  3. SCT-013-030 current monitor sensor
65 Posts 16 Posters 58.6k Views 15 Watching
  • fredokF fredok
    its seem good kWh every 2min
    1864W is the power value
    send(IrmsMsg1.set(intrms * 232.0, 1));
    the sketch send power value P (in W) and energy (in kWh) calculated over 2min.
    double energie = (intrms * 232.0 * SEND_FREQUENCY / 1000) / 3.6E6;
    // and after
    nrj1 += energie;
    send(kWhMsg1.set(nrj1, 5));
    in domoticz i have one "dispositif" included instant power Watt and day cumulate energy kWh
    bye
    warmaniacW
    warmaniacW
    warmaniac
    @fredok
    Thank you very much! Only one question left, with multimeter I measured my voltage 241.0 V could I update it in sketch or ?
    • fredokF
      fredokF
      fredok
      a clamp measure only intensity I (in A) and Power =UrmsxIrms so if in u home Urms=241V u can change with this value but the power measurment not consider cosphy
      by example the power measurment of my fridge =257W but true value is (with cosphy) 257x0,56=....W
      so if u change 232V with 241V why not but at the end its will continu to be a approximate of the true power.
      bye
      warmaniacW 1 Reply Last reply
      • fredokF fredok
        bye
        warmaniacW
        warmaniacW
        warmaniac
        @fredok
        Okay :) understand now, and what about calibration for wiring I followig this site
        https://learn.openenergymonitor.org/electricity-monitoring/ct-sensors/how-to-build-an-arduino-energy-monitor-measuring-current-only?redirected=true
        And they calibrate
         emon1.current(1, 111.1);
        And yours calibration
          emon1.current(PIN_ANALOG_I1, 30.0);
        Is some difference after this calibrations in measuring ?
          They also have the same sensor with also voltage measurement for a more accurate reading
            warmaniacW
            warmaniacW
            warmaniac
            @gohan
            Because with test sketch from that site I get actual consumption 0,5 kWh but from mysensors sketch I get much higher values look
            0_1490962213606_upload-ed834413-8133-438b-8e2a-95c017b3f33c
            1,7 kWh per one hour is too much , I had only TV and fridge in power on mode, I had total consumption per last year about 2140 kWh , which is about 6 kWh per day.
            • fredokF
              fredokF
              fredok
              hello,
              1. the constant 30 is the divide between ratio/burden resistor including inside the clamp
                for me ration=1800 and R=62ohm (1800/62 approx 30)
                http://www.planete-domotique.com/notices/S/C/SCT013-030V.pdf
              2. i can see 1677 Wh=1,677 kWh ... but 1900W for only TV+fridge its many
                mine clamp2 log in domoticz
              3. Maybe it can help u??? i have a pulse powercounter count every flash (1 Wh of energy) of mine electric box and the power (Watt) send to gw is wrong in domoticz but the energy counting (kWh) is great.
                Where come the wrong of fake power (GW ? sketch ? domoticz , i dont know)
                bye
              • fredokF fredok
                hello,
                  bye
                warmaniacW
                warmaniacW
                warmaniac
                @fredok
                I had SCT-013-000 , not SCT-013-030 maybe this is the problem of measuring .
                • warmaniacW
                  warmaniacW
                  warmaniac
                  updated my sketch with new values for SCT-013-00 result is now
                  // EmonLibrary examples openenergymonitor.org, Licence GNU GPL V3  ***/
                  #include "EmonLib.h"             // Include Emon Library
                  EnergyMonitor emon1;             // Create an instance
                  #define CHILD_ID_CLAMP1 0
                  #define PIN_ANALOG_I1 A1 //pince amperemetrique1
                  unsigned long lastSend_power = millis();
                  unsigned long lastSend_c = millis();
                  unsigned long SEND_FREQUENCY = 120000; // Minimum time between send (in milliseconds). We don't wnat to spam the gateway.
                  unsigned long SEND_FREQUENCY_C = SEND_FREQUENCY / 30;
                  int index = 0;
                  double Irms1 = 0;
                  boolean pcReceived1 = false;
                  float nrj1 = 0, old_nrj1;
                  MyMessage IrmsMsg1(CHILD_ID_CLAMP1, V_WATT);
                  MyMessage kWhMsg1(CHILD_ID_CLAMP1, V_KWH);
                  MyMessage pcMsg1(CHILD_ID_CLAMP1, V_VAR1);
                  void before() {
                    sendSketchInfo("Multisensors_Entree", "2.0");  // Send the sketch version information to the gateway and Controller
                    present(CHILD_ID_CLAMP1, S_POWER);   // Register this device as power sensor
                    request(CHILD_ID_CLAMP1, V_VAR1);
                    if (message.type == V_VAR1)
                      nrj1 = old_nrj1 = message.getFloat();
                      Serial.print("Received last nrj count from gw:");
                      Serial.println(nrj1);
                      pcReceived1 = true;
                    emon1.current(PIN_ANALOG_I1, 111.1);       // Current: input pin, calibration.
                    Serial.println("SETUP completed");
                  void envoi_donnees(double intrms, int id_clamp)
                    Serial.print("Envoi des donnees .... clamp="); Serial.println(id_clamp);
                    double energie = (intrms * 240.0 * SEND_FREQUENCY / 1000) / 3.6E6;
                    switch (id_clamp) //can be modified ...
                      case 1:
                          send(IrmsMsg1.set(intrms * 240.0, 1));
                          nrj1 += energie;
                          send(pcMsg1.set(nrj1, 5));
                          old_nrj1 = nrj1;
                    unsigned long now = millis();
                    bool sendTime_c = now - lastSend_c > SEND_FREQUENCY_C;
                    // Calcul de Irms1 et Irms2
                    if (sendTime_c) //calcul Irms moy clamp1/clamp2
                      if (index == 0)
                        Irms1 = emon1.calcIrms(1480);
                        Irms1 = (index * Irms1 + emon1.calcIrms(1480)) / (index + 1);
                      lastSend_c = now;
                      index++;
                  bool sendTime_power = now - lastSend_power > SEND_FREQUENCY;
                   if (sendTime_power)
                    // Envoi ou request Puissance1
                    if (pcReceived1) envoi_donnees(Irms1, 1);
                    else     {
                      Serial.println("Request VAR1");
                    //on reinitialise les compteurs
                    lastSend_power = now;
                    index = 0;
                  0_1490992284051_upload-583cafbf-bd94-4bad-8fd3-8c510f5cfbfc
                  • fredokF
                    fredokF
                    fredok
                    great !!!!!
                    • B
                      B
                      brahim
                      Hi , i update your sketch for Multiple sensor
                      #include <EmonLib.h>
                      #define SERIAL_BAUD 115200
                      #define PIN_ANALOG_I1 A0   // The input you attached SCT1.
                      #define PIN_ANALOG_I2 A1   // The input you attached SCT2.
                      #define PIN_ANALOG_I3 A2   // The input you attached SCT3.
                      #define CHILD_ID_WATT 0    // child-id of sensor
                      #define CHILD_ID_KWH  1    // child-id of sensor
                      #define CHILD_ID_VAR1 2    // child-id of sensor
                      #define MAX_CT 3           // Number of CT sensor
                      EnergyMonitor ct1, ct2, ct3;
                      MyMessage msgWatt(CHILD_ID_WATT,V_WATT);
                      MyMessage msgKwh(CHILD_ID_KWH,V_KWH);
                      MyMessage msgVar(CHILD_ID_VAR1,V_VAR1);
                      unsigned long SEND_FREQUENCY   = 60000;               // 1 mn Minimum time between send (in milliseconds).
                      unsigned long FREQUENCY_SAMPLE = SEND_FREQUENCY / 12 ; // ( 5 s)
                      #define MAX_CT 3
                      double  Irms[MAX_CT];
                      float   nrj[MAX_CT];
                      boolean pcReceived[MAX_CT];
                      int    index = 0;
                      #ifdef MY_DEBUG
                        Serial.begin(SERIAL_BAUD);
                        Serial.println("Begin SETUP");
                        //ct1.current(PIN_ANALOG_I1, 111.1);     // Current: input pin, calibration.
                        ct1.current(PIN_ANALOG_I1, 60);          // current constant = (100 ÷ 0.050) ÷ 33 Homs = 60
                        ct2.current(PIN_ANALOG_I2, 60);
                        ct3.current(PIN_ANALOG_I3, 60);
                        Irms[0] = ct1.calcIrms(1480);            // initial boot to charge up capacitor (no reading is taken) - testing
                        Irms[1] = ct2.calcIrms(1480);
                        Irms[2] = ct3.calcIrms(1480);
                        for (int i=0; i<MAX_CT; i++) {
                             Irms[i] = nrj[i] = 0;
                             pcReceived[i]=false;
                      #ifdef MY_DEBUG
                        sendSketchInfo("Energy Meter", "2.1");
                        present(0, S_POWER);
                        request(0, V_VAR1);
                        present(1, S_POWER);
                        request(1, V_VAR1);
                        present(2, S_POWER);
                        request(2, V_VAR1);
                        int SensorID ;
                        SensorID = message.sensor ;
                        if (message.type == V_VAR1) {
                            nrj[SensorID] =  message.getFloat();
                            pcReceived[SensorID] = true;
                      #ifdef MY_DEBUG
                            Serial.print("Received last nrj[");
                            Serial.print(SensorID);
                            Serial.print("] count from GW:");
                            Serial.println(nrj[SensorID]);
                      void send_data(double intrms, int SensorID) {
                      #ifdef MY_DEBUG
                        Serial.print("Send data for SensorID=");
                        Serial.println(SensorID);
                        nrj[SensorID] += energie;
                        send(msgWatt.setSensor(SensorID).set(intrms * 240.0, 1));
                        send(msgKwh.setSensor(SensorID).set(nrj[SensorID], 5));
                        send(msgVar.setSensor(SensorID).set(nrj[SensorID], 5));
                        double _Irms[MAX_CT];
                        bool sendTime_c = now - lastSend_c > FREQUENCY_SAMPLE;
                        if (sendTime_c)
                          _Irms[0] = ct1.calcIrms(1480) ; if (_Irms[0] < 0.3) _Irms[0] = 0;
                          _Irms[1] = ct2.calcIrms(1480) ; if (_Irms[1] < 0.3) _Irms[1] = 0;
                          _Irms[2] = ct3.calcIrms(1480) ; if (_Irms[2] < 0.3) _Irms[2] = 0;
                          Irms[0] = (index * Irms[0] + _Irms[0]) / (index + 1);
                          Irms[1] = (index * Irms[1] + _Irms[1]) / (index + 1);
                          Irms[2] = (index * Irms[2] + _Irms[2]) / (index + 1);
                          lastSend_c = now;
                          index++;
                      #ifdef MY_DEBUG
                              Serial.print("CT");
                              Serial.print(i);  Serial.print(" : ");
                              Serial.print(Irms[i]*240.0);  // Apparent power
                              Serial.print(" ");
                              Serial.println(Irms[i]);      // Irms
                        if (sendTime_power)
                             if (pcReceived[i])
                               send_data(Irms[i], i);
                               request(i, V_VAR1);
                          index = 0;
                      • fredokF
                        fredokF
                        fredok
                        fine thx....
