  2. Bug Reports
  3. Sleep() with interrupt only works with level "LOW"
18 Posts 6 Posters 7.6k Views 5 Watching
  • AWIA AWI
    @Yveaux Not really.. since 2.1.1 I'm losing it... :blush: Still in the process of finding differences with the previous version...
    @AWI There goes my pleed:
    0_1490901898593_upload-682ef4f5-a21b-4fbe-822c-339d0e3db1a7
    Source: http://gammon.com.au/interrupts
    Back to the drawing board then...
    AWIA 1 Reply Last reply
    • YveauxY Yveaux
      AWIA
      AWIA
      AWI
      @Yveaux Good find! and good news ;-)
      • AWIA AWI
        @AWI Took me a day of debugging, datasheet reading and searching the internet, but It looks like I fixed the sleep with external interrupts issues in the MySensors library!
        Main issue was this one: https://github.com/mysensors/MySensors/issues/811
        If an interrupt was pending (if it had been registered before actually sleeping the AVR) it would immediately wake the AVR again, just 2ms after sleeping it. It didn't matter if this interrupt was registered just before calling sleep or 1 hour ago...
        Furthermore https://github.com/mysensors/MySensors/issues/812 and https://github.com/mysensors/MySensors/issues/809 were also fixed, but have minor impact.
        I tested it on a ProMini with ATMega328P @ 8MHz, powered directly by 2xAA battery -- a 'standard' sleeping sensor processor setup.
        I verified sleeping modes LOW, CHANGE, RISING & FALLING to work Ok. This confirms your findings and Nick Gammon's.
        Sidenote: Mode HIGH is mapped onto CHANGE in Arduino ATMega328P port (duh!). The library can therefore not distinguish between the two and will use CHANGE in both situations.
        The bugs are solved in development branch, so please give it a try!
        ileneken3I AWIA 2 Replies Last reply
        • YveauxY Yveaux
          ileneken3I
          ileneken3I
          ileneken3
          @Yveaux
          The new version didn't seem to help with my scenario - a vibration sensor where I only want to send one message per "event". (A vibration detected within a few seconds, or more). Using the default handling:
          switch ( sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), CHANGE, SLEEP_TIME) )
              case MY_WAKE_UP_BY_TIMER:
                sendHeartbeat();
              case MY_SLEEP_NOT_POSSIBLE:
                Serial.println("Unable to sleep ;-(");
              default:
                Serial.println("Sending a message with value = 1 !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!");
                send(msg.set(1));
          There are always 2 messages sent. This happens even if I add a sleep either before or after the send().
          My workaround has been to add this after the send():
            while (sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), CHANGE, 2000) != MY_WAKE_UP_BY_TIMER ) {
              Serial.println("Clearing interrupts");
          I'm not sure the workaround is a good idea - because it may cause other problems. Any other ideas? Or is this correct?
          AWIA mfalkviddM 2 Replies Last reply
          • YveauxY Yveaux
            AWIA
            AWIA
            AWI
            @Yveaux great work :+1:
            • ileneken3I ileneken3
              @Yveaux
                    sendHeartbeat();
                  default:
                    send(msg.set(1));
              AWIA
              AWIA
              AWI
              wrote on last edited by AWI
              @ileneken3 Could it be that your sensor is better handled with a RISING or FALLING interrupt? CHANGE fires on both edges. Else post your whole sketch and debug log.
                @Yveaux
                      sendHeartbeat();
                    default:
                      send(msg.set(1));
                @ileneken3 for how long did you sleep when trying to use sleep to debounce the interrupt after sending? If you used a number less than 15, could you try with 15 or above? The sleep function does not work very well with small sleep times. or replace that sleep with wait.
                ileneken3I 1 Reply Last reply
                • ileneken3I
                  ileneken3I
                  ileneken3
                  @AWI
                  Tried all suggestions. Here is the whole code:
                     The MySensors dev version
                  #define MY_NODE_ID 89
                  #define MY_PARENT_NODE_ID 88 // Main floor repeater
                  #define CHILD_ID 88  // Id of the sensor child
                  #define MY_RF24_PA_LEVEL RF24_PA_HIGH // Attempt to get radio to work
                  #define MY_BAUD_RATE 9600
                  #define MY_DEBUG    // Enables debug messages
                  unsigned long SLEEP_TIME = 360000; // 6 minutes between heartbeats
                  #define DIGITAL_INPUT_SENSOR 3 // The digital input attached to vibration sensor.
                  // Initialize  message
                    Serial.begin(9600); // 9600 needed for 1MHZ
                    pinMode(DIGITAL_INPUT_SENSOR, INPUT_PULLUP);
                    wait(100);
                    Serial.println("Sending a message with value = 1 to get things started");
                    send(msg.set(1));
                  void presentation()  {
                    sendSketchInfo("Mailbox Sensor 1Mhz", "1.5");
                    present(CHILD_ID, S_MOTION);
                    // Sleep until woken by sensor, or timeout
                    // Tried with FALLING and RISING also.
                        Serial.println("Woke up after SLEEP_TIME seconds so sending heartbeat");
                        sendHeartbeat();
                      default:
                        Serial.println("Sending a message with value = 1 !!!!!!");
                        // Tried with sleep(15), sleep(1000), sleep(10000). delay(1000) and wait(4000)
                        wait(4000);
                  #ifdef SHOULD_NOT_BE_NEEDED
                  Here is the debug log:
                  0 MCO:BGN:INIT NODE,CP=RNNNA---,VER=2.2.0-beta
                  49 TSM:INIT
                  65 TSF:WUR:MS=0
                  81 TSM:INIT:TSP OK
                  114 TSM:INIT:STATID=89
                  131 TSF:SID:OK,ID=89
                  163 TSM:FPAR
                  212 TSF:MSG:SEND,89-89-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  737 TSF:MSG:READ,0-0-89,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                  786 TSF:MSG:FPAR OK,ID=0,D=1
                  1179 TSF:MSG:READ,88-88-89,s=255,c=3,t=8,pt=1,l=1,sg=0:1
                  1245 TSF:MSG:FPAR PREF
                  1261 TSF:MSG:FPAR OK,ID=88,D=2
                  1294 TSM:FPAR:OK
                  1327 TSM:ID
                  1343 TSM:ID:OK
                  1359 TSM:UPL
                  1376 TSF:MSG:SEND,89-89-88-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                  3473 TSM:UPL
                  3489 TSF:MSG:SEND,89-89-88-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                  3571 TSF:MSG:READ,0-88-89,s=255,c=3,t=25,pt=1,l=1,sg=0:2
                  3637 TSF:MSG:PONG RECV,HP=2
                  3670 TSM:UPL:OK
                  3686 TSM:READY:ID=89,PAR=88,DIS=2
                  3735 TSF:MSG:SEND,89-89-88-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                  3817 TSF:MSG:READ,0-88-89,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                  3899 TSF:MSG:SEND,89-89-88-0,s=255,c=0,t=17,pt=0,l=10,sg=0,ft=0,st=OK:2.2.0-beta
                  3997 TSF:MSG:SEND,89-89-88-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:88
                  6111 TSF:MSG:SEND,89-89-88-0,s=255,c=3,t=11,pt=0,l=19,sg=0,ft=0,st=OK:Mailbox Sensor 1Mhz
                  6225 TSF:MSG:SEND,89-89-88-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.5
                  6324 TSF:MSG:SEND,89-89-88-0,s=88,c=0,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
                  6406 MCO:REG:REQ
                  6422 TSF:MSG:SEND,89-89-88-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                  6504 TSF:MSG:READ,0-88-89,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                  6586 MCO:PIM:NODE REG=1
                  6602 MCO:BGN:STP
                  6766 TSF:MSG:SEND,89-89-88-0,s=88,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:1
                  6881 MCO:BGN:INIT OK,TSP=1
                  6897 MCO:SLP:MS=360000,SMS=0,I1=1,M1=1,I2=255,M2=255
                  6963 TSF:TDI:TSL
                  6995 MCO:SLP:WUP=1
                  7012 TSF:TRI:TSB
                  11059 MCO:SLP:MS=360000,SMS=0,I1=1,M1=1,I2=255,M2=255
                  11108 TSF:TDI:TSL
                  11141 MCO:SLP:WUP=1
                  11157 TSF:TRI:TSB
                  15204 MCO:SLP:MS=360000,SMS=0,I1=1,M1=1,I2=255,M2=255
                  15253 TSF:TDI:TSL
                  I always get at least two messages, sometimes more.
                  Here is the sensor:
                  https://www.aliexpress.com/item/normally-closed-type-vibration-sensor-module-Alarm-sensor-module-Vibration-switch-SW-420/32552946060.html?ws_ab_test=searchweb0_0,searchweb201602_1_10065_10130_10068_10136_10137_10138_10060_10062_10141_10056_10055_10054_10059_10099_129_10103_10102_10096_10148_10052_10053_10050_10107_10142_10051_10143_10084_10083_10119_10080_10082_10081_10110_10111_10112_10113_10114_10037_10032_10078_10079_10077_10073_10070_10123_10120_10124-10120,searchweb201603_4,afswitch_1_afChannel,ppcSwitch_5,single_sort_0_default&btsid=ad1187d9-117e-4c3a-b352-613dbf796c4f&algo_expid=761b80f8-c1bc-4235-8891-522e2e83f548-10&algo_pvid=761b80f8-c1bc-4235-8891-522e2e83f548
                    ileneken3I
                    ileneken3I
                    ileneken3
                    @mfalkvidd
                    I did try many combinations of sleep,wait,delay. I always get at least 2 messages sent.
                    Below, I posted the code and the debug log.
                    Thanks again.
                      Remove the MY_PARENT_NODE_ID and set pa_level to min
                        ileneken3I
                        ileneken3I
                        ileneken3
                        @gohan
                        I tried. Unfortunately, it didn't seem to matter with either or both those changes :(
