  3. Domoticz
  4. Requesting value from Domoticz
39 Posts 9 Posters 17.9k Views 11 Watching
  • dbemowskD dbemowsk
    You can use that though to set the value that the node can grab. Are you wondering how to grab the value?
    benyaB
    benyaB
    benya
    I am trying to figure what values to pass to
    void request(uint8_t childSensorId, uint8_t variableType, uint8_t destination);
    Where are the corresponding values show up in Domoticz UI?
    • dbemowskD
      dbemowskD
      I pull the thermostat mode from my thermostat bridge node like this:
          request( CHILD_ID_MODE, V_TEXT );
      I have never used the destination attribute, so I can't speak to it's use, but using the childSensorId and variableType works for me. You still need to use the technique I described to set the MySensors child node from the dummy sensor though.
      loic13L ? 2 Replies Last reply
        loic13L
        loic13L
        loic13
        Hi @dbemowsk,
        I'm trying to figure out the message format in the receive() function. Could you show an example of your receive() function ? I couldn't find the received message format.
        Thank's
        • dbemowskD
          dbemowskD
          You are going to use 2 things. message.type and message.data. The message.type in my scenario is V_TEXT, and message.data is the payload, which in my case is O, H, C or A, but can be whatever you pass from Domoticz. The code in your receive function would look something like this:
          if (message.type == V_TEXT) {
            Serial.println("Received data" + String(message.data));
            //Here you would do something with message.data
          If you have more than one child sensor sending V_TEXT data, you would then use an if statement or a switch/case to check message.sensor for the child ID of the sensor and process each as above.
            if (message.sensor == 1) {
              Serial.println("Received data from child 1" + String(message.data));
              //Here you would do something with message.data for the first child
            } else if (message.sensor == 2) {
              Serial.println("Received data from child 2" + String(message.data));
              //Here you would do something with message.data for the second child
          Let us know if you have trouble.
          loic13L 1 Reply Last reply
            loic13L
            loic13L
            loic13
            That is perfect thanks a lot.
              A Former User
              wrote on last edited by [[global:former-user]]
              @dbemowsk
              At the moment I'm trying to send a text value from Domoticz with MySensors Gateway to one of my nodes.
              I need to implement the "request" function in this node. So here's my question: what value did you assign to "CHILD_ID_MODE". I presume that's the ID of the dummy selector described in another topic on this forum? How did you obtain this value? Is it available somewhere in Domoticz UI?
              Now I request a text value, but all I get is a blank message, cause I don't know what I should insert as "uint8_t childSensorId".
                The child ID is something you define when you present the sensors of the node
                ? 1 Reply Last reply
                  A Former User
                  @gohan Yes, I understand, but when I create a dummy text sensor I can't define its child ID. Can I find it somewhere?
                    You have to create a sensor in the sensor node sketch, assign a child ID to it and present it like the others sensors during setup, then it should show on the controller. I can't be more specific because I haven't worked on text sensors yet
                      A Former User
                      @gohan Dummy sensors are created in Domoticz, they don't use the MySensors library, so one doesn't upload any sketches to Arduino :)
                      What I want to achieve specifically is to send outside temperature received from WeatherUnderground to one of my MySensors nodes.
                        I know, but if you don't create a sensor able to receive the value, you can't send anything to it through the mysensors network
                          A Former User
                          @gohan hey, now I get it!
                          got it working the way I wanted, thank you so much :D
                          mar.conteM 1 Reply Last reply
                            Just for my curiosity, why are you using the temperature from weather underground? Is it just displayed on a screen?
                              A Former User
                              #23
                              @gohan I'm doing a project for my master's thesis.
                              There's a mathematical thermal model of a building running on MySensors node. I wanted to supply it with an information about actual outside temperature to have accurate results.
                                A real mysensors project would require an external node with temperature and humidity sensor 😁
                                  A Former User
                                  @gohan This model is just a small part of my project. But I get your concept.
                                  There's already a DHT11 node running inside my house, measuring quantities that you've mentioned.
                                  • ? A Former User
                                    mar.conteM
                                    mar.conteM
                                    mar.conte
                                    wrote on last edited by mar.conte
                                    #26
                                    @tomek_olo
                                    Sorry what is the way for send from domoticz child -node to other node through lua script for example Tanks
                                    M.C.
                                    • mar.conteM mar.conte
                                      @tomek_olo
                                      A Former User
                                      #27
                                      @mar.conte I don't understand your question. Can you clarify, please?
                                      • ? A Former User
                                        mar.conteM
                                        mar.conteM
                                        mar.conte
                                        @tomek_olo
                                        M.C.
                                          @tomek_olo
                                          A Former User
                                          #29
                                          @mar.conte
                                          OK, I'll try to describe everything I've done to get it working:
                                          1. I'm presenting MySensors node to Domoticz as S_INFO: "present(CHILD_ID, S_INFO);"
                                          2. Next step is to add this node in your Domoticz. It should be visible at first in "Devices" as a "Text" device. After you add it it will be present in the "Utility" tab.
                                          3. Now you have to edit a text value of this device in Domoticz. (I think that's what interests you but in reverse) I'm using a "Device" script that updates this text value with outside temperature every time the weather is updated:
                                          commandArray = {}
                                          local tempOut = devicechanged["Outside_Temperature"]
                                          local tempOutIdx = 25
                                          if ( devicechanged["Outside"]) then
                                          commandArray['UpdateDevice'] = otherdevices_idx['TextNode']..'|1|'..tempOut
                                          end
                                          1. Now when I want to download this new value to my node I use "request( CHILD_ID, V_TEXT );" and inside "receive()" function:
                                          if (message.sensor == CHILD_ID) {
                                          outTemp = message.getFloat();
                                          That's all, it's complicated. If you have any questions feel free to ask. I'll do my best to help.
