  3. Garage door contraption (yet another)
12 Posts 4 Posters 5.4k Views 6 Watching
  • barduinoB
    barduinoB
    barduino
    wrote on last edited by barduino
    Hi Folks
    After leaving my garage door open all night for several times, I had to go ahead and make a MySensors contraptions for it.
    The garage door system I have has 1 single button it will either open or close the door depending on position, the safety beams and the last operations.
    Since I know nothing about electronics, hacking the motor electronics was beyond my skill set, so I decide to sensorize the button operations. In order to figure out if the door was opening or closing I used a sonic distance relative to de door rail. I was expecting to have issues with precision but I was rather surprised it worked so well.
    The base is the fantastic Easy/Newbie PCB for MySensors by @sundberg84 with a bumper/box of my own creation.
    Coupled with some extra pieces as the rail support, the insert for the sonic sensor and the box lid it self.
    On the controller it looks like this
    With door Open
    With door Closed
    On the other side, I've created a simple led sensor which receives a door open/closed signal directly from the garage sensor to turn on or off a led.
    As always feedback is appreciated
    dbemowskD gohanG 2 Replies Last reply
    • barduinoB barduino
      Hi Folks
      With door Open
      With door Closed
      dbemowskD
      dbemowskD
      @barduino Love the enclosure design. I like the way you printed it so that the PCBs slide into the slots. No screws needed. Interesting use of an ultrasonic sensor too. Good job.
      I just recently got my 3D printer and I am loving it for my MySensors projects. It's primarily why I bought it though.
      barduinoB 1 Reply Last reply
        Hi Folks
        With door Open
        With door Closed
        @barduino nice project, but may I ask you why you choose the distance sensor instead of a reed switch or micro switch?
        • dbemowskD
          dbemowskD
          Though I do think it is an interesting concept, but I would pose the same question as @gohan. Why not a reed or micro switch. Those seem like much cheaper options.
          • K
            K
            koen01
            wrote on last edited by koen01
            Maybe bescause he had the parts around?
            Or this way you can check if it's moving up or down as it's fixed on the rail and senses the door moving to or fro ?
            Edit: he explains in the text itself.
            • barduinoB
              barduinoB
              barduino
              Yeah, I wanted to know the exact position of the door, if it was opening or closing etc.
              Anyway I'll gladly share the 3D files for the Easy board
              0_1490732701131_Base.zip
              This is the SketchUp file with the base, rail, lid and enclosure for the sonic.
              0_1490732828480_GarageDoorMonitor.zip
              And this one the base and lid for the monitor.
              The Easy boards I have are v8 and the mounting holes are so small that I couldn't create a support that wouldn't break, so I decided to make some rail/slide system.
              Also because I don't solder the Arduino or radio directly to the board, the lid becomes very tall. But its easy to adjust in the 3D files.
              0_1490733122009_upload-44b48d4c-7fdc-4241-81e7-2c49e1dc5ae9
              0_1490734763849_upload-39cb18fb-7f9c-4adf-9d1d-f64a29b014b8
              If you prefer STL files, I'll upload them
              K 1 Reply Last reply
              • dbemowskD dbemowsk
                barduinoB
                barduinoB
                barduino
                @dbemowsk, I'm very interested in your decora style wall plate, maybe we can compare notes
                dbemowskD 1 Reply Last reply
                  dbemowskD
                  dbemowskD
                  @barduino Last night I created another decora plate that has 2 bigger switches. I will probably be pushing that one up to my thingiverse account tonight. I have to make the board for it yet, but I think this one will be a bit easier since I only have 4 switches and 2 LEDs to deal with instead of 8 and 4 with the other one.
                  0_1490737574834_upload-b2e10497-2630-48fc-83bf-146aab4e4812
                  I also have a project I did with my easy newbie boards where I made an enclosure for my bathroom temp/humidity sensor. Here is the link:
                  https://forum.mysensors.org/topic/6485/hdc1080-battery-operated-temp-humidity-sensor-with-wall-box
                  You mentioned that you couldn't create a support that wouldn't break. If you look at the temp/humidity enclosure I just have 4 mounting tabs inside the box. I am using 2mm x 5mm screws to secure it. These are the screws I bought to use on my decora switches. They work great. the tabs are big enough where there is no real chance that they would break. I could possibly get some longer screws because if I screw these in and take them out too much the hole kind of gets stripped. That shouldn't be much of a problem now that I have the enclosure perfected, I shouldn't have a need to remove screws much.
                    barduinoB
                    barduinoB
                    barduino
                    @dbemowsk , the problem is that I lost my screws... (portuguese joke meaning lost my marbles or gone crazy)
                    Anyway, do you create the threads for the screws in the plastic? or do you use self-threading...
                    When I do my supports I make them snap-on, like a little wider in the base and then a bit of plastic that goes through the board holes. If the holes are too thin the snap-on bit breaks.
                    cheers
                      cheers
                      dbemowskD
                      dbemowskD
                      @barduino I get it, I just have holes that I use self tapping screws in like this style:
                      0_1490813906802_upload-1149abd3-0401-4403-a3aa-a8ac8bc1efc4
                      I just bought some 2mm x 5mm ones from ebay. As long as you don't torque them in real tight, they hold good. So to hold a circuit board in a box, it is more than enough.
                        K
                        K
                        koen01
                        @barduino
                        I had a test setup that also had a sensor looking down so I could 'see' if my car was parked in the garage or not.... if distance < 1m == car parked.
                        My garage door opener is directly above my car when its parked.
                        • K koen01
                          @barduino
                          barduinoB
                          barduinoB
                          barduino
                          @koen01
                          I'm going for a similar next step.
                          The cars must be parked in a very specific position relative to the side wall and the garage door, or otherwise it's almost impossible to move around the garage.
                          Something like this Hek project.
