      [usbc2]
                                      usb_used = 1
                                      usb_drv_vbus_gpio =
                                      usb_restrict_gpio =
                                      usb_not_suspend = 0
                                      [usbc3]
                                      usb_used = 1
                                      usb_drv_vbus_gpio =
                                      usb_restrict_gpio =
                                      usb_not_suspend = 0
                                      [usb_feature]
                                      vendor_id = 6353
                                      mass_storage_id = 1
                                      adb_id = 2
                                      [msc_feature]
                                      release = 100
                                      luns = 3
                                      [serial_feature]
                                      serial_unique = 0
                                      [module_para]
                                      module_num = 7
                                      module_power1 =
                                      module_power1_vol =
                                      module_power2 =
                                      module_power2_vol =
                                      module_power3 =
                                      module_power3_vol =
                                      chip_en =
                                      lpo_use_apclk =
                                      [wifi_para]
                                      wifi_used = 0
                                      wifi_sdc_id = 1
                                      wifi_usbc_id = 5
                                      wifi_usbc_type = 1
                                      [bt_para]
                                      bt_used = 0
                                      bt_uart_id = 1
                                      bt_rst_n =
                                      bt_wake =
                                      bt_host_wake =
                                      [pcm0]
                                      daudio_used = 0
                                      daudio_master = 4
                                      daudio_select = 1
                                      audio_format = 1
                                      mclk_fs = 128
                                      msb_lsb_first = 0
                                      sign_extend = 0
                                      slot_index = 0
                                      slot_width = 32
                                      frame_width = 0
                                      tx_data_mode = 0
                                      rx_data_mode = 0
                                      [pcm1]
                                      daudio_used = 0
                                      daudio_master = 4
                                      daudio_select = 1
                                      audio_format = 1
                                      mclk_fs = 128
                                      msb_lsb_first = 0
                                      sign_extend = 0
                                      slot_index = 0
                                      slot_width = 32
                                      frame_width = 0
                                      tx_data_mode = 0
                                      rx_data_mode = 0
                                      [audio0]
                                      audio_used = 1
                                      lineout_vol = 31
                                      cap_vol = 5
                                      adcagc_used = 0
                                      adcdrc_used = 0
                                      dacdrc_used = 0
                                      adchpf_used = 0
                                      dachpf_used = 0
                                      [spdif0]
                                      spdif_used = 0
                                      [audiohub]
                                      hub_used = 0
                                      codec_used = 1
                                      spdif_used = 1
                                      hdmi_used = 1
                                      [s_cir0]
                                      ir_used = 0
                                      ir_addr_code5 = 239
                                      [cir]
                                      ir_used = 1
                                      [dvfs_table]
                                      pmuic_type = 1
                                      pmu_level0 = 11300
                                      pmu_level1 = 1100
                                      LV_count = 5
                                      LV1_volt = 1300
                                      LV2_volt = 1300
                                      LV3_volt = 1100
                                      LV4_volt = 1100
                                      LV5_volt = 1100
                                      [gpu_dvfs_table]
                                      G_LV_count = 3
                                      [Vdevice]
                                      Vdevice_used = 0
                                      [s_uart0]
                                      s_uart_used = 0
                                      [s_rsb0]
                                      s_rsb_used = 1
                                      [s_jtag0]
                                      s_jtag_used = 0
                                      [s_powchk]
                                      s_power_reg = 0
                                      s_system_power = 50
                                      [sim0]
                                      scr_used = 0
                                      [ts0]
                                      tsc_used = 0
                                      [gpio_power_key]
                                      key_used = 1
                                      [key_para]
                                      key_used = 0
                                      key_cnt = 5
                                      key1_vol = 222
                                      key2_vol = 444
                                      key3_vol = 666
                                      key4_vol = 857
                                      key5_vol = 2000
                                      [d7s_para]
                                      d7s_used = 0
                                      ;mali parameters
                                      [mali_para]
                                      mali_used = 1
                                      mali_clkdiv = 1
                                      [w1_para]
                                      w1_used = 1
                                      gpio = 20
                                      [corekeeper]
                                      SdeWeb
                                      @Reza
                                      Hello, it seems when i read your previous post, that you forgot to reverse your custom .fex file in the system.
                                      In fact, after modifying the .fex in nano, you must do "fex2bin" your .fex file to replace in the system the script.bin file.
                                      If you didn't to that, your .fex file is not used, is useless until you "fex2bin" it.
                                      Your pinout seems OK, a option is to use Pin 17 (3.3V) an Pin 20 (GND) to powering your NRF module.
                                      Regards.
                                      Seb.
                                      • S SdeWeb
                                        @Reza
                                        Regards.
                                        Seb.
                                        R
                                        R
                                        Reza
                                        @SdeWeb sorry i am worng in typing.but i do all steps but there is problem for me.
                                        pin 1 and 6 is 3.3v and gnd .what is defference between 1 & 17 and 6 & 20?
                                        this is all steps that i was follow:
                                        Hit:2 http://ports.ubuntu.com xenial-security InRelease
                                        Hit:3 http://apt.armbian.com xenial InRelease
                                        root@orangepione:~# sudo apt-get install sunxi-tools
                                        Building dependency tree
                                        Reading state information... Done
                                        sunxi-tools is already the newest version (1.4.2-1~armbian5.25+1).
                                        0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                                        and in orange.fex :
                                        [product]
                                        version = "100"
                                        [platform]
                                        debug_mode = 1
                                        eraseflag = 1
                                        next_work = 2
                                        [target]
                                        boot_clock = 1008
                                        storage_type = -1
                                        [key_detect_en]
                                        keyen_flag = 0
                                        [fel_key]
                                        fel_key_max = 7
                                        fel_key_min = 2
                                        [card_boot]
                                        next_work = 3
                                        [box_start_os]
                                        used = 1
                                        start_type = 1
                                        irkey_used = 1
                                        pmukey_used = 1
                                        pmukey_num = 3
                                        led_power = 0
                                        led_state = 0
                                        [boot_init_gpio]
                                        used = 1
                                        [recovery_para]
                                        used = 1
                                        mode = 2
                                        [pm_para]
                                        standby_mode = 1
                                        [card0_boot_para]
                                        card_ctrl = 0
                                        card_high_speed = 1
                                        card_line = 4
                                        [card2_boot_para]
                                        card_ctrl = 2
                                        card_high_speed = 1
                                        card_line = 8
                                        sdc_2xmode = 1
                                        sdc_ddrmode = 1
                                        [twi_para]
                                        twi_port = 0
                                        [uart_para]
                                        uart_debug_port = 0
                                        [force_uart_para]
                                        force_uart_port = 0
                                        [jtag_para]
                                        jtag_enable = 0
                                        [clock]
                                        pll_video = 297
                                        pll_ve = 402
                                        pll_periph0 = 600
                                        pll_gpu = 576
                                        pll_periph1 = 600
                                        pll_de = 864
                                        [dram_para]
                                        dram_clk = 624
                                        dram_type = 3
                                        dram_zq = 0x3b3bfb
                                        dram_odt_en = 1
                                        dram_para2 = 0
                                        dram_mr0 = 6208
                                        dram_mr1 = 64
                                        dram_mr2 = 24
                                        dram_mr3 = 2
                                        dram_tpr2 = 0x76051
                                        dram_tpr3 = 0x0
                                        dram_tpr4 = 0x0
                                        dram_tpr5 = 0x0
                                        dram_tpr6 = 0x64
                                        dram_tpr7 = 0x0
                                        dram_tpr8 = 0x0
                                        dram_tpr9 = 0x0
                                        dram_tpr10 = 0x0
                                        dram_tpr12 = 0x7979
                                        [wakeup_src_para]
                                        cpu_en = 0
                                        cpu_freq = 48
                                        pll_ratio = 273
                                        dram_freq = 36
                                        wakeup_src0 =
                                        [twi0]
                                        twi_used = 1
                                        [twi1]
                                        twi_used = 1
                                        [twi2]
                                        twi_used = 0
                                        [uart0]
                                        uart_used = 1
                                        uart_port = 0
                                        uart_type = 2
                                        [uart1]
                                        uart_used = 0
                                        uart_port = 1
                                        uart_type = 4
                                        [uart2]
                                        uart_used = 0
                                        uart_port = 2
                                        uart_type = 4
                                        [uart3]
                                        uart_used = 0
                                        uart_port = 3
                                        uart_type = 4
                                        [spi0]
                                        spi_used = 1
                                        spi_cs_bitmap = 1
                                        [spi1]
                                        spi_used = 0
                                        spi_cs_bitmap = 1
                                        [spi_devices]
                                        spi_dev_num = 1
                                        [spi_board0]
                                        modalias = "spidev"
                                        bus_num = 0
                                        chip_select = 0
                                        mode = 0
                                        full_duplex = 1
                                        manual_cs = 0
                                        [gpio_para]
                                        gpio_used = 0
                                        gpio_num = 0
                                        ;[led_assign]
                                        [leds_para]
                                        leds_used = 1
                                        [ths_para]
                                        ths_used = 1
                                        ths_trip1_count = 6
                                        ths_trip1_0 = 75
                                        ths_trip1_1 = 80
                                        ths_trip1_2 = 85
                                        ths_trip1_3 = 90
                                        ths_trip1_4 = 95
                                        ths_trip1_5 = 105
                                        ths_trip1_6 = 0
                                        ths_trip1_7 = 0
                                        ths_trip1_0_min = 0
                                        ths_trip1_0_max = 1
                                        ths_trip1_1_min = 1
                                        ths_trip1_1_max = 2
                                        ths_trip1_2_min = 2
                                        ths_trip1_2_max = 3
                                        ths_trip1_3_min = 3
                                        ths_trip1_3_max = 4
                                        ths_trip1_4_min = 4
                                        ths_trip1_4_max = 5
                                        ths_trip1_5_min = 5
                                        ths_trip1_5_max = 7
                                        ths_trip1_6_min = 0
                                        ths_trip1_6_max = 0
                                        ths_trip2_count = 1
                                        ths_trip2_0 = 105
                                        [cooler_table]
                                        cooler_count = 8
                                        [nand0_para]
                                        nand0_used = 0
                                        [boot_disp]
                                        advert_disp = 0
                                        auto_hpd = 1
                                        output_type = 4
                                        hdmi_channel = 0
                                        hdmi_mode = 4
                                        cvbs_channel = 1
                                        cvbs_mode = 11
                                        output_full = 1
                                        hdmi_mode_check = 1
                                        [disp_init]
                                        disp_mode = 0
                                        fb0_format = 0
                                        fb0_width = 0
                                        fb0_height = 0
                                        fb1_format = 0
                                        fb1_width = 0
                                        fb1_height = 0
                                        [hdmi_para]
                                        hdmi_used = 1
                                        [tv_para]
                                        tv_used = 0
                                        tv_dac_used = 1
                                        tv_dac_src0 = 0
                                        [pwm0_para]
                                        pwm_used = 0
                                        [gmac0]
                                        gmac_used = 2
                                        gmac_power1 =
                                        [csi0]
                                        vip_used = 1
                                        vip_mode = 0
                                        vip_dev_qty = 1
                                        vip_dev0_lane = 1
                                        vip_dev0_twi_id = 2
                                        vip_dev0_fmt = 0
                                        vip_dev0_vflip = 1
                                        vip_dev0_hflip = 1
                                        vip_dev0_iovdd = ""
                                        vip_dev0_avdd = ""
                                        vip_dev0_dvdd = ""
                                        vip_dev0_afvdd = ""
                                        vip_dev0_flash_en =
                                        vip_dev0_af_pwdn =
                                        vip_dev1_mname = ""
                                        vip_dev1_lane = 1
                                        vip_dev1_twi_id = 0
                                        vip_dev1_twi_addr =
                                        vip_dev1_fmt = 1
                                        vip_dev1_vflip = 0
                                        vip_dev1_hflip = 0
                                        vip_dev1_iovdd = ""
                                        vip_dev1_avdd = ""
                                        vip_dev1_dvdd = ""
                                        vip_dev1_afvdd = ""
                                        vip_dev1_power_en =
                                        vip_dev1_reset =
                                        vip_dev1_pwdn =
                                        vip_dev1_flash_en =
                                        vip_dev1_af_pwdn =
                                        [tvout_para]
                                        tvout_used = 0
                                        tvout_channel_num =
                                        tv_en = 0
                                        [tvin_para]
                                        tvin_used = 0
                                        tvin_channel_num =
                                        [di_para]
                                        di_used = 1
                                        [mmc0_para]
                                        sdc_used = 1
                                        sdc_detmode = 3
                                        sdc_buswidth = 4
                                        sdc_use_wp = 0
                                        sdc_wp =
                                        sdc_isio = 0
                                        [mmc1_para]
                                        sdc_used = 1
                                        sdc_detmode = 4
                                        sdc_buswidth = 4
                                        sdc_det =
                                        sdc_use_wp = 0
                                        sdc_wp =
                                        sdc_isio = 1
                                        sdc_2xmode = 1
                                        sdc_ddrmode = 1
                                        [mmc2_para]
                                        sdc_used = 0
                                        sdc_detmode = 3
                                        sdc_buswidth = 8
                                        sdc_det =
                                        sdc_use_wp = 0
                                        sdc_wp =
                                        sdc_isio = 0
                                        sdc_2xmode = 1
                                        sdc_ddrmode = 1
                                        [smc_para]
                                        smc_used = 0
                                        [usbc0]
                                        usb_used = 1
                                        usb_port_type = 2
                                        usb_detect_type = 0
                                        usb_restrict_gpio =
                                        usb_not_suspend = 0
                                        [usbc1]
                                        usb_used = 1
                                        usb_drv_vbus_gpio =
                                        usb_restrict_gpio =
                                        usb_not_suspend = 0
                                        [usbc2]
                                        usb_used = 1
                                        usb_drv_vbus_gpio =
                                        usb_restrict_gpio =
                                        usb_not_suspend = 0
                                        [usbc3]
                                        usb_used = 1
                                        usb_drv_vbus_gpio =
                                        usb_restrict_gpio =
                                        usb_not_suspend = 0
                                        [usb_feature]
                                        vendor_id = 6353
                                        mass_storage_id = 1
                                        adb_id = 2
                                        [msc_feature]
                                        release = 100
                                        luns = 3
                                        [serial_feature]
                                        serial_unique = 0
                                        [module_para]
                                        module_num = 7
                                        module_power1 =
                                        module_power1_vol =
                                        module_power2 =
                                        module_power2_vol =
                                        module_power3 =
                                        module_power3_vol =
                                        chip_en =
                                        lpo_use_apclk =
                                        [wifi_para]
                                        wifi_used = 0
                                        wifi_sdc_id = 1
                                        wifi_usbc_id = 5
                                        wifi_usbc_type = 1
                                        [bt_para]
                                        bt_used = 0
                                        bt_uart_id = 1
                                        bt_rst_n =
                                        bt_wake =
                                        bt_host_wake =
                                        [pcm0]
                                        daudio_used = 0
                                        daudio_master = 4
                                        daudio_select = 1
                                        audio_format = 1
                                        mclk_fs = 128
                                        msb_lsb_first = 0
                                        sign_extend = 0
                                        slot_index = 0
                                        slot_width = 32
                                        frame_width = 0
                                        tx_data_mode = 0
                                        rx_data_mode = 0
                                        [pcm1]
                                        daudio_used = 0
                                        daudio_master = 4
                                        daudio_select = 1
                                        audio_format = 1
                                        mclk_fs = 128
                                        msb_lsb_first = 0
                                        sign_extend = 0
                                        slot_index = 0
                                        slot_width = 32
                                        frame_width = 0
                                        tx_data_mode = 0
                                        rx_data_mode = 0
                                        [audio0]
                                        audio_used = 1
                                        lineout_vol = 31
                                        cap_vol = 5
                                        adcagc_used = 0
                                        adcdrc_used = 0
                                        dacdrc_used = 0
                                        adchpf_used = 0
                                        dachpf_used = 0
                                        [spdif0]
                                        spdif_used = 0
                                        [audiohub]
                                        hub_used = 0
                                        codec_used = 1
                                        spdif_used = 1
                                        hdmi_used = 1
                                        [s_cir0]
                                        ir_used = 0
                                        ir_addr_code5 = 239
                                        [cir]
                                        ir_used = 1
                                        [dvfs_table]
                                        pmuic_type = 1
                                        pmu_level0 = 11300
                                        pmu_level1 = 1100
                                        LV_count = 5
                                        LV1_volt = 1300
                                        LV2_volt = 1300
                                        LV3_volt = 1100
                                        LV4_volt = 1100
                                        LV5_volt = 1100
                                        [gpu_dvfs_table]
                                        G_LV_count = 3
                                        [Vdevice]
                                        Vdevice_used = 0
                                        [s_uart0]
                                        s_uart_used = 0
                                        [s_rsb0]
                                        s_rsb_used = 1
                                        [s_jtag0]
                                        s_jtag_used = 0
                                        [s_powchk]
                                        s_power_reg = 0
                                        s_system_power = 50
                                        [sim0]
                                        scr_used = 0
                                        [ts0]
                                        tsc_used = 0
                                        [gpio_power_key]
                                        key_used = 1
                                        [key_para]
                                        key_used = 0
                                        key_cnt = 5
                                        key1_vol = 222
                                        key2_vol = 444
                                        key3_vol = 666
                                        key4_vol = 857
                                        key5_vol = 2000
                                        [d7s_para]
                                        d7s_used = 0
                                        ;mali parameters
                                        [mali_para]
                                        mali_used = 1
                                        mali_clkdiv = 1
                                        [w1_para]
                                        w1_used = 1
                                        gpio = 20
                                        [corekeeper]
                                        then:
                                        root@orangepione:~# sudo fex2bin /tmp/orange.fex /boot/script.bin
                                        root@orangepione:~# sudo reboot
                                        then:
                                        crw------- 1 root root 153, 0 Mar 19 22:57 /dev/spidev0.0
                                        then:
                                        root@orangepione:~# git clone https://github.com/mysensors/MySensors.git
                                        Receiving objects: 100% (13985/13985), 9.70 MiB | 310.00 KiB/s, done.
                                        [OK] Finished.
                                        [OK] Finished.
                                        mysgw: TSM:INIT
                                        mysgw: TSF:WUR:MS=0
                                        mysgw: TSM:FAIL:PDT
                                        mysgw: TSM:INIT
                                        mysgw: TSM:FAIL:PDT
                                        mysgw: TSM:INIT
                                        mysgw: TSM:FAIL:PDT
                                        ^Z
                                        [1]+  Stopped                 sudo ./bin/mysgw -d
                                        also i change 3.3v and gnd to 17 and 20 but . . . :(
                                        • G
                                          G
                                          giran
                                          wrote on last edited by giran
                                          #58
                                          Hi all
                                          I have problems with Orange zero to make it work as a MYS gateway.
                                          What is done:
                                          1. take Debian img from https://www.armbian.com/orange-pi-zero/
                                          2. added /dev/spidev1.0 using instructions from here: https://www.mysensors.org/build/orange
                                            So I actually see spidev1.0 in ls -l /dev/spidev*
                                          3. wired everything up as is described here: https://www.mysensors.org/build/orange
                                            So everything is connected to the spi1 pins.
                                            I used nrf24 with a capacitor and without - same result
                                          4. ran commands
                                          cd MySensors
                                          ./configure --spi-spidev-device=/dev/spidev1.0 --my-transport=nrf24 --my-rf24-ce-pin=2 --my-rf24-cs-pin=13 --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyUSB020 --my-serial-baudrate=115200
                                          sudo make
                                          sudo make install
                                          sudo ./bin/mysgw -d
                                          And I see failed logs
                                          mysgw: TSM:INIT
                                          mysgw: TSF:WUR:MS=0
                                          mysgw: TSM:FAIL:PDT
                                          mysgw: TSM:INIT
                                          Has anyone set it up for Zero?
                                          What am I doing wrong?
                                          Thanks in advance!
                                          pansenP 1 Reply Last reply
