  3. Windows GUI/Controller for MySensors
myscontrollermysbootloader
486 Posts 101 Posters 502.1k Views 73 Watching
  • techRHT techRH
    @Anduril said in Windows GUI/Controller for MySensors:
    itiate a reboot of a node from gateway side? I don't know how, but it's needed for updating OTA. Th
    Right click on the node and than "reboot"
    AndurilA
    AndurilA
    Anduril
    @techRH that doesn't work for the new bootloader/MySensors 2.x
    tekkaT 1 Reply Last reply
    • AndurilA Anduril
      tekkaT
      tekkaT
      tekka
      @Anduril it does work, unless your node is sleeping and not able to process incoming messages
      • AndurilA
        AndurilA
        Anduril
        @tekka ok and whats the way to deal with sleeping nodes? Do I have to add a wait(xx) to receive reboot commands?
        • AndurilA Anduril
          tekkaT
          tekkaT
          tekka
          @Anduril The solution is to use smart sleep. If you are on MySensors 2.1.x, use:
          sleep(xyz_MS, true);
          This will issue a heartbeat message followed by a short wait() interval to process incoming messages, and finally send the node to sleep. The heartbeat message triggers the release of pending messages (i.e. reboot request) in MYSController (node has to be defined as battery-powered / sleeping node).
          In the upcoming MySensors 2.2.0 release we will introduce a dedicated sleep intention message.
          • AndurilA
            AndurilA
            Anduril
            @tekka thanks for your hint. Is smartsleep supported if the controller (pimatic) does not? So do I get problems when using withoug MYSController for debug?
            And another thing is that this node tries to save power and only sends updates if values have changed. So using smartsleep and sending a messag every sleep cycle would be against that. Can I simply put a wait(50) after the first message sending is triggered? What would be the necessary time to do wait(x)?
            • AndurilA Anduril
              tekkaT
              tekkaT
              tekka
              @Anduril Yes, smartsleep is just a sequence of events (sending heartbeat message, wait(default=500), sleep()) that gives the controller the possibility to react before the node is going to sleep.
              • dirkcD
                dirkcD
                dirkc
                I have problems using the OTA feature with MYSController.
                1. "undefined firmware/type" reported.
                  My setup:
                • ESP8266 Gateway 2.1.1
                • MYSController Version 1.0.0beta (build 3314)
                • atmega328p chip with own pcb, internal osc 8MHz, and MYSBootloaderV13pre.hex (taken from the same zip file as MYSController.exe)
                The log file in MYSController shows "undefined firmware/type" :
                Where can I find the latest software (exe and boot loader)?
                1. the "Reload repo" toolbar button is always greyed, but the "firmware_config" is available, has all entries and the hex files are in the same directory.
                2. is there a more detailed description available for the columns of the "firmware_config" file?
                thanks in advance
                Controller: Home Assistant & FHEM - Gateway: ESP8266wifi - MySensors: 2.3.2 (nRF24)
                • dirkcD dirkc
                    My setup:
                  thanks in advance
                  tekkaT
                  tekkaT
                  tekka
                  wrote on last edited by tekka
                  #442
                  @dirkc If you are using MYSBootloader there is no need to define MY_OTA_FIRMWARE_FEATURE since the FW update happens offline, see here for additional infos.
                  See here for a firmware_config.csv example:
                  1,DoorSensor_V1,1,DoorSensorV1.hex,Door sensor version 1
                  1,DoorSensor_V2,2,DoorSensorV2.hex,Door sensor version 2
                  1,DoorSensor_V3,3,DoorSensorV3.hex,Door sensor version 3
                  10,TestSensor,1,TestSensor.hex,Test FW
                  11,LightSensor,1,LightSensor.hex,Light sensor
                  20,TempSensor Indoor V1,1,TempSensorIndoorV1.hex,Temp. Sensor indoor V1
                  20,TempSensor Indoor V2,2,TempSensorIndoorV2.hex,Temp. Sensor indoor V2
                  30,TempSensor Outdoor V1,1,TempSensorOutdoorV1.hex,Temp. Sensor outdoor V2
                  Impotant: All defined files need to be present in the directory, only comma delimiters are allowed.
                  • R
                    R
                    romeo01
                    wrote on last edited by romeo01
                    #443
                    With MSController 1.0.0 & SerialGateway with 2.2.0 MySensor lib, 1 problem occurs.
                    MSController crash at the presentation step by the node
                    Below what the node send when reeboot. (Debug log via Serial)
                    0 MCO:BGN:INIT NODE,CP=RNNNA---,VER=2.2.0-beta
                    26 TSM:INIT
                    27 TSF:WUR:MS=0
                    34 TSM:INIT:TSP OK
                    35 TSM:INIT:STATID=1
                    37 TSF:SID:OK,ID=1
                    39 TSM:FPAR
                    75 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    1051 TSF:MSG:READ,0-0-1,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                    1056 TSF:MSG:FPAR OK,ID=0,D=1
                    2083 TSM:FPAR:OK
                    2084 TSM:ID
                    2085 TSM:ID:OK
                    2087 TSM:UPL
                    2091 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                    2101 TSF:MSG:READ,0-0-1,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                    2106 TSF:MSG:PONG RECV,HP=1
                    2109 TSM:UPL:OK
                    2110 TSM:READY:ID=1,PAR=0,DIS=1
                    2115 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                    2122 TSF:MSG:READ,0-0-1,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                    2129 TSF:MSG:SEND,1-1-0-0,s=255,c=0,t=17,pt=0,l=10,sg=0,ft=0,st=OK:2.2.0-beta
                    2139 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                    2155 TSF:MSG:READ,0-0-1,s=255,c=3,t=6,pt=0,l=1,sg=0:M
                    2162 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=11,pt=0,l=10,sg=0,ft=0,st=OK:OTA Test 2
                    2171 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:2.0
                    2180 TSF:MSG:SEND,1-1-0-0,s=1,c=0,t=3,pt=0,l=8,sg=0,ft=0,st=OK:Sensor 1
                    2187 MCO:REG:REQ
                    2190 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                    2197 TSF:MSG:READ,0-0-1,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                    2202 MCO:PIM:NODE REG=1
                    2204 MCO:BGN:STP
                    2205 MCO:BGN:INIT OK,TSP=1
                    Below is the log in MSController
                    08/05/2017 18:12:26	RX	0;255;3;0;9;33925 TSF:MSG:READ,1-1-255,s=255,c=3,t=7,pt=1,l=1,sg=0:0
                    08/05/2017 18:12:26	RX	0;255;3;0;9;33931 TSF:MSG:BC
                    08/05/2017 18:12:26	RX	0;255;3;0;9;33933 TSF:MSG:FPAR REQ,ID=1
                    08/05/2017 18:12:26	RX	0;255;3;0;9;33937 TSF:PNG:SEND,TO=0
                    08/05/2017 18:12:26	RX	0;255;3;0;9;33940 TSF:CKU:OK
                    08/05/2017 18:12:26	RX	0;255;3;0;9;33943 TSF:MSG:GWL OK
                    08/05/2017 18:12:26	RX	0;255;3;0;9;34102 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                    08/05/2017 18:12:29	RX	0;255;3;0;9;37248 TSF:MSG:READ,1-1-255,s=255,c=3,t=7,pt=1,l=1,sg=0:0
                    08/05/2017 18:12:29	RX	0;255;3;0;9;37254 TSF:MSG:BC
                    08/05/2017 18:12:29	RX	0;255;3;0;9;37257 TSF:MSG:FPAR REQ,ID=1
                    08/05/2017 18:12:29	RX	0;255;3;0;9;37260 TSF:CKU:OK,FCTRL
                    08/05/2017 18:12:29	RX	0;255;3;0;9;37263 TSF:MSG:GWL OK
                    08/05/2017 18:12:30	RX	0;255;3;0;9;37669 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                    08/05/2017 18:12:32	RX	0;255;3;0;9;40570 TSF:MSG:READ,1-1-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                    08/05/2017 18:12:32	RX	0;255;3;0;9;40579 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                    08/05/2017 18:12:33	RX	0;255;3;0;9;40729 TSF:MSG:READ,1-1-0,s=255,c=4,t=0,pt=6,l=10,sg=0:28000100E803E5750103
                    08/05/2017 18:12:33	RX	1;255;4;0;0;28000100E803E5750103
                    08/05/2017 18:12:33	INFO	BL version=259
                    08/05/2017 18:12:33	INFO	No FW assigned
                    08/05/2017 18:12:36	RX	0;255;3;0;9;44053 TSF:MSG:READ,1-1-0,s=255,c=4,t=0,pt=6,l=10,sg=0:28000100E803E5750103
                    08/05/2017 18:12:36	RX	1;255;4;0;0;28000100E803E5750103
                    08/05/2017 18:12:36	INFO	BL version=259
                    08/05/2017 18:12:36	INFO	No FW assigned
                    08/05/2017 18:12:39	RX	0;255;3;0;9;47376 TSF:MSG:READ,1-1-0,s=255,c=4,t=0,pt=6,l=10,sg=0:28000100E803E5750103
                    08/05/2017 18:12:39	RX	1;255;4;0;0;28000100E803E5750103
                    08/05/2017 18:12:39	INFO	BL version=259
                    08/05/2017 18:12:39	INFO	No FW assigned
                    08/05/2017 18:12:43	RX	0;255;3;0;9;50700 TSF:MSG:READ,1-1-0,s=255,c=4,t=0,pt=6,l=10,sg=0:28000100E803E5750103
                    08/05/2017 18:12:43	RX	1;255;4;0;0;28000100E803E5750103
                    08/05/2017 18:12:43	INFO	BL version=259
                    08/05/2017 18:12:43	INFO	No FW assigned
                    08/05/2017 18:12:46	RX	0;255;3;0;9;54213 TSF:MSG:READ,1-1-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                    08/05/2017 18:12:46	RX	0;255;3;0;9;54219 TSF:MSG:BC
                    08/05/2017 18:12:46	RX	0;255;3;0;9;54222 TSF:MSG:FPAR REQ,ID=1
                    08/05/2017 18:12:46	RX	0;255;3;0;9;54226 TSF:PNG:SEND,TO=0
                    08/05/2017 18:12:46	RX	0;255;3;0;9;54230 TSF:CKU:OK
                    08/05/2017 18:12:46	RX	0;255;3;0;9;54232 TSF:MSG:GWL OK
                    08/05/2017 18:12:47	RX	0;255;3;0;9;55224 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                    08/05/2017 18:12:48	RX	0;255;3;0;9;56261 TSF:MSG:READ,1-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                    08/05/2017 18:12:48	RX	0;255;3;0;9;56267 TSF:MSG:PINGED,ID=1,HP=1
                    08/05/2017 18:12:48	RX	0;255;3;0;9;56273 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
                    08/05/2017 18:12:48	RX	0;255;3;0;9;56286 TSF:MSG:READ,1-1-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                    08/05/2017 18:12:48	RX	0;255;3;0;9;56294 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                    08/05/2017 18:12:48	RX	0;255;3;0;9;56302 TSF:MSG:READ,1-1-0,s=255,c=0,t=17,pt=0,l=10,sg=0:2.2.0-beta
                    08/05/2017 18:12:48	RX	1;255;0;0;17;2.2.0-beta
                    08/05/2017 18:12:48	DEBUG	Update child id=255, type=S_ARDUINO_NODE
                    08/05/2017 18:12:48	RX	0;255;3;0;9;56309 TSF:MSG:READ,1-1-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
                    08/05/2017 18:12:48	RX	1;255;3;0;6;0
                    08/05/2017 18:12:48	TX	1;255;3;0;6;M
                    08/05/2017 18:12:48	RX	0;255;3;0;9;56328 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=6,pt=0,l=1,sg=0,ft=0,st=OK:M
                    08/05/2017 18:12:48	RX	0;255;3;0;9;56335 TSF:MSG:READ,1-1-0,s=255,c=3,t=11,pt=0,l=10,sg=0:OTA Test 2
                    08/05/2017 18:12:48	RX	1;255;3;0;11;OTA Test 2
                    08/05/2017 18:12:48	RX	0;255;3;0;9;56343 TSF:MSG:READ,1-1-0,s=255,c=3,t=12,pt=0,l=3,sg=0:2.0
                    08/05/2017 18:12:48	RX	1;255;3;0;12;2.0
                    08/05/2017 18:12:48	RX	0;255;3;0;9;56351 TSF:MSG:READ,1-1-0,s=1,c=0,t=3,pt=0,l=8,sg=0:Sensor 1
                    Here a screenshot when MSController crash.
                    When I click on "request presentation", same error.
                    This error is only with SerialGateway & Library 2.2.0 beta
                    With library 2.1.1that's ok
                    • R romeo01
                      26 TSM:INIT
                      27 TSF:WUR:MS=0
                      34 TSM:INIT:TSP OK
                      37 TSF:SID:OK,ID=1
                      39 TSM:FPAR
                      2083 TSM:FPAR:OK
                      2084 TSM:ID
                      2085 TSM:ID:OK
                      2087 TSM:UPL
                      2109 TSM:UPL:OK
                      2187 MCO:REG:REQ
                      2204 MCO:BGN:STP
                      tekkaT
                      tekkaT
                      tekka
                      @romeo01 Thanks for reporting, this is a known issue with build 3314 and lib 2.2.0: The msg parser requires some changes - build 3316 is in preparation (also supporting new 2.2.0 features).
                      V 1 Reply Last reply
                      • siodS
                        siodS
                        siod
                        Hi, I am trying your software but I only get "connection refused" though in the status bar it says Connected... what can I do?
                        still learning...
                        • tekkaT tekka
                          V
                          V
                          vikasjee
                          @tekka hi, can we access the previous build if that is working for MySensors2.1.1?
                          • siodS siod
                            tekkaT
                            tekkaT
                            tekka
                            @siod Seems like something is wrong with your GW - either GW is not working or too many connections.
                            • V vikasjee
                              tekkaT
                              tekkaT
                              tekka
                              @vikasjee What build are you looking for?
                              • tekkaT tekka
                                V
                                V
                                vikasjee
                                @tekka , I upgraded Arduino IDE from 1.6.0 to 1.8.2 recently. Burnt the gateway with the MySensors2.1.1 gateway sketch and the nodes bootloader with MysBootloader1.3.0beta3 from the master branch on github.
                                As per my understanding the Node with MysBootloader should connect to the Gateway (checked with MysController 1.0beta b3314) where i can specify the Firmware for this new node. But i am not able to get the Node entry in the left hand side tree in MysController. Upon checking the MysController Debug, there are a stream of messages from the node but are being endlessly repeated:
                                6/12/2017 19:24:59	RX	0;255;3;0;9;TSF:CKU:OK,FCTRL
                                6/12/2017 19:24:59	RX	0;255;3;0;9;TSF:MSG:GWL OK
                                6/12/2017 19:25:01	RX	0;255;3;0;9;TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                                6/12/2017 19:25:06	RX	0;255;3;0;9;TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=1,l=1,sg=0:235
                                6/12/2017 19:25:06	RX	0;255;3;0;9;TSF:MSG:BC
                                6/12/2017 19:25:06	RX	0;255;3;0;9;TSF:MSG:FPAR REQ,ID=255
                                6/12/2017 19:25:06	RX	0;255;3;0;9;TSF:CKU:OK,FCTRL
                                6/12/2017 19:25:06	RX	0;255;3;0;9;TSF:MSG:GWL OK
                                6/12/2017 19:25:08	RX	0;255;3;0;9;TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                                6/12/2017 19:25:09	RX	0;255;3;0;9;TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=1,l=1,sg=0:235
                                6/12/2017 19:25:09	RX	0;255;3;0;9;TSF:MSG:BC
                                6/12/2017 19:25:09	RX	0;255;3;0;9;TSF:MSG:FPAR REQ,ID=255
                                6/12/2017 19:25:09	RX	0;255;3;0;9;TSF:CKU:OK,FCTRL
                                6/12/2017 19:25:09	RX	0;255;3;0;9;TSF:MSG:GWL OK
                                I am unable to get to the root of the problem... and could not find any mention of a similar problem on this forum (searched far and wide :) )
                                Any pointers to a solution or hint of what may be wrong will definitely help me save time...
                                • V
                                  V
                                  vikasjee
                                  @tekka , there seems to be an issue with the build 3314 and MYSBootloader for MySensors 2.1.1,as noted above. Any good, working previous version should do...
                                  • V
                                    V
                                    vikasjee
                                    wrote on last edited by vikasjee
                                    #451
                                    @tekka please help with the MysController build 3312 if that one works with MYSBootloader for MySensors 2.1.1 master.
                                    • V vikasjee
                                      tekkaT
                                      tekkaT
                                      tekka
                                      @vikasjee Apologies for the late reply. This issue is not related to MYSController:
                                      The debug log hints to some issues with the radio (range, connection) and/or power supply (node does not receive the find_parent_response message), please double-check the wiring, power supply (appropriate caps on both, GW and node), change the distance between GW and node, or try with different radio modules.
                                      • tekkaT tekka
                                        V
                                        V
                                        vikasjee
                                        @tekka No Issues. Thanks for the response.
                                        I have tried all of these with all my 35 radios (were all working before the upgrade) and equal number of nodes! :(
                                        I will go through all this sequence once again though... Thanks for clearing the doubts on MYSController build. Indebted!
                                          swiss
                                          Newbie can't make it happen...
                                          I've been struggling for the last couple of days, trying to make the mysensors world to fly. But unfortunately i have no success so i will try to post one of my many trials, would be very glad if you could let me know what i'm missing...
                                          Hardware:
                                          • Aurduino Mini Pro
                                          • W5100 ETH interface
                                          • long-distance NRF24L01 (Gateway)
                                          • NRF24L01+ 2.4GHz Antenna Wireless Transceiver Module (Sensor)
                                          Software:
                                          • https://github.com/mysensors/MySensors/blob/master/examples/GatewayW5100/GatewayW5100.ino (Gateway)
                                          • https://github.com/mysensors/MySensorsArduinoExamples/blob/master/examples/BinarySwitchSensor/BinarySwitchSensor.ino (Sensor)
                                          All i did was to load both sketch to the according mini.
                                          Of course changing the IP of the gateway.
                                          I can ping the gateway using Windows terminal, but i can't access the gateway using the MYSController. As soon i try to dicover any node the connection is terminated by the remot side (entry in the debug window of MYSCtrl)
                                          If i did understand it correct i do not have to load the Bootloader as of now (as long i do not need OTA)
                                          Any help would be highly appriciated,
                                          matt
