  3. 💬 NodeManager
💬 NodeManager
contest2017arduinonewbiemysensorsbattery sensor
196 Posts 42 Posters 117.0k Views 41 Watching
  • Ivan ZI
    Ivan ZI
    Ivan Z
    Sorry, not fully read text
    • Ivan ZI
      Ivan ZI
      Ivan Z
      What about BMP085 ??
      U 1 Reply Last reply
      • Ivan ZI Ivan Z
        @user2684
        Function name alt text
        Do you mean the formula to calculate the percentage?
        Append flag IFDEF for not send this information (Only voltage)
        U
        U
        user2684
        @Ivan-Z oh I see about the comment but they are correct because both setBatteryPin() and setBatteryVoltsPerBit() applies only if setBatteryInternalVcc() is set to false.
        Regarding the ifdef thing, the behavior right now is to send percentage by default with sendBatteryLevel() and optionally the battery voltage through the custom service. I'd prefer to keep it in this way since sendBatteryLevel() is the part of the core MySensors api, I'd rather make it mandatory. Thanks!
        • Ivan ZI Ivan Z
          U
          U
          user2684
          @Ivan-Z said in 💬 NodeManager:
          I've ordered one and waiting for its delivery :-)
          • Ivan ZI
            Ivan ZI
            Ivan Z
            wrote on last edited by Ivan Z
            #37
            Why did you use the REQ type for the relay?
            Please add support for SET too
            REQ - nide to read Relay status
            • B
              B
              bilbolodz
              It's already requested feature:
              https://github.com/mysensors/NodeManager/issues/73
              and it will be done.
              • core_cC
                core_cC
                core_c
                very clean coding.. i like it.
                Well done. :cool:
                • U
                  U
                  user2684
                  Hello, I think I was able to implement most of the requests discussed here during the last few weeks in a pre-release v1.5 version. Please consider it still as a dev release which gone through very limited testing but since I had to make quite a few changes to core code, would be great to start collecting some feedback now.
                  Is is available here: https://github.com/mysensors/NodeManager/tree/9a485cdcaf8e9856219338553335e2dce7253eb3
                  It is complicated to reference each of you who requested something so please whoever is interested the full list of new additions/fixes is available here https://github.com/mysensors/NodeManager/milestone/5?closed=1. I did my best to add verbose comments so you should find all the details there. Please add any comment and report any problem directly to the existing issues on github so I can better understand the context. The documentation has been updated as well.
                  • U user2684
                    @ksga said in 💬 NodeManager:
                    Pretty sure I have to use the other library - tried using Adafruit's examples, and it claims no BME is attached...
                    Thanks for digging into it! I just want to be sure with the Adafruit library I'm using you can get the sensor working before evaluating and integrating the other library. As far as I remember during my tests I got a similar issue and if I'm not wrong this is because the chinese version of the BME sensor is on the 0x76 address instead of the 0x77 Adafruit's. Try if you don't mind with the plain Adafruit example and passing the address to begin() to see if you get better results. Thanks!
                    K
                    K
                    ksga
                    @user2684
                    Tried again with adafruits library and got it working changing the address.
                    But still can't get any useful data from it using NodeManager.
                    Did a bit of copy/paste and got this code working (with adafruit and the alternative library):
                    #include <BH1750.h>
                    #include <BME280I2C.h>
                    #define BARO_CHILD 0
                    #define TEMP_CHILD 1
                    #define HUM_CHILD 2
                    #define CHILD_ID_LIGHT 3
                    #define R1 687000
                    #define R2 222000
                    #define VMIN 3.30
                    #define VMAX 4.18
                    #define ADC_PRECISION 1023
                    #define VREF 1.107
                    unsigned long SLEEP_TIME = 300000;
                    const float ALTITUDE = 10;
                    BME280I2C bme;
                    BH1750 lightSensor;
                    MyMessage humMsg(HUM_CHILD, V_HUM);
                    MyMessage lightMsg(CHILD_ID_LIGHT, V_LEVEL);
                    float lastbaro = -1;
                    float lasttemp = -1;
                    float lasthum = -1;
                    float lastlux = -1;
                    float oldBatteryPcnt = -1;
                    int BATTERY_SENSE_PIN = A0;
                      lightSensor.begin();
                      bme.begin();
                      analogReference(INTERNAL);
                      pinMode(BATTERY_SENSE_PIN, INPUT);
                      delay(100);
                      sendSketchInfo("BME280_BH1750", "1.1");
                      present(BARO_CHILD, S_BARO);
                      present(TEMP_CHILD, S_TEMP);
                      present(HUM_CHILD, S_HUM);
                      float baro_local = bme.pres() / 100.0;
                      float baro = ( baro_local / pow((1.0 - ( ALTITUDE / 44330.0 )), 5.255));
                      if (baro != lastbaro) {
                          send(pressureMsg.set(baro,2));
                          lastbaro = baro;
                      float temp = bme.temp();
                      if (temp != lasttemp) {
                          send(tempMsg.set(temp,1));
                          lasttemp = temp;
                      float hum = bme.hum();
                      if (hum != lasthum) {
                          send(humMsg.set(hum,1));
                          lasthum = hum;
                      float lux = lightSensor.readLightLevel();
                      if (lux != lastlux) {
                          send(lightMsg.set(lux,0));
                          lastlux = lux;
                      float batteryPcnt = getBatteryPercentage();
                      // Power up radio after sleep
                      oldBatteryPcnt = batteryPcnt;
                      sleep(SLEEP_TIME);
                    float getBatteryPercentage()
                    delay(500);
                    int inputValue = analogRead(BATTERY_SENSE_PIN);
                    float voltageDividerFactor = (R1 + R2) / R2;
                    float maxValue = voltageDividerFactor * VREF;
                    float voltsPerBit = maxValue / ADC_PRECISION;
                    float batteryVoltage = voltsPerBit * inputValue;
                    float batteryPercentage = ((batteryVoltage-VMIN)/(VMAX-VMIN))*100;
                    return batteryPercentage;
                    • K ksga
                      @user2684
                      #include <BH1750.h>
                      #define HUM_CHILD 2
                      #define R1 687000
                      #define R2 222000
                      #define VMIN 3.30
                      #define VMAX 4.18
                      #define VREF 1.107
                      BME280I2C bme;
                      BH1750 lightSensor;
                      float lasthum = -1;
                      float lastlux = -1;
                        bme.begin();
                        delay(100);
                            lastbaro = baro;
                            lasttemp = temp;
                            lasthum = hum;
                            lastlux = lux;
                        sleep(SLEEP_TIME);
                      delay(500);
                      U
                      U
                      user2684
                      @ksga I have no problem in adding this other alternative library in NodeManager but it is really strange it is working for you with the adafruit library but not in NodeManager which is using the same library :-/ Did you set the same address in NodeManager's as well? Can you share the sketch you got it working with the Adafruit library so I can compare the code and see what I do differently in NodeManager preventing it to work for you? Thanks!
                      • core_cC
                        core_cC
                        core_c
                        I have a BMP280 sensor (as far as i know, they are quite similar). At first it seemed like the sensor was not detected. After inspecting the datasheet, i found out that the address could be selected (one of 2 possibilities).
                        Here's the text from the datasheet:
                        Connecting SDO to GND results in slave
                        address 1110110 (0x76); connection it to VDDIO results in slave address 1110111 (0x77)
                        Some people change the library code, but (like in my case), i only needed to connect the SDO pin to +3.3V.
                        At first i did not connect the SDO pin at all, and my sensor was not reporting at all. That was because of this:
                        The SDO pin cannot be left floating; if left floating, the
                        I²C address will be undefined.
                        Perhaps those issues can be the cause of your problems ksga?
                        • core_cC core_c
                          U
                          U
                          user2684
                          @core_c this is what I was thinking of as well. Right now in NodeManager the only way to change the i2c address is to change the core code under registerSensor() in NodeManager.cpp which is not handy. I need to find out how to provide an easy way to set it. The problem is registerSensor() takes a fixed number of parameters (and I want it to stay in this way) and it is responsible to create the bmp/bme object, passing it to the 2-3 child sensors. I can provide a setAddress() function but the user needs just after to retrieve each sensor (temperature, humidity, pressure, etc.) and set it manually which is not not great.
                          I've opened https://github.com/mysensors/NodeManager/issues/85 for this which is needed regardless. Thanks
                          • U user2684
                            U
                            U
                            user2684
                            @core_c found a great way to to let NodeManager identifying automatically which i2c address the sensor is using without the need for the user to change anything in the code. This is done by requesting the chip_id for the two i2c address and comparing it with the expected one to identify the right address. I've implemented it for both the BME280 and BMP085/BMP180 sensors and it is available in 1.5-dev3 (https://github.com/mysensors/NodeManager/tree/702a05c7e2f4425c188d5abf62b4a119fea29bc8). Also, under the hood, I've created a SensorBosch class which is not exposed but helps providing common functionalities to the two sensors without duplicating the code.
                            Finally, specifically for your problem @ksga, I found a critical bug in the BME280 class. I wonder how I've missed it so far. For some unknown reasons, the bme object created by registerSensor and passed to the SensorBME280 class, was not stored by the latter. This means it was calling e.g. readTemperature on a null pointer which I even wonder why was not crashing everything. It has been fixed in 1.5-dev3 so if you would like to give it a try, I'm more confident it will work just fine finally :-)
                            • U
                              U
                              user2684
                              Do you think would make any sense to add NodeManager among the Arduino's examples? So that from the IDE one can select Examples, MySensors and NodeManager would show up like MotionSensor and the others. However I'd expect new versions of NM to be released more frequently than updates to the core code so it might happen an outdated version to be available there...
                              • U
                                U
                                user2684
                                I've added a rain gauge out-out-the-box sensor for the latest dev release called 1.5-dev5 (https://github.com/mysensors/NodeManager/tree/126812a9d01311640416222be8225fdcca1e7266). This is intended to be the last enhancement for the upcoming v1.5 version but of course I'll wait for some additional days to collect (and fix) any issue all the new sensors might have.
                                The implementation of the rain gauge sensor has to be different than the one from the build section for a good number of reasons and limitations. All the details here: https://github.com/mysensors/NodeManager/issues/90.
                                • D
                                  Dencan
                                  Hi, nice work!
                                  I have changed the code for REBOOT so there is no need for a reboot-pin.
                                  like this...
                                  else if (strcmp(message, "REBOOT") == 0) {
                                  #if DEBUG == 1
                                  Serial.println(F("REBOOT"));
                                  // Software reboot with watchdog timer
                                  // Enter Watchdog Configuration mode:
                                  WDTCSR |= (1<<WDCE) | (1<<WDE);
                                  // Reset enable
                                  WDTCSR= (1<<WDE);
                                  // Infinite loop until watchdog reset after 16 ms
                                  while(true){}
                                  U core_cC 3 Replies Last reply
                                  • D Dencan
                                    Hi, nice work!
                                    like this...
                                    #if DEBUG == 1
                                    // Reset enable
                                    WDTCSR= (1<<WDE);
                                    while(true){}
                                    U
                                    U
                                    user2684
                                    @Dencan interesting thanks! I initially thought there were two use cases, one is to reboot with a remote command and the other is by using a pin (e.g. when having physical access is easier than sending out a message). But I think you're right, if you have physical access, well, hitting the reset button is way easier than connecting the reboot pin to RST ;-)
                                    I'll use this snippet for the version about to be released (https://github.com/mysensors/NodeManager/issues/101). Thanks!
                                    • D Dencan
                                      Hi, nice work!
                                      like this...
                                      #if DEBUG == 1
                                      // Reset enable
                                      WDTCSR= (1<<WDE);
                                      while(true){}
                                      core_cC
                                      core_cC
                                      core_c
                                      @Dencan That is a method i never even thought about Dencan.
                                      Cool.. You tought me something. Thanks. I have to try it out for myself. :)
                                      My first thought was jumping to the address of the RESET interrupt vector in memory.
                                      It's located in the very first bytes at address 0.
                                      __asm__ __volatile__ ("jmp 0");
                                      • U
                                        U
                                        user2684
                                        Version 1.5 of NodeManager is finally available here!
                                        I've done my best to implement most of the requests received so far since unfortunately I'm expecting starting from June very little spare time to spend here so I tried to hurry up a bit :-) The result is a pretty long change log and a total of 26 between ad-hoc and generic out-of-the-box sensors supported up to this release:
                                        • Added support for ACS712 current sensor
                                        • Added support for HC-SR04 distance sensor
                                        • Added support for BMP085/BMP180 temperature and pressure sensor
                                        • Added support for Sonoff smart switch
                                        • Added support for Rain Gauge sensor
                                        • Added support for MCP9808 temperature sensor
                                        • Added forecast output to all Bosch sensors
                                        • Added I2C address auto-discovery for all Bosch sensors
                                        • Added support for running as a gateway
                                        • Added option to retrieve the latest value of a sensor from outside NodeManager
                                        • Remote reboot now does not need a reboot pin configured
                                        • A heartbeat is now sent also when waking up from a wait cycle
                                        • When waking up for an interrupt, only the code of the sensor expecting that interrupt is executed
                                        • Added capability to retrieve the time from the controller
                                        • Optimized battery life for DS18B20 sensors
                                        • SLEEP_MANAGER has been deprecated (now always enabled) and setMode() replaces setSleepMode()
                                        • New mode ALWAYS_ON to let the node staying awake and executing each sensors' loop
                                        • ESP8266WiFi.h has to be included in the main sketch if MY_GATEWAY_ESP8266 is defined
                                        • Added receiveTime() wrapper in the main sketch
                                        • Fixed the logic for output sensors
                                        • Added common gateway settings in config.h
                                        I've added upgrade instructions as well in the documentation. Generally speaking to upgrade it is safe to just replace the existing NodeManager.h and NodeManager.cpp files but with this release I had to do some minor changes to the main sketch as well, as documented in the release notes.
                                        Thanks everybody for all the advice and for reporting any issue always in a constructive way :-)
                                        • U
                                          U
                                          user2684
                                          Hi, I've added a "How to contribute" section in the documentation of the dev release in case anybody is interested to contribute to this project: https://github.com/mysensors/NodeManager/tree/development#contributing.
                                          I'm not a git expert so I hope those instructions to have some sense :)
