  3. Sensor dht+relay won't send data or present
12 Posts 3 Posters 3.1k Views 3 Watching
  • MasMatM Offline
    MasMatM Offline
    MasMat
    Hi everyone,
    Started a challenging sensor immediately: RF24+relay+dht11.
    Radio seems to work, sensor gets power and the debug-mqtt appears to show all proper presentations. Using Domoticz, the node is seen but only s_hum and s_binary. The humidity sensor wont show in devices, the relay is seen but doesnt respond.
    I think I have a problem with my code. I'm using a millis-counter to send temp+hum every 60s and have the relay at the ready constantly.
    Pls help.
    // Enable debug prints
    //#define MY_RS485
    #define DHT_DATA_PIN 4
    #define SENSOR_TEMP_OFFSET 0
    static const uint64_t UPDATE_INTERVAL = 60000;
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    float lastTemp;
    float lastHum;
    uint8_t nNoUpdatesTemp;
    uint8_t nNoUpdatesHum;
    bool metric = true;
    // Generally, you should use "unsigned long" for variables that hold time
    // The value will quickly become too large for an int to store
    unsigned long previousMillis = 0;        // will store last time DHT was updated
    // constants won't change :
    const long interval = 60000;           // interval at which to read DHT (milliseconds)
    DHT dht;
    void before()
        pinMode(pin, OUTPUT);
      sendSketchInfo("TemperatureAndHumidity", "1.1");
      present(CHILD_ID_HUM, S_HUM);
      sendSketchInfo("Relay", "1.0");
        present(sensor, S_BINARY);
      if (currentMillis - previousMillis >= interval) {
        // save the last time you checked DHT
      dht.readSensor(true);
      if (isnan(temperature)) {
        lastTemp = temperature;
        if (!metric) {
        // Reset no updates counter
        nNoUpdatesTemp = 0;
        #ifdef MY_DEBUG
        Serial.print("T: ");
        nNoUpdatesTemp++;
      if (isnan(humidity)) {
        lastHum = humidity;
        nNoUpdatesHum = 0;
        #ifdef MY_DEBUG
        Serial.print("H: ");
        Serial.println(humidity);
        nNoUpdatesHum++;
      //sleep(UPDATE_INTERVAL);
      if (message.type==V_STATUS) {
        // Change relay state
        // Store state in eeprom
      On my Domoticz the dht11 shows as a combined temphum and it shows both data even if I present it separately
      • MasMatM Offline
        MasMatM Offline
        MasMat
        I think there's a bigger clitch in my code somewhere that is causing that. I'm not sure if the millis-timer is properly used here or if that is somehow interfering with the other code.
          I'd use a wait (500) or (1000) at the end of the loop, to slow things down a bit
          MasMatM 1 Reply Last reply
            MasMatM Offline
            MasMatM Offline
            MasMat
            @gohan you mean "delay(500)"? Will that not affect the radio function if it is waiting for a command for the relay for example?
            H 1 Reply Last reply
            • MasMatM Offline
              MasMatM Offline
              MasMat
              The startup serial "seems" OK, but the relay function is not there. The MQTT log appears to send empty strings "" rather than 0 or 1 when I attempt to activate the relay from Domoticz.
              Just in case, the startup serial is as follows:
              3 MCO:BGN:BFR
              4 TSM:INIT
              5 TSF:WUR:MS=0
              12 TSM:INIT:TSP OK
              14 TSF:SID:OK,ID=1
              16 TSM:FPAR
              52 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
              319 TSF:MSG:READ,0-0-1,s=255,c=3,t=8,pt=1,l=1,sg=0:0
              324 TSF:MSG:FPAR OK,ID=0,D=1
              2059 TSM:FPAR:OK
              2060 TSM:ID
              2061 TSM:ID:OK
              2063 TSM:UPL
              2068 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
              2075 TSF:MSG:READ,0-0-1,s=255,c=3,t=25,pt=1,l=1,sg=0:1
              2080 TSF:MSG:PONG RECV,HP=1
              2082 TSM:UPL:OK
              2084 TSM:READY:ID=1,PAR=0,DIS=1
              2089 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
              2098 TSF:MSG:READ,0-0-1,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
              2105 TSF:MSG:SEND,1-1-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.1.1
              2113 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
              2240 TSF:MSG:READ,0-0-1,s=255,c=3,t=6,pt=0,l=1,sg=0:M
              2247 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=11,pt=0,l=22,sg=0,ft=0,st=OK:TemperatureAndHumidity
              2257 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.1
              2266 TSF:MSG:SEND,1-1-0-0,s=0,c=0,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
              2273 TSF:MSG:SEND,1-1-0-0,s=1,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=OK:
              2281 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=11,pt=0,l=5,sg=0,ft=0,st=OK:Relay
              2289 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.0
              2297 TSF:MSG:SEND,1-1-0-0,s=1,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
              2304 MCO:REG:REQ
              2307 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
              2345 TSF:MSG:READ,0-0-1,s=255,c=3,t=27,pt=1,l=1,sg=0:1
              2351 MCO:PIM:NODE REG=1
              2353 MCO:BGN:STP
              2355 MCO:SLP:MS=2000,SMS=0,I1=255,M1=255,I2=255,M2=255
              2360 MCO:SLP:TPD
              2362 MCO:SLP:WUP=-1
              2364 MCO:BGN:INIT OK,TSP=1```
              • MasMatM MasMat
                H Offline
                H Offline
                HenryWhite
                @MasMat said in Sensor dht+relay won't send data or present:
                That's what wait() is for (mysensors specific) , it will not interfere with the radio commumication.
                • MasMatM Offline
                  MasMatM Offline
                  MasMat
                  Thanks for the tip. Good to learn these things as I go.
                  I'm to the point of rebuilding the sensor (or building a duplicate really) to see if this could be a hardware glitch.
                    You could try ethernet gateway instead of mqtt if it works better and move to mqtt later on
                      MasMatM Offline
                      MasMatM Offline
                      MasMat
                      @gohan I cant see the upside to going back since I couldnt get the Ethernet gw working but the mqtt appears to be working AND Domoticz supports it apparently.
                      I did a quick breadboard setup and it seems the problem might be hardware rather than sketch.
                      Question about the wait command: could I use wait (=soooo simple) rather than a millis timer to have a sensor/node be ready to activate a relay at any time but to only send DHT data every 60s or so?
                        sure you can use the wait()
                        • MasMatM Offline
                          MasMatM Offline
                          MasMat
                          To follow up. It was hardware: broken vcc pin on the dht11 corrupted the whole sensor code badly. Resolder and added wait-code, inverted the on-off 0-vs-1 and I have a good working sensor. The duplicate is also installed and working reliably.
                          A 6-relay board is also working nicely and Domoticz is great. My old system is nearly replaced and I couldnt be happier.
                          Respect and thanks all around!
