  3. Rpi3 GW, Nano, NRF24L01+ not connecting.
8 Posts 2 Posters 1.8k Views 2 Watching
  • leitefrogL
    leitefrogL
    leitefrog
    Hi everyone,
    I am setting up my first sensor network. I have a Raspi 3 running OH2 and MQTT gateway. That part went well. I can subscribe to mqtt messages, and see the gateway come on line and connect. So far so good. I am trying to create a simple relay actuator sensor. I wired some NRF24L01+ radios to a couple of Arduino Nanos. But with each nano I see the following 0_1489768498609_arduinoRelay.JPG
    and the gateway shows
    I measured the power, 3.3v to the radios. I've tried changing power sources, but it's the same. The gateway and the sensors are sitting on the same bench a foot away from each other.
    Can anyone suggest what to try next?
    leitefrogL 1 Reply Last reply
      I think you missed to set up node ID on the 2 Nano, but I don't see the complete log.
      Also check the log in the parser https://www.mysensors.org/build/parser
      • leitefrogL leitefrog
        Hi everyone,
        leitefrogL
        leitefrogL
        leitefrog
        @leitefrog quick addition, if I add two sensors (#13 and #81), they appear to see each other. The serial monitor shows
          Pls add the log as text with the code TAG, don't post screenshot. Also post the log from the beginning and if possible the code you are using
          • leitefrogL
            leitefrogL
            leitefrog
            Thanks for the heads up.
            I rebooted everything to get a clean log. It acted a bit different.
            Here is the sensor log.
            0 MCO:BGN:INIT REPEATER,CP=RNNRA--,VER=2.1.1
            3 MCO:BGN:BFR
             b4 5 TSM:INIT
            6 TSF:WUR:MS=0
            13 TSM:INIT:TSP OK
            14 TSM:INIT:STATID=13
            16 TSF:SID:OK,ID=13
            18 TSM:FPAR
            55 TSF:MSG:SEND,13-13-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            435 TSF:MSG:READ,81-81-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
            440 TSF:MSG:BC
            2062 !TSM:FPAR:NO REPLY
            2064 TSM:FPAR
            2100 TSF:MSG:SEND,13-13-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            2483 TSF:MSG:READ,81-81-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
            2488 TSF:MSG:BC
            4108 !TSM:FPAR:NO REPLY
            4110 TSM:FPAR
            4146 TSF:MSG:SEND,13-13-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            4533 TSF:MSG:READ,81-81-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
            4538 TSF:MSG:BC
            6154 !TSM:FPAR:NO REPLY
            6156 TSM:FPAR
            6192 TSF:MSG:SEND,13-13-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            8200 !TSM:FPAR:FAIL
            8201 TSM:FAIL:CNT=1
            8203 TSM:FAIL:PDT
            18206 TSM:FAIL:RE-INIT
            18208 TSM:INIT
            18215 TSM:INIT:TSP OK
            18217 TSM:INIT:STATID=13
            18220 TSF:SID:OK,ID=13
            18222 TSM:FPAR
            18258 TSF:MSG:SEND,13-13-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            18647 TSF:MSG:READ,81-81-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
            18652 TSF:MSG:BC
            20267 !TSM:FPAR:NO REPLY
            20269 TSM:FPAR
            20305 TSF:MSG:SEND,13-13-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            20694 TSF:MSG:READ,81-81-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
            20699 TSF:MSG:BC
            22313 !TSM:FPAR:NO REPLY
            22316 TSM:FPAR
            22352 TSF:MSG:SEND,13-13-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            22740 TSF:MSG:READ,81-81-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
            22746 TSF:MSG:BC
            24360 !TSM:FPAR:NO REPLY
            24363 TSM:FPAR
            24399 TSF:MSG:SEND,13-13-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            26407 !TSM:FPAR:FAIL
            26408 TSM:FAIL:CNT=2
            26411 TSM:FAIL:PDT
            36414 TSM:FAIL:RE-INIT
            36416 TSM:INIT
            36423 TSM:INIT:TSP OK
            36425 TSM:INIT:STATID=13
            36427 TSF:SID:OK,ID=13
            36429 TSM:FPAR
            36466 TSF:MSG:SEND,13-13-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            36578 TSF:MSG:READ,0-0-13,s=255,c=3,t=8,pt=1,l=1,sg=0:0
            36583 TSF:MSG:FPAR OK,ID=0,D=1
            36854 TSF:MSG:READ,81-81-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
            36859 TSF:MSG:BC
            38473 TSM:FPAR:OK
            38474 TSM:ID
            38476 TSM:ID:OK
            38477 TSM:UPL
            38514 !TSF:MSG:SEND,13-13-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
            38901 TSF:MSG:READ,81-81-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
            38906 TSF:MSG:BC
            40522 TSM:UPL
            40559 !TSF:MSG:SEND,13-13-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
            40948 TSF:MSG:READ,81-81-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
            40953 TSF:MSG:BC
            42566 TSM:UPL
            42603 !TSF:MSG:SEND,13-13-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
            44610 TSM:UPL
            44647 !TSF:MSG:SEND,13-13-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
            46654 !TSM:UPL:FAIL
            46655 TSM:FPAR
            46692 TSF:MSG:SEND,13-13-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=4,st=OK:
            48700 !TSM:FPAR:NO REPLY
            48702 TSM:FPAR
            48739 TSF:MSG:SEND,13-13-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            50746 !TSM:FPAR:NO REPLY
            50748 TSM:FPAR
            50785 TSF:MSG:SEND,13-13-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            52792 !TSM:FPAR:NO REPLY
            52794 TSM:FPAR
            52831 TSF:MSG:SEND,13-13-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            53015 TSF:MSG:READ,81-81-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
            53021 TSF:MSG:BC
            54838 !TSM:FPAR:FAIL
            54839 TSM:FAIL:CNT=3
            54841 TSM:FAIL:PDT
            64844 TSM:FAIL:RE-INIT
            64846 TSM:INIT
            64854 TSM:INIT:TSP OK
            64856 TSM:INIT:STATID=13
            64858 TSF:SID:OK,ID=13
            64860 TSM:FPAR
            64897 TSF:MSG:SEND,13-13-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            66904 !TSM:FPAR:NO REPLY
            66906 TSM:FPAR
            66942 TSF:MSG:SEND,13-13-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            68950 !TSM:FPAR:NO REPLY
            68952 TSM:FPAR
            68988 TSF:MSG:SEND,13-13-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            70996 !TSM:FPAR:NO REPLY
            70999 TSM:FPAR
            71035 TSF:MSG:SEND,13-13-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            73043 !TSM:FPAR:FAIL
            73044 TSM:FAIL:CNT=4
            73047 TSM:FAIL:PDT
            83050 TSM:FAIL:RE-INIT
            83052 TSM:INIT
            83059 TSM:INIT:TSP OK
            83061 TSM:INIT:STATID=13
            83063 TSF:SID:OK,ID=13
            83065 TSM:FPAR
            83102 TSF:MSG:SEND,13-13-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            85109 !TSM:FPAR:NO REPLY
            85111 TSM:FPAR
            85148 TSF:MSG:SEND,13-13-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            85756 TSF:MSG:READ,0-0-13,s=255,c=3,t=8,pt=1,l=1,sg=0:0
            85762 TSF:MSG:FPAR OK,ID=0,D=1
            87155 TSM:FPAR:OK
            87156 TSM:ID
            87158 TSM:ID:OK
            87159 TSM:UPL
            87196 !TSF:MSG:SEND,13-13-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
            87203 TSF:MSG:READ,0-0-13,s=255,c=3,t=25,pt=1,l=1,sg=0:1
            87208 TSF:MSG:PONG RECV,HP=1
            87212 TSM:UPL:OK
            87213 TSM:READY:ID=13,PAR=0,DIS=1
            87252 !TSF:MSG:SEND,13-13-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=NACK:0100
            89296 !TSF:MSG:SEND,13-13-0-0,s=255,c=0,t=18,pt=0,l=5,sg=0,ft=1,st=NACK:2.1.1
            89339 !TSF:MSG:SEND,13-13-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=2,st=NACK:0
            91384 !TSF:MSG:SEND,13-13-0-0,s=255,c=3,t=11,pt=0,l=5,sg=0,ft=3,st=NACK:Relay
            91428 !TSF:MSG:SEND,13-13-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=4,st=NACK:1.0
            91470 !TSF:MSG:SEND,13-13-0-0,s=1,c=0,t=3,pt=0,l=0,sg=0,ft=5,st=NACK:
            91512 !TSF:MSG:SEND,13-13-0-0,s=2,c=0,t=3,pt=0,l=0,sg=0,ft=6,st=NACK:
            91518 MCO:REG:REQ
            91556 !TSF:MSG:SEND,13-13-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=7,st=NACK:2
            93529 TSF:MSG:READ,81-81-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
            93534 TSF:MSG:BC
            93535 TSF:MSG:FPAR REQ,ID=81
            93538 TSF:CKU:OK,FCTRL
            93540 TSF:MSG:GWL OK
            93901 TSF:MSG:SEND,13-13-81-81,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=8,st=OK:1
            93944 !TSF:MSG:SEND,13-13-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=8,st=NACK:2
            95579 TSF:MSG:READ,81-81-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
            95584 TSF:MSG:REL MSG
            95587 TSF:MSG:REL PxNG,HP=1
            95625 !TSF:MSG:SEND,81-13-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=9,st=NACK:2
            95985 !TSF:MSG:SEND,13-13-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=10,st=NACK:2
            95992 !TSM:READY:UPL FAIL,SNP
            95995 TSM:FPAR
            96032 TSF:MSG:SEND,13-13-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=11,st=OK:
            97590 TSF:MSG:READ,81-81-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
            97992 !TSF:SND:TNR
            98039 !TSM:FPAR:NO REPLY
            98041 TSM:FPAR
            98078 TSF:MSG:SEND,13-13-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            99624 TSF:MSG:READ,81-81-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
            101636 TSF:MSG:READ,81-81-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
            101994 !TSM:FPAR:NO REPLY
            101996 TSM:FPAR
            102033 TSF:MSG:SEND,13-13-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            103650 TSF:MSG:READ,81-81-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
            103655 TSF:MSG:BC
            104040 !TSM:FPAR:NO REPLY
            104042 TSM:FPAR
            104079 TSF:MSG:SEND,13-13-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            105694 TSF:MSG:READ,81-81-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
            105699 TSF:MSG:BC
            106086 !TSM:FPAR:FAIL
            106088 TSM:FAIL:CNT=1
            106090 TSM:FAIL:PDT
            116093 TSM:FAIL:RE-INIT
            116096 TSM:INIT
            116103 TSM:INIT:TSP OK
            116105 TSM:INIT:STATID=13
            116107 TSF:SID:OK,ID=13
            116110 TSM:FPAR
            116147 TSF:MSG:SEND,13-13-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            118154 !TSM:FPAR:NO REPLY
            118156 TSM:FPAR
            118193 TSF:MSG:SEND,13-13-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            120200 !TSM:FPAR:NO REPLY
            120202 TSM:FPAR
            120239 TSF:MSG:SEND,13-13-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            121858 TSF:MSG:READ,81-81-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
            121864 TSF:MSG:BC
            122246 !TSM:FPAR:NO REPLY
            122248 TSM:FPAR
            122285 TSF:MSG:SEND,13-13-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            123907 TSF:MSG:READ,81-81-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
            123912 TSF:MSG:BC
            124292 !TSM:FPAR:FAIL
            124294 TSM:FAIL:CNT=2
            124296 TSM:FAIL:PDT
            134299 TSM:FAIL:RE-INIT
            134301 TSM:INIT
            134308 TSM:INIT:TSP OK
            134310 TSM:INIT:STATID=13
            134312 TSF:SID:OK,ID=13
            134316 TSM:FPAR
            134352 TSF:MSG:SEND,13-13-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            136360 !TSM:FPAR:NO REPLY
            136363 TSM:FPAR
            136399 TSF:MSG:SEND,13-13-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            138407 !TSM:FPAR:NO REPLY
            138409 TSM:FPAR
            138446 TSF:MSG:SEND,13-13-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            140453 !TSM:FPAR:NO REPLY
            140455 TSM:FPAR
            140492 TSF:MSG:SEND,13-13-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            142499 !TSM:FPAR:FAIL
            142501 TSM:FAIL:CNT=3
            142503 TSM:FAIL:PDT
            The sketch I took from the examples in the library.
             * Version 1.0 - Henrik Ekblad
             * Example sketch showing how to control physical relays.
             * This example will remember relay state after power failure.
             * http://www.mysensors.org/build/relay
            #define MY_NODE_ID 81
            #define MY_REPEATER_FEATURE
            #define NUMBER_OF_RELAYS 2 // Total number of attached relays
            void before()
            		pinMode(pin, OUTPUT);
            	sendSketchInfo("Relay", "1.0");
            		present(sensor, S_BINARY);
            	if (message.type==V_STATUS) {
            		// Change relay state
            		// Store state in eeprom
              wrote on last edited by gohan
              Did you enable the repeater for a reason? Do you also have a log of the gateway?
              • leitefrogL
                leitefrogL
                leitefrog
                Thanks again for the help. I went to get the gateway log as you questioned, and noticed that the MQTT was dropping and reconnecting pretty regularly, just as I would see messages coming across. I decided to try using the Ethernet Gateway, so I recompiled, and reinstalled. With that I got things to start working. I have a relay turning on and off from the OpenHab UI. Very cool. Now I'm trying to figure out how to use a two channel relay, but I'll start to search for that.
                This is a very helpful forum, and again thanks. I really like the log parser too.
                -George
                  Regarding the mqtt disconnecting, there was already another user with same problem and, if I remember well, the problem was the client id that was conflicting with another device
