  3. Domoticz
  4. Different Node ID for same node
2 Posts 2 Posters 1.2k Views 2 Watching
  • J
    J
    jacikaas
    Does Node ID which I set on the node when I'm uploading code need to be same when it shows in Domoticz?
    MyController:
    0_1491041637857_upload-da348eef-39b4-462e-bd94-14723da9f607
    Domoticz LOG:
    2017-04-01 13:00:35.251 MySensors: Node: 21, Sketch Name: Plant moisture w bat
    2017-04-01 13:00:35.252 MySensors: Node: 21, Sketch Version: 1.5
    2017-04-01 13:00:36.253 (NRF RPi) Humidity (Hum)
    2017-04-01 13:00:36.256 (NRF RPi) General/Voltage (Voltage)
    Domoticz ID column:
    0_1491041818469_upload-9a546f39-4aa9-43d5-a6e6-691f37f3cb52
    • L
      L
      LastSamurai
      Domoticz lists the nodes as hex imo (and also adds the child number at the end). Have a look at your gateway in the "hardware" tab. It should list the right (the same as in your sketch) node id there.
