  3. Low power light sensor to generate wakeup interrupt
18 Posts 7 Posters 11.4k Views 7 Watching
  • sundberg84S
    sundberg84S
    Or a photoresistor and a transistor?
    • dbemowskD
      dbemowskD
      Why not just an LDR voltage divider. 2 components. Look at this:
      https://learn.adafruit.com/photocells/using-a-photocell
      • Vladimir DobrikovV
        Vladimir DobrikovV
        Vladimir Dobrikov
        Hm, let me try. I just think photoresistor will consume quite a lot of power just by itself. But let me try
        dbemowskD 1 Reply Last reply
        • Nca78N
          I bought OPT3001 here :
          https://www.aliexpress.com/item/High-Quality-CJMCU-3001-OPT3001-ambient-light-sensor-to-the-human-eye-as-a-single-chip/32672773503.html?spm=2114.13010608.0.0.UGMh7i
          And MAX44009 breakout board (GY-49) here :
          https://www.aliexpress.com/item/GY49-MAX44009-Ambient-Light-Sensor-Module-for-Arduino-with-4P-Pin-Header-Module/32772767521.html
          Both have interrupt pin broken out, it's just on the opposite side for the MAX44009 board (next to "49" text) instead of inline with other pins like for OPT3001.
          MAX44009 is much cheaper as a breakout board, and after removing the regulator (I run it on button cell) the power consumption is just insanely low, I can't even see the difference with my multimeter when it's connected to the board or not.
          I have not tested the OPT3001 yet but I don't expect much more power consumption after removing regulator.
          If you keep the regulator you should stay below 10µA with the 2 boards, I don't believe you can get that low with a photoresistor.
            @dbemowsk
            because an i2c sensor is so cool to use :sunglasses: (digital value, optimized, repeatibility ..) but the LDR is timeless style sure :)
              Vladimir DobrikovV
              Vladimir Dobrikov
              Yes, I also just love I2C sensors, thus prefer them against other due to power and pins consumption.
              BTW tried to run my test node without light sensor (while waiting for them to be tested) and found results quite frustrated: it appears that PIR sensor generates a lot of false positives (~ each min). For PIR I use HC-SR501 which connected to 3.3v directly like:
              dbemowskD AffordableTechA 2 Replies Last reply
              • Vladimir DobrikovV Vladimir Dobrikov
                dbemowskD
                dbemowskD
                @Vladimir-Dobrikov If you are getting false positives, it could be because of your input voltage. You are only supplying 3.3 volts which is too low. The operating voltage of these is 4.5 - 20 volts.
                AffordableTechA 1 Reply Last reply
                  dbemowskD
                  dbemowskD
                  @Vladimir-Dobrikov Using a 10K pull-down resistor at full brightness using 3.3volts you are going to consume somewhere around 0.3mA, which is going to probably be your highest consumption. On a dark moonlit night you are only consume around 41 uA. I wouldn't think that should be too bad. Unless I calculated something wrong, that should last a while.
                    Vladimir DobrikovV
                    Vladimir Dobrikov
                    @dbemowsk for the moment I don't use any light sensor (still waiting for delivery). As for PIR, I've connected it a bit unregular way. When I test it with serial connection, it works pretty stable and predictable way even with 3.3v.
                      Vladimir DobrikovV
                      Vladimir Dobrikov
                      Made some measurements with current config:
                      Sending data: 0.54 mA
                      Sleep (motion on): 0.16 mA
                      Sleep (motion off): 0.09 mA
                      Wiring:
                      Sketch:
                      *  Multisensor MySensors node (temperature, humidity, light, motion)
                      *  MCU:
                      *   - Arduino Mini 3.3v
                      *  Integration type:
                      *   - MySensors (Radio NRF24)
                      *  MySensors version:
                      *   2.1.0
                      *  Modules:
                      *   - nRF24L01: radio
                      *   - HTU21 / GY-21: temperature/humidity
                      *   - TBD: light
                      *   - HC-SR501: motion
                      *   Wiring:
                      *    Arduino       nRF24L01
                      *      9  <------>  CE
                      *     10  <------>  CSN/CS
                      *     13  <------>  SCK
                      *     11  <------>  MOSI
                      *     12  <------>  MISO
                      *    N/C  <------>  IRQ (not connected)
                      *     Arduino      HTU21
                      *      A4  <----->  SCL
                      *      A5  <----->  SDA
                      *     Arduino      Light (TBD)
                      *     Arduino      HC-SR501
                      *       2  <------> Dout
                      *  Author:
                      *   Vladimir Dobrikov <hedin.mail@gmail.com>
                      // Enable debug prints
                      // #define MY_DEBUG
                      #define SKETCH_NAME "temp-hum-light-movement"
                      #define SKETCH_VERSION "1.1"
                      #define MY_RF24_PA_LEVEL RF24_PA_MIN // RF24_PA_MIN, RF24_PA_LOW, RF24_PA_HIGH, RF24_PA_MAX
                      //#define MY_NODE_ID 10
                      // Keep MySensors.h below config definitions
                      #include <Arduino.h>
                      #include <SparkFunHTU21D.h>
                      #define THRESHOLD_TEMP 2 // threshold to send update
                      #define THRESHOLD_HUMD 2 // threshold to send update
                      const unsigned long INIT_PIR_TIMEOUT_SEC = 5; // 3 sec to init PIR after poweron
                      const unsigned long SLEEP_TIME_MIN = 15; // Sleep time between reports (in milliseconds)
                      const byte BATT_WAKEUPS_MAX = 100; // Max wakeup times to send battery status
                      const byte ENV_WAKEUPS_MAX = 10; // Max wakeup times to send temp/humidity status
                      // #define DEBUG_OUPUT
                      #if defined(DEBUG_OUPUT)
                        #define DBGPRINT(str) Serial.print(str)
                        #define DBGPRINTLN(str) Serial.println(str)
                      // Only 2 and 3 generates interrupt!
                      #define PIN_MOTION 2
                      #define PIN_LIGHT 3
                      #define PIN_BATT A0
                      // Child nodes IDs
                      #define CHILD_ID_MOTION 1
                      #define CHILD_ID_LIGHT 2
                      #define CHILD_ID_TEMP 3
                      #define CHILD_ID_HUMD 4
                      // Initialize messages
                      MyMessage msgMotion(CHILD_ID_MOTION, V_TRIPPED);
                      MyMessage msgLight(CHILD_ID_LIGHT, V_TRIPPED);
                      MyMessage msgHumd(CHILD_ID_HUMD, V_HUM);
                      HTU21D sensorTempHumd;
                      int8_t wakeupReason = -42;
                      // Is there any convenient tool lib for that?
                      bool prevMotion = false;
                      bool motion = false;
                      bool prevLight = false;
                      bool light = false;
                      float prevHumd = 0;
                      float humd = 0;
                      float prevTemp = 0;
                      float temp = 0;
                      int prevBattPcnt = 0;
                      int battPcnt = 0;
                      byte battWakeups = 0;
                      byte envWakeups = 0;
                        analogReference(INTERNAL); // For batt measurement
                        pinMode(PIN_MOTION, INPUT);
                        pinMode(PIN_LIGHT, INPUT);
                        sensorTempHumd.begin();
                        sensorTempHumd.setResolution(USER_REGISTER_RESOLUTION_RH10_TEMP13);
                        DBGPRINTLN(F("Sleep till PIR init"));
                        sleep(INIT_PIR_TIMEOUT_SEC * 1000);
                        present(CHILD_ID_MOTION, S_MOTION);
                        present(CHILD_ID_LIGHT, S_CUSTOM);
                        present(CHILD_ID_HUMD, S_HUM);
                        // negative: timeout
                        // 0: 1st interrupt
                        // 1: 2nd interrupt
                        DBGPRINTLN(F("---------------------------"));
                        DBGPRINT(F("wakeupReason = "));DBGPRINTLN(wakeupReason < 0 ? "timeout" : wakeupReason == 0 ? "motion" : wakeupReason == 1 ? "light" : "unknown");
                        battWakeups = battWakeups >= BATT_WAKEUPS_MAX ? 0 : battWakeups + 1;
                        DBGPRINT(F("battWakeups = "));DBGPRINTLN(battWakeups);
                        envWakeups = envWakeups >= ENV_WAKEUPS_MAX ? 0 : envWakeups + 1;
                        DBGPRINT(F("envWakeups = "));DBGPRINTLN(envWakeups);
                        if (battWakeups == 0) {
                          battPcnt = getBattPcnt();
                          DBGPRINT(F("battPcnt = "));DBGPRINTLN(battPcnt);
                        motion = digitalRead(PIN_MOTION) == HIGH;
                        DBGPRINT(F("motion = "));DBGPRINTLN(motion);
                        light = digitalRead(PIN_LIGHT) == LOW; // Reverse logic
                        DBGPRINT(F("light = "));DBGPRINTLN(light);
                        if (envWakeups == 0 || wakeupReason < 0) {
                          humd = sensorTempHumd.readHumidity();
                          DBGPRINT(F("humd = "));DBGPRINTLN(humd);
                          humd = roundFloat(humd);
                          temp = sensorTempHumd.readTemperature();
                          DBGPRINT(F("temp = "));DBGPRINTLN(temp);
                          temp = roundFloat(temp);
                        // Keep send action in the bottom close to each other to wakeup radio only
                        // if needed and have it awake minimum time
                        sendDataIfUpdate();
                        // Sleep until interrupt comes in on motion or light sensor or sleep timeout.
                        DBGPRINT(F("Going to sleep for (min): "));DBGPRINTLN(SLEEP_TIME_MIN);
                        wakeupReason = sleep(digitalPinToInterrupt(PIN_MOTION), CHANGE, digitalPinToInterrupt(PIN_LIGHT), CHANGE, SLEEP_TIME_MIN * 60 * 1000);
                      void sendDataIfUpdate() {
                        if (prevBattPcnt != battPcnt) {
                          prevBattPcnt = battPcnt;
                          DBGPRINT(F("  Sending batt: "));DBGPRINTLN(battPcnt);
                          sendBatteryLevel(battPcnt);
                        if (prevMotion != motion) {
                          prevMotion = motion;
                          DBGPRINT(F("  Sending motion: "));DBGPRINTLN(motion);
                          send(msgMotion.set(motion));
                        if (prevLight != light) {
                          prevLight = light;
                          DBGPRINT(F("  Sending light: "));DBGPRINTLN(light);
                          send(msgLight.set(light));
                        if (abs(prevHumd - humd) >= THRESHOLD_HUMD) {
                          prevHumd = humd;
                          DBGPRINT(F("  Sending humd: "));DBGPRINTLN(humd);
                          send(msgHumd.set(humd, 1));  // 1 means number of digits of fractional part
                        if (abs(prevTemp - temp) >= THRESHOLD_TEMP) {
                          prevTemp = temp;
                          DBGPRINT(F("  Sending temp: "));DBGPRINTLN(temp);
                          send(msgTemp.set(temp, 1));  // 1 means number of digits of fractional part
                      int getBattPcnt() {
                        int rawBattVal = analogRead(PIN_BATT);
                        DBGPRINT(F("rawBattVal = "));DBGPRINTLN(rawBattVal);
                        return rawBattVal / 10;
                      // Round to 0.5
                      float roundFloat(float val) {
                        return round(val * 2) / 2;
                        Does anybody know any low power light sensor which can produce pin change interrupt for Arduino?
                        I planned to use the one with photoresistor:
                        Photoresistor sensor
                        But it appears to be quite power greedy. There are 2 LEDs onboard: power and threshold. I've made some measurements:
                        2 LEDs on: 3.7 mA
                        1 LED on: 2.3 mA
                        Both LEDs removed: 1.1 mA
                        That's way too high for battery powered node. What I want to build is the node with movement, light (on/off), temperature and humidity sensors. For the moment this light module is the showstopper for my node.
                        I also have BH1750FVI GY-302 one which good power budget, but it's not able to produce pin change signal to wake my node up on when light is on or off.
                        Just ordered APDS-9930 which seems to have INT pin which can be configured to rise by threshold, but maybe somebody know the better solution?
                        AffordableTechA
                        AffordableTechA
                        AffordableTech
                        wrote on last edited by AffordableTech
                        Hi @Vladimir-Dobrikov
                        A simple solution you can use is to power the LDR Sensor board (shown) from an output pin on the Arduino, turning the pin/power on briefly while you take a light sample. (An arduino pin can drive 20ma safely from memory).
                        For example, if you sample the light level for 10ms (0.01 sec), every 10 seconds (or 1 sec etc), your average power requirements (for the light sensor) will drop from 1.1ma to 0.00011 if I've done my maths right.
                        This is assuming you don't need to 'instantly' know every little change in light level. If you are recording general ambient light levels, having an interrupt for every minor change could generate excessive interrupts and data transmissions, consuming heaps of power for the RF transmission.
                        In my system, I measure ambient light with a 10 cent LDR and resistor, and UV levels with a UV sensor. I started sampling every 10 seconds during initial tests, but now I only wake the Arduino once a minute, take a sample and ONLY transmit data if either has changed or 15 minutes has passed.
                        By doing this, my light sensor module has been running 18 months with a small lithium battery, charged by a small solar panel. I checked it a few weeks ago and found the solar cell covered in cob-webs and dust etc, but it was still charging fine.
                        I would strongly suggest you check out https://github.com/mysensors/NodeManager as it will give you the following benefits:
                        • Has templates for LDR, Temp, Hum & Motion sensors.
                        • Looks after power management sleeping the Arduino
                        • Can manage turning your LDR on/off as required.
                        • Report current battery level.
                        Regards,
                        Paul
                        • dbemowskD dbemowsk
                          AffordableTechA
                          AffordableTechA
                          AffordableTech
                          Hello @dbemowsk
                          I don't have the specs in front of me at the moment, but the versions of this device I have (with circuit diagram) look the same and operate internally on 3.3v and have an LDO 3v3 regulator, enabling them to run off 5v+. I think you can see it it the large picture, under letters VCC (in red), it's marked "7133-1#". @Vladimir-Dobrikov is correctly powering it by providing 3.3V to pin 3 of jumper block 1, this bypasses the regulator, providing your 3.3v direct to the circuitry (on mine at least).
                          Refer: http://www.electrodragon.com/w/PIR_sensor#PIR_sensor_Schematic
                          The wiring @Vladimir-Dobrikov used looks the same as mine, i.e. the jumper and power to the pin in the upper right of the photo.
                          In my case, I use them to turn on several different room lights when someone enters and have not noticed any false triggers once I adjusted the sensitivity down a bit. Great value and low power - fantastic devices!!!
                          Paul
                            AffordableTechA
                            AffordableTechA
                            AffordableTech
                            @Vladimir-Dobrikov
                            Have you adjusted the sensitivity? All of mine (10) arrived set to almost maximum sensitivity and I had false triggers in an empty room, however once I adjusted the sensitivity a low as I could, yet detect a person, they have been 100% reliable.
                            NOTE: These devices need to warm up, so I recommend leaving them powered up for 30 minutes before you attempt to adjust them.
                            Hope that helps,
                            Paul
                              Vladimir DobrikovV
                              Vladimir Dobrikov
                              @AffordableTech, regarding PIR sensors, I've got an advice to add 3rd battery since this sensor is very sensible to VCC level and under 3v isn't predictable. So I've connected batteries as suggested here:
                              PIR battery wiring
                              I also thought about step-up convertor to power PIR with exactly 3.3v, but I was said this kind of power line is quite noisy which again will cause false positives so Ive rejected this option.
                              With this setup (3AA) my node became reliable and works that way about 1 week.
                              As for light sensor, after some thoughts I came into decision to use BH1750FVI sensor which is also I2C one with low consumption if configure it with one time measurement mode (by default it's continuous mode).
                              My use case is to trigger light by motion only if light level is 0. Now I just send light level alongside with motion event, thus no need of waking up by light interrupt anymore.
