  3. wish to have a non-Repeating node in a sketch based on RELAY example
3 Posts 2 Posters 1.5k Views 1 Watching
  • BulldogLowellB
    BulldogLowellB
    BulldogLowell
    Do not want a RELAY node
    Can anyone help me modify this so that the node will not become a relaying node?
    Forcing it to be a regular non-repeating node will eliminate that as a suspect to other problems.
    I am using:
    S_LIGHT
    not
    S_ARDUINO_RELAY
    but still get a relay node when I add it to the network.
    my code here:
    #define RELAY_PIN  13  // Arduino Digital I/O pin number for relay
    #define BUTTON_PIN  2  // Arduino Digital I/O pin number for button
    #define RELAY_ON 1
    #define RELAY_OFF 0
    #define RADIO_ID 12
    int ledPin3 =  3;      // White using PWM
    int ledPin4 =  4;      // Red
    int ledPin5 =  5;      // Blue using PWM
    int ledPin6 =  6;      // Blue using PWM
    int ledPin7 =  7;      // Green
    int ledPin8 =  8;      // White (No PWM)
    Bounce debouncer = Bounce();
    int oldValue=0;
    bool state;
    int dipInterval = 10;
    int darkTime = 250;
    unsigned long currentDipTime;
    unsigned long dipStartTime;
    unsigned long currentMillis;
    int ledState = LOW;
    long previousMillis = 0;
    int led = 5;
    int interval = 2000;
    int twitch = 50;
    int dipCount = 0;
    int analogLevel = 100;
    boolean timeToDip = false;
      pinMode(ledPin3, OUTPUT);
      pinMode(ledPin4, OUTPUT);
      pinMode(ledPin5, OUTPUT);
      pinMode(ledPin6, OUTPUT);
      pinMode(ledPin7, OUTPUT);
      pinMode(ledPin8, OUTPUT);
      pinMode(BUTTON_PIN,INPUT_PULLUP);
      //digitalWrite(BUTTON_PIN,HIGH);
      debouncer.attach(BUTTON_PIN);
      debouncer.interval(5);
      gw.begin(incomingMessage, RADIO_ID, true);
      dely(3000);
      gw.sendSketchInfo("PhoneyTV", "3.0");
      delay(3000);
      gw.present(CHILD_ID, S_LIGHT);
      pinMode(RELAY_PIN, OUTPUT);
      state = gw.loadState(CHILD_ID);
      debouncer.update();
      int value = debouncer.read();
      if (value != oldValue && value==0)
        gw.send(msg.set(state?false:true), true);
      oldValue = value;
      if (state == true)
        if (timeToDip == false)
          currentMillis = millis();
          if(currentMillis-previousMillis > interval)
            interval = random(750,4001);//Adjusts the interval for more/less frequent random light changes
            twitch = random(40,100);// Twitch provides motion effect but can be a bit much if too high
            dipCount = dipCount++;
          if(currentMillis-previousMillis<twitch)
            led=random(3,9);
            analogLevel=random(50,255);// set the range of the 3 pwm leds
            ledState = ledState == LOW ? HIGH: LOW; // if the LED is off turn it on and vice-versa:
            switch (led) //for the three PWM pins
            case 3:
              pwmWrite();
            case 5:
              pwmWrite();
            case 6:
              pwmWrite();
            default:
              digitalWrite(led, ledState);
            if (dipCount > dipInterval)
              timeToDip = true;
              dipCount = 0;
              dipStartTime = millis();
              darkTime = random(50,150);
              dipInterval = random(5,250);// cycles of flicker
          Serial.println("Dip Time");
          currentDipTime = millis();
          if (currentDipTime - dipStartTime < darkTime)
            for (int i=3;i<9;i++)
              digitalWrite(i,LOW);
            timeToDip = false;
      if (message.isAck()) {
      if (message.type == V_LIGHT && strlen(msg.getString()) != 0) {
        // Change relay state
        state = message.getBool();
        // Store state in eeprom
        gw.saveState(CHILD_ID, state);
    void pwmWrite() {
      if (ledState==HIGH){
        analogWrite(led,analogLevel);
      else{
        digitalWrite(led,LOW);
    hekH 1 Reply Last reply
      I am using:
      S_LIGHT
      not
      S_ARDUINO_RELAY
      my code here:
      #define RELAY_ON 1
      #define RELAY_OFF 0
      #define RADIO_ID 12
      int oldValue=0;
      bool state;
      int darkTime = 250;
      int ledState = LOW;
      int led = 5;
      int twitch = 50;
      int dipCount = 0;
        dely(3000);
        delay(3000);
        debouncer.update();
        oldValue = value;
        if (state == true)
              led=random(3,9);
              case 3:
                pwmWrite();
              case 5:
                pwmWrite();
              case 6:
                pwmWrite();
              default:
                timeToDip = true;
                dipCount = 0;
              timeToDip = false;
      void pwmWrite() {
        else{
      @BulldogLowell
      gw.begin(incomingMessage, RADIO_ID, false);
      • BulldogLowellB
        BulldogLowellB
        BulldogLowell
        so... how could have I missed that HIGHLIGHTED AND BOLDFACED in the MySensors API?
        thanks Henrik!
