  3. Any RFM95 user reports?
56 Posts 8 Posters 20.4k Views 8 Watching
    mihai.aldea
    Yes, I am very much aware of that, it's just that I wasn't expecting such a long TX time. And my conclusion is that they have no use with battery powered sensors, unless maybe BW500CR45SF128 is used, but then it will defeat the "LoRa" purpose.
      mihai.aldea
      It would though be very nice to have RFM9x <-> RFM69 or RFM9x <-> RF24 home gateway. The end nodes would use an appropriate protocol for the required range and cost (RFM69 or RF24) to send data to the gateway, and then the gateway would forward the packets over the LoRaWAN network to "the cloud".
      alexsh1A 1 Reply Last reply
      • M mihai.aldea
        alexsh1A
        alexsh1A
        alexsh1
        @mihai.aldea I'm waiting for the delivery of loraWAN GW. So far I have an ESP Single Channel GW, but it has got limitations. I will try to measure time / consumption a node is transferring packets.
        There is a battery application for it. Like a remote flood warning device. Or gas sampling
          mihai.aldea
          I'm planning to get myself one of those and set it up in my neighborhood, however at least for the time being I find it a bit useless since I don't know of any Home <-> LoRaWAN gateway that would effectively push the end nodes data over the LoRa network and up to a hub. Moreover, if that gateway would exist, then there should be some considerations regarding the way the LoRaWAN gateway handles packets, eg. authentication, message signing, encryption, ACL or rate limiting. This would enforce a private communication channel, free of any abuser that would hammer down the gateway by sending readings every 5 sec. from a set of couple of dozen sensors, congesting the gateway.
          It may be that some manufactures such as Cisco have already considered these but I'm not aware of that, and testing their solutions is rather cost prohibitive.
          • mfalkviddM
            The duty cycle limits combined with long send times makes it very hard to use LoRa for home automation. Having to wait 20-200 seconds (depending on frequency band) between messages is a severe limitation.
            There are definitely some use cases where LoRa is still applicable, but I think the duty cycle is a big reason to why there are no gateways between LoRa and home automation systems.
            A good thread on the limitations https://www.thethingsnetwork.org/forum/t/limitations-data-rate-packet-size-30-seconds-uplink-and-10-messages-downlink-per-day-fair-access-policy/1300
            An airtime calculator is available at https://docs.google.com/spreadsheets/d/1voGAtQAjC1qBmaVuP1ApNKs1ekgUjavHuVQIXyYSvNc/edit?usp=sharing
              mihai.aldea
              I see, but the end nodes shouldn't necessary route their data in an a synchronous manner. The gateway can buffer the data and commit the reading asynchronously over to the LoRaWAN network once every 5 minutes. Sensor data downsampling could be performed by the gateway in order to shorten the TX window to the utmost minimum. Downsampling and/or a heavy compression algorithm could help.
              On the other hand, I do realize that all these feature could lead to a fairly complex solution that's going to be so complicated to use that's never gonna get any traction.
                I don't see any good point is directly interfacing a home automation system with a LoRaWAN device: if you need to perform data collection or some remote control, the controller could take care of that without having bridges rfm69<->nrf24. As mentioned before, there is a community for Lora public GW https://www.thethingsnetwork.org/community that people could use maybe together with mqtt.
                • alexsh1A
                  alexsh1A
                  alexsh1
                  Anything concerning loraWAN is expensive and one has to develop it. This is probably good for developers aiming for a final product, for example, air sampling at the remote site without any internet access. However, even in this case 4G network can be used. If such site does not have internet / electricity, this is where loraWAN comes very handy
                    For data sampling you could even use 2G gprs that is pretty much covered everywhere
                      mihai.aldea
                      Indeed, I see LoRa as an option for either experimenting, or as a solid alternative where there's no other option. Because at the end of the day, those who'll require a reliable transport layer will not resort to the open bands but use 2G/3G modems or even radio modems or satellite uplinks. While the LoRaWAN users will have to cope with the drastic FAP limitations, or use point-to-point systems for setups that allows no alternative, like I do.
                        alexsh1A
                        alexsh1A
                        alexsh1
                        @gohan true, but there are applications where Lora is more appropriate. High Altitude Ballooning is one of them
                          I am talking for more ground level needs :D
                            alexsh1A
                            alexsh1A
                            alexsh1
                            @gohan in a highly populated area Lora is better from my perspective. However, as already mentioned the cost is high (GW - €300, node - €55+ etc). Plus one is expected to develop
                            M mfalkviddM 2 Replies Last reply
                            • alexsh1A
                              alexsh1A
                              alexsh1
                              This is a moteino Lora node.
                              I understand the battery consumption is not an issue, but again I have not measured the current.
                              • alexsh1A alexsh1
                                mihai.aldea
                                @alexsh1 said in Any RFM95 user reports?:
                                And why is that? Dense population = likely more users = frequent gw congestions.
                                • M mihai.aldea
                                  alexsh1A
                                  alexsh1A
                                  alexsh1
                                  @mihai.aldea
                                  When I said Lora I'm referring to LoraWAN, which is not the same thing.
                                  • 2G requires more power to transmit than LoraWAN
                                  • LoRaWAN is optimized for uplink (from the node to a server). For downlink there is 8 times less bandwidth available. This means it is designed to received info from sensors
                                  • A gateway can receive on 8 channels at the same time
                                  All that said, the ideal use case for LoRaWAN is:
                                  • Simple sensors that need to transmit infrequently
                                  • Missing 5-85% of data at times is okay
                                  • Little ability to control this device
                                  • No ability to update device firmware over-the-air
                                  • Deployed in the dozens to hundreds
                                  Some Automatic Meter Reading is a great example of a good use case for LoRaWAN. For meters that update the reading, say once per hour, it does not matter if some readings are missed, as long as some make it through.
                                  Finally, places like Amsterdam were completely covered by LoraWAN in just two weeks. There is no chance for the city of this size to be covered by 2G in such a short time.
                                  • alexsh1A
                                    alexsh1A
                                    alexsh1
                                    Couple of graphs:
                                    • alexsh1A
                                      alexsh1A
                                      alexsh1
                                      And this has truely shocked me:
                                      The ballon covered the distance 325km and was still some budget left in the receiver.
                                      • alexsh1A alexsh1
                                        Regarding the cost, I have built prototype nodes on Wemos D1 Mini + RFM96 using these clones and wire antennas:
                                        http://www.ebay.com/itm/231784606792
                                        https://www.aliexpress.com/item/D1-mini-Mini-NodeMcu-4M-bytes-Lua-WIFI-Internet-of-Things-development-board-based-ESP8266-by/32662942091.html
                                          alexsh1A
                                          alexsh1A
                                          alexsh1
                                          @mfalkvidd when it comes to a loraWAN GW the cost is different - the DIY GW is going to set you off by €200+.
                                          Rfm95/96 are cheap, but there are cheap for a reason. RN2483 is more expensive but it is loraWAN compliant.
