  3. Noob problem on debugging transmissions
3 Posts 2 Posters 925 Views 2 Watching
  • ? Offline
    ? Offline
    A Former User
    wrote on last edited by A Former User
    I'm quite new to MySensor and Arduino/Raspberry world.
    I'm struggling since few days to add some sensors on Domoticz by using a NRF24L01+ device (Gateway is direclty connected on Rpi3 using SPI).
    Currently, i'm trying to send data with a DHT22:
    On the sensor part, the monitor displays the following:
    4 TSM:INIT
    4 TSF:WUR:MS=0
    12 TSM:INIT:TSP OK
    14 TSM:INIT:STATID=4
    16 TSF:SID:OK,ID=4
    18 TSM:FPAR
    53 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    759 TSF:MSG:READ,0-0-4,s=255,c=3,t=8,pt=1,l=1,sg=0:0
    765 TSF:MSG:FPAR OK,ID=0,D=1
    2062 TSM:FPAR:OK
    2062 TSM:ID
    2064 TSM:ID:OK
    2066 TSM:UPL
    2070 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
    4077 TSM:UPL
    4079 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
    6088 TSM:UPL
    6090 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
    8099 TSM:UPL
    8101 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
    While on the Raspberry side (GW):
    4;255;3;0;24;1
    4;255;3;0;24;1
    4;255;3;0;24;1
    4;255;3;0;24;1
    What is strange, is that I never see any data from the DHT Sensor.
    My code:
    #define MY_DEBUG                      // Active le mode debug / Enable debug prints to serial monitor
    #define MY_RADIO_NRF24                // Mode Radio / Enable and select radio type attached
    #define MY_NODE_ID 4                  // Noeud de l'objet / Object Node
    #define RF_CE    9
    #define RF_CSN   10
    #define CHILD_ID_HUM 1
    #define CHILD_ID_TEMP 2
    #define DHTTYPE DHT22   // DHT 22  (AM2302), DHT11
    unsigned long SLEEP_TIME = 10000;     // Sleep time between reads (in milliseconds)
    float lastTemp;
    float lastHum;
    boolean metric = true;
    int reportCount = 1;
    void setup()  {
    void presentation(){
      sendSketchInfo("Outdoor temperature + Humidity", "1.0");
      present(CHILD_ID_HUM, S_HUM);
    void loop()      {
      // Temperature
      DHT dht(HUMIDITY_SENSOR_DIGITAL_PIN, DHTTYPE, 3);
      float temperature = dht.readTemperature();
      if (isnan(temperature)) {
      else {
        Serial.print("T: ");
        if(lastTemp != temperature || reportCount == 10) {
          lastTemp = temperature;
      // Humidity
      float humidity = dht.readHumidity();
      if (isnan(humidity)) {
      else {
        Serial.print("H: ");
        Serial.println(humidity);
        if(lastHum != humidity || reportCount == 10) {
          lastHum = humidity;
      if(reportCount == 10) {
        reportCount = 1;
      else {
        reportCount++;
      sleep(SLEEP_TIME);
    Shouldn't I see the measurement values in the monitor (serial.print cmd) ?
    Thanks for helping !
    • rejoe2R Offline
      rejoe2R Offline
      rejoe2
      @Korleone said in Noob problem on debugging transmissions:
      4;255;3;0;24;1
      Do you know the log parser: https://www.mysensors.org/build/parser?
      Seems your node doesn't get registered by your controller. The gateway is in inclusion mode?
      If there is no registration, your node will never go into loop() - at least in standard configuration.
      Wrt. your code, I would recommend to define all of the variables in the header, not in the loop() and - more important to declare the DHT object in setup().
      Kind regards
      • ? Offline
        ? Offline
        A Former User
        Thanks for the quick answer and advices. I understand my mistake:
        It is not linked to the inclusion, but on the Gateway and Nodes versions: (Gateway was on MySensors 1.4, while Nodes were on MySensors 2).
        Reconfiguration of the Gateway gives appropriate results and is immediately included in Domoticz !
