  2. Announcements
  3. 💬 Building a Orange Pi Gateway
110 Posts 24 Posters 66.3k Views 21 Watching
  • T Tag
    @Reza
    try this:
    ./configure --spi-spidev-device=/dev/spidev0.0 --my-transport=nrf24 --my-rf24-ce-pin=2 --my-rf24-cs-pin=3
    See this page for your header pinout: http://linux-sunxi.org/Orange_Pi_One#Orientation_of_the_GPIO_header
    the --my-rf24-cs-pin= is key to have it right on your system
    R
    R
    Reza
    @Tag my-rf24-cs-pin=3 . 3 is pin15 ? i do it. cs is connect to pin15 (GPIO3) and configre again .but dont work
    S T 2 Replies Last reply
    • R Reza
      SdeWeb
      wrote on last edited by SdeWeb
      #43
      @Reza Try to connect like mine, look above in this thread, then use my own ./configure setup.
      If it's not work, try to use the .fex file for your Orange PI download it here :
      http://linux-sunxi.org/Orange_Pi_One#Sunxi.2FLegacy_Kernel
      R 1 Reply Last reply
      • S SdeWeb
        R
        R
        Reza
        @SdeWeb said in 💬 Building a Orange Pi Gateway:
        sorry i cannot understand what is say in this link. thank you .perhaps other friend can found this for orange pi one or lite . i cannot understand really.
        • R Reza
          Tag
          wrote on last edited by Tag
          #45
          @Reza
          Did you also change the SPI channel?
          if you use the OPIzero pinout, SPI1 will be SPI0 on the OPI one......
          Your other option will be using a serial gateway: https://www.mysensors.org/build/serial_gateway
          This works for sure on the OPI One
          • T Tag
            @Reza
            R
            R
            Reza
            @Tag i change this but dont work, i am useing serial gateway now.but i want use a orangepi gateway:(
            S 1 Reply Last reply
            • R Reza
              SdeWeb
              @Reza
              Tell us how you connect your NRF24 module on your Orange PI.
              On this guide https://www.mysensors.org/build/orange do you followed the section "configure spidev" ?
              The main things are :
              1 - install sunxy-tools
              2 - install MySensors.git
              But the pinout of the GPIO on your Orange PI is different of the Orange PI zero explained here : https://www.mysensors.org/build/orange
              So you need to modify the script.bin file, with the command "bin2fex / fex2bin" as explained in the "configure spidev" chapter, if you fail to find the right configuration, try to use the .fex file that you can download here :
              If you have a Orange PI lite :
              https://github.com/igorpecovnik/lib/blob/master/config/fex/orangepilite.fex
              Or if you have a Orange PI One :
              https://github.com/igorpecovnik/lib/blob/master/config/fex/orangepione.fex
              then "fex2bin" the file you downloaded, to replace your own script.bin as described in the tuto at the chapter "configure spidev".
              I think that the pinout of your Orange PI is the same than mine, i got a Orange PI Plus 2E, so look my setup as explained above in this forum, then connect your NRF24 module like mine and use my "./configure" setup.
              If you succes your gateway setup, dont forget than the next step it's to install a controler to drive it, so you'll need to read guide about setup a controler : https://www.mysensors.org/controller
              Regards.
              • S SdeWeb
                @Reza
                Regards.
                R
                R
                Reza
                wrote on last edited by Reza
                #48
                @SdeWeb
                this is my levels:
                sudo apt-get update
                sudo apt-get install sunxi-tools
                bin2fex /boot/script.bin /tmp/orange.fex
                nano /tmp/orange.fex
                and replace
                and save .
                so:
                sudo fex2bin /tmp/orange.fex /boot/script.bin
                sudo reboot
                root@orangepione:~# ls -l /dev/spidev*
                crw------- 1 root root 153, 0 Mar 16 12:00 /dev/spidev0.0
                sudo modprobe gpio-sunxi
                echo "gpio-sunxi" >> /etc/modules
                cd MySensors
                ./configure --spi-spidev-device=/dev/spidev0.0 --my-transport=nrf24 --my-rf24-ce-pin=2 --my-rf24-cs-pin=13
                ./configure --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyUSB020
                make
                sudo ./bin/mysgw -d
                so i see :
                mysgw: Starting gateway...
                mysgw: TSM:INIT
                mysgw: TSF:WUR:MS=0
                mysgw: !TSM:INIT:TSP FAIL
                mysgw: TSM:FAIL:CNT=1
                mysgw: TSM:FAIL:PDT
                wiring is similar to zero...
                • R Reza
                  @SdeWeb
                  this is my levels:
                  sudo apt-get update
                  and replace
                  and save .
                  so:
                  sudo reboot
                  cd MySensors
                  make
                  sudo ./bin/mysgw -d
                  so i see :
                  mysgw: TSM:INIT
                  mysgw: TSF:WUR:MS=0
                  mysgw: TSM:FAIL:PDT
                  SdeWeb
                  @Reza
                  Try to wire like mine and apply my configure setup, here is the copy/paste of the famous previous post from me :
                  I connected my NRF24L01 on OPI P2E like this :
                  NRF24L01 Port Name / (Pin N°) ----- OPI Port (Pin N°) / Name
                                        GND (1)  <-----------> (20) / GND
                                        VCC (2)  <-----------> (17) / 3.3V PWR
                                        CE (3)   <-----------> (22) / (PA2 / GPIO2)
                                        CSN (4)  <-----------> (24) / (PC3 / GPIO67)
                                        SCK (5)  <-----------> (23)
                                        MOSI (6) <-----------> (19) MOSI
                                        MISO (7) <-----------> (21) MISO
                                        IRQ (8)  <-----------> NC
                  So "MySensors" setup is :
                  ./configure --spi-spidev-device=/dev/spidev0.0 --my-transport=nrf24 --my-rf24-ce-pin=2 --my-rf24-cs-pin=67
                  Then
                  ./bin/mysgw -d
                  Return :
                  root@orangepiplus2e:~/MySensors# ./bin/mysgw -d
                  mysgw: TSM:INIT
                  mysgw: TSF:WUR:MS=0
                  mysgw: TSM:INIT:TSP OK
                  mysgw: TSM:INIT:GW MODE
                  mysgw: MCO:REG:NOT NEEDED
                  mysgw: MCO:BGN:STP
                  mysgw: MCO:BGN:INIT OK,TSP=1
                  Best.
                  Seb.
                  • S SdeWeb
                    @Reza
                    Then
                    ./bin/mysgw -d
                    Return :
                    mysgw: TSM:INIT
                    mysgw: TSF:WUR:MS=0
                    mysgw: MCO:BGN:STP
                    Best.
                    Seb.
                    R
                    R
                    Reza
                    @SdeWeb
                    i do wiring true and do your levels... but there is same problem...
                    root@orangepione:~/MySensors# ./configure --spi-spidev-device=/dev/spidev0.0 --my-transport=nrf24 --my-rf24-ce-pin=2 --my-rf24-cs-pin=67
                    [OK] Finished.
                    root@orangepione:~/MySensors# ./configure --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyUSB020
                    [OK] Finished.
                    root@orangepione:~/MySensors# make
                    gcc -MT build/drivers/Linux/log.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/log.c -o build/drivers/Linux/log.o
                    g++ -MT build/drivers/Linux/noniso.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/noniso.cpp -o build/drivers/Linux/noniso.o
                    g++ -MT build/drivers/Linux/GPIO.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/GPIO.cpp -o build/drivers/Linux/GPIO.o
                    g++ -MT build/drivers/Linux/Print.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/Print.cpp -o build/drivers/Linux/Print.o
                    g++ -MT build/drivers/Linux/EthernetClient.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/EthernetClient.cpp -o build/drivers/Linux/EthernetClient.o
                    g++ -MT build/drivers/Linux/SerialPort.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/SerialPort.cpp -o build/drivers/Linux/SerialPort.o
                    g++ -MT build/drivers/Linux/Stream.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/Stream.cpp -o build/drivers/Linux/Stream.o
                    g++ -MT build/drivers/Linux/IPAddress.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/IPAddress.cpp -o build/drivers/Linux/IPAddress.o
                    g++ -MT build/drivers/Linux/compatibility.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/compatibility.cpp -o build/drivers/Linux/compatibility.o
                    g++ -MT build/drivers/Linux/interrupt.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/interrupt.cpp -o build/drivers/Linux/interrupt.o
                    g++ -MT build/drivers/Linux/SerialSimulator.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/SerialSimulator.cpp -o build/drivers/Linux/SerialSimulator.o
                    g++ -MT build/drivers/Linux/SoftEeprom.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/SoftEeprom.cpp -o build/drivers/Linux/SoftEeprom.o
                    g++ -MT build/drivers/Linux/EthernetServer.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/EthernetServer.cpp -o build/drivers/Linux/EthernetServer.o
                    g++ -MT build/examples_linux/mysgw.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c examples_linux/mysgw.cpp -o build/examples_linux/mysgw.o
                    examples_linux/mysgw.cpp:31:0: warning: "MY_RADIO_NRF24" redefined
                    <command-line>:0:0: note: this is the location of the previous definition
                    g++ -MT build/drivers/SPIDEV/SPI.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/SPIDEV/SPI.cpp -o build/drivers/SPIDEV/SPI.o
                    g++ -pthread  -o bin/mysgw build/drivers/Linux/log.o build/drivers/Linux/noniso.o build/drivers/Linux/GPIO.o build/drivers/Linux/Print.o build/drivers/Linux/EthernetClient.o build/drivers/Linux/SerialPort.o build/drivers/Linux/Stream.o build/drivers/Linux/IPAddress.o build/drivers/Linux/compatibility.o build/drivers/Linux/interrupt.o build/drivers/Linux/SerialSimulator.o build/drivers/Linux/SoftEeprom.o build/drivers/Linux/EthernetServer.o build/examples_linux/mysgw.o  build/drivers/SPIDEV/SPI.o
                    root@orangepione:~/MySensors# sudo ./bin/mysgw -d
                    mysgw: TSM:INIT
                    mysgw: TSF:WUR:MS=0
                    mysgw: TSM:FAIL:PDT
                    mysgw: TSM:FAIL:RE-INIT
                    mysgw: TSM:INIT
                    mysgw: TSM:FAIL:CNT=2
                    mysgw: TSM:FAIL:PDT
                    • R
                      R
                      Reza
                      this is all my steps
                      root@orangepione:~# sudo apt-get update
                      Hit:1 http://ports.ubuntu.com xenial InRelease
                      Hit:2 http://apt.armbian.com xenial InRelease
                      Hit:3 http://ports.ubuntu.com xenial-security InRelease
                      Hit:4 http://ports.ubuntu.com xenial-updates InRelease
                      Hit:5 http://ports.ubuntu.com xenial-backports InRelease
                      Reading package lists... Done
                      root@orangepione:~# bin2fex /boot/script.bin /tmp/orange.fex
                      fexc-bin: /boot/script.bin: version: 1.2
                      fexc-bin: /boot/script.bin: size: 34704 (81 sections), header value: 34704
                      root@orangepione:~# nano /tmp/orange.fex
                      crw------- 1 root root 153, 0 Mar 19 11:17 /dev/spidev0.0
                      root@orangepione:~# sudo modprobe gpio-sunxi
                      root@orangepione:~# echo "gpio-sunxi" >> /etc/modules
                      root@orangepione:~# vncserver
                      New 'X' desktop is orangepione:1
                      Starting applications specified in /root/.vnc/xstartup
                      Log file is /root/.vnc/orangepione:1.log
                      root@orangepione:~# *** Error in `pasystray': corrupted double-linked list (not small): 0x01cdb908 ***
                      Cloning into 'MySensors'...
                      remote: Counting objects: 13985, done.
                      remote: Compressing objects: 100% (45/45), done.
                      remote: Total 13985 (delta 8), reused 0 (delta 0), pack-reused 13940
                      Receiving objects: 100% (13985/13985), 9.70 MiB | 181.00 KiB/s, done.
                      Resolving deltas: 100% (8436/8436), done.
                      Checking connectivity... done.
                      root@orangepione:~# cd MySensors
                      [OK] Finished.
                      [OK] Finished.
                      mysgw: MCO:BGN:INIT GW,CP=RNNG----,VER=2.2.0-beta
                      mysgw: TSM:INIT
                      mysgw: TSF:WUR:MS=0
                      mysgw: TSM:FAIL:PDT
                      mysgw: TSM:INIT
                      mysgw: TSM:FAIL:PDT
                      mysgw: TSM:INIT
                      mysgw: TSM:FAIL:CNT=3
                      mysgw: TSM:FAIL:PDT
                      • pansenP
                        pansenP
                        pansen
                        Can you post a picture of your wiring?
                        Orange Pi Plus 2e connected to nrf24 PA via SPI running git-development MySensors gateway, OpenHAB2, mosquitto and MySQL persistence.
                        • R Reza
                          [OK] Finished.
                          [OK] Finished.
                          mysgw: TSM:INIT
                          mysgw: TSF:WUR:MS=0
                          mysgw: TSM:FAIL:PDT
                          mysgw: TSM:INIT
                          mysgw: TSM:FAIL:PDT
                          mysgw: TSM:INIT
                          mysgw: TSM:FAIL:PDT
                          SdeWeb
                          @Reza Hello,
                          Did you modifying the .Fex file before applying the 'configure' setup ?
                          What did you do with nano ?
                          Regards.
                          • pansenP pansen
                            R
                            R
                            Reza
                            #54
                            @pansen
                            red is 3.3
                            brown is GND
                            green is CE
                            orange is SCK
                            yellow is MISO
                            violet is CS
                            blue is MOSI
                            IRQ is empty
                            • S SdeWeb
                              @Reza Hello,
                              Regards.
                              R
                              R
                              Reza
                              #55
                              @SdeWeb
                              yes. use:
                              sudo nano /tmp/orange.fex
                              and remove all line and copy , paste your link and save this.
                              now orange.fex is:
                              [product]
                              version = "100"
                              machine = "Xunlong Orange Pi One"
                              [platform]
                              debug_mode = 1
                              eraseflag = 1
                              next_work = 2
                              [target]
                              boot_clock = 1008
                              storage_type = -1
                              [key_detect_en]
                              keyen_flag = 0
                              [fel_key]
                              fel_key_max = 7
                              fel_key_min = 2
                              [card_boot]
                              logical_start = 40960
                              sprite_work_delay = 500
                              sprite_err_delay = 200
                              sprite_gpio0 = port:PL10<1><default><default><default>
                              next_work = 3
                              [box_start_os]
                              used = 1
                              start_type = 1
                              irkey_used = 1
                              pmukey_used = 1
                              pmukey_num = 3
                              led_power = 0
                              led_state = 0
                              [boot_init_gpio]
                              used = 1
                              gpio0 = port:PL10<1><default><default><1>
                              gpio1 = port:PG11<1><default><default><1>
                              [recovery_para]
                              used = 1
                              mode = 2
                              recovery_key = port:PL04<0><default><default><default>
                              [pm_para]
                              standby_mode = 1
                              [card0_boot_para]
                              card_ctrl = 0
                              card_high_speed = 1
                              card_line = 4
                              sdc_d1 = port:PF00<2><1><2><default>
                              sdc_d0 = port:PF01<2><1><2><default>
                              sdc_clk = port:PF02<2><1><2><default>
                              sdc_cmd = port:PF03<2><1><2><default>
                              sdc_d3 = port:PF04<2><1><2><default>
                              sdc_d2 = port:PF05<2><1><2><default>
                              [card2_boot_para]
                              card_ctrl = 2
                              card_high_speed = 1
                              card_line = 8
                              sdc_cmd = port:PC06<3><1><2><default>
                              sdc_clk = port:PC05<3><1><2><default>
                              sdc_d0 = port:PC08<3><1><2><default>
                              sdc_d1 = port:PC09<3><1><2><default>
                              sdc_d2 = port:PC10<3><1><2><default>
                              sdc_d3 = port:PC11<3><1><2><default>
                              sdc_d4 = port:PC12<3><1><2><default>
                              sdc_d5 = port:PC13<3><1><2><default>
                              sdc_d6 = port:PC14<3><1><2><default>
                              sdc_d7 = port:PC15<3><1><2><default>
                              sdc_2xmode = 1
                              sdc_ddrmode = 1
                              [twi_para]
                              twi_port = 0
                              twi_scl = port:PA11<2><default><default><default>
                              twi_sda = port:PA12<2><default><default><default>
                              [uart_para]
                              uart_debug_port = 0
                              uart_debug_tx = port:PA04<2><1><default><default>
                              uart_debug_rx = port:PA05<2><1><default><default>
                              [force_uart_para]
                              force_uart_port = 0
                              force_uart_tx = port:PF02<3><1><default><default>
                              force_uart_rx = port:PF04<3><1><default><default>
                              [jtag_para]
                              jtag_enable = 0
                              jtag_ms = port:PA00<3><default><default><default>
                              jtag_ck = port:PA01<3><default><default><default>
                              jtag_do = port:PA02<3><default><default><default>
                              jtag_di = port:PA03<3><default><default><default>
                              [clock]
                              pll_video = 297
                              pll_ve = 402
                              pll_periph0 = 600
                              pll_gpu = 576
                              pll_periph1 = 600
                              pll_de = 864
                              [dram_para]
                              dram_clk = 624
                              dram_type = 3
                              dram_zq = 0x3b3bfb
                              dram_odt_en = 1
                              dram_para1 = 283377664
                              dram_para2 = 0
                              dram_mr0 = 6208
                              dram_mr1 = 64
                              dram_mr2 = 24
                              dram_mr3 = 2
                              dram_tpr0 = 0x48a192
                              dram_tpr1 = 0x1c2418d
                              dram_tpr2 = 0x76051
                              dram_tpr3 = 0x0
                              dram_tpr4 = 0x0
                              dram_tpr5 = 0x0
                              dram_tpr6 = 0x64
                              dram_tpr7 = 0x0
                              dram_tpr8 = 0x0
                              dram_tpr9 = 0x0
                              dram_tpr10 = 0x0
                              dram_tpr11 = 0x6aaa0000
                              dram_tpr12 = 0x7979
                              dram_tpr13 = 0x800800
                              [wakeup_src_para]
                              cpu_en = 0
                              cpu_freq = 48
                              pll_ratio = 273
                              dram_selfresh_en = 1
                              dram_freq = 36
                              wakeup_src0 =
                              wakeup_src_wl = port:PG10<4><default><default><0>
                              wakeup_src_bt = port:PL03<6><default><default><0>
                              [twi0]
                              twi_used = 1
                              [twi1]
                              twi_used = 1
                              twi_scl = port:PA18<3><default><default><default>
                              twi_sda = port:PA19<3><default><default><default>
                              [twi2]
                              twi_used = 0
                              twi_scl = port:PE12<3><default><default><default>
                              twi_sda = port:PE13<3><default><default><default>
                              [uart0]
                              uart_used = 1
                              uart_port = 0
                              uart_type = 2
                              uart_tx = port:PA04<2><1><default><default>
                              uart_rx = port:PA05<2><1><default><default>
                              [uart1]
                              uart_used = 0
                              uart_port = 1
                              uart_type = 4
                              uart_tx = port:PG06<2><1><default><default>
                              uart_rx = port:PG07<2><1><default><default>
                              uart_rts = port:PG08<2><1><default><default>
                              uart_cts = port:PG09<2><1><default><default>
                              [uart2]
                              uart_used = 0
                              uart_port = 2
                              uart_type = 4
                              uart_tx = port:PA00<2><1><default><default>
                              uart_rx = port:PA01<2><1><default><default>
                              uart_rts = port:PA02<2><1><default><default>
                              uart_cts = port:PA03<2><1><default><default>
                              [uart3]
                              uart_used = 0
                              uart_port = 3
                              uart_type = 4
                              uart_tx = port:PA13<3><1><default><default>
                              uart_rx = port:PA14<3><1><default><default>
                              uart_rts = port:PA15<3><1><default><default>
                              uart_cts = port:PA16<3><1><default><default>
                              [spi0]
                              spi_used = 1
                              spi_cs_bitmap = 1
                              spi_mosi = port:PC00<3><default><default><default>
                              spi_miso = port:PC01<3><default><default><default>
                              spi_sclk = port:PC02<3><default><default><default>
                              spi_cs0 = port:PC03<3><1><default><default>
                              [spi1]
                              spi_used = 0
                              spi_cs_bitmap = 1
                              spi_cs0 = port:PA13<2><1><default><default>
                              spi_sclk = port:PA14<2><default><default><default>
                              spi_mosi = port:PA15<2><default><default><default>
                              spi_miso = port:PA16<2><default><default><default>
                              [spi_devices]
                              spi_dev_num = 1
                              [spi_board0]
                              modalias = "spidev"
                              max_speed_hz = 33000000
                              bus_num = 0
                              chip_select = 0
                              mode = 0
                              full_duplex = 1
                              manual_cs = 0
                              ; NOTE: This section is necessary only for "gpio_sunxi" driver
                              ; which is obsolete for H3 boards
                              [gpio_para]
                              gpio_used = 0
                              gpio_num = 0
                              ;[led_assign]
                              ;normal_led = "gpio_pin_2"
                              ;standby_led = "gpio_pin_1"
                              [leds_para]
                              leds_used = 1
                              green_led = port:PL10<1><default><default><1>
                              green_led_active_low = 0
                              red_led = port:PA15<1><default><default><0>
                              red_led_active_low = 0
                              [ths_para]
                              ths_used = 1
                              ths_trip1_count = 6
                              ths_trip1_0 = 75
                              ths_trip1_1 = 80
                              ths_trip1_2 = 85
                              ths_trip1_3 = 90
                              ths_trip1_4 = 95
                              ths_trip1_5 = 105
                              ths_trip1_6 = 0
                              ths_trip1_7 = 0
                              ths_trip1_0_min = 0
                              ths_trip1_0_max = 1
                              ths_trip1_1_min = 1
                              ths_trip1_1_max = 2
                              ths_trip1_2_min = 2
                              ths_trip1_2_max = 3
                              ths_trip1_3_min = 3
                              ths_trip1_3_max = 4
                              ths_trip1_4_min = 4
                              ths_trip1_4_max = 5
                              ths_trip1_5_min = 5
                              ths_trip1_5_max = 7
                              ths_trip1_6_min = 0
                              ths_trip1_6_max = 0
                              ths_trip2_count = 1
                              ths_trip2_0 = 105
                              [cooler_table]
                              cooler_count = 8
                              cooler0 = "1200000 4 4294967295 0"
                              cooler1 = "912000 4 4294967295 0"
                              cooler2 = "768000 4 4294967295 0"
                              cooler3 = "648000 4 4294967295 0"
                              cooler4 = "480000 4 4294967295 0"
                              cooler5 = "480000 3 4294967295 0"
                              cooler6 = "480000 2 4294967295 0"
                              cooler7 = "480000 1 4294967295 0"
                              [nand0_para]
                              nand_support_2ch = 0
                              nand0_used = 0
                              nand0_we = port:PC00<2><default><default><default>
                              nand0_ale = port:PC01<2><default><default><default>
                              nand0_cle = port:PC02<2><default><default><default>
                              nand0_ce1 = port:PC03<2><default><default><default>
                              nand0_ce0 = port:PC04<2><default><default><default>
                              nand0_nre = port:PC05<2><default><default><default>
                              nand0_rb0 = port:PC06<2><default><default><default>
                              nand0_rb1 = port:PC07<2><default><default><default>
                              nand0_d0 = port:PC08<2><default><default><default>
                              nand0_d1 = port:PC09<2><default><default><default>
                              nand0_d2 = port:PC10<2><default><default><default>
                              nand0_d3 = port:PC11<2><default><default><default>
                              nand0_d4 = port:PC12<2><default><default><default>
                              nand0_d5 = port:PC13<2><default><default><default>
                              nand0_d6 = port:PC14<2><default><default><default>
                              nand0_d7 = port:PC15<2><default><default><default>
                              nand0_ndqs = port:PC16<2><default><default><default>
                              [boot_disp]
                              advert_disp = 0
                              auto_hpd = 1
                              output_type = 4
                              hdmi_channel = 0
                              hdmi_mode = 4
                              cvbs_channel = 1
                              cvbs_mode = 11
                              output_full = 1
                              hdmi_mode_check = 1
                              [disp_init]
                              disp_init_enable = 1
                              disp_mode = 0
                              screen0_output_type = 3
                              screen0_output_mode = 5
                              screen1_output_type = 3
                              screen1_output_mode = 5
                              fb0_format = 0
                              fb0_width = 0
                              fb0_height = 0
                              fb1_format = 0
                              fb1_width = 0
                              fb1_height = 0
                              [hdmi_para]
                              hdmi_used = 1
                              hdmi_power = "vcc-hdmi-18"
                              [tv_para]
                              tv_used = 0
                              tv_dac_used = 1
                              tv_dac_src0 = 0
                              [pwm0_para]
                              pwm_used = 0
                              pwm_positive = port:PA05<3><0><default><default>
                              ;       If set gamc_phy to use = 2
                              [gmac0]
                              gmac_used = 2
                              gmac_power1 =
                              [csi0]
                              vip_used = 1
                              vip_mode = 0
                              vip_dev_qty = 1
                              vip_define_sensor_list = 0
                              vip_csi_pck = port:PE00<2><default><default><default>
                              vip_csi_mck = port:PE01<2><default><default><default>
                              vip_csi_hsync = port:PE02<2><default><default><default>
                              vip_csi_vsync = port:PE03<2><default><default><default>
                              vip_csi_d0 = port:PE04<2><default><default><default>
                              vip_csi_d1 = port:PE05<2><default><default><default>
                              vip_csi_d2 = port:PE06<2><default><default><default>
                              vip_csi_d3 = port:PE07<2><default><default><default>
                              vip_csi_d4 = port:PE08<2><default><default><default>
                              vip_csi_d5 = port:PE09<2><default><default><default>
                              vip_csi_d6 = port:PE10<2><default><default><default>
                              vip_csi_d7 = port:PE11<2><default><default><default>
                              vip_csi_sck = port:PE12<2><default><default><default>
                              vip_csi_sda = port:PE13<2><default><default><default>
                              vip_dev0_mname = "gc2035"
                              vip_dev0_pos = "front"
                              vip_dev0_lane = 1
                              vip_dev0_twi_id = 2
                              vip_dev0_twi_addr = 120
                              vip_dev0_isp_used = 0
                              vip_dev0_fmt = 0
                              vip_dev0_stby_mode = 0
                              vip_dev0_vflip = 1
                              vip_dev0_hflip = 1
                              vip_dev0_iovdd = ""
                              vip_dev0_iovdd_vol = 2800000
                              vip_dev0_avdd = ""
                              vip_dev0_avdd_vol = 2800000
                              vip_dev0_dvdd = ""
                              vip_dev0_dvdd_vol = 1800000
                              vip_dev0_afvdd = ""
                              vip_dev0_afvdd_vol = 2800000
                              vip_dev0_power_en = port:PA17<1><default><default><1>
                              vip_dev0_reset = port:PE14<1><default><default><1>
                              vip_dev0_pwdn = port:PE15<1><default><default><0>
                              vip_dev0_flash_en =
                              vip_dev0_flash_mode =
                              vip_dev0_af_pwdn =
                              vip_dev0_act_used = 0
                              vip_dev0_act_name = "ad5820_act"
                              vip_dev0_act_slave = 24
                              vip_dev1_mname = ""
                              vip_dev1_pos = "rear"
                              vip_dev1_lane = 1
                              vip_dev1_twi_id = 0
                              vip_dev1_twi_addr =
                              vip_dev1_isp_used = 0
                              vip_dev1_fmt = 1
                              vip_dev1_stby_mode = 0
                              vip_dev1_vflip = 0
                              vip_dev1_hflip = 0
                              vip_dev1_iovdd = ""
                              vip_dev1_iovdd_vol = 2800000
                              vip_dev1_avdd = ""
                              vip_dev1_avdd_vol = 2800000
                              vip_dev1_dvdd = ""
                              vip_dev1_dvdd_vol = 1500000
                              vip_dev1_afvdd = ""
                              vip_dev1_afvdd_vol = 2800000
                              vip_dev1_power_en =
                              vip_dev1_reset =
                              vip_dev1_pwdn =
                              vip_dev1_flash_en =
                              vip_dev1_flash_mode =
                              vip_dev1_af_pwdn =
                              [tvout_para]
                              tvout_used = 0
                              tvout_channel_num =
                              tv_en = 0
                              [tvin_para]
                              tvin_used = 0
                              tvin_channel_num =
                              [di_para]
                              di_used = 1
                              [mmc0_para]
                              sdc_used = 1
                              sdc_detmode = 3
                              sdc_buswidth = 4
                              sdc_det = port:PF06<0><1><2><default>
                              sdc_use_wp = 0
                              sdc_wp =
                              sdc_isio = 0
                              sdc_regulator = "none"
                              sdc_power_supply = "none"
                              [mmc1_para]
                              sdc_used = 1
                              sdc_detmode = 4
                              sdc_buswidth = 4
                              sdc_clk = port:PG00<2><1><3><default>
                              sdc_cmd = port:PG01<2><1><3><default>
                              sdc_d0 = port:PG02<2><1><3><default>
                              sdc_d1 = port:PG03<2><1><3><default>
                              sdc_d2 = port:PG04<2><1><3><default>
                              sdc_d3 = port:PG05<2><1><3><default>
                              sdc_det =
                              sdc_use_wp = 0
                              sdc_wp =
                              sdc_isio = 1
                              sdc_2xmode = 1
                              sdc_ddrmode = 1
                              [mmc2_para]
                              sdc_used = 0
                              sdc_detmode = 3
                              sdc_buswidth = 8
                              emmc_rst = port:PC16<3><1><2><default>
                              sdc_det =
                              sdc_use_wp = 0
                              sdc_wp =
                              sdc_isio = 0
                              sdc_2xmode = 1
                              sdc_ddrmode = 1
                              [smc_para]
                              smc_used = 0
                              smc_rst = port:PA09<2><default><default><default>
                              smc_vppen = port:PA20<3><default><default><default>
                              smc_vppp = port:PA21<3><default><default><default>
                              smc_det = port:PA10<2><default><default><default>
                              smc_vccen = port:PA06<2><default><default><default>
                              smc_sck = port:PA07<2><default><default><default>
                              smc_sda = port:PA08<2><default><default><default>
                              [usbc0]
                              usb_used = 1
                              usb_port_type = 2
                              usb_detect_type = 0
                              usb_id_gpio = port:PG12<0><1><default><default>
                              usb_det_vbus_gpio = port:PG12<0><1><default><default>
                              usb_drv_vbus_gpio = port:PL02<1><0><default><0>
                              usb_host_init_state = 1
                              usb_restrict_gpio =
                              usb_restric_flag = 0
                              usb_restric_voltage = 3550000
                              usb_restric_capacity = 5
                              usb_regulator_io = "nocare"
                              usb_regulator_vol = 0
                              usb_not_suspend = 0
                              [usbc1]
                              usb_used = 1
                              usb_drv_vbus_gpio =
                              usb_restrict_gpio =
                              usb_not_suspend = 0
                              [usbc2]
                              usb_used = 1
                              usb_drv_vbus_gpio =
                              usb_restrict_gpio =
                              usb_not_suspend = 0
                              [usbc3]
                              usb_used = 1
                              usb_drv_vbus_gpio =
                              usb_restrict_gpio =
                              usb_not_suspend = 0
                              [usb_feature]
                              vendor_id = 6353
                              mass_storage_id = 1
                              adb_id = 2
                              manufacturer_name = "USB Developer"
                              product_name = "Android"
                              serial_number = "20080411"
                              [msc_feature]
                              vendor_name = "USB 2.0"
                              product_name = "USB Flash Driver"
                              release = 100
                              luns = 3
                              [serial_feature]
                              serial_unique = 0
                              [module_para]
                              module_num = 7
                              module_power0 = "vcc-wifi-33"
                              module_power0_vol = 0
                              module_power1 =
                              module_power1_vol =
                              module_power2 =
                              module_power2_vol =
                              module_power3 =
                              module_power3_vol =
                              chip_en =
                              lpo_use_apclk =
                              [wifi_para]
                              wifi_used = 0
                              wifi_sdc_id = 1
                              wifi_usbc_id = 5
                              wifi_usbc_type = 1
                              wl_reg_on = port:PL07<1><default><default><0>
                              wl_host_wake = port:PG10<0><default><default><0>
                              wl_host_wake_invert = 0
                              [bt_para]
                              bt_used = 0
                              bt_uart_id = 1
                              bt_rst_n =
                              bt_wake =
                              bt_host_wake =
                              bt_host_wake_invert = 0
                              [pcm0]
                              daudio_used = 0
                              daudio_master = 4
                              daudio_select = 1
                              audio_format = 1
                              signal_inversion = 1
                              mclk_fs = 128
                              sample_resolution = 16
                              slot_width_select = 32
                              pcm_lrck_period = 32
                              pcm_lrckr_period = 1
                              msb_lsb_first = 0
                              sign_extend = 0
                              slot_index = 0
                              slot_width = 32
                              frame_width = 0
                              tx_data_mode = 0
                              rx_data_mode = 0
                              i2s_mclk = port:PA18<2><1><default><default>
                              i2s_bclk = port:PA19<2><1><default><default>
                              i2s_dout0 = port:PA20<2><1><default><default>
                              i2s_din = port:PA21<2><1><default><default>
                              [pcm1]
                              daudio_used = 0
                              daudio_master = 4
                              daudio_select = 1
                              audio_format = 1
                              mclk_fs = 128
                              msb_lsb_first = 0
                              sign_extend = 0
                              slot_index = 0
                              slot_width = 32
                              frame_width = 0
                              tx_data_mode = 0
                              rx_data_mode = 0
                              i2s_mclk = port:PG10<2><1><default><default>
                              i2s_bclk = port:PG11<2><1><default><default>
                              i2s_dout0 = port:PG12<2><1><default><default>
                              i2s_din = port:PG13<2><1><default><default>
                              [audio0]
                              audio_used = 1
                              lineout_vol = 31
                              cap_vol = 5
                              audio_hp_ldo = "none"
                              adcagc_used = 0
                              adcdrc_used = 0
                              dacdrc_used = 0
                              adchpf_used = 0
                              dachpf_used = 0
                              audio_pa_ctrl = port:PA16<1><default><default><0>
                              [spdif0]
                              spdif_used = 0
                              spdif_dout = port:PA17<2><1><default><default>
                              [audiohub]
                              hub_used = 0
                              codec_used = 1
                              spdif_used = 1
                              hdmi_used = 1
                              [s_cir0]
                              ir_used = 0
                              ir_rx = port:PL11<2><1><default><default>
                              ir_power_key_code0 = 87
                              ir_addr_code0 = 40704
                              ir_power_key_code1 = 26
                              ir_addr_code1 = 64260
                              ir_power_key_code2 = 20
                              ir_addr_code2 = 32640
                              ir_power_key_code3 = 21
                              ir_addr_code3 = 32640
                              ir_power_key_code4 = 11
                              ir_addr_code4 = 63240
                              ir_power_key_code5 = 3
                              ir_addr_code5 = 239
                              ir_power_key_code6 = 159
                              ir_addr_code6 = 19635
                              ir_power_key_code7 = 10
                              ir_addr_code7 = 30536
                              ir_power_key_code8 = 69
                              ir_addr_code8 = 48386
                              ir_power_key_code9 = 77
                              ir_addr_code9 = 56865
                              ir_power_key_code10 = 24
                              ir_addr_code10 = 65025
                              ir_power_key_code11 = 87
                              ir_addr_code11 = 65280
                              ir_power_key_code12 = 77
                              ir_addr_code12 = 65344
                              [cir]
                              ir_used = 1
                              ir_tx = port:PH07<2><default><default><default>
                              ; dvfs voltage-frequency table configuration
                              ; pmuic_type:0:none, 1:gpio, 2:i2c
                              ; pmu_gpio0: gpio config.
                              ; pmu_levelx: 0~9999: voltage(mV), 10000~90000:gpio0 state. voltage form high to low.
                              ; extremity_freq(Hz): cpu extremity frequency when run benckmark or demo apk
                              ;                     1536MHz@1500mV with radiator, 1296MHz@1340mV without radiator
                              ; max_freq: cpu maximum frequency, based on Hz, can not be more than 1200MHz
                              ; min_freq: cpu minimum frequency, based on Hz, can not be less than 60MHz
                              ; LV_count: count of LV_freq/LV_volt, must be < 16
                              ; LV1: core vdd is 1.50v if cpu frequency is (1296Mhz,  1536Mhz]
                              ; LV2: core vdd is 1.34v if cpu frequency is (1200Mhz,  1296Mhz]
                              ; LV3: core vdd is 1.32v if cpu frequency is (1008Mhz,  1200Mhz]
                              ; LV4: core vdd is 1.20v if cpu frequency is (816Mhz,   1008Mhz]
                              ; LV5: core vdd is 1.10v if cpu frequency is (648Mhz,    816Mhz]
                              ; LV6: core vdd is 1.04v if cpu frequency is (0Mhz,      648Mhz]
                              ; LV7: core vdd is 1.04v if cpu frequency is (0Mhz,      648Mhz]
                              ; LV8: core vdd is 1.04v if cpu frequency is (0Mhz,      648Mhz]
                              [dvfs_table]
                              pmuic_type = 1
                              pmu_gpio0 = port:PL06<1><1><2><1>
                              pmu_level0 = 11300
                              pmu_level1 = 1100
                              max_freq = 1200000000
                              min_freq = 480000000
                              LV_count = 5
                              LV1_freq = 1200000000
                              LV1_volt = 1300
                              LV2_freq = 1008000000
                              LV2_volt = 1300
                              LV3_freq = 912000000
                              LV3_volt = 1100
                              LV4_freq = 648000000
                              LV4_volt = 1100
                              LV5_freq = 480000000
                              LV5_volt = 1100
                              [gpu_dvfs_table]
                              G_LV_count = 3
                              G_LV0_freq = 312000000
                              G_LV0_volt = 1200000
                              G_LV1_freq = 384000000
                              G_LV1_volt = 1200000
                              G_LV2_freq = 456000000
                              G_LV2_volt = 1200000
                              [Vdevice]
                              Vdevice_used = 0
                              Vdevice_0 = port:PH10<5><1><2><default>
                              Vdevice_1 = port:PH11<5><1><2><default>
                              [s_uart0]
                              s_uart_used = 0
                              s_uart_tx = port:PL02<2><default><default><default>
                              s_uart_rx = port:PL03<2><default><default><default>
                              [s_rsb0]
                              s_rsb_used = 1
                              s_rsb_sck = port:PL00<2><1><2><default>
                              s_rsb_sda = port:PL01<2><1><2><default>
                              [s_jtag0]
                              s_jtag_used = 0
                              s_jtag_tms = port:PL04<2><1><2><default>
                              s_jtag_tck = port:PL05<2><1><2><default>
                              s_jtag_tdo = port:PL06<2><1><2><default>
                              s_jtag_tdi = port:PL07<2><1><2><default>
                              [s_powchk]
                              s_powchk_used = -2147483648
                              s_power_reg = 0
                              s_system_power = 50
                              [sim0]
                              scr_used = 0
                              scr_vccen = port:PA06<2><default><default><default>
                              scr_slk = port:PA07<2><default><default><default>
                              scr_sda = port:PA08<2><default><default><default>
                              scr_rst = port:PA09<2><default><default><default>
                              scr_det = port:PA10<2><default><default><default>
                              [ts0]
                              tsc_used = 0
                              tsc_clk = port:PE00<3><default><default><default>
                              tsc_err = port:PE01<3><default><default><default>
                              tsc_sync = port:PE02<3><default><default><default>
                              tsc_dvld = port:PE03<3><default><default><default>
                              tsc_d0 = port:PE04<3><default><default><default>
                              tsc_d1 = port:PE05<3><default><default><default>
                              tsc_d2 = port:PE06<3><default><default><default>
                              tsc_d3 = port:PE07<3><default><default><default>
                              tsc_d4 = port:PE08<3><default><default><default>
                              tsc_d5 = port:PE09<3><default><default><default>
                              tsc_d6 = port:PE10<3><default><default><default>
                              tsc_d7 = port:PE11<3><default><default><default>
                              [gpio_power_key]
                              key_used = 1
                              key_io = port:PL03<6><default><default><0>
                              [key_para]
                              key_used = 0
                              key_cnt = 5
                              key1_vol = 222
                              key2_vol = 444
                              key3_vol = 666
                              key4_vol = 857
                              key5_vol = 2000
                              [d7s_para]
                              d7s_used = 0
                              din_gpio = port:PD00<1><default><default><1>
                              clk_gpio = port:PD01<1><default><default><1>
                              stb_gpio = port:PD02<1><default><default><1>
                              ;mali parameters
                              [mali_para]
                              mali_used = 1
                              mali_clkdiv = 1
                              mali_extreme_freq = 600
                              mali_extreme_vol = 1400
                              ;1wire parameters (default - PA20)
                              [w1_para]
                              w1_used = 1
                              gpio = 20
                              [corekeeper]
                              corekeeper_enabled = 1
                              • R Reza
                                @SdeWeb
                                yes. use:
                                now orange.fex is:
                                [product]
                                version = "100"
                                [platform]
                                debug_mode = 1
                                eraseflag = 1
                                next_work = 2
                                [target]
                                boot_clock = 1008
                                storage_type = -1
                                [key_detect_en]
                                keyen_flag = 0
                                [fel_key]
                                fel_key_max = 7
                                fel_key_min = 2
                                [card_boot]
                                next_work = 3
                                [box_start_os]
                                used = 1
                                start_type = 1
                                irkey_used = 1
                                pmukey_used = 1
                                pmukey_num = 3
                                led_power = 0
                                led_state = 0
                                [boot_init_gpio]
                                used = 1
                                [recovery_para]
                                used = 1
                                mode = 2
                                [pm_para]
                                standby_mode = 1
                                [card0_boot_para]
                                card_ctrl = 0
                                card_high_speed = 1
                                card_line = 4
                                [card2_boot_para]
                                card_ctrl = 2
                                card_high_speed = 1
                                card_line = 8
                                sdc_2xmode = 1
                                sdc_ddrmode = 1
                                [twi_para]
                                twi_port = 0
                                [uart_para]
                                uart_debug_port = 0
                                [force_uart_para]
                                force_uart_port = 0
                                [jtag_para]
                                jtag_enable = 0
                                [clock]
                                pll_video = 297
                                pll_ve = 402
                                pll_periph0 = 600
                                pll_gpu = 576
                                pll_periph1 = 600
                                pll_de = 864
                                [dram_para]
                                dram_clk = 624
                                dram_type = 3
                                dram_zq = 0x3b3bfb
                                dram_odt_en = 1
                                dram_para2 = 0
                                dram_mr0 = 6208
                                dram_mr1 = 64
                                dram_mr2 = 24
                                dram_mr3 = 2
                                dram_tpr2 = 0x76051
                                dram_tpr3 = 0x0
                                dram_tpr4 = 0x0
                                dram_tpr5 = 0x0
                                dram_tpr6 = 0x64
                                dram_tpr7 = 0x0
                                dram_tpr8 = 0x0
                                dram_tpr9 = 0x0
                                dram_tpr10 = 0x0
                                dram_tpr12 = 0x7979
                                [wakeup_src_para]
                                cpu_en = 0
                                cpu_freq = 48
                                pll_ratio = 273
                                dram_freq = 36
                                wakeup_src0 =
                                [twi0]
                                twi_used = 1
                                [twi1]
                                twi_used = 1
                                [twi2]
                                twi_used = 0
                                [uart0]
                                uart_used = 1
                                uart_port = 0
                                uart_type = 2
                                [uart1]
                                uart_used = 0
                                uart_port = 1
                                uart_type = 4
                                [uart2]
                                uart_used = 0
                                uart_port = 2
                                uart_type = 4
                                [uart3]
                                uart_used = 0
                                uart_port = 3
                                uart_type = 4
                                [spi0]
                                spi_used = 1
                                spi_cs_bitmap = 1
                                [spi1]
                                spi_used = 0
                                spi_cs_bitmap = 1
                                [spi_devices]
                                spi_dev_num = 1
                                [spi_board0]
                                modalias = "spidev"
                                bus_num = 0
                                chip_select = 0
                                mode = 0
                                full_duplex = 1
                                manual_cs = 0
                                [gpio_para]
                                gpio_used = 0
                                gpio_num = 0
                                ;[led_assign]
                                [leds_para]
                                leds_used = 1
                                [ths_para]
                                ths_used = 1
                                ths_trip1_count = 6
                                ths_trip1_0 = 75
                                ths_trip1_1 = 80
                                ths_trip1_2 = 85
                                ths_trip1_3 = 90
                                ths_trip1_4 = 95
                                ths_trip1_5 = 105
                                ths_trip1_6 = 0
                                ths_trip1_7 = 0
                                ths_trip1_0_min = 0
                                ths_trip1_0_max = 1
                                ths_trip1_1_min = 1
                                ths_trip1_1_max = 2
                                ths_trip1_2_min = 2
                                ths_trip1_2_max = 3
                                ths_trip1_3_min = 3
                                ths_trip1_3_max = 4
                                ths_trip1_4_min = 4
                                ths_trip1_4_max = 5
                                ths_trip1_5_min = 5
                                ths_trip1_5_max = 7
                                ths_trip1_6_min = 0
                                ths_trip1_6_max = 0
                                ths_trip2_count = 1
                                ths_trip2_0 = 105
                                [cooler_table]
                                cooler_count = 8
                                [nand0_para]
                                nand0_used = 0
                                [boot_disp]
                                advert_disp = 0
                                auto_hpd = 1
                                output_type = 4
                                hdmi_channel = 0
                                hdmi_mode = 4
                                cvbs_channel = 1
                                cvbs_mode = 11
                                output_full = 1
                                hdmi_mode_check = 1
                                [disp_init]
                                disp_mode = 0
                                fb0_format = 0
                                fb0_width = 0
                                fb0_height = 0
                                fb1_format = 0
                                fb1_width = 0
                                fb1_height = 0
                                [hdmi_para]
                                hdmi_used = 1
                                [tv_para]
                                tv_used = 0
                                tv_dac_used = 1
                                tv_dac_src0 = 0
                                [pwm0_para]
                                pwm_used = 0
                                [gmac0]
                                gmac_used = 2
                                gmac_power1 =
                                [csi0]
                                vip_used = 1
                                vip_mode = 0
                                vip_dev_qty = 1
                                vip_dev0_lane = 1
                                vip_dev0_twi_id = 2
                                vip_dev0_fmt = 0
                                vip_dev0_vflip = 1
                                vip_dev0_hflip = 1
                                vip_dev0_iovdd = ""
                                vip_dev0_avdd = ""
                                vip_dev0_dvdd = ""
                                vip_dev0_afvdd = ""
                                vip_dev0_flash_en =
                                vip_dev0_af_pwdn =
                                vip_dev1_mname = ""
                                vip_dev1_lane = 1
                                vip_dev1_twi_id = 0
                                vip_dev1_twi_addr =
                                vip_dev1_fmt = 1
                                vip_dev1_vflip = 0
                                vip_dev1_hflip = 0
                                vip_dev1_iovdd = ""
                                vip_dev1_avdd = ""
                                vip_dev1_dvdd = ""
                                vip_dev1_afvdd = ""
                                vip_dev1_power_en =
                                vip_dev1_reset =
                                vip_dev1_pwdn =
                                vip_dev1_flash_en =
                                vip_dev1_af_pwdn =
                                [tvout_para]
                                tvout_used = 0
                                tvout_channel_num =
                                tv_en = 0
                                [tvin_para]
                                tvin_used = 0
                                tvin_channel_num =
                                [di_para]
                                di_used = 1
                                [mmc0_para]
                                sdc_used = 1
                                sdc_detmode = 3
                                sdc_buswidth = 4
                                sdc_use_wp = 0
                                sdc_wp =
                                sdc_isio = 0
                                [mmc1_para]
                                sdc_used = 1
                                sdc_detmode = 4
                                sdc_buswidth = 4
                                sdc_det =
                                sdc_use_wp = 0
                                sdc_wp =
                                sdc_isio = 1
                                sdc_2xmode = 1
                                sdc_ddrmode = 1
                                [mmc2_para]
                                sdc_used = 0
                                sdc_detmode = 3
                                sdc_buswidth = 8
                                sdc_det =
                                sdc_use_wp = 0
                                sdc_wp =
                                sdc_isio = 0
                                sdc_2xmode = 1
                                sdc_ddrmode = 1
                                [smc_para]
                                smc_used = 0
                                [usbc0]
                                usb_used = 1
                                usb_port_type = 2
                                usb_detect_type = 0
                                usb_restrict_gpio =
                                usb_not_suspend = 0
                                [usbc1]
                                usb_used = 1
                                usb_drv_vbus_gpio =
                                usb_restrict_gpio =
                                usb_not_suspend = 0
                                [usbc2]
                                usb_used = 1
                                usb_drv_vbus_gpio =
                                usb_restrict_gpio =
                                usb_not_suspend = 0
                                [usbc3]
                                usb_used = 1
                                usb_drv_vbus_gpio =
                                usb_restrict_gpio =
                                usb_not_suspend = 0
                                [usb_feature]
                                vendor_id = 6353
                                mass_storage_id = 1
                                adb_id = 2
                                [msc_feature]
                                release = 100
                                luns = 3
                                [serial_feature]
                                serial_unique = 0
                                [module_para]
                                module_num = 7
                                module_power1 =
                                module_power1_vol =
                                module_power2 =
                                module_power2_vol =
                                module_power3 =
                                module_power3_vol =
                                chip_en =
                                lpo_use_apclk =
                                [wifi_para]
                                wifi_used = 0
                                wifi_sdc_id = 1
                                wifi_usbc_id = 5
                                wifi_usbc_type = 1
                                [bt_para]
                                bt_used = 0
                                bt_uart_id = 1
                                bt_rst_n =
                                bt_wake =
                                bt_host_wake =
                                [pcm0]
                                daudio_used = 0
                                daudio_master = 4
                                daudio_select = 1
                                audio_format = 1
                                mclk_fs = 128
                                msb_lsb_first = 0
                                sign_extend = 0
                                slot_index = 0
                                slot_width = 32
                                frame_width = 0
                                tx_data_mode = 0
                                rx_data_mode = 0
                                [pcm1]
                                daudio_used = 0
                                daudio_master = 4
                                daudio_select = 1
                                audio_format = 1
                                mclk_fs = 128
                                msb_lsb_first = 0
                                sign_extend = 0
                                slot_index = 0
                                slot_width = 32
                                frame_width = 0
                                tx_data_mode = 0
                                rx_data_mode = 0
                                [audio0]
                                audio_used = 1
                                lineout_vol = 31
                                cap_vol = 5
                                adcagc_used = 0
                                adcdrc_used = 0
                                dacdrc_used = 0
                                adchpf_used = 0
                                dachpf_used = 0
                                [spdif0]
                                spdif_used = 0
                                [audiohub]
                                hub_used = 0
                                codec_used = 1
                                spdif_used = 1
                                hdmi_used = 1
                                [s_cir0]
                                ir_used = 0
                                ir_addr_code5 = 239
                                [cir]
                                ir_used = 1
                                [dvfs_table]
                                pmuic_type = 1
                                pmu_level0 = 11300
                                pmu_level1 = 1100
                                LV_count = 5
                                LV1_volt = 1300
                                LV2_volt = 1300
                                LV3_volt = 1100
                                LV4_volt = 1100
                                LV5_volt = 1100
                                [gpu_dvfs_table]
                                G_LV_count = 3
                                [Vdevice]
                                Vdevice_used = 0
                                [s_uart0]
                                s_uart_used = 0
                                [s_rsb0]
                                s_rsb_used = 1
                                [s_jtag0]
                                s_jtag_used = 0
                                [s_powchk]
                                s_power_reg = 0
                                s_system_power = 50
                                [sim0]
                                scr_used = 0
                                [ts0]
                                tsc_used = 0
                                [gpio_power_key]
                                key_used = 1
                                [key_para]
                                key_used = 0
                                key_cnt = 5
                                key1_vol = 222
                                key2_vol = 444
                                key3_vol = 666
                                key4_vol = 857
                                key5_vol = 2000
                                [d7s_para]
                                d7s_used = 0
                                ;mali parameters
                                [mali_para]
                                mali_used = 1
                                mali_clkdiv = 1
                                [w1_para]
                                w1_used = 1
                                gpio = 20
                                [corekeeper]
                                SdeWeb
                                @Reza
                                Hello, it seems when i read your previous post, that you forgot to reverse your custom .fex file in the system.
                                In fact, after modifying the .fex in nano, you must do "fex2bin" your .fex file to replace in the system the script.bin file.
                                If you didn't to that, your .fex file is not used, is useless until you "fex2bin" it.
                                Your pinout seems OK, a option is to use Pin 17 (3.3V) an Pin 20 (GND) to powering your NRF module.
                                Regards.
                                Seb.
                                • S SdeWeb
                                  @Reza
                                  Regards.
                                  Seb.
                                  R
                                  R
                                  Reza
                                  @SdeWeb sorry i am worng in typing.but i do all steps but there is problem for me.
                                  pin 1 and 6 is 3.3v and gnd .what is defference between 1 & 17 and 6 & 20?
                                  this is all steps that i was follow:
                                  Hit:2 http://ports.ubuntu.com xenial-security InRelease
                                  Hit:3 http://apt.armbian.com xenial InRelease
                                  root@orangepione:~# sudo apt-get install sunxi-tools
                                  Building dependency tree
                                  Reading state information... Done
                                  sunxi-tools is already the newest version (1.4.2-1~armbian5.25+1).
                                  0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                                  and in orange.fex :
                                  [product]
                                  version = "100"
                                  [platform]
                                  debug_mode = 1
                                  eraseflag = 1
                                  next_work = 2
                                  [target]
                                  boot_clock = 1008
                                  storage_type = -1
                                  [key_detect_en]
                                  keyen_flag = 0
                                  [fel_key]
                                  fel_key_max = 7
                                  fel_key_min = 2
                                  [card_boot]
                                  next_work = 3
                                  [box_start_os]
                                  used = 1
                                  start_type = 1
                                  irkey_used = 1
                                  pmukey_used = 1
                                  pmukey_num = 3
                                  led_power = 0
                                  led_state = 0
                                  [boot_init_gpio]
                                  used = 1
                                  [recovery_para]
                                  used = 1
                                  mode = 2
                                  [pm_para]
                                  standby_mode = 1
                                  [card0_boot_para]
                                  card_ctrl = 0
                                  card_high_speed = 1
                                  card_line = 4
                                  [card2_boot_para]
                                  card_ctrl = 2
                                  card_high_speed = 1
                                  card_line = 8
                                  sdc_2xmode = 1
                                  sdc_ddrmode = 1
                                  [twi_para]
                                  twi_port = 0
                                  [uart_para]
                                  uart_debug_port = 0
                                  [force_uart_para]
                                  force_uart_port = 0
                                  [jtag_para]
                                  jtag_enable = 0
                                  [clock]
                                  pll_video = 297
                                  pll_ve = 402
                                  pll_periph0 = 600
                                  pll_gpu = 576
                                  pll_periph1 = 600
                                  pll_de = 864
                                  [dram_para]
                                  dram_clk = 624
                                  dram_type = 3
                                  dram_zq = 0x3b3bfb
                                  dram_odt_en = 1
                                  dram_para2 = 0
                                  dram_mr0 = 6208
                                  dram_mr1 = 64
                                  dram_mr2 = 24
                                  dram_mr3 = 2
                                  dram_tpr2 = 0x76051
                                  dram_tpr3 = 0x0
                                  dram_tpr4 = 0x0
                                  dram_tpr5 = 0x0
                                  dram_tpr6 = 0x64
                                  dram_tpr7 = 0x0
                                  dram_tpr8 = 0x0
                                  dram_tpr9 = 0x0
                                  dram_tpr10 = 0x0
                                  dram_tpr12 = 0x7979
                                  [wakeup_src_para]
                                  cpu_en = 0
                                  cpu_freq = 48
                                  pll_ratio = 273
                                  dram_freq = 36
                                  wakeup_src0 =
                                  [twi0]
                                  twi_used = 1
                                  [twi1]
                                  twi_used = 1
                                  [twi2]
                                  twi_used = 0
                                  [uart0]
                                  uart_used = 1
                                  uart_port = 0
                                  uart_type = 2
                                  [uart1]
                                  uart_used = 0
                                  uart_port = 1
                                  uart_type = 4
                                  [uart2]
                                  uart_used = 0
                                  uart_port = 2
                                  uart_type = 4
                                  [uart3]
                                  uart_used = 0
                                  uart_port = 3
                                  uart_type = 4
                                  [spi0]
                                  spi_used = 1
                                  spi_cs_bitmap = 1
                                  [spi1]
                                  spi_used = 0
                                  spi_cs_bitmap = 1
                                  [spi_devices]
                                  spi_dev_num = 1
                                  [spi_board0]
                                  modalias = "spidev"
                                  bus_num = 0
                                  chip_select = 0
                                  mode = 0
                                  full_duplex = 1
                                  manual_cs = 0
                                  [gpio_para]
                                  gpio_used = 0
                                  gpio_num = 0
                                  ;[led_assign]
                                  [leds_para]
                                  leds_used = 1
                                  [ths_para]
                                  ths_used = 1
                                  ths_trip1_count = 6
                                  ths_trip1_0 = 75
                                  ths_trip1_1 = 80
                                  ths_trip1_2 = 85
                                  ths_trip1_3 = 90
                                  ths_trip1_4 = 95
                                  ths_trip1_5 = 105
                                  ths_trip1_6 = 0
                                  ths_trip1_7 = 0
                                  ths_trip1_0_min = 0
                                  ths_trip1_0_max = 1
                                  ths_trip1_1_min = 1
                                  ths_trip1_1_max = 2
                                  ths_trip1_2_min = 2
                                  ths_trip1_2_max = 3
                                  ths_trip1_3_min = 3
                                  ths_trip1_3_max = 4
                                  ths_trip1_4_min = 4
                                  ths_trip1_4_max = 5
                                  ths_trip1_5_min = 5
                                  ths_trip1_5_max = 7
                                  ths_trip1_6_min = 0
                                  ths_trip1_6_max = 0
                                  ths_trip2_count = 1
                                  ths_trip2_0 = 105
                                  [cooler_table]
                                  cooler_count = 8
                                  [nand0_para]
                                  nand0_used = 0
                                  [boot_disp]
                                  advert_disp = 0
                                  auto_hpd = 1
                                  output_type = 4
                                  hdmi_channel = 0
                                  hdmi_mode = 4
                                  cvbs_channel = 1
                                  cvbs_mode = 11
                                  output_full = 1
                                  hdmi_mode_check = 1
                                  [disp_init]
                                  disp_mode = 0
                                  fb0_format = 0
                                  fb0_width = 0
                                  fb0_height = 0
                                  fb1_format = 0
                                  fb1_width = 0
                                  fb1_height = 0
                                  [hdmi_para]
                                  hdmi_used = 1
                                  [tv_para]
                                  tv_used = 0
                                  tv_dac_used = 1
                                  tv_dac_src0 = 0
                                  [pwm0_para]
                                  pwm_used = 0
                                  [gmac0]
                                  gmac_used = 2
                                  gmac_power1 =
                                  [csi0]
                                  vip_used = 1
                                  vip_mode = 0
                                  vip_dev_qty = 1
                                  vip_dev0_lane = 1
                                  vip_dev0_twi_id = 2
                                  vip_dev0_fmt = 0
                                  vip_dev0_vflip = 1
                                  vip_dev0_hflip = 1
                                  vip_dev0_iovdd = ""
                                  vip_dev0_avdd = ""
                                  vip_dev0_dvdd = ""
                                  vip_dev0_afvdd = ""
                                  vip_dev0_flash_en =
                                  vip_dev0_af_pwdn =
                                  vip_dev1_mname = ""
                                  vip_dev1_lane = 1
                                  vip_dev1_twi_id = 0
                                  vip_dev1_twi_addr =
                                  vip_dev1_fmt = 1
                                  vip_dev1_vflip = 0
                                  vip_dev1_hflip = 0
                                  vip_dev1_iovdd = ""
                                  vip_dev1_avdd = ""
                                  vip_dev1_dvdd = ""
                                  vip_dev1_afvdd = ""
                                  vip_dev1_power_en =
                                  vip_dev1_reset =
                                  vip_dev1_pwdn =
                                  vip_dev1_flash_en =
                                  vip_dev1_af_pwdn =
                                  [tvout_para]
                                  tvout_used = 0
                                  tvout_channel_num =
                                  tv_en = 0
                                  [tvin_para]
                                  tvin_used = 0
                                  tvin_channel_num =
                                  [di_para]
                                  di_used = 1
                                  [mmc0_para]
                                  sdc_used = 1
                                  sdc_detmode = 3
                                  sdc_buswidth = 4
                                  sdc_use_wp = 0
                                  sdc_wp =
                                  sdc_isio = 0
                                  [mmc1_para]
                                  sdc_used = 1
                                  sdc_detmode = 4
                                  sdc_buswidth = 4
                                  sdc_det =
                                  sdc_use_wp = 0
                                  sdc_wp =
                                  sdc_isio = 1
                                  sdc_2xmode = 1
                                  sdc_ddrmode = 1
                                  [mmc2_para]
                                  sdc_used = 0
                                  sdc_detmode = 3
                                  sdc_buswidth = 8
                                  sdc_det =
                                  sdc_use_wp = 0
                                  sdc_wp =
                                  sdc_isio = 0
                                  sdc_2xmode = 1
                                  sdc_ddrmode = 1
                                  [smc_para]
                                  smc_used = 0
                                  [usbc0]
                                  usb_used = 1
                                  usb_port_type = 2
                                  usb_detect_type = 0
                                  usb_restrict_gpio =
                                  usb_not_suspend = 0
                                  [usbc1]
                                  usb_used = 1
                                  usb_drv_vbus_gpio =
                                  usb_restrict_gpio =
                                  usb_not_suspend = 0
                                  [usbc2]
                                  usb_used = 1
                                  usb_drv_vbus_gpio =
                                  usb_restrict_gpio =
                                  usb_not_suspend = 0
                                  [usbc3]
                                  usb_used = 1
                                  usb_drv_vbus_gpio =
                                  usb_restrict_gpio =
                                  usb_not_suspend = 0
                                  [usb_feature]
                                  vendor_id = 6353
                                  mass_storage_id = 1
                                  adb_id = 2
                                  [msc_feature]
                                  release = 100
                                  luns = 3
                                  [serial_feature]
                                  serial_unique = 0
                                  [module_para]
                                  module_num = 7
                                  module_power1 =
                                  module_power1_vol =
                                  module_power2 =
                                  module_power2_vol =
                                  module_power3 =
                                  module_power3_vol =
                                  chip_en =
                                  lpo_use_apclk =
                                  [wifi_para]
                                  wifi_used = 0
                                  wifi_sdc_id = 1
                                  wifi_usbc_id = 5
                                  wifi_usbc_type = 1
                                  [bt_para]
                                  bt_used = 0
                                  bt_uart_id = 1
                                  bt_rst_n =
                                  bt_wake =
                                  bt_host_wake =
                                  [pcm0]
                                  daudio_used = 0
                                  daudio_master = 4
                                  daudio_select = 1
                                  audio_format = 1
                                  mclk_fs = 128
                                  msb_lsb_first = 0
                                  sign_extend = 0
                                  slot_index = 0
                                  slot_width = 32
                                  frame_width = 0
                                  tx_data_mode = 0
                                  rx_data_mode = 0
                                  [pcm1]
                                  daudio_used = 0
                                  daudio_master = 4
                                  daudio_select = 1
                                  audio_format = 1
                                  mclk_fs = 128
                                  msb_lsb_first = 0
                                  sign_extend = 0
                                  slot_index = 0
                                  slot_width = 32
                                  frame_width = 0
                                  tx_data_mode = 0
                                  rx_data_mode = 0
                                  [audio0]
                                  audio_used = 1
                                  lineout_vol = 31
                                  cap_vol = 5
                                  adcagc_used = 0
                                  adcdrc_used = 0
                                  dacdrc_used = 0
                                  adchpf_used = 0
                                  dachpf_used = 0
                                  [spdif0]
                                  spdif_used = 0
                                  [audiohub]
                                  hub_used = 0
                                  codec_used = 1
                                  spdif_used = 1
                                  hdmi_used = 1
                                  [s_cir0]
                                  ir_used = 0
                                  ir_addr_code5 = 239
                                  [cir]
                                  ir_used = 1
                                  [dvfs_table]
                                  pmuic_type = 1
                                  pmu_level0 = 11300
                                  pmu_level1 = 1100
                                  LV_count = 5
                                  LV1_volt = 1300
                                  LV2_volt = 1300
                                  LV3_volt = 1100
                                  LV4_volt = 1100
                                  LV5_volt = 1100
                                  [gpu_dvfs_table]
                                  G_LV_count = 3
                                  [Vdevice]
                                  Vdevice_used = 0
                                  [s_uart0]
                                  s_uart_used = 0
                                  [s_rsb0]
                                  s_rsb_used = 1
                                  [s_jtag0]
                                  s_jtag_used = 0
                                  [s_powchk]
                                  s_power_reg = 0
                                  s_system_power = 50
                                  [sim0]
                                  scr_used = 0
                                  [ts0]
                                  tsc_used = 0
                                  [gpio_power_key]
                                  key_used = 1
                                  [key_para]
                                  key_used = 0
                                  key_cnt = 5
                                  key1_vol = 222
                                  key2_vol = 444
                                  key3_vol = 666
                                  key4_vol = 857
                                  key5_vol = 2000
                                  [d7s_para]
                                  d7s_used = 0
                                  ;mali parameters
                                  [mali_para]
                                  mali_used = 1
                                  mali_clkdiv = 1
                                  [w1_para]
                                  w1_used = 1
                                  gpio = 20
                                  [corekeeper]
                                  then:
                                  root@orangepione:~# sudo fex2bin /tmp/orange.fex /boot/script.bin
                                  root@orangepione:~# sudo reboot
                                  then:
                                  crw------- 1 root root 153, 0 Mar 19 22:57 /dev/spidev0.0
                                  then:
                                  root@orangepione:~# git clone https://github.com/mysensors/MySensors.git
                                  Receiving objects: 100% (13985/13985), 9.70 MiB | 310.00 KiB/s, done.
                                  [OK] Finished.
                                  [OK] Finished.
                                  mysgw: TSM:INIT
                                  mysgw: TSF:WUR:MS=0
                                  mysgw: TSM:FAIL:PDT
                                  mysgw: TSM:INIT
                                  mysgw: TSM:FAIL:PDT
                                  mysgw: TSM:INIT
                                  mysgw: TSM:FAIL:PDT
                                  ^Z
                                  [1]+  Stopped                 sudo ./bin/mysgw -d
                                  also i change 3.3v and gnd to 17 and 20 but . . . :(
                                  • G
                                    G
                                    giran
                                    wrote on last edited by giran
                                    #58
                                    Hi all
                                    I have problems with Orange zero to make it work as a MYS gateway.
                                    What is done:
                                    1. take Debian img from https://www.armbian.com/orange-pi-zero/
                                    2. added /dev/spidev1.0 using instructions from here: https://www.mysensors.org/build/orange
                                      So I actually see spidev1.0 in ls -l /dev/spidev*
                                    3. wired everything up as is described here: https://www.mysensors.org/build/orange
                                      So everything is connected to the spi1 pins.
                                      I used nrf24 with a capacitor and without - same result
                                    4. ran commands
                                    cd MySensors
                                    ./configure --spi-spidev-device=/dev/spidev1.0 --my-transport=nrf24 --my-rf24-ce-pin=2 --my-rf24-cs-pin=13 --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyUSB020 --my-serial-baudrate=115200
                                    sudo make
                                    sudo make install
                                    sudo ./bin/mysgw -d
                                    And I see failed logs
                                    mysgw: TSM:INIT
                                    mysgw: TSF:WUR:MS=0
                                    mysgw: TSM:FAIL:PDT
                                    mysgw: TSM:INIT
                                    Has anyone set it up for Zero?
                                    What am I doing wrong?
                                    Thanks in advance!
                                    pansenP 1 Reply Last reply
                                    • G giran
                                      Hi all
                                      What is done:
                                      4. ran commands
                                      cd MySensors
                                      sudo make
                                      sudo make install
                                      sudo ./bin/mysgw -d
                                      mysgw: TSM:INIT
                                      mysgw: TSF:WUR:MS=0
                                      mysgw: TSM:FAIL:PDT
                                      mysgw: TSM:INIT
                                      Thanks in advance!
                                      pansenP
                                      pansenP
                                      pansen
                                      @giran hi i don't think you can run the service and the binary standalone at the same time since hardware access is exclusive. Try to stop the service and then run the binary again.
                                      G 1 Reply Last reply
                                      • pansenP pansen
                                        G
                                        G
                                        giran
                                        #60
                                        @pansen Thanks for answering.
                                        Even when I stopped the service
                                        or when I run
                                        sudo make
                                        sudo ./bin/mysgw -d
                                        I still see failed logs.
                                        • G giran
                                          or when I run
                                          sudo make
                                          sudo ./bin/mysgw -d
                                          SdeWeb
                                          @giran Hi, how did you connect you NRF module on the Orange PI ?
                                          Is you use the GPIO, you should'nt use TTY stup for MuSensors.
                                          Look above my setup in this forum, if you use the GPIO.
                                          Regards.
