  2. Announcements
  3. 💬 Building a Orange Pi Gateway
110 Posts 24 Posters 66.3k Views 21 Watching
  • S SdeWeb
    @Reza
    Tell us how you connect your NRF24 module on your Orange PI.
    On this guide https://www.mysensors.org/build/orange do you followed the section "configure spidev" ?
    The main things are :
    1 - install sunxy-tools
    2 - install MySensors.git
    But the pinout of the GPIO on your Orange PI is different of the Orange PI zero explained here : https://www.mysensors.org/build/orange
    So you need to modify the script.bin file, with the command "bin2fex / fex2bin" as explained in the "configure spidev" chapter, if you fail to find the right configuration, try to use the .fex file that you can download here :
    If you have a Orange PI lite :
    https://github.com/igorpecovnik/lib/blob/master/config/fex/orangepilite.fex
    Or if you have a Orange PI One :
    https://github.com/igorpecovnik/lib/blob/master/config/fex/orangepione.fex
    then "fex2bin" the file you downloaded, to replace your own script.bin as described in the tuto at the chapter "configure spidev".
    I think that the pinout of your Orange PI is the same than mine, i got a Orange PI Plus 2E, so look my setup as explained above in this forum, then connect your NRF24 module like mine and use my "./configure" setup.
    If you succes your gateway setup, dont forget than the next step it's to install a controler to drive it, so you'll need to read guide about setup a controler : https://www.mysensors.org/controller
    Regards.
    R
    R
    Reza
    wrote on last edited by Reza
    #48
    @SdeWeb
    this is my levels:
    sudo apt-get update
    sudo apt-get install sunxi-tools
    bin2fex /boot/script.bin /tmp/orange.fex
    nano /tmp/orange.fex
    and replace
    and save .
    so:
    sudo fex2bin /tmp/orange.fex /boot/script.bin
    sudo reboot
    root@orangepione:~# ls -l /dev/spidev*
    crw------- 1 root root 153, 0 Mar 16 12:00 /dev/spidev0.0
    sudo modprobe gpio-sunxi
    echo "gpio-sunxi" >> /etc/modules
    cd MySensors
    ./configure --spi-spidev-device=/dev/spidev0.0 --my-transport=nrf24 --my-rf24-ce-pin=2 --my-rf24-cs-pin=13
    ./configure --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyUSB020
    make
    sudo ./bin/mysgw -d
    so i see :
    mysgw: Starting gateway...
    mysgw: TSM:INIT
    mysgw: TSF:WUR:MS=0
    mysgw: !TSM:INIT:TSP FAIL
    mysgw: TSM:FAIL:CNT=1
    mysgw: TSM:FAIL:PDT
    wiring is similar to zero...
    S 1 Reply Last reply
    • R Reza
      @SdeWeb
      this is my levels:
      sudo apt-get update
      and replace
      and save .
      so:
      sudo reboot
      cd MySensors
      make
      sudo ./bin/mysgw -d
      so i see :
      mysgw: TSM:INIT
      mysgw: TSF:WUR:MS=0
      mysgw: TSM:FAIL:PDT
      SdeWeb
      @Reza
      Try to wire like mine and apply my configure setup, here is the copy/paste of the famous previous post from me :
      I connected my NRF24L01 on OPI P2E like this :
      NRF24L01 Port Name / (Pin N°) ----- OPI Port (Pin N°) / Name
                            GND (1)  <-----------> (20) / GND
                            VCC (2)  <-----------> (17) / 3.3V PWR
                            CE (3)   <-----------> (22) / (PA2 / GPIO2)
                            CSN (4)  <-----------> (24) / (PC3 / GPIO67)
                            SCK (5)  <-----------> (23)
                            MOSI (6) <-----------> (19) MOSI
                            MISO (7) <-----------> (21) MISO
                            IRQ (8)  <-----------> NC
      So "MySensors" setup is :
      ./configure --spi-spidev-device=/dev/spidev0.0 --my-transport=nrf24 --my-rf24-ce-pin=2 --my-rf24-cs-pin=67
      Then
      ./bin/mysgw -d
      Return :
      root@orangepiplus2e:~/MySensors# ./bin/mysgw -d
      mysgw: TSM:INIT
      mysgw: TSF:WUR:MS=0
      mysgw: TSM:INIT:TSP OK
      mysgw: TSM:INIT:GW MODE
      mysgw: MCO:REG:NOT NEEDED
      mysgw: MCO:BGN:STP
      mysgw: MCO:BGN:INIT OK,TSP=1
      Best.
      Seb.
      R 1 Reply Last reply
      • S SdeWeb
        @Reza
        Then
        ./bin/mysgw -d
        Return :
        mysgw: TSM:INIT
        mysgw: TSF:WUR:MS=0
        mysgw: MCO:BGN:STP
        Best.
        Seb.
        R
        R
        Reza
        @SdeWeb
        i do wiring true and do your levels... but there is same problem...
        root@orangepione:~/MySensors# ./configure --spi-spidev-device=/dev/spidev0.0 --my-transport=nrf24 --my-rf24-ce-pin=2 --my-rf24-cs-pin=67
        [OK] Finished.
        root@orangepione:~/MySensors# ./configure --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyUSB020
        [OK] Finished.
        root@orangepione:~/MySensors# make
        gcc -MT build/drivers/Linux/log.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/log.c -o build/drivers/Linux/log.o
        g++ -MT build/drivers/Linux/noniso.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/noniso.cpp -o build/drivers/Linux/noniso.o
        g++ -MT build/drivers/Linux/GPIO.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/GPIO.cpp -o build/drivers/Linux/GPIO.o
        g++ -MT build/drivers/Linux/Print.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/Print.cpp -o build/drivers/Linux/Print.o
        g++ -MT build/drivers/Linux/EthernetClient.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/EthernetClient.cpp -o build/drivers/Linux/EthernetClient.o
        g++ -MT build/drivers/Linux/SerialPort.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/SerialPort.cpp -o build/drivers/Linux/SerialPort.o
        g++ -MT build/drivers/Linux/Stream.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/Stream.cpp -o build/drivers/Linux/Stream.o
        g++ -MT build/drivers/Linux/IPAddress.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/IPAddress.cpp -o build/drivers/Linux/IPAddress.o
        g++ -MT build/drivers/Linux/compatibility.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/compatibility.cpp -o build/drivers/Linux/compatibility.o
        g++ -MT build/drivers/Linux/interrupt.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/interrupt.cpp -o build/drivers/Linux/interrupt.o
        g++ -MT build/drivers/Linux/SerialSimulator.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/SerialSimulator.cpp -o build/drivers/Linux/SerialSimulator.o
        g++ -MT build/drivers/Linux/SoftEeprom.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/SoftEeprom.cpp -o build/drivers/Linux/SoftEeprom.o
        g++ -MT build/drivers/Linux/EthernetServer.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/EthernetServer.cpp -o build/drivers/Linux/EthernetServer.o
        g++ -MT build/examples_linux/mysgw.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c examples_linux/mysgw.cpp -o build/examples_linux/mysgw.o
        examples_linux/mysgw.cpp:31:0: warning: "MY_RADIO_NRF24" redefined
        <command-line>:0:0: note: this is the location of the previous definition
        g++ -MT build/drivers/SPIDEV/SPI.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/SPIDEV/SPI.cpp -o build/drivers/SPIDEV/SPI.o
        g++ -pthread  -o bin/mysgw build/drivers/Linux/log.o build/drivers/Linux/noniso.o build/drivers/Linux/GPIO.o build/drivers/Linux/Print.o build/drivers/Linux/EthernetClient.o build/drivers/Linux/SerialPort.o build/drivers/Linux/Stream.o build/drivers/Linux/IPAddress.o build/drivers/Linux/compatibility.o build/drivers/Linux/interrupt.o build/drivers/Linux/SerialSimulator.o build/drivers/Linux/SoftEeprom.o build/drivers/Linux/EthernetServer.o build/examples_linux/mysgw.o  build/drivers/SPIDEV/SPI.o
        root@orangepione:~/MySensors# sudo ./bin/mysgw -d
        mysgw: TSM:INIT
        mysgw: TSF:WUR:MS=0
        mysgw: TSM:FAIL:PDT
        mysgw: TSM:FAIL:RE-INIT
        mysgw: TSM:INIT
        mysgw: TSM:FAIL:CNT=2
        mysgw: TSM:FAIL:PDT
        • R
          R
          Reza
          this is all my steps
          root@orangepione:~# sudo apt-get update
          Hit:1 http://ports.ubuntu.com xenial InRelease
          Hit:2 http://apt.armbian.com xenial InRelease
          Hit:3 http://ports.ubuntu.com xenial-security InRelease
          Hit:4 http://ports.ubuntu.com xenial-updates InRelease
          Hit:5 http://ports.ubuntu.com xenial-backports InRelease
          Reading package lists... Done
          root@orangepione:~# bin2fex /boot/script.bin /tmp/orange.fex
          fexc-bin: /boot/script.bin: version: 1.2
          fexc-bin: /boot/script.bin: size: 34704 (81 sections), header value: 34704
          root@orangepione:~# nano /tmp/orange.fex
          crw------- 1 root root 153, 0 Mar 19 11:17 /dev/spidev0.0
          root@orangepione:~# sudo modprobe gpio-sunxi
          root@orangepione:~# echo "gpio-sunxi" >> /etc/modules
          root@orangepione:~# vncserver
          New 'X' desktop is orangepione:1
          Starting applications specified in /root/.vnc/xstartup
          Log file is /root/.vnc/orangepione:1.log
          root@orangepione:~# *** Error in `pasystray': corrupted double-linked list (not small): 0x01cdb908 ***
          Cloning into 'MySensors'...
          remote: Counting objects: 13985, done.
          remote: Compressing objects: 100% (45/45), done.
          remote: Total 13985 (delta 8), reused 0 (delta 0), pack-reused 13940
          Receiving objects: 100% (13985/13985), 9.70 MiB | 181.00 KiB/s, done.
          Resolving deltas: 100% (8436/8436), done.
          Checking connectivity... done.
          root@orangepione:~# cd MySensors
          [OK] Finished.
          [OK] Finished.
          mysgw: MCO:BGN:INIT GW,CP=RNNG----,VER=2.2.0-beta
          mysgw: TSM:INIT
          mysgw: TSF:WUR:MS=0
          mysgw: TSM:FAIL:PDT
          mysgw: TSM:INIT
          mysgw: TSM:FAIL:PDT
          mysgw: TSM:INIT
          mysgw: TSM:FAIL:CNT=3
          mysgw: TSM:FAIL:PDT
          • pansenP
            pansenP
            pansen
            Can you post a picture of your wiring?
            Orange Pi Plus 2e connected to nrf24 PA via SPI running git-development MySensors gateway, OpenHAB2, mosquitto and MySQL persistence.
            • R Reza
              [OK] Finished.
              [OK] Finished.
              mysgw: TSM:INIT
              mysgw: TSF:WUR:MS=0
              mysgw: TSM:FAIL:PDT
              mysgw: TSM:INIT
              mysgw: TSM:FAIL:PDT
              mysgw: TSM:INIT
              mysgw: TSM:FAIL:PDT
              SdeWeb
              @Reza Hello,
              Did you modifying the .Fex file before applying the 'configure' setup ?
              What did you do with nano ?
              Regards.
              • pansenP pansen
                R
                R
                Reza
                #54
                @pansen
                red is 3.3
                brown is GND
                green is CE
                orange is SCK
                yellow is MISO
                violet is CS
                blue is MOSI
                IRQ is empty
                • S SdeWeb
                  @Reza Hello,
                  Regards.
                  R
                  R
                  Reza
                  #55
                  @SdeWeb
                  yes. use:
                  sudo nano /tmp/orange.fex
                  and remove all line and copy , paste your link and save this.
                  now orange.fex is:
                  [product]
                  version = "100"
                  machine = "Xunlong Orange Pi One"
                  [platform]
                  debug_mode = 1
                  eraseflag = 1
                  next_work = 2
                  [target]
                  boot_clock = 1008
                  storage_type = -1
                  [key_detect_en]
                  keyen_flag = 0
                  [fel_key]
                  fel_key_max = 7
                  fel_key_min = 2
                  [card_boot]
                  logical_start = 40960
                  sprite_work_delay = 500
                  sprite_err_delay = 200
                  sprite_gpio0 = port:PL10<1><default><default><default>
                  next_work = 3
                  [box_start_os]
                  used = 1
                  start_type = 1
                  irkey_used = 1
                  pmukey_used = 1
                  pmukey_num = 3
                  led_power = 0
                  led_state = 0
                  [boot_init_gpio]
                  used = 1
                  gpio0 = port:PL10<1><default><default><1>
                  gpio1 = port:PG11<1><default><default><1>
                  [recovery_para]
                  used = 1
                  mode = 2
                  recovery_key = port:PL04<0><default><default><default>
                  [pm_para]
                  standby_mode = 1
                  [card0_boot_para]
                  card_ctrl = 0
                  card_high_speed = 1
                  card_line = 4
                  sdc_d1 = port:PF00<2><1><2><default>
                  sdc_d0 = port:PF01<2><1><2><default>
                  sdc_clk = port:PF02<2><1><2><default>
                  sdc_cmd = port:PF03<2><1><2><default>
                  sdc_d3 = port:PF04<2><1><2><default>
                  sdc_d2 = port:PF05<2><1><2><default>
                  [card2_boot_para]
                  card_ctrl = 2
                  card_high_speed = 1
                  card_line = 8
                  sdc_cmd = port:PC06<3><1><2><default>
                  sdc_clk = port:PC05<3><1><2><default>
                  sdc_d0 = port:PC08<3><1><2><default>
                  sdc_d1 = port:PC09<3><1><2><default>
                  sdc_d2 = port:PC10<3><1><2><default>
                  sdc_d3 = port:PC11<3><1><2><default>
                  sdc_d4 = port:PC12<3><1><2><default>
                  sdc_d5 = port:PC13<3><1><2><default>
                  sdc_d6 = port:PC14<3><1><2><default>
                  sdc_d7 = port:PC15<3><1><2><default>
                  sdc_2xmode = 1
                  sdc_ddrmode = 1
                  [twi_para]
                  twi_port = 0
                  twi_scl = port:PA11<2><default><default><default>
                  twi_sda = port:PA12<2><default><default><default>
                  [uart_para]
                  uart_debug_port = 0
                  uart_debug_tx = port:PA04<2><1><default><default>
                  uart_debug_rx = port:PA05<2><1><default><default>
                  [force_uart_para]
                  force_uart_port = 0
                  force_uart_tx = port:PF02<3><1><default><default>
                  force_uart_rx = port:PF04<3><1><default><default>
                  [jtag_para]
                  jtag_enable = 0
                  jtag_ms = port:PA00<3><default><default><default>
                  jtag_ck = port:PA01<3><default><default><default>
                  jtag_do = port:PA02<3><default><default><default>
                  jtag_di = port:PA03<3><default><default><default>
                  [clock]
                  pll_video = 297
                  pll_ve = 402
                  pll_periph0 = 600
                  pll_gpu = 576
                  pll_periph1 = 600
                  pll_de = 864
                  [dram_para]
                  dram_clk = 624
                  dram_type = 3
                  dram_zq = 0x3b3bfb
                  dram_odt_en = 1
                  dram_para1 = 283377664
                  dram_para2 = 0
                  dram_mr0 = 6208
                  dram_mr1 = 64
                  dram_mr2 = 24
                  dram_mr3 = 2
                  dram_tpr0 = 0x48a192
                  dram_tpr1 = 0x1c2418d
                  dram_tpr2 = 0x76051
                  dram_tpr3 = 0x0
                  dram_tpr4 = 0x0
                  dram_tpr5 = 0x0
                  dram_tpr6 = 0x64
                  dram_tpr7 = 0x0
                  dram_tpr8 = 0x0
                  dram_tpr9 = 0x0
                  dram_tpr10 = 0x0
                  dram_tpr11 = 0x6aaa0000
                  dram_tpr12 = 0x7979
                  dram_tpr13 = 0x800800
                  [wakeup_src_para]
                  cpu_en = 0
                  cpu_freq = 48
                  pll_ratio = 273
                  dram_selfresh_en = 1
                  dram_freq = 36
                  wakeup_src0 =
                  wakeup_src_wl = port:PG10<4><default><default><0>
                  wakeup_src_bt = port:PL03<6><default><default><0>
                  [twi0]
                  twi_used = 1
                  [twi1]
                  twi_used = 1
                  twi_scl = port:PA18<3><default><default><default>
                  twi_sda = port:PA19<3><default><default><default>
                  [twi2]
                  twi_used = 0
                  twi_scl = port:PE12<3><default><default><default>
                  twi_sda = port:PE13<3><default><default><default>
                  [uart0]
                  uart_used = 1
                  uart_port = 0
                  uart_type = 2
                  uart_tx = port:PA04<2><1><default><default>
                  uart_rx = port:PA05<2><1><default><default>
                  [uart1]
                  uart_used = 0
                  uart_port = 1
                  uart_type = 4
                  uart_tx = port:PG06<2><1><default><default>
                  uart_rx = port:PG07<2><1><default><default>
                  uart_rts = port:PG08<2><1><default><default>
                  uart_cts = port:PG09<2><1><default><default>
                  [uart2]
                  uart_used = 0
                  uart_port = 2
                  uart_type = 4
                  uart_tx = port:PA00<2><1><default><default>
                  uart_rx = port:PA01<2><1><default><default>
                  uart_rts = port:PA02<2><1><default><default>
                  uart_cts = port:PA03<2><1><default><default>
                  [uart3]
                  uart_used = 0
                  uart_port = 3
                  uart_type = 4
                  uart_tx = port:PA13<3><1><default><default>
                  uart_rx = port:PA14<3><1><default><default>
                  uart_rts = port:PA15<3><1><default><default>
                  uart_cts = port:PA16<3><1><default><default>
                  [spi0]
                  spi_used = 1
                  spi_cs_bitmap = 1
                  spi_mosi = port:PC00<3><default><default><default>
                  spi_miso = port:PC01<3><default><default><default>
                  spi_sclk = port:PC02<3><default><default><default>
                  spi_cs0 = port:PC03<3><1><default><default>
                  [spi1]
                  spi_used = 0
                  spi_cs_bitmap = 1
                  spi_cs0 = port:PA13<2><1><default><default>
                  spi_sclk = port:PA14<2><default><default><default>
                  spi_mosi = port:PA15<2><default><default><default>
                  spi_miso = port:PA16<2><default><default><default>
                  [spi_devices]
                  spi_dev_num = 1
                  [spi_board0]
                  modalias = "spidev"
                  max_speed_hz = 33000000
                  bus_num = 0
                  chip_select = 0
                  mode = 0
                  full_duplex = 1
                  manual_cs = 0
                  ; NOTE: This section is necessary only for "gpio_sunxi" driver
                  ; which is obsolete for H3 boards
                  [gpio_para]
                  gpio_used = 0
                  gpio_num = 0
                  ;[led_assign]
                  ;normal_led = "gpio_pin_2"
                  ;standby_led = "gpio_pin_1"
                  [leds_para]
                  leds_used = 1
                  green_led = port:PL10<1><default><default><1>
                  green_led_active_low = 0
                  red_led = port:PA15<1><default><default><0>
                  red_led_active_low = 0
                  [ths_para]
                  ths_used = 1
                  ths_trip1_count = 6
                  ths_trip1_0 = 75
                  ths_trip1_1 = 80
                  ths_trip1_2 = 85
                  ths_trip1_3 = 90
                  ths_trip1_4 = 95
                  ths_trip1_5 = 105
                  ths_trip1_6 = 0
                  ths_trip1_7 = 0
                  ths_trip1_0_min = 0
                  ths_trip1_0_max = 1
                  ths_trip1_1_min = 1
                  ths_trip1_1_max = 2
                  ths_trip1_2_min = 2
                  ths_trip1_2_max = 3
                  ths_trip1_3_min = 3
                  ths_trip1_3_max = 4
                  ths_trip1_4_min = 4
                  ths_trip1_4_max = 5
                  ths_trip1_5_min = 5
                  ths_trip1_5_max = 7
                  ths_trip1_6_min = 0
                  ths_trip1_6_max = 0
                  ths_trip2_count = 1
                  ths_trip2_0 = 105
                  [cooler_table]
                  cooler_count = 8
                  cooler0 = "1200000 4 4294967295 0"
                  cooler1 = "912000 4 4294967295 0"
                  cooler2 = "768000 4 4294967295 0"
                  cooler3 = "648000 4 4294967295 0"
                  cooler4 = "480000 4 4294967295 0"
                  cooler5 = "480000 3 4294967295 0"
                  cooler6 = "480000 2 4294967295 0"
                  cooler7 = "480000 1 4294967295 0"
                  [nand0_para]
                  nand_support_2ch = 0
                  nand0_used = 0
                  nand0_we = port:PC00<2><default><default><default>
                  nand0_ale = port:PC01<2><default><default><default>
                  nand0_cle = port:PC02<2><default><default><default>
                  nand0_ce1 = port:PC03<2><default><default><default>
                  nand0_ce0 = port:PC04<2><default><default><default>
                  nand0_nre = port:PC05<2><default><default><default>
                  nand0_rb0 = port:PC06<2><default><default><default>
                  nand0_rb1 = port:PC07<2><default><default><default>
                  nand0_d0 = port:PC08<2><default><default><default>
                  nand0_d1 = port:PC09<2><default><default><default>
                  nand0_d2 = port:PC10<2><default><default><default>
                  nand0_d3 = port:PC11<2><default><default><default>
                  nand0_d4 = port:PC12<2><default><default><default>
                  nand0_d5 = port:PC13<2><default><default><default>
                  nand0_d6 = port:PC14<2><default><default><default>
                  nand0_d7 = port:PC15<2><default><default><default>
                  nand0_ndqs = port:PC16<2><default><default><default>
                  [boot_disp]
                  advert_disp = 0
                  auto_hpd = 1
                  output_type = 4
                  hdmi_channel = 0
                  hdmi_mode = 4
                  cvbs_channel = 1
                  cvbs_mode = 11
                  output_full = 1
                  hdmi_mode_check = 1
                  [disp_init]
                  disp_init_enable = 1
                  disp_mode = 0
                  screen0_output_type = 3
                  screen0_output_mode = 5
                  screen1_output_type = 3
                  screen1_output_mode = 5
                  fb0_format = 0
                  fb0_width = 0
                  fb0_height = 0
                  fb1_format = 0
                  fb1_width = 0
                  fb1_height = 0
                  [hdmi_para]
                  hdmi_used = 1
                  hdmi_power = "vcc-hdmi-18"
                  [tv_para]
                  tv_used = 0
                  tv_dac_used = 1
                  tv_dac_src0 = 0
                  [pwm0_para]
                  pwm_used = 0
                  pwm_positive = port:PA05<3><0><default><default>
                  ;       If set gamc_phy to use = 2
                  [gmac0]
                  gmac_used = 2
                  gmac_power1 =
                  [csi0]
                  vip_used = 1
                  vip_mode = 0
                  vip_dev_qty = 1
                  vip_define_sensor_list = 0
                  vip_csi_pck = port:PE00<2><default><default><default>
                  vip_csi_mck = port:PE01<2><default><default><default>
                  vip_csi_hsync = port:PE02<2><default><default><default>
                  vip_csi_vsync = port:PE03<2><default><default><default>
                  vip_csi_d0 = port:PE04<2><default><default><default>
                  vip_csi_d1 = port:PE05<2><default><default><default>
                  vip_csi_d2 = port:PE06<2><default><default><default>
                  vip_csi_d3 = port:PE07<2><default><default><default>
                  vip_csi_d4 = port:PE08<2><default><default><default>
                  vip_csi_d5 = port:PE09<2><default><default><default>
                  vip_csi_d6 = port:PE10<2><default><default><default>
                  vip_csi_d7 = port:PE11<2><default><default><default>
                  vip_csi_sck = port:PE12<2><default><default><default>
                  vip_csi_sda = port:PE13<2><default><default><default>
                  vip_dev0_mname = "gc2035"
                  vip_dev0_pos = "front"
                  vip_dev0_lane = 1
                  vip_dev0_twi_id = 2
                  vip_dev0_twi_addr = 120
                  vip_dev0_isp_used = 0
                  vip_dev0_fmt = 0
                  vip_dev0_stby_mode = 0
                  vip_dev0_vflip = 1
                  vip_dev0_hflip = 1
                  vip_dev0_iovdd = ""
                  vip_dev0_iovdd_vol = 2800000
                  vip_dev0_avdd = ""
                  vip_dev0_avdd_vol = 2800000
                  vip_dev0_dvdd = ""
                  vip_dev0_dvdd_vol = 1800000
                  vip_dev0_afvdd = ""
                  vip_dev0_afvdd_vol = 2800000
                  vip_dev0_power_en = port:PA17<1><default><default><1>
                  vip_dev0_reset = port:PE14<1><default><default><1>
                  vip_dev0_pwdn = port:PE15<1><default><default><0>
                  vip_dev0_flash_en =
                  vip_dev0_flash_mode =
                  vip_dev0_af_pwdn =
                  vip_dev0_act_used = 0
                  vip_dev0_act_name = "ad5820_act"
                  vip_dev0_act_slave = 24
                  vip_dev1_mname = ""
                  vip_dev1_pos = "rear"
                  vip_dev1_lane = 1
                  vip_dev1_twi_id = 0
                  vip_dev1_twi_addr =
                  vip_dev1_isp_used = 0
                  vip_dev1_fmt = 1
                  vip_dev1_stby_mode = 0
                  vip_dev1_vflip = 0
                  vip_dev1_hflip = 0
                  vip_dev1_iovdd = ""
                  vip_dev1_iovdd_vol = 2800000
                  vip_dev1_avdd = ""
                  vip_dev1_avdd_vol = 2800000
                  vip_dev1_dvdd = ""
                  vip_dev1_dvdd_vol = 1500000
                  vip_dev1_afvdd = ""
                  vip_dev1_afvdd_vol = 2800000
                  vip_dev1_power_en =
                  vip_dev1_reset =
                  vip_dev1_pwdn =
                  vip_dev1_flash_en =
                  vip_dev1_flash_mode =
                  vip_dev1_af_pwdn =
                  [tvout_para]
                  tvout_used = 0
                  tvout_channel_num =
                  tv_en = 0
                  [tvin_para]
                  tvin_used = 0
                  tvin_channel_num =
                  [di_para]
                  di_used = 1
                  [mmc0_para]
                  sdc_used = 1
                  sdc_detmode = 3
                  sdc_buswidth = 4
                  sdc_det = port:PF06<0><1><2><default>
                  sdc_use_wp = 0
                  sdc_wp =
                  sdc_isio = 0
                  sdc_regulator = "none"
                  sdc_power_supply = "none"
                  [mmc1_para]
                  sdc_used = 1
                  sdc_detmode = 4
                  sdc_buswidth = 4
                  sdc_clk = port:PG00<2><1><3><default>
                  sdc_cmd = port:PG01<2><1><3><default>
                  sdc_d0 = port:PG02<2><1><3><default>
                  sdc_d1 = port:PG03<2><1><3><default>
                  sdc_d2 = port:PG04<2><1><3><default>
                  sdc_d3 = port:PG05<2><1><3><default>
                  sdc_det =
                  sdc_use_wp = 0
                  sdc_wp =
                  sdc_isio = 1
                  sdc_2xmode = 1
                  sdc_ddrmode = 1
                  [mmc2_para]
                  sdc_used = 0
                  sdc_detmode = 3
                  sdc_buswidth = 8
                  emmc_rst = port:PC16<3><1><2><default>
                  sdc_det =
                  sdc_use_wp = 0
                  sdc_wp =
                  sdc_isio = 0
                  sdc_2xmode = 1
                  sdc_ddrmode = 1
                  [smc_para]
                  smc_used = 0
                  smc_rst = port:PA09<2><default><default><default>
                  smc_vppen = port:PA20<3><default><default><default>
                  smc_vppp = port:PA21<3><default><default><default>
                  smc_det = port:PA10<2><default><default><default>
                  smc_vccen = port:PA06<2><default><default><default>
                  smc_sck = port:PA07<2><default><default><default>
                  smc_sda = port:PA08<2><default><default><default>
                  [usbc0]
                  usb_used = 1
                  usb_port_type = 2
                  usb_detect_type = 0
                  usb_id_gpio = port:PG12<0><1><default><default>
                  usb_det_vbus_gpio = port:PG12<0><1><default><default>
                  usb_drv_vbus_gpio = port:PL02<1><0><default><0>
                  usb_host_init_state = 1
                  usb_restrict_gpio =
                  usb_restric_flag = 0
                  usb_restric_voltage = 3550000
                  usb_restric_capacity = 5
                  usb_regulator_io = "nocare"
                  usb_regulator_vol = 0
                  usb_not_suspend = 0
                  [usbc1]
                  usb_used = 1
                  usb_drv_vbus_gpio =
                  usb_restrict_gpio =
                  usb_not_suspend = 0
                  [usbc2]
                  usb_used = 1
                  usb_drv_vbus_gpio =
                  usb_restrict_gpio =
                  usb_not_suspend = 0
                  [usbc3]
                  usb_used = 1
                  usb_drv_vbus_gpio =
                  usb_restrict_gpio =
                  usb_not_suspend = 0
                  [usb_feature]
                  vendor_id = 6353
                  mass_storage_id = 1
                  adb_id = 2
                  manufacturer_name = "USB Developer"
                  product_name = "Android"
                  serial_number = "20080411"
                  [msc_feature]
                  vendor_name = "USB 2.0"
                  product_name = "USB Flash Driver"
                  release = 100
                  luns = 3
                  [serial_feature]
                  serial_unique = 0
                  [module_para]
                  module_num = 7
                  module_power0 = "vcc-wifi-33"
                  module_power0_vol = 0
                  module_power1 =
                  module_power1_vol =
                  module_power2 =
                  module_power2_vol =
                  module_power3 =
                  module_power3_vol =
                  chip_en =
                  lpo_use_apclk =
                  [wifi_para]
                  wifi_used = 0
                  wifi_sdc_id = 1
                  wifi_usbc_id = 5
                  wifi_usbc_type = 1
                  wl_reg_on = port:PL07<1><default><default><0>
                  wl_host_wake = port:PG10<0><default><default><0>
                  wl_host_wake_invert = 0
                  [bt_para]
                  bt_used = 0
                  bt_uart_id = 1
                  bt_rst_n =
                  bt_wake =
                  bt_host_wake =
                  bt_host_wake_invert = 0
                  [pcm0]
                  daudio_used = 0
                  daudio_master = 4
                  daudio_select = 1
                  audio_format = 1
                  signal_inversion = 1
                  mclk_fs = 128
                  sample_resolution = 16
                  slot_width_select = 32
                  pcm_lrck_period = 32
                  pcm_lrckr_period = 1
                  msb_lsb_first = 0
                  sign_extend = 0
                  slot_index = 0
                  slot_width = 32
                  frame_width = 0
                  tx_data_mode = 0
                  rx_data_mode = 0
                  i2s_mclk = port:PA18<2><1><default><default>
                  i2s_bclk = port:PA19<2><1><default><default>
                  i2s_dout0 = port:PA20<2><1><default><default>
                  i2s_din = port:PA21<2><1><default><default>
                  [pcm1]
                  daudio_used = 0
                  daudio_master = 4
                  daudio_select = 1
                  audio_format = 1
                  mclk_fs = 128
                  msb_lsb_first = 0
                  sign_extend = 0
                  slot_index = 0
                  slot_width = 32
                  frame_width = 0
                  tx_data_mode = 0
                  rx_data_mode = 0
                  i2s_mclk = port:PG10<2><1><default><default>
                  i2s_bclk = port:PG11<2><1><default><default>
                  i2s_dout0 = port:PG12<2><1><default><default>
                  i2s_din = port:PG13<2><1><default><default>
                  [audio0]
                  audio_used = 1
                  lineout_vol = 31
                  cap_vol = 5
                  audio_hp_ldo = "none"
                  adcagc_used = 0
                  adcdrc_used = 0
                  dacdrc_used = 0
                  adchpf_used = 0
                  dachpf_used = 0
                  audio_pa_ctrl = port:PA16<1><default><default><0>
                  [spdif0]
                  spdif_used = 0
                  spdif_dout = port:PA17<2><1><default><default>
                  [audiohub]
                  hub_used = 0
                  codec_used = 1
                  spdif_used = 1
                  hdmi_used = 1
                  [s_cir0]
                  ir_used = 0
                  ir_rx = port:PL11<2><1><default><default>
                  ir_power_key_code0 = 87
                  ir_addr_code0 = 40704
                  ir_power_key_code1 = 26
                  ir_addr_code1 = 64260
                  ir_power_key_code2 = 20
                  ir_addr_code2 = 32640
                  ir_power_key_code3 = 21
                  ir_addr_code3 = 32640
                  ir_power_key_code4 = 11
                  ir_addr_code4 = 63240
                  ir_power_key_code5 = 3
                  ir_addr_code5 = 239
                  ir_power_key_code6 = 159
                  ir_addr_code6 = 19635
                  ir_power_key_code7 = 10
                  ir_addr_code7 = 30536
                  ir_power_key_code8 = 69
                  ir_addr_code8 = 48386
                  ir_power_key_code9 = 77
                  ir_addr_code9 = 56865
                  ir_power_key_code10 = 24
                  ir_addr_code10 = 65025
                  ir_power_key_code11 = 87
                  ir_addr_code11 = 65280
                  ir_power_key_code12 = 77
                  ir_addr_code12 = 65344
                  [cir]
                  ir_used = 1
                  ir_tx = port:PH07<2><default><default><default>
                  ; dvfs voltage-frequency table configuration
                  ; pmuic_type:0:none, 1:gpio, 2:i2c
                  ; pmu_gpio0: gpio config.
                  ; pmu_levelx: 0~9999: voltage(mV), 10000~90000:gpio0 state. voltage form high to low.
                  ; extremity_freq(Hz): cpu extremity frequency when run benckmark or demo apk
                  ;                     1536MHz@1500mV with radiator, 1296MHz@1340mV without radiator
                  ; max_freq: cpu maximum frequency, based on Hz, can not be more than 1200MHz
                  ; min_freq: cpu minimum frequency, based on Hz, can not be less than 60MHz
                  ; LV_count: count of LV_freq/LV_volt, must be < 16
                  ; LV1: core vdd is 1.50v if cpu frequency is (1296Mhz,  1536Mhz]
                  ; LV2: core vdd is 1.34v if cpu frequency is (1200Mhz,  1296Mhz]
                  ; LV3: core vdd is 1.32v if cpu frequency is (1008Mhz,  1200Mhz]
                  ; LV4: core vdd is 1.20v if cpu frequency is (816Mhz,   1008Mhz]
                  ; LV5: core vdd is 1.10v if cpu frequency is (648Mhz,    816Mhz]
                  ; LV6: core vdd is 1.04v if cpu frequency is (0Mhz,      648Mhz]
                  ; LV7: core vdd is 1.04v if cpu frequency is (0Mhz,      648Mhz]
                  ; LV8: core vdd is 1.04v if cpu frequency is (0Mhz,      648Mhz]
                  [dvfs_table]
                  pmuic_type = 1
                  pmu_gpio0 = port:PL06<1><1><2><1>
                  pmu_level0 = 11300
                  pmu_level1 = 1100
                  max_freq = 1200000000
                  min_freq = 480000000
                  LV_count = 5
                  LV1_freq = 1200000000
                  LV1_volt = 1300
                  LV2_freq = 1008000000
                  LV2_volt = 1300
                  LV3_freq = 912000000
                  LV3_volt = 1100
                  LV4_freq = 648000000
                  LV4_volt = 1100
                  LV5_freq = 480000000
                  LV5_volt = 1100
                  [gpu_dvfs_table]
                  G_LV_count = 3
                  G_LV0_freq = 312000000
                  G_LV0_volt = 1200000
                  G_LV1_freq = 384000000
                  G_LV1_volt = 1200000
                  G_LV2_freq = 456000000
                  G_LV2_volt = 1200000
                  [Vdevice]
                  Vdevice_used = 0
                  Vdevice_0 = port:PH10<5><1><2><default>
                  Vdevice_1 = port:PH11<5><1><2><default>
                  [s_uart0]
                  s_uart_used = 0
                  s_uart_tx = port:PL02<2><default><default><default>
                  s_uart_rx = port:PL03<2><default><default><default>
                  [s_rsb0]
                  s_rsb_used = 1
                  s_rsb_sck = port:PL00<2><1><2><default>
                  s_rsb_sda = port:PL01<2><1><2><default>
                  [s_jtag0]
                  s_jtag_used = 0
                  s_jtag_tms = port:PL04<2><1><2><default>
                  s_jtag_tck = port:PL05<2><1><2><default>
                  s_jtag_tdo = port:PL06<2><1><2><default>
                  s_jtag_tdi = port:PL07<2><1><2><default>
                  [s_powchk]
                  s_powchk_used = -2147483648
                  s_power_reg = 0
                  s_system_power = 50
                  [sim0]
                  scr_used = 0
                  scr_vccen = port:PA06<2><default><default><default>
                  scr_slk = port:PA07<2><default><default><default>
                  scr_sda = port:PA08<2><default><default><default>
                  scr_rst = port:PA09<2><default><default><default>
                  scr_det = port:PA10<2><default><default><default>
                  [ts0]
                  tsc_used = 0
                  tsc_clk = port:PE00<3><default><default><default>
                  tsc_err = port:PE01<3><default><default><default>
                  tsc_sync = port:PE02<3><default><default><default>
                  tsc_dvld = port:PE03<3><default><default><default>
                  tsc_d0 = port:PE04<3><default><default><default>
                  tsc_d1 = port:PE05<3><default><default><default>
                  tsc_d2 = port:PE06<3><default><default><default>
                  tsc_d3 = port:PE07<3><default><default><default>
                  tsc_d4 = port:PE08<3><default><default><default>
                  tsc_d5 = port:PE09<3><default><default><default>
                  tsc_d6 = port:PE10<3><default><default><default>
                  tsc_d7 = port:PE11<3><default><default><default>
                  [gpio_power_key]
                  key_used = 1
                  key_io = port:PL03<6><default><default><0>
                  [key_para]
                  key_used = 0
                  key_cnt = 5
                  key1_vol = 222
                  key2_vol = 444
                  key3_vol = 666
                  key4_vol = 857
                  key5_vol = 2000
                  [d7s_para]
                  d7s_used = 0
                  din_gpio = port:PD00<1><default><default><1>
                  clk_gpio = port:PD01<1><default><default><1>
                  stb_gpio = port:PD02<1><default><default><1>
                  ;mali parameters
                  [mali_para]
                  mali_used = 1
                  mali_clkdiv = 1
                  mali_extreme_freq = 600
                  mali_extreme_vol = 1400
                  ;1wire parameters (default - PA20)
                  [w1_para]
                  w1_used = 1
                  gpio = 20
                  [corekeeper]
                  corekeeper_enabled = 1
                  • R Reza
                    @SdeWeb
                    yes. use:
                    now orange.fex is:
                    [product]
                    version = "100"
                    [platform]
                    debug_mode = 1
                    eraseflag = 1
                    next_work = 2
                    [target]
                    boot_clock = 1008
                    storage_type = -1
                    [key_detect_en]
                    keyen_flag = 0
                    [fel_key]
                    fel_key_max = 7
                    fel_key_min = 2
                    [card_boot]
                    next_work = 3
                    [box_start_os]
                    used = 1
                    start_type = 1
                    irkey_used = 1
                    pmukey_used = 1
                    pmukey_num = 3
                    led_power = 0
                    led_state = 0
                    [boot_init_gpio]
                    used = 1
                    [recovery_para]
                    used = 1
                    mode = 2
                    [pm_para]
                    standby_mode = 1
                    [card0_boot_para]
                    card_ctrl = 0
                    card_high_speed = 1
                    card_line = 4
                    [card2_boot_para]
                    card_ctrl = 2
                    card_high_speed = 1
                    card_line = 8
                    sdc_2xmode = 1
                    sdc_ddrmode = 1
                    [twi_para]
                    twi_port = 0
                    [uart_para]
                    uart_debug_port = 0
                    [force_uart_para]
                    force_uart_port = 0
                    [jtag_para]
                    jtag_enable = 0
                    [clock]
                    pll_video = 297
                    pll_ve = 402
                    pll_periph0 = 600
                    pll_gpu = 576
                    pll_periph1 = 600
                    pll_de = 864
                    [dram_para]
                    dram_clk = 624
                    dram_type = 3
                    dram_zq = 0x3b3bfb
                    dram_odt_en = 1
                    dram_para2 = 0
                    dram_mr0 = 6208
                    dram_mr1 = 64
                    dram_mr2 = 24
                    dram_mr3 = 2
                    dram_tpr2 = 0x76051
                    dram_tpr3 = 0x0
                    dram_tpr4 = 0x0
                    dram_tpr5 = 0x0
                    dram_tpr6 = 0x64
                    dram_tpr7 = 0x0
                    dram_tpr8 = 0x0
                    dram_tpr9 = 0x0
                    dram_tpr10 = 0x0
                    dram_tpr12 = 0x7979
                    [wakeup_src_para]
                    cpu_en = 0
                    cpu_freq = 48
                    pll_ratio = 273
                    dram_freq = 36
                    wakeup_src0 =
                    [twi0]
                    twi_used = 1
                    [twi1]
                    twi_used = 1
                    [twi2]
                    twi_used = 0
                    [uart0]
                    uart_used = 1
                    uart_port = 0
                    uart_type = 2
                    [uart1]
                    uart_used = 0
                    uart_port = 1
                    uart_type = 4
                    [uart2]
                    uart_used = 0
                    uart_port = 2
                    uart_type = 4
                    [uart3]
                    uart_used = 0
                    uart_port = 3
                    uart_type = 4
                    [spi0]
                    spi_used = 1
                    spi_cs_bitmap = 1
                    [spi1]
                    spi_used = 0
                    spi_cs_bitmap = 1
                    [spi_devices]
                    spi_dev_num = 1
                    [spi_board0]
                    modalias = "spidev"
                    bus_num = 0
                    chip_select = 0
                    mode = 0
                    full_duplex = 1
                    manual_cs = 0
                    [gpio_para]
                    gpio_used = 0
                    gpio_num = 0
                    ;[led_assign]
                    [leds_para]
                    leds_used = 1
                    [ths_para]
                    ths_used = 1
                    ths_trip1_count = 6
                    ths_trip1_0 = 75
                    ths_trip1_1 = 80
                    ths_trip1_2 = 85
                    ths_trip1_3 = 90
                    ths_trip1_4 = 95
                    ths_trip1_5 = 105
                    ths_trip1_6 = 0
                    ths_trip1_7 = 0
                    ths_trip1_0_min = 0
                    ths_trip1_0_max = 1
                    ths_trip1_1_min = 1
                    ths_trip1_1_max = 2
                    ths_trip1_2_min = 2
                    ths_trip1_2_max = 3
                    ths_trip1_3_min = 3
                    ths_trip1_3_max = 4
                    ths_trip1_4_min = 4
                    ths_trip1_4_max = 5
                    ths_trip1_5_min = 5
                    ths_trip1_5_max = 7
                    ths_trip1_6_min = 0
                    ths_trip1_6_max = 0
                    ths_trip2_count = 1
                    ths_trip2_0 = 105
                    [cooler_table]
                    cooler_count = 8
                    [nand0_para]
                    nand0_used = 0
                    [boot_disp]
                    advert_disp = 0
                    auto_hpd = 1
                    output_type = 4
                    hdmi_channel = 0
                    hdmi_mode = 4
                    cvbs_channel = 1
                    cvbs_mode = 11
                    output_full = 1
                    hdmi_mode_check = 1
                    [disp_init]
                    disp_mode = 0
                    fb0_format = 0
                    fb0_width = 0
                    fb0_height = 0
                    fb1_format = 0
                    fb1_width = 0
                    fb1_height = 0
                    [hdmi_para]
                    hdmi_used = 1
                    [tv_para]
                    tv_used = 0
                    tv_dac_used = 1
                    tv_dac_src0 = 0
                    [pwm0_para]
                    pwm_used = 0
                    [gmac0]
                    gmac_used = 2
                    gmac_power1 =
                    [csi0]
                    vip_used = 1
                    vip_mode = 0
                    vip_dev_qty = 1
                    vip_dev0_lane = 1
                    vip_dev0_twi_id = 2
                    vip_dev0_fmt = 0
                    vip_dev0_vflip = 1
                    vip_dev0_hflip = 1
                    vip_dev0_iovdd = ""
                    vip_dev0_avdd = ""
                    vip_dev0_dvdd = ""
                    vip_dev0_afvdd = ""
                    vip_dev0_flash_en =
                    vip_dev0_af_pwdn =
                    vip_dev1_mname = ""
                    vip_dev1_lane = 1
                    vip_dev1_twi_id = 0
                    vip_dev1_twi_addr =
                    vip_dev1_fmt = 1
                    vip_dev1_vflip = 0
                    vip_dev1_hflip = 0
                    vip_dev1_iovdd = ""
                    vip_dev1_avdd = ""
                    vip_dev1_dvdd = ""
                    vip_dev1_afvdd = ""
                    vip_dev1_power_en =
                    vip_dev1_reset =
                    vip_dev1_pwdn =
                    vip_dev1_flash_en =
                    vip_dev1_af_pwdn =
                    [tvout_para]
                    tvout_used = 0
                    tvout_channel_num =
                    tv_en = 0
                    [tvin_para]
                    tvin_used = 0
                    tvin_channel_num =
                    [di_para]
                    di_used = 1
                    [mmc0_para]
                    sdc_used = 1
                    sdc_detmode = 3
                    sdc_buswidth = 4
                    sdc_use_wp = 0
                    sdc_wp =
                    sdc_isio = 0
                    [mmc1_para]
                    sdc_used = 1
                    sdc_detmode = 4
                    sdc_buswidth = 4
                    sdc_det =
                    sdc_use_wp = 0
                    sdc_wp =
                    sdc_isio = 1
                    sdc_2xmode = 1
                    sdc_ddrmode = 1
                    [mmc2_para]
                    sdc_used = 0
                    sdc_detmode = 3
                    sdc_buswidth = 8
                    sdc_det =
                    sdc_use_wp = 0
                    sdc_wp =
                    sdc_isio = 0
                    sdc_2xmode = 1
                    sdc_ddrmode = 1
                    [smc_para]
                    smc_used = 0
                    [usbc0]
                    usb_used = 1
                    usb_port_type = 2
                    usb_detect_type = 0
                    usb_restrict_gpio =
                    usb_not_suspend = 0
                    [usbc1]
                    usb_used = 1
                    usb_drv_vbus_gpio =
                    usb_restrict_gpio =
                    usb_not_suspend = 0
                    [usbc2]
                    usb_used = 1
                    usb_drv_vbus_gpio =
                    usb_restrict_gpio =
                    usb_not_suspend = 0
                    [usbc3]
                    usb_used = 1
                    usb_drv_vbus_gpio =
                    usb_restrict_gpio =
                    usb_not_suspend = 0
                    [usb_feature]
                    vendor_id = 6353
                    mass_storage_id = 1
                    adb_id = 2
                    [msc_feature]
                    release = 100
                    luns = 3
                    [serial_feature]
                    serial_unique = 0
                    [module_para]
                    module_num = 7
                    module_power1 =
                    module_power1_vol =
                    module_power2 =
                    module_power2_vol =
                    module_power3 =
                    module_power3_vol =
                    chip_en =
                    lpo_use_apclk =
                    [wifi_para]
                    wifi_used = 0
                    wifi_sdc_id = 1
                    wifi_usbc_id = 5
                    wifi_usbc_type = 1
                    [bt_para]
                    bt_used = 0
                    bt_uart_id = 1
                    bt_rst_n =
                    bt_wake =
                    bt_host_wake =
                    [pcm0]
                    daudio_used = 0
                    daudio_master = 4
                    daudio_select = 1
                    audio_format = 1
                    mclk_fs = 128
                    msb_lsb_first = 0
                    sign_extend = 0
                    slot_index = 0
                    slot_width = 32
                    frame_width = 0
                    tx_data_mode = 0
                    rx_data_mode = 0
                    [pcm1]
                    daudio_used = 0
                    daudio_master = 4
                    daudio_select = 1
                    audio_format = 1
                    mclk_fs = 128
                    msb_lsb_first = 0
                    sign_extend = 0
                    slot_index = 0
                    slot_width = 32
                    frame_width = 0
                    tx_data_mode = 0
                    rx_data_mode = 0
                    [audio0]
                    audio_used = 1
                    lineout_vol = 31
                    cap_vol = 5
                    adcagc_used = 0
                    adcdrc_used = 0
                    dacdrc_used = 0
                    adchpf_used = 0
                    dachpf_used = 0
                    [spdif0]
                    spdif_used = 0
                    [audiohub]
                    hub_used = 0
                    codec_used = 1
                    spdif_used = 1
                    hdmi_used = 1
                    [s_cir0]
                    ir_used = 0
                    ir_addr_code5 = 239
                    [cir]
                    ir_used = 1
                    [dvfs_table]
                    pmuic_type = 1
                    pmu_level0 = 11300
                    pmu_level1 = 1100
                    LV_count = 5
                    LV1_volt = 1300
                    LV2_volt = 1300
                    LV3_volt = 1100
                    LV4_volt = 1100
                    LV5_volt = 1100
                    [gpu_dvfs_table]
                    G_LV_count = 3
                    [Vdevice]
                    Vdevice_used = 0
                    [s_uart0]
                    s_uart_used = 0
                    [s_rsb0]
                    s_rsb_used = 1
                    [s_jtag0]
                    s_jtag_used = 0
                    [s_powchk]
                    s_power_reg = 0
                    s_system_power = 50
                    [sim0]
                    scr_used = 0
                    [ts0]
                    tsc_used = 0
                    [gpio_power_key]
                    key_used = 1
                    [key_para]
                    key_used = 0
                    key_cnt = 5
                    key1_vol = 222
                    key2_vol = 444
                    key3_vol = 666
                    key4_vol = 857
                    key5_vol = 2000
                    [d7s_para]
                    d7s_used = 0
                    ;mali parameters
                    [mali_para]
                    mali_used = 1
                    mali_clkdiv = 1
                    [w1_para]
                    w1_used = 1
                    gpio = 20
                    [corekeeper]
                    SdeWeb
                    @Reza
                    Hello, it seems when i read your previous post, that you forgot to reverse your custom .fex file in the system.
                    In fact, after modifying the .fex in nano, you must do "fex2bin" your .fex file to replace in the system the script.bin file.
                    If you didn't to that, your .fex file is not used, is useless until you "fex2bin" it.
                    Your pinout seems OK, a option is to use Pin 17 (3.3V) an Pin 20 (GND) to powering your NRF module.
                    Regards.
                    Seb.
                    • S SdeWeb
                      @Reza
                      Regards.
                      Seb.
                      R
                      R
                      Reza
                      @SdeWeb sorry i am worng in typing.but i do all steps but there is problem for me.
                      pin 1 and 6 is 3.3v and gnd .what is defference between 1 & 17 and 6 & 20?
                      this is all steps that i was follow:
                      Hit:2 http://ports.ubuntu.com xenial-security InRelease
                      Hit:3 http://apt.armbian.com xenial InRelease
                      root@orangepione:~# sudo apt-get install sunxi-tools
                      Building dependency tree
                      Reading state information... Done
                      sunxi-tools is already the newest version (1.4.2-1~armbian5.25+1).
                      0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                      and in orange.fex :
                      [product]
                      version = "100"
                      [platform]
                      debug_mode = 1
                      eraseflag = 1
                      next_work = 2
                      [target]
                      boot_clock = 1008
                      storage_type = -1
                      [key_detect_en]
                      keyen_flag = 0
                      [fel_key]
                      fel_key_max = 7
                      fel_key_min = 2
                      [card_boot]
                      next_work = 3
                      [box_start_os]
                      used = 1
                      start_type = 1
                      irkey_used = 1
                      pmukey_used = 1
                      pmukey_num = 3
                      led_power = 0
                      led_state = 0
                      [boot_init_gpio]
                      used = 1
                      [recovery_para]
                      used = 1
                      mode = 2
                      [pm_para]
                      standby_mode = 1
                      [card0_boot_para]
                      card_ctrl = 0
                      card_high_speed = 1
                      card_line = 4
                      [card2_boot_para]
                      card_ctrl = 2
                      card_high_speed = 1
                      card_line = 8
                      sdc_2xmode = 1
                      sdc_ddrmode = 1
                      [twi_para]
                      twi_port = 0
                      [uart_para]
                      uart_debug_port = 0
                      [force_uart_para]
                      force_uart_port = 0
                      [jtag_para]
                      jtag_enable = 0
                      [clock]
                      pll_video = 297
                      pll_ve = 402
                      pll_periph0 = 600
                      pll_gpu = 576
                      pll_periph1 = 600
                      pll_de = 864
                      [dram_para]
                      dram_clk = 624
                      dram_type = 3
                      dram_zq = 0x3b3bfb
                      dram_odt_en = 1
                      dram_para2 = 0
                      dram_mr0 = 6208
                      dram_mr1 = 64
                      dram_mr2 = 24
                      dram_mr3 = 2
                      dram_tpr2 = 0x76051
                      dram_tpr3 = 0x0
                      dram_tpr4 = 0x0
                      dram_tpr5 = 0x0
                      dram_tpr6 = 0x64
                      dram_tpr7 = 0x0
                      dram_tpr8 = 0x0
                      dram_tpr9 = 0x0
                      dram_tpr10 = 0x0
                      dram_tpr12 = 0x7979
                      [wakeup_src_para]
                      cpu_en = 0
                      cpu_freq = 48
                      pll_ratio = 273
                      dram_freq = 36
                      wakeup_src0 =
                      [twi0]
                      twi_used = 1
                      [twi1]
                      twi_used = 1
                      [twi2]
                      twi_used = 0
                      [uart0]
                      uart_used = 1
                      uart_port = 0
                      uart_type = 2
                      [uart1]
                      uart_used = 0
                      uart_port = 1
                      uart_type = 4
                      [uart2]
                      uart_used = 0
                      uart_port = 2
                      uart_type = 4
                      [uart3]
                      uart_used = 0
                      uart_port = 3
                      uart_type = 4
                      [spi0]
                      spi_used = 1
                      spi_cs_bitmap = 1
                      [spi1]
                      spi_used = 0
                      spi_cs_bitmap = 1
                      [spi_devices]
                      spi_dev_num = 1
                      [spi_board0]
                      modalias = "spidev"
                      bus_num = 0
                      chip_select = 0
                      mode = 0
                      full_duplex = 1
                      manual_cs = 0
                      [gpio_para]
                      gpio_used = 0
                      gpio_num = 0
                      ;[led_assign]
                      [leds_para]
                      leds_used = 1
                      [ths_para]
                      ths_used = 1
                      ths_trip1_count = 6
                      ths_trip1_0 = 75
                      ths_trip1_1 = 80
                      ths_trip1_2 = 85
                      ths_trip1_3 = 90
                      ths_trip1_4 = 95
                      ths_trip1_5 = 105
                      ths_trip1_6 = 0
                      ths_trip1_7 = 0
                      ths_trip1_0_min = 0
                      ths_trip1_0_max = 1
                      ths_trip1_1_min = 1
                      ths_trip1_1_max = 2
                      ths_trip1_2_min = 2
                      ths_trip1_2_max = 3
                      ths_trip1_3_min = 3
                      ths_trip1_3_max = 4
                      ths_trip1_4_min = 4
                      ths_trip1_4_max = 5
                      ths_trip1_5_min = 5
                      ths_trip1_5_max = 7
                      ths_trip1_6_min = 0
                      ths_trip1_6_max = 0
                      ths_trip2_count = 1
                      ths_trip2_0 = 105
                      [cooler_table]
                      cooler_count = 8
                      [nand0_para]
                      nand0_used = 0
                      [boot_disp]
                      advert_disp = 0
                      auto_hpd = 1
                      output_type = 4
                      hdmi_channel = 0
                      hdmi_mode = 4
                      cvbs_channel = 1
                      cvbs_mode = 11
                      output_full = 1
                      hdmi_mode_check = 1
                      [disp_init]
                      disp_mode = 0
                      fb0_format = 0
                      fb0_width = 0
                      fb0_height = 0
                      fb1_format = 0
                      fb1_width = 0
                      fb1_height = 0
                      [hdmi_para]
                      hdmi_used = 1
                      [tv_para]
                      tv_used = 0
                      tv_dac_used = 1
                      tv_dac_src0 = 0
                      [pwm0_para]
                      pwm_used = 0
                      [gmac0]
                      gmac_used = 2
                      gmac_power1 =
                      [csi0]
                      vip_used = 1
                      vip_mode = 0
                      vip_dev_qty = 1
                      vip_dev0_lane = 1
                      vip_dev0_twi_id = 2
                      vip_dev0_fmt = 0
                      vip_dev0_vflip = 1
                      vip_dev0_hflip = 1
                      vip_dev0_iovdd = ""
                      vip_dev0_avdd = ""
                      vip_dev0_dvdd = ""
                      vip_dev0_afvdd = ""
                      vip_dev0_flash_en =
                      vip_dev0_af_pwdn =
                      vip_dev1_mname = ""
                      vip_dev1_lane = 1
                      vip_dev1_twi_id = 0
                      vip_dev1_twi_addr =
                      vip_dev1_fmt = 1
                      vip_dev1_vflip = 0
                      vip_dev1_hflip = 0
                      vip_dev1_iovdd = ""
                      vip_dev1_avdd = ""
                      vip_dev1_dvdd = ""
                      vip_dev1_afvdd = ""
                      vip_dev1_power_en =
                      vip_dev1_reset =
                      vip_dev1_pwdn =
                      vip_dev1_flash_en =
                      vip_dev1_af_pwdn =
                      [tvout_para]
                      tvout_used = 0
                      tvout_channel_num =
                      tv_en = 0
                      [tvin_para]
                      tvin_used = 0
                      tvin_channel_num =
                      [di_para]
                      di_used = 1
                      [mmc0_para]
                      sdc_used = 1
                      sdc_detmode = 3
                      sdc_buswidth = 4
                      sdc_use_wp = 0
                      sdc_wp =
                      sdc_isio = 0
                      [mmc1_para]
                      sdc_used = 1
                      sdc_detmode = 4
                      sdc_buswidth = 4
                      sdc_det =
                      sdc_use_wp = 0
                      sdc_wp =
                      sdc_isio = 1
                      sdc_2xmode = 1
                      sdc_ddrmode = 1
                      [mmc2_para]
                      sdc_used = 0
                      sdc_detmode = 3
                      sdc_buswidth = 8
                      sdc_det =
                      sdc_use_wp = 0
                      sdc_wp =
                      sdc_isio = 0
                      sdc_2xmode = 1
                      sdc_ddrmode = 1
                      [smc_para]
                      smc_used = 0
                      [usbc0]
                      usb_used = 1
                      usb_port_type = 2
                      usb_detect_type = 0
                      usb_restrict_gpio =
                      usb_not_suspend = 0
                      [usbc1]
                      usb_used = 1
                      usb_drv_vbus_gpio =
                      usb_restrict_gpio =
                      usb_not_suspend = 0
                      [usbc2]
                      usb_used = 1
                      usb_drv_vbus_gpio =
                      usb_restrict_gpio =
                      usb_not_suspend = 0
                      [usbc3]
                      usb_used = 1
                      usb_drv_vbus_gpio =
                      usb_restrict_gpio =
                      usb_not_suspend = 0
                      [usb_feature]
                      vendor_id = 6353
                      mass_storage_id = 1
                      adb_id = 2
                      [msc_feature]
                      release = 100
                      luns = 3
                      [serial_feature]
                      serial_unique = 0
                      [module_para]
                      module_num = 7
                      module_power1 =
                      module_power1_vol =
                      module_power2 =
                      module_power2_vol =
                      module_power3 =
                      module_power3_vol =
                      chip_en =
                      lpo_use_apclk =
                      [wifi_para]
                      wifi_used = 0
                      wifi_sdc_id = 1
                      wifi_usbc_id = 5
                      wifi_usbc_type = 1
                      [bt_para]
                      bt_used = 0
                      bt_uart_id = 1
                      bt_rst_n =
                      bt_wake =
                      bt_host_wake =
                      [pcm0]
                      daudio_used = 0
                      daudio_master = 4
                      daudio_select = 1
                      audio_format = 1
                      mclk_fs = 128
                      msb_lsb_first = 0
                      sign_extend = 0
                      slot_index = 0
                      slot_width = 32
                      frame_width = 0
                      tx_data_mode = 0
                      rx_data_mode = 0
                      [pcm1]
                      daudio_used = 0
                      daudio_master = 4
                      daudio_select = 1
                      audio_format = 1
                      mclk_fs = 128
                      msb_lsb_first = 0
                      sign_extend = 0
                      slot_index = 0
                      slot_width = 32
                      frame_width = 0
                      tx_data_mode = 0
                      rx_data_mode = 0
                      [audio0]
                      audio_used = 1
                      lineout_vol = 31
                      cap_vol = 5
                      adcagc_used = 0
                      adcdrc_used = 0
                      dacdrc_used = 0
                      adchpf_used = 0
                      dachpf_used = 0
                      [spdif0]
                      spdif_used = 0
                      [audiohub]
                      hub_used = 0
                      codec_used = 1
                      spdif_used = 1
                      hdmi_used = 1
                      [s_cir0]
                      ir_used = 0
                      ir_addr_code5 = 239
                      [cir]
                      ir_used = 1
                      [dvfs_table]
                      pmuic_type = 1
                      pmu_level0 = 11300
                      pmu_level1 = 1100
                      LV_count = 5
                      LV1_volt = 1300
                      LV2_volt = 1300
                      LV3_volt = 1100
                      LV4_volt = 1100
                      LV5_volt = 1100
                      [gpu_dvfs_table]
                      G_LV_count = 3
                      [Vdevice]
                      Vdevice_used = 0
                      [s_uart0]
                      s_uart_used = 0
                      [s_rsb0]
                      s_rsb_used = 1
                      [s_jtag0]
                      s_jtag_used = 0
                      [s_powchk]
                      s_power_reg = 0
                      s_system_power = 50
                      [sim0]
                      scr_used = 0
                      [ts0]
                      tsc_used = 0
                      [gpio_power_key]
                      key_used = 1
                      [key_para]
                      key_used = 0
                      key_cnt = 5
                      key1_vol = 222
                      key2_vol = 444
                      key3_vol = 666
                      key4_vol = 857
                      key5_vol = 2000
                      [d7s_para]
                      d7s_used = 0
                      ;mali parameters
                      [mali_para]
                      mali_used = 1
                      mali_clkdiv = 1
                      [w1_para]
                      w1_used = 1
                      gpio = 20
                      [corekeeper]
                      then:
                      root@orangepione:~# sudo fex2bin /tmp/orange.fex /boot/script.bin
                      root@orangepione:~# sudo reboot
                      then:
                      crw------- 1 root root 153, 0 Mar 19 22:57 /dev/spidev0.0
                      then:
                      root@orangepione:~# git clone https://github.com/mysensors/MySensors.git
                      Receiving objects: 100% (13985/13985), 9.70 MiB | 310.00 KiB/s, done.
                      [OK] Finished.
                      [OK] Finished.
                      mysgw: TSM:INIT
                      mysgw: TSF:WUR:MS=0
                      mysgw: TSM:FAIL:PDT
                      mysgw: TSM:INIT
                      mysgw: TSM:FAIL:PDT
                      mysgw: TSM:INIT
                      mysgw: TSM:FAIL:PDT
                      ^Z
                      [1]+  Stopped                 sudo ./bin/mysgw -d
                      also i change 3.3v and gnd to 17 and 20 but . . . :(
                      • G
                        G
                        giran
                        wrote on last edited by giran
                        #58
                        Hi all
                        I have problems with Orange zero to make it work as a MYS gateway.
                        What is done:
                        1. take Debian img from https://www.armbian.com/orange-pi-zero/
                        2. added /dev/spidev1.0 using instructions from here: https://www.mysensors.org/build/orange
                          So I actually see spidev1.0 in ls -l /dev/spidev*
                        3. wired everything up as is described here: https://www.mysensors.org/build/orange
                          So everything is connected to the spi1 pins.
                          I used nrf24 with a capacitor and without - same result
                        4. ran commands
                        cd MySensors
                        ./configure --spi-spidev-device=/dev/spidev1.0 --my-transport=nrf24 --my-rf24-ce-pin=2 --my-rf24-cs-pin=13 --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyUSB020 --my-serial-baudrate=115200
                        sudo make
                        sudo make install
                        sudo ./bin/mysgw -d
                        And I see failed logs
                        mysgw: TSM:INIT
                        mysgw: TSF:WUR:MS=0
                        mysgw: TSM:FAIL:PDT
                        mysgw: TSM:INIT
                        Has anyone set it up for Zero?
                        What am I doing wrong?
                        Thanks in advance!
                        pansenP 1 Reply Last reply
                        • G giran
                          Hi all
                          What is done:
                          4. ran commands
                          cd MySensors
                          sudo make
                          sudo make install
                          sudo ./bin/mysgw -d
                          mysgw: TSM:INIT
                          mysgw: TSF:WUR:MS=0
                          mysgw: TSM:FAIL:PDT
                          mysgw: TSM:INIT
                          Thanks in advance!
                          pansenP
                          pansenP
                          pansen
                          @giran hi i don't think you can run the service and the binary standalone at the same time since hardware access is exclusive. Try to stop the service and then run the binary again.
                          G 1 Reply Last reply
                          • pansenP pansen
                            G
                            G
                            giran
                            #60
                            @pansen Thanks for answering.
                            Even when I stopped the service
                            or when I run
                            sudo make
                            sudo ./bin/mysgw -d
                            I still see failed logs.
                            • G giran
                              or when I run
                              sudo make
                              sudo ./bin/mysgw -d
                              SdeWeb
                              @giran Hi, how did you connect you NRF module on the Orange PI ?
                              Is you use the GPIO, you should'nt use TTY stup for MuSensors.
                              Look above my setup in this forum, if you use the GPIO.
                              Regards.
                              • S SdeWeb
                                Regards.
                                G
                                G
                                giran
                                #62
                                @SdeWeb Just a minute ago everything worked )) With all steps I described, instead of the 1st one.
                                I faced with issues when I installed Debian Jessie (https://www.armbian.com/orange-pi-zero/)
                                but when I tried Ubuntu Xential - everything worked!
                                By using this img time to time my OrangeZero stops to respond. I'll investigate this later.
                                But for now I'm happy I set up MYS.
                                Thanks everyone who was trying to help. And I believe someone would find this post useful, with trying another img.
                                  marceloaqno
                                  Code Contributor
                                  wrote on last edited by marceloaqno
                                  #63
                                  Support for RFM69 has been added, check the build guide for more information.
                                  • awilnerA
                                    awilnerA
                                    awilner
                                    Hi, everyone
                                    I hope someone can help me, I'm lost trying to wrap my head around the proper pin numbers. I'm using a 433MHz RFM69 connected to an OrangePi PC with this configuration:
                                       OPI PC <-----------> RFM69
                                    17 / 3.3V <-----------> VCC
                                     19 / PC0 <-----------> MOSI
                                     21 / PC1 <-----------> MISO
                                     22 / PA2 <-----------> DI00
                                     23 / PC2 <-----------> SCK
                                     24 / PC3 <-----------> NSS
                                     25 / GND <-----------> GND
                                    Pin codes were taken from this picture:
                                    OrangePi pins
                                    I have the most recent version of the code in the development branch:
                                    fanta@orangepipc:~/MySensors$ git status
                                    On branch development
                                    Your branch is up-to-date with 'origin/development'.
                                    nothing to commit, working directory clean
                                    fanta@orangepipc:~/MySensors$ git log --pretty=format:'%h' -n 1
                                    ff0953d
                                    Although the OrangePi PC apparently does not use spidev0.0 for NAND flash like the Zero, I ended up changing the FEX. This is my current state:
                                    [product]
                                    version = "100"
                                    machine = "orangepi-pc"
                                    [platform]
                                    debug_mode = 1
                                    eraseflag = 1
                                    next_work = 2
                                    [target]
                                    boot_clock = 1008
                                    storage_type = -1
                                    [key_detect_en]
                                    keyen_flag = 0
                                    [fel_key]
                                    fel_key_max = 7
                                    fel_key_min = 2
                                    [card_boot]
                                    next_work = 3
                                    [box_start_os]
                                    used = 1
                                    start_type = 1
                                    irkey_used = 1
                                    pmukey_used = 1
                                    pmukey_num = 3
                                    led_power = 0
                                    led_state = 0
                                    [boot_init_gpio]
                                    used = 1
                                    [recovery_para]
                                    used = 1
                                    mode = 2
                                    [pm_para]
                                    standby_mode = 1
                                    [card0_boot_para]
                                    card_ctrl = 0
                                    card_high_speed = 1
                                    card_line = 4
                                    [card2_boot_para]
                                    card_ctrl = 2
                                    card_high_speed = 1
                                    card_line = 8
                                    sdc_2xmode = 1
                                    sdc_ddrmode = 1
                                    [twi_para]
                                    twi_port = 0
                                    [uart_para]
                                    uart_debug_port = 0
                                    [force_uart_para]
                                    force_uart_port = 0
                                    [jtag_para]
                                    jtag_enable = 0
                                    [clock]
                                    pll_video = 297
                                    pll_ve = 402
                                    pll_periph0 = 600
                                    pll_gpu = 576
                                    pll_periph1 = 600
                                    pll_de = 864
                                    [dram_para]
                                    dram_clk = 624
                                    dram_type = 3
                                    dram_zq = 0x3b3bfb
                                    dram_odt_en = 1
                                    dram_para2 = 0
                                    dram_mr0 = 6208
                                    dram_mr1 = 64
                                    dram_mr2 = 24
                                    dram_mr3 = 2
                                    dram_tpr2 = 0x76051
                                    dram_tpr3 = 0x0
                                    dram_tpr4 = 0x0
                                    dram_tpr5 = 0x0
                                    dram_tpr6 = 0x64
                                    dram_tpr7 = 0x0
                                    dram_tpr8 = 0x0
                                    dram_tpr9 = 0x0
                                    dram_tpr10 = 0x0
                                    dram_tpr12 = 0x7979
                                    [wakeup_src_para]
                                    cpu_en = 0
                                    cpu_freq = 48
                                    pll_ratio = 273
                                    dram_freq = 36
                                    wakeup_src0 =
                                    [twi0]
                                    twi_used = 1
                                    [twi1]
                                    twi_used = 1
                                    [twi2]
                                    twi_used = 0
                                    [uart0]
                                    uart_used = 1
                                    uart_port = 0
                                    uart_type = 2
                                    [uart1]
                                    uart_used = 0
                                    uart_port = 1
                                    uart_type = 4
                                    [uart2]
                                    uart_used = 0
                                    uart_port = 2
                                    uart_type = 4
                                    [uart3]
                                    uart_used = 0
                                    uart_port = 3
                                    uart_type = 4
                                    [spi0]
                                    spi_used = 1
                                    spi_cs_bitmap = 1
                                    [spi1]
                                    spi_used = 1
                                    spi_cs_bitmap = 1
                                    [spi_devices]
                                    spi_dev_num = 2
                                    [spi_board0]
                                    modalias = "spidev"
                                    bus_num = 0
                                    chip_select = 0
                                    mode = 0
                                    full_duplex = 1
                                    manual_cs = 0
                                    [spi_board1]
                                    modalias = "spidev"
                                    bus_num = 1
                                    chip_select = 0
                                    mode = 0
                                    full_duplex = 1
                                    manual_cs = 0
                                    [gpio_para]
                                    gpio_used = 1
                                    gpio_num = 20
                                    gpio_pin_1 = port:PA06<1><default><default><0>
                                    gpio_pin_2 = port:PA13<1><default><default><0>
                                    gpio_pin_3 = port:PA14<1><default><default><0>
                                    gpio_pin_4 = port:PA01<1><default><default><0>
                                    gpio_pin_5 = port:PD14<1><default><default><0>
                                    gpio_pin_6 = port:PA00<1><default><default><0>
                                    gpio_pin_7 = port:PA03<1><default><default><0>
                                    gpio_pin_8 = port:PC04<1><default><default><0>
                                    gpio_pin_9 = port:PC07<1><default><default><0>
                                    gpio_pin_10 = port:PA02<1><default><default><0>
                                    gpio_pin_11 = port:PA21<1><default><default><0>
                                    gpio_pin_12 = port:PA07<1><default><default><0>
                                    gpio_pin_13 = port:PA08<1><default><default><0>
                                    gpio_pin_14 = port:PG08<1><default><default><0>
                                    gpio_pin_15 = port:PA09<1><default><default><0>
                                    gpio_pin_16 = port:PA10<1><default><default><0>
                                    gpio_pin_17 = port:PG09<1><default><default><0>
                                    gpio_pin_18 = port:PG06<1><default><default><0>
                                    gpio_pin_19 = port:PG07<1><default><default><0>
                                    gpio_pin_20 = port:PC03<1><default><default><0>
                                    [leds_para]
                                    leds_used = 1
                                    [ths_para]
                                    ths_used = 1
                                    ths_trip1_count = 6
                                    ths_trip1_0 = 75
                                    ths_trip1_1 = 80
                                    ths_trip1_2 = 85
                                    ths_trip1_3 = 90
                                    ths_trip1_4 = 95
                                    ths_trip1_5 = 105
                                    ths_trip1_6 = 0
                                    ths_trip1_7 = 0
                                    ths_trip1_0_min = 0
                                    ths_trip1_0_max = 1
                                    ths_trip1_1_min = 1
                                    ths_trip1_1_max = 2
                                    ths_trip1_2_min = 2
                                    ths_trip1_2_max = 3
                                    ths_trip1_3_min = 3
                                    ths_trip1_3_max = 4
                                    ths_trip1_4_min = 4
                                    ths_trip1_4_max = 8
                                    ths_trip1_5_min = 8
                                    ths_trip1_5_max = 8
                                    ths_trip1_6_min = 0
                                    ths_trip1_6_max = 0
                                    ths_trip2_count = 1
                                    ths_trip2_0 = 105
                                    [cooler_table]
                                    cooler_count = 9
                                    cooler0 = "1296000 4 4294967295 0"
                                    cooler1 = "1200000 4 4294967295 0"
                                    cooler2 = "1008000 4 4294967295 0"
                                    cooler3 = "816000 4 4294967295 0"
                                    cooler4 = "648000 4 4294967295 0"
                                    cooler5 = "480000 4 4294967295 0"
                                    cooler6 = "480000 3 4294967295 0"
                                    cooler7 = "480000 2 4294967295 0"
                                    cooler8 = "480000 1 4294967295 0"
                                    [nand0_para]
                                    nand0_used = 0
                                    [boot_disp]
                                    advert_disp = 0
                                    auto_hpd = 1
                                    output_type = 4
                                    hdmi_channel = 0
                                    hdmi_mode = 4
                                    cvbs_channel = 1
                                    cvbs_mode = 11
                                    output_full = 1
                                    hdmi_mode_check = 1
                                    [disp_init]
                                    disp_mode = 0
                                    fb0_format = 0
                                    fb0_width = 0
                                    fb0_height = 0
                                    fb1_format = 0
                                    fb1_width = 0
                                    fb1_height = 0
                                    [hdmi_para]
                                    hdmi_used = 1
                                    [tv_para]
                                    tv_used = 0
                                    tv_dac_used = 1
                                    tv_dac_src0 = 0
                                    [pwm0_para]
                                    pwm_used = 0
                                    [gmac0]
                                    gmac_used = 2
                                    gmac_power1 =
                                    [csi0]
                                    vip_used = 1
                                    vip_mode = 0
                                    vip_dev_qty = 1
                                    vip_dev0_lane = 1
                                    vip_dev0_twi_id = 2
                                    vip_dev0_fmt = 0
                                    vip_dev0_vflip = 1
                                    vip_dev0_hflip = 1
                                    vip_dev0_iovdd = ""
                                    vip_dev0_avdd = ""
                                    vip_dev0_dvdd = ""
                                    vip_dev0_afvdd = ""
                                    vip_dev0_flash_en =
                                    vip_dev0_af_pwdn =
                                    vip_dev1_mname = ""
                                    vip_dev1_lane = 1
                                    vip_dev1_twi_id = 0
                                    vip_dev1_twi_addr =
                                    vip_dev1_fmt = 1
                                    vip_dev1_vflip = 0
                                    vip_dev1_hflip = 0
                                    vip_dev1_iovdd = ""
                                    vip_dev1_avdd = ""
                                    vip_dev1_dvdd = ""
                                    vip_dev1_afvdd = ""
                                    vip_dev1_power_en =
                                    vip_dev1_reset =
                                    vip_dev1_pwdn =
                                    vip_dev1_flash_en =
                                    vip_dev1_af_pwdn =
                                    [tvout_para]
                                    tvout_used =
                                    tvout_channel_num =
                                    tv_en =
                                    [tvin_para]
                                    tvin_used =
                                    tvin_channel_num =
                                    [di_para]
                                    di_used = 1
                                    [mmc0_para]
                                    sdc_used = 1
                                    sdc_detmode = 3
                                    sdc_buswidth = 4
                                    sdc_use_wp = 0
                                    sdc_wp =
                                    sdc_isio = 0
                                    [mmc1_para]
                                    sdc_used = 1
                                    sdc_detmode = 4
                                    sdc_buswidth = 4
                                    sdc_det =
                                    sdc_use_wp = 0
                                    sdc_wp =
                                    sdc_isio = 1
                                    sdc_2xmode = 1
                                    sdc_ddrmode = 1
                                    [mmc2_para]
                                    sdc_used = 0
                                    sdc_detmode = 3
                                    sdc_buswidth = 8
                                    sdc_det =
                                    sdc_use_wp = 0
                                    sdc_wp =
                                    sdc_isio = 0
                                    sdc_2xmode = 1
                                    sdc_ddrmode = 1
                                    [smc_para]
                                    smc_used = 0
                                    [usbc0]
                                    usb_used = 1
                                    usb_port_type = 2
                                    usb_detect_type = 0
                                    usb_restrict_gpio =
                                    usb_not_suspend = 0
                                    [usbc1]
                                    usb_used = 1
                                    usb_drv_vbus_gpio =
                                    usb_restrict_gpio =
                                    usb_not_suspend = 0
                                    [usbc2]
                                    usb_used = 1
                                    usb_drv_vbus_gpio =
                                    usb_restrict_gpio =
                                    usb_not_suspend = 0
                                    [usbc3]
                                    usb_used = 1
                                    usb_drv_vbus_gpio =
                                    usb_restrict_gpio =
                                    usb_not_suspend = 0
                                    [usb_feature]
                                    vendor_id = 6353
                                    mass_storage_id = 1
                                    adb_id = 2
                                    [msc_feature]
                                    release = 100
                                    luns = 3
                                    [serial_feature]
                                    serial_unique = 0
                                    [module_para]
                                    module_num = 7
                                    module_power1 =
                                    module_power1_vol =
                                    module_power2 =
                                    module_power2_vol =
                                    module_power3 =
                                    module_power3_vol =
                                    chip_en =
                                    lpo_use_apclk =
                                    [wifi_para]
                                    wifi_used = 0
                                    wifi_sdc_id = 1
                                    wifi_usbc_id = 5
                                    wifi_usbc_type = 1
                                    [bt_para]
                                    bt_used = 0
                                    bt_uart_id = 1
                                    bt_rst_n =
                                    bt_wake =
                                    bt_host_wake =
                                    [pcm0]
                                    daudio_used = 0
                                    daudio_master = 4
                                    daudio_select = 1
                                    audio_format = 1
                                    mclk_fs = 128
                                    msb_lsb_first = 0
                                    sign_extend = 0
                                    slot_index = 0
                                    slot_width = 32
                                    frame_width = 0
                                    tx_data_mode = 0
                                    rx_data_mode = 0
                                    [pcm1]
                                    daudio_used = 0
                                    daudio_master = 4
                                    daudio_select = 1
                                    audio_format = 1
                                    mclk_fs = 128
                                    msb_lsb_first = 0
                                    sign_extend = 0
                                    slot_index = 0
                                    slot_width = 32
                                    frame_width = 0
                                    tx_data_mode = 0
                                    rx_data_mode = 0
                                    [audio0]
                                    audio_used = 1
                                    lineout_vol = 31
                                    cap_vol = 5
                                    adcagc_used = 0
                                    adcdrc_used = 0
                                    dacdrc_used = 0
                                    adchpf_used = 0
                                    dachpf_used = 0
                                    [spdif0]
                                    spdif_used = 0
                                    [audiohub]
                                    hub_used = 0
                                    codec_used = 1
                                    spdif_used = 1
                                    hdmi_used = 1
                                    [s_cir0]
                                    ir_used = 1
                                    ir_addr_code5 = 239
                                    [cir]
                                    ir_used = 1
                                    [dvfs_table]
                                    pmuic_type = 2
                                    pmu_level0 = 11300
                                    pmu_level1 = 1100
                                    extremity_freq = 1296000000
                                    LV_count = 7
                                    LV1_freq = 1296000000
                                    LV1_volt = 1320
                                    LV2_freq = 1200000000
                                    LV2_volt = 1240
                                    LV3_freq = 1104000000
                                    LV3_volt = 1180
                                    LV4_freq = 1008000000
                                    LV4_volt = 1140
                                    LV5_freq = 960000000
                                    LV5_volt = 1080
                                    LV6_freq = 816000000
                                    LV6_volt = 1020
                                    LV7_freq = 480000000
                                    LV7_volt = 980
                                    [gpu_dvfs_table]
                                    G_LV_count = 3
                                    [Vdevice]
                                    Vdevice_used = 0
                                    [s_uart0]
                                    s_uart_used = 0
                                    [s_rsb0]
                                    s_rsb_used = 1
                                    [s_jtag0]
                                    s_jtag_used = 0
                                    [s_powchk]
                                    s_power_reg = 0
                                    s_system_power = 50
                                    [sim0]
                                    scr_used = 0
                                    [ts0]
                                    tsc_used = 0
                                    [gpio_power_key]
                                    key_used = 1
                                    [key_para]
                                    key_used = 0
                                    key_cnt = 5
                                    key1_vol = 222
                                    key2_vol = 444
                                    key3_vol = 666
                                    key4_vol = 857
                                    key5_vol = 2000
                                    [d7s_para]
                                    d7s_used = 0
                                    [mali_para]
                                    mali_used = 1
                                    mali_clkdiv = 1
                                    [w1_para]
                                    w1_used = 1
                                    gpio = 20
                                    [corekeeper]
                                    Note that I added a line to the gpio section in one of my attempts to make this work, in order to map PA2 to GPIO20 (or at least that was what I was trying to accomplish).
                                    I'm trying to compile an MQTT gateway, so my configure line is:
                                    ./configure --spi-spidev-device=/dev/spidev0.0 --my-rfm69-irq-pin=10 --my-rfm69-cs-pin=20 --my-transport=rfm69 --my-rfm69-frequency=433 --my-gateway=mqtt --my-controller-ip-address=127.0.0.1 --my-mqtt-publish-topic-prefix=mysensors-out --my-mqtt-subscribe-topic-prefix=mysensors-in --my-mqtt-client-id=mygateway1 --extra-cxxflags="-DMY_DEBUG_VERBOSE_RFM69"
                                    And here is the core of my problem - which values to use for IRQ pin and CS pin. If I use 10 for IRQ. I compile with no problems, but when I run
                                    sudo bin/mysgw -d
                                    I get:
                                    fanta@orangepipc:~/MySensors$ sudo bin/mysgw -d
                                    mysgw: TSF:LRT:OK
                                    mysgw: TSM:INIT
                                    mysgw: TSF:WUR:MS=0
                                    mysgw: RFM69:INIT
                                    mysgw: RFM69:INIT:PIN,CS=20,IQP=10,IQN=2
                                    mysgw: RFM69:PTX:LEVEL=5 dBm
                                    mysgw: Could not open /sys/class/gpio/gpio10/direction
                                    I have already tried enabling GPIO10:
                                    fanta@orangepipc:~/MySensors$ echo "10" |sudo tee /sys/class/gpio/export
                                    tee: /sys/class/gpio/export: Device or resource busy
                                    My gpio readall outputs this:
                                    fanta@orangepipc:~/MySensors$ gpio readall
                                     +-----+-----+----------+------+---+-Orange Pi+---+---+------+---------+-----+--+
                                     | BCM | wPi |   Name   | Mode | V | Physical | V | Mode | Name     | wPi | BCM |
                                     |     |     |     3.3v |      |   |  1 || 2  |   |      | 5v       |     |     |
                                     |  12 |   8 |    SDA.0 | ALT5 | 0 |  3 || 4  |   |      | 5V       |     |     |
                                     |  11 |   9 |    SCL.0 | ALT5 | 0 |  5 || 6  |   |      | 0v       |     |     |
                                     |   6 |   7 |   GPIO.7 |  OUT | 0 |  7 || 8  | 0 | OUT  | TxD3     | 15  | 13  |
                                     |     |     |       0v |      |   |  9 || 10 | 0 | OUT  | RxD3     | 16  | 14  |
                                     |   1 |   0 |     RxD2 |  OUT | 0 | 11 || 12 | 0 | OUT  | GPIO.1   | 1   | 110 |
                                     |   0 |   2 |     TxD2 |  OUT | 0 | 13 || 14 |   |      | 0v       |     |     |
                                     |   3 |   3 |     CTS2 |  OUT | 0 | 15 || 16 | 0 | OUT  | GPIO.4   | 4   | 68  |
                                     |     |     |     3.3v |      |   | 17 || 18 | 0 | OUT  | GPIO.5   | 5   | 71  |
                                     |  64 |  12 |     MOSI | ALT4 | 0 | 19 || 20 |   |      | 0v       |     |     |
                                     |  65 |  13 |     MISO | ALT4 | 0 | 21 || 22 | 0 | OUT  | RTS2     | 6   | 2   |
                                     |  66 |  14 |     SCLK | ALT4 | 0 | 23 || 24 | 0 | OUT  | CE0      | 10  | 67  |
                                     |     |     |       0v |      |   | 25 || 26 | 0 | OUT  | GPIO.11  | 11  | 21  |
                                     |  19 |  30 |    SDA.1 | ALT4 | 0 | 27 || 28 | 0 | ALT4 | SCL.1    | 31  | 18  |
                                     |   7 |  21 |  GPIO.21 |  OUT | 0 | 29 || 30 |   |      | 0v       |     |     |
                                     |   8 |  22 |  GPIO.22 |  OUT | 0 | 31 || 32 | 0 | OUT  | RTS1     | 26  | 200 |
                                     |   9 |  23 |  GPIO.23 |  OUT | 0 | 33 || 34 |   |      | 0v       |     |     |
                                     |  10 |  24 |  GPIO.24 |  OUT | 0 | 35 || 36 | 0 | OUT  | CTS1     | 27  | 201 |
                                     |  20 |  25 |  GPIO.25 |  OUT | 1 | 37 || 38 | 0 | OUT  | TxD1     | 28  | 198 |
                                     |     |     |       0v |      |   | 39 || 40 | 0 | OUT  | RxD1     | 29  | 199 |
                                     +-----+-----+----------+------+---+-Orange Pi+---+------+----------+-----+-----+
                                    So I tried --my-rfm69-irq-pin=2 --my-rfm69-cs-pin=67 as well, but I run into the same problem with pin 2.
                                    Can anyone help me find out which pin numbers to use?
                                    Thanks in advance!
                                    • pansenP
                                      pansenP
                                      pansen
                                      @awilner I am in a hurry right now so I cannot go through what you wrote in detail, but maybe my post about pin numbering can help you: https://forum.mysensors.org/post/58309 It is related to an OPi Plus2e using nrf24 but the numbering formulas should still be valid.
                                      Good luck!
                                      awilnerA 1 Reply Last reply
                                      • pansenP pansen
                                        Good luck!
                                        awilnerA
                                        awilnerA
                                        awilner
                                        @pansen , Thank you so much!!! I managed to find two pins that didn't give me this error, PA11 and PA12, and now at least the chip configuration and communication apparently works.
                                          I wanted to build MQTT client gateway with whitelisting and encryption + 3 LEDs with Arduino UNO and Ethernet shield but it does not have enough memory.
                                          Before going to Arduino MEGA I found this and I think this will be a better way to do it. Smaller, cheaper..just not sure if it has all the options. Can someone confirm? Whitelisting will be easier then reflashing Arduino all the time too.
                                          I plan to use Orange Pi Zero H2+ Quad Core 256MB
