  3. šŸ’¬ 3.3v Boost Converter with Pass-Through
boosterdc-dcvoltageconverterpass-throughltc3525dmote3.3vstep-upboost converter
9 Posts 3 Posters 4.0k Views 2 Watching
  • openhardware.ioO
    openhardware.ioO
    openhardware.io
    https://www.openhardware.io/view/285/33v-Boost-Converter-with-Pass-Through
      Last night I posted Version 3, which updates the silkscreen to 1. show PCB component values to make for faster/easier assembly, and 2. use a larger font for the pin labels to improve legibility.
        I just now posted Version 4, which redesigns the board after I realilzed there's reason to disallow header access to the SW pin on the chip.
          I just now posted Version 5, which increased the capacitor value from 10uF to 22uF in order to reduce voltage ripple. See datasheet.
            Just now posted Version 6.
            Changes from Version 5:
            1. Changed to using same inductor and capacitors that I'm using in my other project: https://forum.mysensors.org/topic/5280/3-3v-buck-boost-dc-dc-converter
            2. Changed top silk screen to more clearly identify Pin 1 on the LTC3525D-3.3 chip and also provide extra clearance to prevent the silk screen from potentially causing the pads to bridge during soldering.
              This project now finished: I've assembleed the pcb and it works. :)
              • rozpruwaczR
                rozpruwaczR
                rozpruwacz
                Hi, I just came across this project and I like the idea of pass trough very much :) I have a question, why did You use the LTC3525D part instead of MCP1640C which You already used in other boost converter projects ? MCP1640C is 5 times cheaper than LTC3525D and they are quite similar.
                • rozpruwaczR rozpruwacz
                  @rozpruwacz
                  Yes. Good catch.
                    @rozpruwacz said in šŸ’¬ 3.3v Boost Converter with Pass-Through:
                    I just now revised the board to expose the Enable pin, so now you can do a pass-through if you wish. I also made it more compact and gave it a ground-plane on the back.
                    https://www.openhardware.io/view/279
                    Enjoy!
                    With your input, this post could be even better šŸ’—
