  3. Home Assistant
  4. Multiple sensors home assistant
10 Posts 3 Posters 5.8k Views 4 Watching
  • S Offline
    sjofel
    Hello everyone,
    I've succesfully created a node which will send it's battery status, temperature and doorstate (reedswitch) to home-assistant. However, in the home-assistant dashboard both the child 1.1 (Door) and child 1.2 (Temperature) show temperature see pictures below:
    My question is it possible to show only the relevant data per child sensor, so sensor 1.1 only show doorstate and battery and sensor 1.2 shows only temperature and battery?
    Thanks in advance.
    • Vladimir DobrikovV Offline
      Vladimir Dobrikov
      I guess you tested different children config, thus got child ids mixed. IMO it needs to either delete this node in mysensors.json or delete the file itself to force homeassistant to refresh this node with all children.
      • S Offline
        sjofel
        Thanks for your response. I did that. I've disconnected my node and then deleted my persistence file (when i don't disconnect my node the persistence file comes back after deletion?). Next, i've rebooted my pi and reconnected my node. When this is done i'll get the output shown in my post above.
          Vladimir Dobrikov
          Can you verify your sketch? Maybe you registered several children with the same ID?
          • S Offline
            sjofel
            I've verified that. In my sketch i've one node id and two child id's. One for the door and the other for the temperature sensor. The battery status is send using the interal message of mysensors.
            • S sjofel
              martinhjelmareM Offline
              martinhjelmare
              @sjofel
              Please post your sketch.
              • S Offline
                sjofel
                I've programmed the sketch in C++ so i've made classes of the temperature, door and battery sensor. I shall post the cpp files only to keep this post short. Every class and the main includes the config.h were the defines are located. Thanks in advance.
                Main:
                #define SLEEP_TIME 300000
                #include "Config.h"
                #include "Battery/Battery.h"
                #include "Temperature/Temperature.h"
                #include "Door/Door.h"
                CBattery battery;
                CTemperature temperature;
                CDoor door;
                void before()
                	temperature.BeforeSetupTemperature();
                	temperature.SetupTemperature();
                	door.SetupDoor();
                  sendSketchInfo("FrontdoorSensor", "1.0");
                  temperature.Present();
                  door.Present();
                	temperature.sendTemperature();
                	battery.sendBatteryStatus();
                	door.SendDoorState();
                	sleep(DOOR_PIN - 2, CHANGE, SLEEP_TIME);
                  if (message.isAck()) {
                  if (message.type == V_TEMP) {
                    if (temperature.getInitialValueSend() == false) {
                      Serial.println("Receiving initial value from controller");
                      temperature.InitialValueIsSend();
                Temperature class:
                #include "Temperature.h"
                CTemperature::CTemperature()
                : temperature(0),
                  lastTemperature(0),
                  initialValueSend(false),
                  oneWire(ONE_WIRE_BUS),
                  sensors(&oneWire),
                  temperatureMsg(CHILD_TEMP, V_TEMP)
                CTemperature::~CTemperature() {
                	// TODO Auto-generated destructor stub
                void CTemperature::BeforeSetupTemperature()
                	  sensors.begin();
                void CTemperature::SetupTemperature()
                void CTemperature::Present()
                	present(CHILD_TEMP, S_TEMP);
                void CTemperature::getTemperature(float &temp)
                  wait(conversionTime);
                  temp = sensors.getTempCByIndex(0);
                void CTemperature::sendTemperature()
                	getTemperature(temperature);
                	SendInitialValue(temperature);
                	if (temperature != -127.00 && temperature != 85.00)
                	 if(temperature != lastTemperature)
                		#ifdef MY_DEBUG
                		 Serial.print("Temperature: ");
                		 Serial.print(temperature);
                		 Serial.println(" C");
                	   send(temperatureMsg.setSensor(1).set(temperature,1));
                void CTemperature::SendInitialValue(float &rTemperature)
                if (!initialValueSend)
                #ifdef MY_DEBUG
                		Serial.println("Sending initial value");
                		send(temperatureMsg.set(static_cast<int>(rTemperature)));
                #ifdef MY_DEBUG
                		Serial.println("Requesting initial value from controller");
                		request(CHILD_TEMP, V_TEMP);
                		wait(2000, C_SET, V_TEMP); //misschien niet nodig???
                void CTemperature::InitialValueIsSend()
                	initialValueSend = true;
                Door class:
                #include "Door.h"
                CDoor::CDoor()
                : oldValue(-1),
                  doorMessage(CHILD_DOOR, V_TRIPPED)
                	// TODO Auto-generated constructor stub
                CDoor::~CDoor() {
                void CDoor::SetupDoor()
                	  // Setup the button
                	  pinMode(DOOR_PIN,INPUT);
                	  // Activate internal pull-up
                	  digitalWrite(DOOR_PIN,HIGH);
                void CDoor::Present()
                	present(CHILD_DOOR, S_DOOR);
                void CDoor::SendDoorState()
                	  delay(100);
                	  // Get the update value
                	  int value = digitalRead(DOOR_PIN);
                #ifdef MY_DEBUG
                	  Serial.print("Doorstate: ");
                	  Serial.println(value);
                	  if (value != oldValue) {
                	     // Send in the new value
                		 Serial.println("Sending door state!");
                	     send(doorMessage.set(value==HIGH ? 1 : 0));
                	     oldValue = value;
                Config.h
                #ifndef CONFIG_H_
                #define CONFIG_H_
                //Default defines
                #define MY_NODE_ID 1
                //Child id's
                #define CHILD_DOOR 1
                #define CHILD_TEMP 2
                //Pin defines
                #define BATT_PIN A0
                #define TEMP_PIN 2
                #define DOOR_PIN 3
                #endif /* CONFIG_H_ */
                Battery class:
                #include "Battery.h"
                CBattery::CBattery()
                : oldBatteryLvl(0),
                  batteryLvl(0)
                CBattery::~CBattery() {
                void CBattery::BatterySetup()
                	pinMode(BATT_PIN, INPUT);
                void CBattery::getBatteryStatus(int &level)
                  int batterylvl = analogRead(BATT_PIN);
                #ifdef MY_DEBUG
                    Serial.println(batterylvl);
                    level = batterylvl / 10;
                #ifdef MY_DEBUG
                    float batteryV  = batterylvl * 0.003363075;
                    Serial.print(batteryV);
                    Serial.println(" V");
                    Serial.print(batterylvl);
                    Serial.println(" %");
                void CBattery::sendBatteryStatus()
                	getBatteryStatus(batteryLvl);
                    if (oldBatteryLvl != batteryLvl) {
                        // Power up radio after sleep
                        sendBatteryLevel(batteryLvl);
                        oldBatteryLvl = batteryLvl;
                • S sjofel
                  Main:
                  #include "Config.h"
                  CBattery battery;
                  CDoor door;
                  void before()
                  	door.SetupDoor();
                    door.Present();
                  Temperature class:
                  : temperature(0),
                    lastTemperature(0),
                    sensors(&oneWire),
                  	  sensors.begin();
                  		#ifdef MY_DEBUG
                  #ifdef MY_DEBUG
                  #ifdef MY_DEBUG
                  Door class:
                  #include "Door.h"
                  CDoor::CDoor()
                  : oldValue(-1),
                  CDoor::~CDoor() {
                  	  // Setup the button
                  	  delay(100);
                  #ifdef MY_DEBUG
                  	     oldValue = value;
                  Config.h
                  #ifndef CONFIG_H_
                  #define CONFIG_H_
                  //Default defines
                  //Child id's
                  //Pin defines
                  #define BATT_PIN A0
                  #define TEMP_PIN 2
                  #define DOOR_PIN 3
                  Battery class:
                  : oldBatteryLvl(0),
                    batteryLvl(0)
                  #ifdef MY_DEBUG
                  #ifdef MY_DEBUG
                  martinhjelmare
                  @sjofel
                  In the temperature class, when you send in the new temperature, you set the sensor to 1. That means you connect the message with child 1, which is the door child. Remove that part of that line, and you should be good.
                  S 2 Replies Last reply
                    @sjofel
                    sjofel
                    @martinhjelmare
                    Thank you. I'll try this tonight when i'll get home and report back if it works.
                      @sjofel
                      sjofel
                      @martinhjelmare
                      This was indeed the problem. Thank you for your help.
