  3. Gateway Backup
Gateway Backup
10 Posts 4 Posters 3.4k Views 4 Watching
  • CrankyCoderC Offline
    CrankyCoder
    Let's say I have a raspberry pi running as my gateway, and it's running as mqtt client gateway.
    Lets also say i have a second pi configured the same way. Is there anything that would prevent me from, in the event of pi1 dying, just powering on pi2 and everything continuing to work?
    Home Automation Tinkerer
    www.CrankyCoder.net
    Gateway: MQTTClientGateway
    MySensors: 2.3
    • CrankyCoderC CrankyCoder
      @CrankyCoder if both rpis are in the same location, doing what you describe should work just fine. The gateway does not store any state except the routing table.
        If you schedule a backup of the controller configuration and data, you restore those in the second rpi and you are good to go. Also swapping SD card should work just fine, given it didn't get corrupted when the first rpi died
          CrankyCoder
          This is good news. I think I could create a failover scenario to have a backup gateway in the same fashion I did with failover openhab.
          www.CrankyCoder.net
          MySensors: 2.3
          • J Offline
            J Offline
            Jan Gatzke
            This will work. You could even automate it with a heartbeat cluster. :D
              CrankyCoder
              That's what I did with my openhab setup. This could help my "single point of failure" phobia lol
              www.CrankyCoder.net
              MySensors: 2.3
                Maybe you could write a guide on how you did it :)
                CrankyCoderC 1 Reply Last reply
                • J Offline
                  J Offline
                  Jan Gatzke
                  especially the synchronisation of the database would be interesting.
                    CrankyCoder
                    @gohan how i did my openhab failover?
                    http://crankycoder.net/2015/11/13/home-automation-move-part-1/
                    http://crankycoder.net/2015/11/15/home-automation-move-part-2/
                    http://crankycoder.net/2016/01/24/openhab-crashing-with-z-wave-fix-it-fix-it-fix-it-fix-it/
                    Hope that helps :)
                    Will have to do another one if i do the multiple mysensors gateways :)
                    www.CrankyCoder.net
                    MySensors: 2.3
                    • J Jan Gatzke
                      CrankyCoder
                      @Jan-Gatzke I haven't messed with the pi gateway yet, but I am thinking maybe doing something like drbd (disk replication)
                      www.CrankyCoder.net
                      MySensors: 2.3
