  3. 💬 NodeManager
💬 NodeManager
contest2017arduinonewbiemysensorsbattery sensor
196 Posts 42 Posters 117.0k Views 41 Watching
  • K ksga
    @user2684 Yeah.. missed that it rebooted... Thanks.
    I cleared EEPROM again, recompiled with and without debug (no usable result without, so decided to add eyes again :) )
    void before() part of the sketch looks like this:
    // before
    void before() {
      Serial.begin(MY_BAUD_RATE);
       * Register below your sensors
      nodeManager.setSleep(SLEEP,1,MINUTES);
      nodeManager.registerSensor(SENSOR_BH1750);
      nodeManager.registerSensor(SENSOR_BME280);
       * Register above your sensors
      nodeManager.before();
    and config.h:
     * NodeManager configuration
    // if enabled, enable debug messages on serial port
    #define DEBUG 1
    //#define DEBUG 0
    // if enabled, will load the sleep manager library. Sleep mode and sleep interval have to be configured to make the board sleeping/waiting
    #define SLEEP_MANAGER 1
    // if enabled, enable the capability to power on sensors with the arduino's pins to save battery while sleeping
    #define POWER_MANAGER 0
    // if enabled, will load the battery manager library to allow the battery level to be reported automatically or on demand
    #define BATTERY_MANAGER 0
    // if enabled, allow modifying the configuration remotely by interacting with the configuration child id
    #define REMOTE_CONFIGURATION 1
    // if enabled, persist the remote configuration settings on EEPROM
    #define PERSIST 0
    // if enabled, send a SLEEPING and AWAKE service messages just before entering and just after leaving a sleep cycle and STARTED when starting/rebooting
    #define SERVICE_MESSAGES 0
    // if enabled, a battery sensor will be created at BATTERY_CHILD_ID and will report vcc voltage together with the battery level percentage
    #define BATTERY_SENSOR 0
    // Enable this module to use one of the following sensors: SENSOR_ANALOG_INPUT, SENSOR_LDR, SENSOR_THERMISTOR, SENSOR_MQ, SENSOR_ML8511
    #define MODULE_ANALOG_INPUT 1
    // Enable this module to use one of the following sensors: SENSOR_DIGITAL_INPUT
    #define MODULE_DIGITAL_INPUT 1
    // Enable this module to use one of the following sensors: SENSOR_DIGITAL_OUTPUT, SENSOR_RELAY, SENSOR_LATCHING_RELAY
    #define MODULE_DIGITAL_OUTPUT 1
    // Enable this module to use one of the following sensors: SENSOR_DHT11, SENSOR_DHT22
    #define MODULE_DHT 0
    // Enable this module to use one of the following sensors: SENSOR_SHT21
    #define MODULE_SHT21 0
    // Enable this module to use one of the following sensors: SENSOR_SWITCH, SENSOR_DOOR, SENSOR_MOTION
    #define MODULE_SWITCH 0
    // Enable this module to use one of the following sensors: SENSOR_DS18B20
    #define MODULE_DS18B20 0
    // Enable this module to use one of the following sensors: SENSOR_BH1750
    #define MODULE_BH1750 1
    // Enable this module to use one of the following sensors: SENSOR_MLX90614
    #define MODULE_MLX90614 0
    // Enable this module to use one of the following sensors: SENSOR_BME280
    #define MODULE_BME280 1
    The serial output seems to show no reboot this time ;):
    REG I=1 P=18 P=16 T=37
    REG I=2 P=18 P=6 T=0
    REG I=3 P=18 P=7 T=1
    REG I=4 P=18 P=8 T=4
    NodeManager v1.4
    INT1 M=255
    INT2 M=255
    RADIO OK
    PRES I=200, T=23
    PRES I=1 T=16
    PRES I=2 T=6
    PRES I=3 T=7
    PRES I=4 T=8
    READY
    MY I=3 M=1
    BH1 I=1 L=-10924
    BME I=2 T=0.00
    SEND D=0 I=2 C=0 T=0 S= N=0 F=0.00
    BME I=3 H=0.00
    SEND D=0 I=3 C=0 T=1 S= N=0 F=0.00
    BME I=4 P=-793.67
    SLEEP 60s
    AWAKE
    BH1 I=1 L=-10924
    BME I=2 T=0.00
    SEND D=0 I=2 C=1 T=0 S= N=0 F=0.00
    BME I=3 H=0.00
    SEND D=0 I=3 C=1 T=1 S= N=0 F=0.00
    BME I=4 P=-793.67
    SLEEP 60s
    I would guess there should be enough memory on the arduino:
    Sketch uses 26.024 bytes (80%) of program storage space. Maximum is 32.256 bytes.
    Global variables use 1.262 bytes (61%) of dynamic memory, leaving 786 bytes for local variables. Maximum is 2.048 bytes.
    Definately not fixed :(
    Maybe I could try adding support for the alternative BME library to NodeManager...
    U
    U
    user2684
    @ksga thanks for running this additional test! I don't like that -10924 for the BH1750 which looks to me like a random value and not impacted by the BME280 library you are using if I've understood correctly. This makes me still think of a memory issue: despite the sketch is not consuming all the memory, both the BME280 and BH1750 objects are allocated dynamically in the code so would not count against that percentage I'm afraid.
    Let's start by disabling MODULE_ANALOG_INPUT, MODULE_DIGITAL_INPUT and MODULE_DIGITAL_OUTPUT to save some more memory. Then I'd still try disabling NodeManager's debug: the serial output would be blank of course but on the controller you should see if the the measures reported will look better. I just want to be sure it is not a memory issue (which typically shows up as random reboots and random values) before moving ahead and troubleshoot the library you are using.
    K 1 Reply Last reply
    • U user2684
      K
      K
      ksga
      wrote on last edited by ksga
      #27
      @user2684 Sorry about the delay - but life claimed some time (stupid life claiming time I want to use for stuff :-| )
      Disabled MODULE_ANALOG_INPUT, MODULE_DIGITAL_INPUT and MODULE_DIGITAL_OUTPUT, and even tried without BH1750 - but still no luck.
      Node registers correctly and fires bogus data on one or two sensors...
      Pretty sure I have to use the other library - tried using Adafruit's examples, and it claims no BME is attached...
      I can make all the logic changes to NodeManager, but have not been able to initialize the sensor - maybe I could upload my edits to Git and someone could help me get the last bits together ???
      Made the changes here.
      U 1 Reply Last reply
      • Ivan ZI
        Ivan ZI
        Ivan Z
        Double comment in NodeMamaged.h - setBatteryInternalVcc
        • Ivan ZI
          Ivan ZI
          Ivan Z
          Please use IFDEF for "Battery procetage"
          I calculate this in the controller (Save battery)
          • K ksga
            U
            U
            user2684
            @ksga said in 💬 NodeManager:
            Thanks for digging into it! I just want to be sure with the Adafruit library I'm using you can get the sensor working before evaluating and integrating the other library. As far as I remember during my tests I got a similar issue and if I'm not wrong this is because the chinese version of the BME sensor is on the 0x76 address instead of the 0x77 Adafruit's. Try if you don't mind with the plain Adafruit example and passing the address to begin() to see if you get better results. Thanks!
            • Ivan ZI Ivan Z
              U
              U
              user2684
              @Ivan-Z said in 💬 NodeManager:
              Do you mean the formula to calculate the percentage? If so, the issue is that the min and max can be defined in the code by the user so I cannot use the preprocessor to do the job. Am I wrong? Regarding the double comment of setBatteryInternalVcc(), I cannot find it, may you please point me out to the affected line numbers? Thanks!
              Ivan ZI 1 Reply Last reply
              • U user2684
                Ivan ZI
                Ivan ZI
                Ivan Z
                @user2684
                Function name alt text
                Append flag IFDEF for not send this information (Only voltage)
                • Ivan ZI
                  Ivan ZI
                  Ivan Z
                  Sorry, not fully read text
                  • Ivan ZI
                    Ivan ZI
                    Ivan Z
                    What about BMP085 ??
                    • Ivan ZI Ivan Z
                      @user2684
                      U
                      U
                      user2684
                      @Ivan-Z oh I see about the comment but they are correct because both setBatteryPin() and setBatteryVoltsPerBit() applies only if setBatteryInternalVcc() is set to false.
                      Regarding the ifdef thing, the behavior right now is to send percentage by default with sendBatteryLevel() and optionally the battery voltage through the custom service. I'd prefer to keep it in this way since sendBatteryLevel() is the part of the core MySensors api, I'd rather make it mandatory. Thanks!
                      • Ivan ZI Ivan Z
                        U
                        U
                        user2684
                        I've ordered one and waiting for its delivery :-)
                        • Ivan ZI
                          Ivan ZI
                          Ivan Z
                          wrote on last edited by Ivan Z
                          #37
                          Why did you use the REQ type for the relay?
                          Please add support for SET too
                          REQ - nide to read Relay status
                          • B
                            B
                            bilbolodz
                            It's already requested feature:
                            https://github.com/mysensors/NodeManager/issues/73
                            and it will be done.
                            • core_cC
                              core_cC
                              core_c
                              very clean coding.. i like it.
                              Well done. :cool:
                              • U
                                U
                                user2684
                                Hello, I think I was able to implement most of the requests discussed here during the last few weeks in a pre-release v1.5 version. Please consider it still as a dev release which gone through very limited testing but since I had to make quite a few changes to core code, would be great to start collecting some feedback now.
                                Is is available here: https://github.com/mysensors/NodeManager/tree/9a485cdcaf8e9856219338553335e2dce7253eb3
                                It is complicated to reference each of you who requested something so please whoever is interested the full list of new additions/fixes is available here https://github.com/mysensors/NodeManager/milestone/5?closed=1. I did my best to add verbose comments so you should find all the details there. Please add any comment and report any problem directly to the existing issues on github so I can better understand the context. The documentation has been updated as well.
                                • U user2684
                                  K
                                  K
                                  ksga
                                  @user2684
                                  Tried again with adafruits library and got it working changing the address.
                                  But still can't get any useful data from it using NodeManager.
                                  Did a bit of copy/paste and got this code working (with adafruit and the alternative library):
                                  #include <BH1750.h>
                                  #include <BME280I2C.h>
                                  #define BARO_CHILD 0
                                  #define TEMP_CHILD 1
                                  #define HUM_CHILD 2
                                  #define CHILD_ID_LIGHT 3
                                  #define R1 687000
                                  #define R2 222000
                                  #define VMIN 3.30
                                  #define VMAX 4.18
                                  #define ADC_PRECISION 1023
                                  #define VREF 1.107
                                  unsigned long SLEEP_TIME = 300000;
                                  const float ALTITUDE = 10;
                                  BME280I2C bme;
                                  BH1750 lightSensor;
                                  MyMessage humMsg(HUM_CHILD, V_HUM);
                                  MyMessage lightMsg(CHILD_ID_LIGHT, V_LEVEL);
                                  float lastbaro = -1;
                                  float lasttemp = -1;
                                  float lasthum = -1;
                                  float lastlux = -1;
                                  float oldBatteryPcnt = -1;
                                  int BATTERY_SENSE_PIN = A0;
                                    lightSensor.begin();
                                    bme.begin();
                                    analogReference(INTERNAL);
                                    pinMode(BATTERY_SENSE_PIN, INPUT);
                                    delay(100);
                                    sendSketchInfo("BME280_BH1750", "1.1");
                                    present(BARO_CHILD, S_BARO);
                                    present(TEMP_CHILD, S_TEMP);
                                    present(HUM_CHILD, S_HUM);
                                    float baro_local = bme.pres() / 100.0;
                                    float baro = ( baro_local / pow((1.0 - ( ALTITUDE / 44330.0 )), 5.255));
                                    if (baro != lastbaro) {
                                        send(pressureMsg.set(baro,2));
                                        lastbaro = baro;
                                    float temp = bme.temp();
                                    if (temp != lasttemp) {
                                        send(tempMsg.set(temp,1));
                                        lasttemp = temp;
                                    float hum = bme.hum();
                                    if (hum != lasthum) {
                                        send(humMsg.set(hum,1));
                                        lasthum = hum;
                                    float lux = lightSensor.readLightLevel();
                                    if (lux != lastlux) {
                                        send(lightMsg.set(lux,0));
                                        lastlux = lux;
                                    float batteryPcnt = getBatteryPercentage();
                                    // Power up radio after sleep
                                    oldBatteryPcnt = batteryPcnt;
                                    sleep(SLEEP_TIME);
                                  float getBatteryPercentage()
                                  delay(500);
                                  int inputValue = analogRead(BATTERY_SENSE_PIN);
                                  float voltageDividerFactor = (R1 + R2) / R2;
                                  float maxValue = voltageDividerFactor * VREF;
                                  float voltsPerBit = maxValue / ADC_PRECISION;
                                  float batteryVoltage = voltsPerBit * inputValue;
                                  float batteryPercentage = ((batteryVoltage-VMIN)/(VMAX-VMIN))*100;
                                  return batteryPercentage;
                                  • K ksga
                                    @user2684
                                    #include <BH1750.h>
                                    #define HUM_CHILD 2
                                    #define R1 687000
                                    #define R2 222000
                                    #define VMIN 3.30
                                    #define VMAX 4.18
                                    #define VREF 1.107
                                    BME280I2C bme;
                                    BH1750 lightSensor;
                                    float lasthum = -1;
                                    float lastlux = -1;
                                      bme.begin();
                                      delay(100);
                                          lastbaro = baro;
                                          lasttemp = temp;
                                          lasthum = hum;
                                          lastlux = lux;
                                      sleep(SLEEP_TIME);
                                    delay(500);
                                    U
                                    U
                                    user2684
                                    @ksga I have no problem in adding this other alternative library in NodeManager but it is really strange it is working for you with the adafruit library but not in NodeManager which is using the same library :-/ Did you set the same address in NodeManager's as well? Can you share the sketch you got it working with the Adafruit library so I can compare the code and see what I do differently in NodeManager preventing it to work for you? Thanks!
                                    • core_cC
                                      core_cC
                                      core_c
                                      I have a BMP280 sensor (as far as i know, they are quite similar). At first it seemed like the sensor was not detected. After inspecting the datasheet, i found out that the address could be selected (one of 2 possibilities).
                                      Here's the text from the datasheet:
                                      Connecting SDO to GND results in slave
                                      address 1110110 (0x76); connection it to VDDIO results in slave address 1110111 (0x77)
                                      Some people change the library code, but (like in my case), i only needed to connect the SDO pin to +3.3V.
                                      At first i did not connect the SDO pin at all, and my sensor was not reporting at all. That was because of this:
                                      The SDO pin cannot be left floating; if left floating, the
                                      I²C address will be undefined.
                                      Perhaps those issues can be the cause of your problems ksga?
                                      • core_cC core_c
                                        U
                                        U
                                        user2684
                                        @core_c this is what I was thinking of as well. Right now in NodeManager the only way to change the i2c address is to change the core code under registerSensor() in NodeManager.cpp which is not handy. I need to find out how to provide an easy way to set it. The problem is registerSensor() takes a fixed number of parameters (and I want it to stay in this way) and it is responsible to create the bmp/bme object, passing it to the 2-3 child sensors. I can provide a setAddress() function but the user needs just after to retrieve each sensor (temperature, humidity, pressure, etc.) and set it manually which is not not great.
                                        I've opened https://github.com/mysensors/NodeManager/issues/85 for this which is needed regardless. Thanks
                                        • U user2684
                                          U
                                          U
                                          user2684
                                          @core_c found a great way to to let NodeManager identifying automatically which i2c address the sensor is using without the need for the user to change anything in the code. This is done by requesting the chip_id for the two i2c address and comparing it with the expected one to identify the right address. I've implemented it for both the BME280 and BMP085/BMP180 sensors and it is available in 1.5-dev3 (https://github.com/mysensors/NodeManager/tree/702a05c7e2f4425c188d5abf62b4a119fea29bc8). Also, under the hood, I've created a SensorBosch class which is not exposed but helps providing common functionalities to the two sensors without duplicating the code.
                                          Finally, specifically for your problem @ksga, I found a critical bug in the BME280 class. I wonder how I've missed it so far. For some unknown reasons, the bme object created by registerSensor and passed to the SensorBME280 class, was not stored by the latter. This means it was calling e.g. readTemperature on a null pointer which I even wonder why was not crashing everything. It has been fixed in 1.5-dev3 so if you would like to give it a try, I'm more confident it will work just fine finally :-)
