  3. Home Assistant
  4. Cannot add node to HA
16 Posts 3 Posters 5.8k Views 4 Watching
  • simonszuS
    simonszuS
    simonszu
    @martinhjelmare Thanks for helping. Unfortunately, i already have added a capacitor between the VCC and GND pin of the arduinos on the gateway and the sensor node. They are ceramic capacitors with 4.7 uF which should be enough in my experience. I also don't think it is a range problem, both devices are lying on my table, they have around 110cm distance between them.
    Since @gohan said that i should post more lines of my logs - yeah, sorry, my fault. This is the serial output of the gateway at the same time the node outputs the log i have pasted above: http://pastebin.com/y916idtc
    You see: After some time, the communication between the node and the gateway succeeds, however, Home Assistant shows nothing. With full respect, but i doubt i have physical issues. The presence of the capacitor and the small range should not be the reason for any errors - and the successful message exchange at the bottom of both log files (for which i didn't change anything from the situation at the top of the file) somehow make me suspicious about any physical issues. Or maybe somehow the laws of physics change magically at my desk, who knows ;)
    Of course i have checked all the wirings and solder points on both devices with my multimeter, they are correct.
    Also, let me say that if i hardcode the node ID into the node, there is a reaction from Home Assistant after 2-3 seconds after i start the sensor node that the node ID is unknown. So the physical radio connection between both devices is capable in working from startup of the sensor node - but somehow the communication between the gateway and home assistant fails?
    So, i ask explicitly: Is the sensor node sketch basically correct, regarding the initial value transmitting and stuff? Is the home assistant component definiton correct? I was unsure regarding the initial value transfer...
      I'd say pls post startup logs of both gateway and node so we can see if they are talking correctly from each other: we need to start excluding possible causes of problems until we find the issue.
      • simonszuS
        simonszuS
        simonszu
        I did ;)
        The complete log from startup to switch to switching off the sensor node after an unsuccessful test is posted as a pastebin link in the initial post from Thursday, and the log from the gateway captured at the same time is added as a pastebin link in my post from a few minutes ago. :)
        • simonszuS simonszu
          I did ;)
          martinhjelmareM
          martinhjelmareM
          martinhjelmare
          @simonszu
          The majority of messages in your logs are find parent requests and responses. If you have more than a pair of those you have communication problems, it's as simple as that.
          You need to get reliable communication going to avoid losing messages and be able to present your node and sensors properly to the controller.
          • simonszuS
            simonszuS
            simonszu
            Okay, this sounds reasonable.
            But... How? The troubleshooting says, reduce range and add a capacitor. I added a capacitor (or should I add one to the vcc and gnd pin of the radio module as well?). I don't want to reduce range, since around 1 meter is quite close, and I don't want to cover my flat with repeater nodes - if I had to, MySensors would be no great use for me.
            • martinhjelmareM
              martinhjelmareM
              martinhjelmare
              The capacitor should be added as close as possible to the vcc and gnd pins of the radio. Where did you put the capacitor? Also, with mysensors 2.x, many are reporting requiring a higher value capacitor. Try with 47 uF.
              You can also try increasing the distance between node and gateway. Sometimes too short distance can generate trouble.
              • simonszuS
                simonszuS
                simonszu
                I'm sorry, it was late last night. I did post wrong facts. I did not solder the capacitor parallel to the VCC and GND pins of the arduino, but parallel to the VCC and GND pins of the radio.
                Here's a photo of the capacitor on the sensor node: https://goo.gl/photos/REYnXMsLvLeKNKpf6
                And here's a photo of the capacitor on the gateway: https://goo.gl/photos/TNVNkJN7ZawcF5qg7
                I am not really sure about the capacity. On the capacitor, there is a 47 printed on it, with a line underneath it. I remember reading an article, explaining this kind of notation, and saying that this means 4.7 uF, but i don't find it any more and am unsure about the line underneath it. Maybe this means 47uF?
                If you say i should clearly try another capacity, i'll try.
                  That looks too little for a ceramic of that capacity. Don't you have some electrolicts to try?
                  • simonszuS
                    simonszuS
                    simonszu
                    I'm afraid, i don't. But i won't hesitate ordering some from ebay. Any recommendation which capacity i should choose? Is 47 uF okay?
                      Don't you have a multimeter to check capacity of that ceramic cap you have?
                      As for the others, usually 4.7uF is enough, but 10 or 47 could also help in some situations; if you find a bag of assorted caps I'd go for that one so you can have some spares around when you need them.
                      • simonszuS
                        simonszuS
                        simonszu
                        I checked with a multimeter. Turns out, the ceramic capacitors had 47pF :D
                        I ordered a set of assorted electrolytic capacitors. Should take some time, they're dispatched directly from China.
                        However, i am unsure about the polarity of the capacitors. Should Cap+ go to VCC or GND of the radio?
                          Usually electrolitic caps have a "-" sign on the negative and goes to gnd. If you reverse polarity they explode 😁😅
                          • simonszuS
                            simonszuS
                            simonszu
                            I knew that they are marked. But I didn't know the polarity. It could have been possible that Cap- goes to VCC on the radio, since in a full capacitor, there is a lack of electrons on Cap+, and very much electrons on Cap-, and also a lack of electrons on VCC, and very much electrons on GND, and the many electrons on the negative side should match the lack of electrons on the matching side of the other device - you see my point? So I was unsure.
                            But Cap- to GND is clear and explicit, yeah.
                            12.5k
