  3. wireless door / window sensor
12 Posts 6 Posters 8.9k Views 7 Watching
    mortommy
    I built a window and a door sensor, just using a normal magnetic switch as proposed in this example. They are working quite well and are powered by a coin cell battery.
    parachutesjP 1 Reply Last reply
    • M mortommy
      parachutesjP
      parachutesjP
      parachutesj
      @mortommy thank you. So you have the whole thing incl. the Arduino powered by a battery?
      That would work most probably but is too bulky for me. Don't like to have a too big case dangling around on my windows. Also using a wireless could save a few arduinos. I give it a shot and order a few and let you know the outcome.
      SJ
      • mikeeM
        mikeeM
        mikee
        Most of these cheap sensors are based on PT2622 chip or similar. RF link works fine with them.
        • mikeeM mikee
          parachutesjP
          parachutesjP
          parachutesj
          @mikee thank you, that ensures my thoughts. There will be SALE on Aliexpress tomorrow...
          • A
            Andrea1
            wrote on last edited by Andrea1
            I heard about a new radio chip monitoring window sensor? Have anyone heard about this? It warns when the windows are left open. It powers up with energy provided by solar power and the maintenance is also easy. Is it good for preventing the break-ins?
            • A Andrea1
              parachutesjP
              parachutesjP
              parachutesj
              @all
              When the window sensors from above arrived, receiving the wireless signal was easy. I noted that they only report open and not change when closed, so I tried to "fix" it but failed after a few hours of improving the original hardware. I took all electronics out and fittet an Arduino pro mini, radio and a reed switch into the case easily.
              Quite expensive after all but exactly what I wanted. I still do have two laying here and not sure if I shall remodel them or go with an out of the box sensor from Homematic here...
              • U
                U
                user2684
                Kind of off topic but personally when I struggle too much in repurposing an existing radio sensor I go with this https://github.com/merbanan/rtl_433, attach a 7$ DVB dongle to a raspberry or equivalent, connect a proper antenna and decode the signal (which is usually pretty easy when it comes to cheap sensors). Of course the learning curve can be quite steep at the beginning so it is not convenient in every situation.
                A bit more on topic, if I have understood correctly, the example at https://www.mysensors.org/build/binary is not suitable for a sleeping sensor cause debouncing and sleeping do not play well together. For a sleeping sensor what I did was attaching to an interrupt and if waking up on CHANGE you get a message when the door/window opens as well as closes. If anybody is interest can copy the relevant code from the SensorDoor of https://sourceforge.net/projects/mynodemanager/
                parachutesjP 2 Replies Last reply
                • U user2684
                  parachutesjP
                  parachutesjP
                  parachutesj
                  @user2684
                  correct, debouncing does not work. below is my code which works pretty well.
                  I forgot the power drain but it was very minimal. The major "problem" are the standard reed switches which are <normally open>
                  that means in most cases when the door is closed, the switch is closed as well and this means the circuit is also closed and power flows which results in a factor 10 higher power consumption. The solution is to use a <normally closed> reed switch which will turn it around (circuit closed when door is open).
                  At least in my case, the door is 98% of the time closed and therefore power consumption is less during close phase.
                  //#include <Bounce2.h>
                  #include <Vcc.h>
                  #define CHILD_ID 3
                  #define BUTTON_PIN  3  // Arduino Digital I/O pin for button/reed switch
                  //Bounce debouncer = Bounce();
                  int oldValue = -1;
                  float oldVolts = 0;
                  const float VccExpected   = 3.00;
                  const float VccCorrection = 3.0 / 3.0; // Measured Vcc by multimeter divided by reported Vcc
                  Vcc vcc(VccCorrection);
                  static int oldBatteryPcnt = 0;
                    // Setup the button
                    pinMode(BUTTON_PIN, INPUT);
                    // Activate internal pull-up
                  //  debouncer.attach(BUTTON_PIN);
                  //  debouncer.interval(5);
                    present(CHILD_ID, S_DOOR);
                  //  debouncer.update();
                    // Get the update value
                    // int value = debouncer.read();
                    int value = digitalRead(BUTTON_PIN);
                    wait(100);
                    if (value != oldValue) {
                      // Send in the new value
                      send(msg.set(value == HIGH ? 1 : 0));
                      oldValue = value;
                    //BAtterie
                    int batteryPcnt = (int)vcc.Read_Perc(VccExpected);
                    float volts = (float)vcc.Read_Volts();
                    int myPerc = volts * 100 / VccExpected;
                    Serial.print(myPerc);
                    Serial.println(" %");
                    Serial.print("Volts: ");
                    Serial.print(volts);
                    Serial.println(" V");
                    if (oldBatteryPcnt != myPerc)
                      sendBatteryLevel(myPerc);
                      oldBatteryPcnt = myPerc;
                    sleep(1, CHANGE, 0);
                  U 1 Reply Last reply
                  • U user2684
                    parachutesjP
                    parachutesjP
                    parachutesj
                    @user2684
                    it was not so much figuring out the 433 signal/transport, the hardware just did not capture the close phase of the switch. I guess this is due to the issue I explained in the other reply regarding power consumption and they just cut that off somehow in order to make the batteries last longer. But thanks a lot for the link, will check this out
                    • parachutesjP parachutesj
                      @user2684
                      #include <Vcc.h>
                      #define CHILD_ID 3
                      int oldValue = -1;
                      float oldVolts = 0;
                        // Setup the button
                        wait(100);
                          oldValue = value;
                        //BAtterie
                      U
                      U
                      user2684
                      Oh you're right, also the "Magnetic Door Switch Sensor" from the example https://www.mysensors.org/build/binary is normally closed. I read somewhere a high value resistor can help in limiting the current flow in these situations but never tried myself
                      • XanderX
                        XanderX
                        Xander
                        If you need a signal both if the window was closed and opened you can buy this sensor:
                        https://www.aliexpress.com/item/Free-shipping-Wireless-window-and-door-magnetic-sensor-open-detector-1527-chips/32334214010.html
                        It is based on a 1527 Chip.
                        Open the rear cover and connect these pins with a solder point:
                        12.5k
