  2. Feature Requests
  3. One-time init only
One-time init only
Scheduled Pinned Locked Moved Feature Requests
9 Posts 4 Posters 3.2k Views 4 Watching
  • ChristWC
    ChristWC
    ChristW
    I've hooked up a DCF77 receiver to an Arduino Nano that I would like to use as a 'time master' in my house.
    I've looked into various ways of getting the time from this node to other nodes. Problem is that once a message fails (because of radio NACK), the whole sketch is re-run, including the startup of the DCF receiver.
    I've put initialising and starting the DCF reception in preHwInit(), but it seems this one is called before every radio init.
    Is there a function that is called only once? Is there a place I can patch the -master branch to get a function that is called only once? I would contribute back to -master, of course!
    Christ van Willegen
    Boots33B YveauxY 2 Replies Last reply
      There is function that can be called to get time from controller if you have one, if that's a possible solution
      • ChristWC ChristW
        Christ van Willegen
        Boots33B
        Boots33B
        Boots33
        @ChristW What about using saveState and loadState
        That would allow you to store a value in eeprom and you could check that to see if it is the first time run.
        As @gohan has said it is very easy for nodes to retrieve the time from a controller as well
        • ChristWC ChristW
          Christ van Willegen
          @ChristW setup() is only called once, or you could use a boolean to check if a function has run before.
          • ChristWC
            ChristWC
            ChristW
            thanks for the replies!
            I have no controller, just nodes and a gateway. I wanted to make the gateway respond to getTime() messages, but could not find if this was possible or not.
            In my logs, I see this:
            Waiting for DCF77 time ...
            It will take at least 2 minutes until a first update can be processed.
            r;255;3;0;9;MCO:BGN:INIT GW,CP=RNNGA--,VER=2.1.1
            0;255;3;0;9;TSM:INIT
            0;255;3;0;9;TSF:WUR:MS=0
            0;255;3;0;9;TSM:INIT:TSP OK
            0;255;3;0;9;TSM:INIT:GW MODE
            0;255;0;0;18;2.1.1
            0;1;0;0;23;
            0;2;0;0;3;
            0;255;3;0;9;MCO:BGN:STP
            EoM
            00111010000EoM
            00110010000110000010110101010110010100100110111000111010000BF
            0time lag inconsistent
            0100101000110000010101101010110010100100110111000111010000BF
            0time lag consistent
            Time is updated
            Just obtained time. Send a message!
            0;255;3;0;9;!TSF:MSG:SEND,0-0-27-27,s=1,c=1,t=48,pt=5,l=4,sg=0,ft=0,st=NACK:1490363760
            0;255;0;0;18;2.1.1
            0;1;0;0;23;
            0;2;0;0;3;
            001110111001100010111101011110010100100110111000111010000EoM
            00101011000000100010100011011110010100100110111000111010000BF
            0011110111010100010110011010110010100100110111000111010000BF
            Time is updated
            0;255;3;0;9;!TSF:MSG:SEND,0-0-27-27,s=1,c=1,t=48,pt=5,l=4,sg=0,ft=0,st=NACK:1490363940
            1;255;3;0;9;MCO:BGN:INIT GW,CP=RNNGA--,VER=2.1.1
            0;255;0;0;18;2.1.1
            0;1;0;0;23;
            0;2;0;0;3;
            001111101011000010100000000001010000100110111000111010000EoM
            00010100000001100010110000001001010000100110111000111010000BF
            1100010101111100010101000001001010000100110111000111010000BF
            Time is updated
            0;255;3;0;9;!TSF:MSG:SEND,0-0-27-27,s=1,c=1,t=48,pt=5,l=4,sg=0,ft=0,st=NACK:1490364120
            0;255;0;0;18;2.1.1
            0;1;0;0;23;
            0;2;0;0;3;
            100010110011000010111000000001010000100110111000111010000EoM
            00010110001110000010100100001001010000100110111000111010000BF
            0011000111100000010110100000001010000100110111000111010000BF
            Time is updated
            0;255;3;0;9;!TSF:MSG:SEND,0-0-27-27,s=1,c=1,t=48,pt=5,l=4,sg=0,ft=0,st=NACK:1490364300
            You can see that each time a !TSF:....st=NACK is logged, you will also see MCO:BGN:STP in the log. This is the setup() callback, which is called every time that radio is initted.
            I put a static boolean into my startDCF() function, but it still starts every time. It seems static variables are initialized every time.
            loadState() and saveState() would be possible, but that would look something like this in pseudocode:
            if (loadState(xxx) == 0) {
              startDCF()
              saveState(xxx, 1);
            ...but where do I call saveState(xxx, 0) to indicate that my time master needs to start the DCF again? Ideally I would need to do this at startup, but then I can call startDCF() instead of that...
            Christ van Willegen
            Boots33B 1 Reply Last reply
              Do you mind if I ask what's the point of not having a controller?
              ChristWC 1 Reply Last reply
                ChristWC
                ChristWC
                ChristW
                @gohan At the moment, I have a few 'weird' nodes that would like to talk to each other. I was pointed to this site because I wanted nodes that talked to each other 'over a certain distance', and MySensors seemed like the best fit, even without being attached to a controller...
                One of the nodes is attached to my washing machine (to indicate if it's ready or not) and dryer (same reason). One node is in our daughter's bedside lamp, that turns purple at night and green at 0700 (so that she knows she can get out of bed), and I have a node attached to an LED screen with 4x 4"-high 7-segments leds. This last node can either run a specific 'show' for my choir (we needed a time machine...) or show data that sensors bring in.
                Most of my nodes don't fit into a standard model really well, and I figured I didn't need to spend EUR100+ on a controller that I wasn't going to use...
                • ChristWC ChristW
                  0;255;0;0;18;2.1.1
                  0;1;0;0;23;
                  0;2;0;0;3;
                  EoM
                  00111010000EoM
                  Time is updated
                  0;255;0;0;18;2.1.1
                  0;1;0;0;23;
                  0;2;0;0;3;
                  Time is updated
                  0;255;0;0;18;2.1.1
                  0;1;0;0;23;
                  0;2;0;0;3;
                  Time is updated
                  0;255;0;0;18;2.1.1
                  0;1;0;0;23;
                  0;2;0;0;3;
                  Time is updated
                    startDCF()
                    saveState(xxx, 1);
                  Christ van Willegen
                  Boots33B
                  Boots33B
                  Boots33
                  wrote on last edited by Boots33
                  @ChristW I am not clear on exactly where you are having trouble, perhaps posting your sketch will help.
                  to just run some code once at startup you can do as @Yveaux has said and place it in setup()
                  If it needs to be run once from the loop() then you could try
                  bool executeOnce = 1;
                    if (executeOnce) {
                      // put code here to execute once at startup
                      executeOnce = 0;
                  As to distributing the time to the nodes you could push the time using node to node messaging if they are on all the time. See here for the basic message format
                  Or you can have the nodes pull the time from your Time node using request()
                  See here for a bit more info
                  • ChristWC
                    ChristWC
                    ChristW
                    Here are my sketches:
                    The TimeMaster:
                    #define CHILD_ID_TIME 1
                    #define CHILD_ID_SIGNAL 2
                    #define TARGET 27
                    // #define TARGET 26
                    MyMessage msgTime(CHILD_ID_TIME, V_CUSTOM);
                    MyMessage msgSignal(CHILD_ID_SIGNAL, V_STATUS);
                    #include "DCF77.h"
                    #include "Time.h"
                    #define DCF_PIN 2	         // Connection pin to DCF 77 device
                    #define DCF_INTERRUPT digitalPinToInterrupt(DCF_PIN)		 // Interrupt number associated with pin
                    time_t time;
                    bool bPresented = false;
                    DCF77 DCF = DCF77(DCF_PIN, DCF_INTERRUPT);
                    void startDCF()
                      static bool bDCFStarted = false;
                      if (!bDCFStarted) {
                        DCF.Start();
                        pinMode(DCF_PIN, INPUT_PULLUP);
                        Serial.println("Waiting for DCF77 time ... ");
                        Serial.println("It will take at least 2 minutes until a first update can be processed.");
                        bDCFStarted = true;
                    void preHwInit()
                      Serial.begin(MY_BAUD_RATE);
                      Serial.println();
                      startDCF();
                      msgSignal.setDestination(TARGET);
                      msgTime.setDestination(TARGET);
                      present(CHILD_ID_TIME, S_CUSTOM);
                      present(CHILD_ID_SIGNAL, S_BINARY);
                    bool bHaveTime = false;
                    unsigned long lastSentTime = 0;
                      time_t DCFtime = DCF.getTime(); // Check if new DCF77 time is available
                      if (DCFtime != 0)
                        Serial.println("Time is updated");
                        setTime(DCFtime);
                        bHaveTime = true;
                        lastSentTime = minute();
                      if (bHaveTime) {
                        if (DCFtime != 0) {
                          Serial.println("Just obtained time. Send a message!");
                          msgTime.set(DCFtime);
                          send(msgTime);
                        if (minute() != lastSentTime) {
                          Serial.println("A minute has passed. Send a message!");
                          msgTime.set(now());
                          send(msgTime);
                    The night light:
                    // #define MY_NODE_ID 27
                    // #define MY_GATEWAY_SERIAL
                    #include <Adafruit_NeoPixel.h>
                    #include <avr/power.h>
                    #include <EEPROM.h>
                    #include <Time.h>
                    #define colorNight(s) (s.Color(255,  20, 147))    // Purple
                    #define colorDay(s)   (s.Color(  0,   0,   0))    // Black
                    #define colorMorn(s)  (s.Color( 44, 201,  13))    // Green
                    #define colorError(s) (s.Color(255,   0,   0))
                    #define colorUp(s)    (s.Color(  0, 255,   0))
                    #define colorDown(s)  (s.Color(  0,   0, 255))
                    #define PIN 6
                    Adafruit_NeoPixel strip = Adafruit_NeoPixel(1, PIN, NEO_GRB + NEO_KHZ800);
                    unsigned long colorPixel = 0;
                    unsigned long colorOld = 0xffff;
                    bool bEmergencyMode = false;
                    bool bEmergencyModeChecked = false;
                    void setPixelColor(unsigned long color)
                      colorPixel = color;
                    void doSetPixelColor(long color)
                      if (!bEmergencyMode || color == colorMorn(strip) || color == colorNight(strip)) {
                        strip.setPixelColor(0, color);
                        strip.show();
                    void doSetPixelColor()
                      if (colorOld != colorPixel) {
                        doSetPixelColor(colorPixel);
                        colorOld = colorPixel;
                      if (!bHaveTime && message.type == V_STATUS) {
                        setPixelColor(message.getBool() ? colorUp(strip) : colorDown(strip));
                      } else if (message.type == V_CUSTOM) {
                        time_t timeNow = message.getULong();
                        setTime(timeNow);
                        bHaveTime = true;
                      setPixelColor(colorUp(strip));
                      present(0, S_LIGHT);
                    void before()
                      strip.begin();
                      doSetPixelColor(colorDown(strip));
                      strip.show(); // Initialize all pixels to 'off'
                      // This is for Trinket 5V 16MHz, you can remove these three lines if you are not using a Trinket
                    #if defined (__AVR_ATtiny85__)
                      if (F_CPU == 16000000) clock_prescale_set(clock_div_1);
                      // End of trinket special code
                      EEPROM.write(300 + 2, EEPROM.read(300 + 1));
                      EEPROM.write(300 + 1, EEPROM.read(300 + 0));
                      EEPROM.write(300 + 0, 0xff);
                      static unsigned long int lastLoop = -1;
                      if (lastLoop == -1 || millis() < lastLoop || millis() - lastLoop > 60000) {
                    //    request(0, V_CUSTOM, 42);
                        lastLoop = millis();
                      if (!bEmergencyModeChecked && millis() < 5000) {
                        bEmergencyModeChecked = true;
                        bool bNeedEmergencyMode = true;
                        for (int t = 0; t <= 2; ++t) {
                          if (EEPROM.read(300 + t) != 0xff) {
                            bNeedEmergencyMode = false;
                        bEmergencyMode = bNeedEmergencyMode;
                        if (bEmergencyMode) {
                          setPixelColor(colorNight(strip));
                      if (bEmergencyModeChecked && millis() >= 10000) {
                        EEPROM.write(300 + 0, 0);
                      if (bEmergencyMode && millis() > 12L * 60 * 60 * 1000) {
                        setPixelColor(colorMorn(strip));
                      if (bHaveTime) {
                        if (hour() >= 19 || hour() < 7) {
                        } else if (hour() >= 8) {
                          setPixelColor(colorDay(strip));
                        } else if (hour() >= 7) {
                      doSetPixelColor();
                    Emergency mode on the night light is triggered by starting and stopping it three times within 10 seconds each time, so that if it can't find a time source, you can still get 12 hours of 'night light' followed by 'day light'.
                    In the night light, I commented out the request() call (and I took out the receive() implementation in the TimeMaster) because I ran into the DCF time receiver starting again every time.
                    Any more info you need right now? Just shout!
