  3. Sensor dht+relay won't send data or present
12 Posts 3 Posters 3.2k Views 3 Watching
    On my Domoticz the dht11 shows as a combined temphum and it shows both data even if I present it separately
    • MasMatM
      MasMatM
      MasMat
      I think there's a bigger clitch in my code somewhere that is causing that. I'm not sure if the millis-timer is properly used here or if that is somehow interfering with the other code.
        I'd use a wait (500) or (1000) at the end of the loop, to slow things down a bit
        MasMatM 1 Reply Last reply
          MasMatM
          MasMatM
          MasMat
          @gohan you mean "delay(500)"? Will that not affect the radio function if it is waiting for a command for the relay for example?
          HenryWhiteH 1 Reply Last reply
          • MasMatM
            MasMatM
            MasMat
            The startup serial "seems" OK, but the relay function is not there. The MQTT log appears to send empty strings "" rather than 0 or 1 when I attempt to activate the relay from Domoticz.
            Just in case, the startup serial is as follows:
            3 MCO:BGN:BFR
            4 TSM:INIT
            5 TSF:WUR:MS=0
            12 TSM:INIT:TSP OK
            14 TSF:SID:OK,ID=1
            16 TSM:FPAR
            52 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            319 TSF:MSG:READ,0-0-1,s=255,c=3,t=8,pt=1,l=1,sg=0:0
            324 TSF:MSG:FPAR OK,ID=0,D=1
            2059 TSM:FPAR:OK
            2060 TSM:ID
            2061 TSM:ID:OK
            2063 TSM:UPL
            2068 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
            2075 TSF:MSG:READ,0-0-1,s=255,c=3,t=25,pt=1,l=1,sg=0:1
            2080 TSF:MSG:PONG RECV,HP=1
            2082 TSM:UPL:OK
            2084 TSM:READY:ID=1,PAR=0,DIS=1
            2089 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
            2098 TSF:MSG:READ,0-0-1,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
            2105 TSF:MSG:SEND,1-1-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.1.1
            2113 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
            2240 TSF:MSG:READ,0-0-1,s=255,c=3,t=6,pt=0,l=1,sg=0:M
            2247 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=11,pt=0,l=22,sg=0,ft=0,st=OK:TemperatureAndHumidity
            2257 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.1
            2266 TSF:MSG:SEND,1-1-0-0,s=0,c=0,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            2273 TSF:MSG:SEND,1-1-0-0,s=1,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=OK:
            2281 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=11,pt=0,l=5,sg=0,ft=0,st=OK:Relay
            2289 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.0
            2297 TSF:MSG:SEND,1-1-0-0,s=1,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
            2304 MCO:REG:REQ
            2307 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
            2345 TSF:MSG:READ,0-0-1,s=255,c=3,t=27,pt=1,l=1,sg=0:1
            2351 MCO:PIM:NODE REG=1
            2353 MCO:BGN:STP
            2355 MCO:SLP:MS=2000,SMS=0,I1=255,M1=255,I2=255,M2=255
            2360 MCO:SLP:TPD
            2362 MCO:SLP:WUP=-1
            2364 MCO:BGN:INIT OK,TSP=1```
            • MasMatM MasMat
              HenryWhiteH
              HenryWhiteH
              HenryWhite
              @MasMat said in Sensor dht+relay won't send data or present:
              That's what wait() is for (mysensors specific) , it will not interfere with the radio commumication.
              • MasMatM
                MasMatM
                MasMat
                Thanks for the tip. Good to learn these things as I go.
                I'm to the point of rebuilding the sensor (or building a duplicate really) to see if this could be a hardware glitch.
                  You could try ethernet gateway instead of mqtt if it works better and move to mqtt later on
                    MasMatM
                    MasMatM
                    MasMat
                    @gohan I cant see the upside to going back since I couldnt get the Ethernet gw working but the mqtt appears to be working AND Domoticz supports it apparently.
                    I did a quick breadboard setup and it seems the problem might be hardware rather than sketch.
                    Question about the wait command: could I use wait (=soooo simple) rather than a millis timer to have a sensor/node be ready to activate a relay at any time but to only send DHT data every 60s or so?
                      sure you can use the wait()
                      • MasMatM
                        MasMatM
                        MasMat
                        To follow up. It was hardware: broken vcc pin on the dht11 corrupted the whole sensor code badly. Resolder and added wait-code, inverted the on-off 0-vs-1 and I have a good working sensor. The duplicate is also installed and working reliably.
                        A 6-relay board is also working nicely and Domoticz is great. My old system is nearly replaced and I couldnt be happier.
                        Respect and thanks all around!
