  3. Secure 5-button keyfob with enclosure (was: 8-button keyfob)
72 Posts 5 Posters 25.7k Views 7 Watching
  • MiKaM
    MiKaM
    MiKa
    Check for inspiration and nice enclosure https://oshpark.com/shared_projects/guV5HKTW Is just missing ATSHA204A
    Regards,
    MiKa
    E 1 Reply Last reply
    • MiKaM MiKa
      Regards,
      MiKa
      E
      E
      elcaron
      @MiKa Hm, having an enclosure ready is a major benefit. Pitty it doesn't have KiCAD files available, so I would have to measure everything ...
      • MiKaM
        MiKaM
        MiKa
        Someone know that guy which one shared pcb on OSH park?
        Would be good to have a kicad project for small editing ;)
        • MiKaM MiKa
          E
          E
          elcaron
          @MiKa I was a little skeptical at first because it seemed the enclosure wasn't that easily available for me in Germany. Now, however, I found out that it seems to be identical to the RND 455-00014 that is e.g. sold at Reichelt for less than 4€. They also have a datasheet with good documentation of the measures. I will not have the keyfob from above made but attempt a redesign over eastern for that enclosure.
          Two questions for the general public:
          • Should I switch to an RFM69? I do not have anything installed yet, so I am free. I understand that range and wall penetration are better, but I am a little worried that the antenna will not fit.
          • Any idea if the contacts for those buttons are an existing footprint in KiCAD?
          AnticimexA 1 Reply Last reply
          • E elcaron
            AnticimexA
            AnticimexA
            Anticimex
            @elcaron I definitely suggest rfm69 because it supports AES encryption in hw and is therefore better suited for security sensitive use (not that encrypting keyfob data makes much sense but anyway...). Also like you say, it has better range. Antenna can probably be coiled. Perhaps a chip antenna could work as well.
            Regarding kicad, it is always possible to make any footprint needed given proper measurements.
            We have official MySensors libraries where the footprints can be stored if created so everyone can benefit from them (perhaps they already exist). See here.
            • AnticimexA Anticimex
              E
              E
              elcaron
              @Anticimex AES is a big plus. I already looked for coiled antennas on Aliexpress and as far as I can see, these will fit into the case. i will make a cutout in the PCB for that. I hope my Reichelt shipment will arrive on Saturday, so I can test it with some coiled 433MHz antennas I have lying around. Diameter is probably the same, I should even be able to clip them off to convert them.
              I know I can make footprints. But if there was a footprint for that type of contact, I would rater use that. Since I am neither a professional nor a native speaker, I don't really have an idea what to look for ...
              Pity that the OSHPark guy chose to name himself after a transistor, that doesn't really make finding him easier ...
              • E
                E
                elcaron
                I have created a 5 button version that fits into the keyfob enclosure. I put the KiCAD project and a dxf file with the PCB measures on GitHub. I'll add an image later.
                https://github.com/kvoit/MySensors_SecureKeyfob/commits/master
                Schematic attached. I would like some comments before I put this into production.0_1492625836524_MySensors_SecureKeyfob.pdf
                • MiKaM
                  MiKaM
                  MiKa
                  Good job!
                  Add also some RGB LED or Fast LED (WS2812B) good place will be on opposit side of the battery ;)
                  MiKa
                  • E
                    E
                    elcaron
                    Yeah, I could do that. No free PWM pins, though. But one could use Software PWM on A0/A1/A7, those woud be easy to route.
                    Any footprint+Aliexpress/EBay link ready for a suitable LED?
                    • MiKaM
                      MiKaM
                      MiKa
                      for example: http://www.tme.eu/sk/details/hsmf-c114/diody-led-smd-farebne/broadcom-avago/ its in 0606 package with common anode
                      • E
                        E
                        elcaron
                        If anybody cares, I have improved a few things - rgb led (choose the standard 505 that is used on RGB strips), impedance to antenna, button footprints ... It is all pushed to Github. There is also a branch with gerbers for a panelized version with v-cuts.
                        I will order it tomorrow evening. (Hint: I'll sit on 60 PCBs for this, soon. Location Germany.)
                        • E elcaron
                          AnticimexA
                          AnticimexA
                          Anticimex
                          @elcaron cool. Do you have atsha204a footprint on them?
                          Edit: of course you do. Sorry for asking such a stupid question :)
                          • E
                            E
                            elcaron
                            wrote on last edited by elcaron
                              E
                              E
                              elcaron
                              @Anticimex Yes, that was the whole point. Someone else already posted a link to a PCB for the same keyfob enclosure without an ATSHA. The ATSHA is next to pin6 of the RFM69.
                              The other PCB also doesn't have dedicated space for an antenny, so I suspect they just somehow shove a wire in there. My design has a cutout for a spring antenna (already tested that it fits into the enclosure), with a defiined 50Ohm impedance trace leading to it.
                              • MiKaM
                                MiKaM
                                MiKa
                                Good work, Thanks!
                                • MiKaM MiKa
                                  Good work, Thanks!
                                  E
                                  E
                                  elcaron
                                  @MiKa Thanks, lets hope so. Did one of you have a close look for issues, at least on the schematic? It's actually my first (MySensors/Ultra low power/THAT small) project.
                                  Anyway, Seeed just dropped the price for 10 10x10cm^2 PCBs to 5$ plus shipping, so there is not much to loose except for 3 weeks waiting. I'll report any success or failure. Until then, the design is to be considered untested.
                                  I'm a little afraid of the TQFP package :) Hope I can handle it with my rework station, don't have a toaster oven ...
                                  • MiKaM
                                    MiKaM
                                    MiKa
                                    I ordered some pieces of PCB 3 days ago based on your repo in Github (before last finalization by You) lets see in 3 weeks :)
                                    TQFP package need just little bit practise and it will be OK :)
                                    Im excited about this project :)
                                    Regards,
                                    MiKa
                                    E 2 Replies Last reply
                                    • MiKaM MiKa
                                      Regards,
                                      MiKa
                                      E
                                      E
                                      elcaron
                                      @MiKa said in Secure 5-button keyfob with enclosure (was: 8-button keyfob):
                                      You should be fine. The antenna might need a little bending at the base, because the cutout didn't fit perfectly, but it is just a matter of <<1mm. The other changes, as far as I remember, were a purely cosmetic shift of the RGB LED and a little modification to keep the clearings for the v-cuts for the panelization.
                                      If you have issues, I could send you a PCB for shipping costs. With the panelization, I'll have more PCBs than I ever could use.
                                      • E
                                        E
                                        elcaron
                                        #26
                                        Since I wanted to get a gateway into the same shipment and only found the shield type gateway for the Wemos D1 Mini, which I didn't like, I quickly clicked together a PCB for that, supporting the RFM69HW (with 50Ohm impedance trace to an SMA connector), the through-hole NRF24L01 module and the SMD version with the ceramic antenna. (And of course an ATSHA204A.)
                                        It can be powered over the D1 Mini or alternatively with up to 24V over a switching regulator.
                                        I guess there are dozens of those things around, so I won't spam another topic (as long as nobody disagrees), but I'll put it here for completeness.
                                        https://github.com/kvoit/MySensors_SecureD1MiniGateway
                                        • MiKaM
                                          MiKaM
                                          MiKa
                                          You created it for some enclosure? (MySensors_SecureD1MiniGateway)
