  2. Announcements
  3. 💬 Motion Sensor
💬 Motion Sensor
63 Posts 30 Posters 34.7k Views 31 Watching
  • ben999B ben999
    @Graham Thank you for your reply
    SR501 seem to work fine on two fronts:
    • the arduino IDE serial monitor shows the SR501 going ON then OFF after 5s (as per dial)
    • same serial monitor shows that sensor gets motion when it occurs...
    I'll have a go with another node just to be sure
    Thanks again for your help (both of you :) )
    EfflonE
    EfflonE
    Efflon
    @ben999 Did you get your sensor sorted? I have the same issue with the sensor reporting tripped after going out of sleep, same goes for wait. Putting the exact same logic in a sketch without MYS and I have no issues... going crazy soon
    • miroM
      miroM
      miro
      wrote on last edited by miro
      #24
      Does anyone know why my sensor only reacts when I move my hand just in front of it. From a distance it does not work. Has tested with different HC-SR501 PIR and adjusted also and various radio but all gave the same result.
       * Version 1.0 - Henrik Ekblad
      // Enable debug prints
      // #define MY_DEBUG
      // Initialize motion message
      void presentation()  {
        present(CHILD_ID, S_MOTION);
        // Read digital motion value
        Serial.println(tripped);
      gohanG 1 Reply Last reply
      • miroM miro
        // #define MY_DEBUG
        @miro
        have you tried to power he sensor with external 5v instead of 5v pin from arduino?
          A Former User
          Hi all,
          The motion sensor project is my first using Arduino and MySensors! I've managed to get the Gateway all up and running and the motion sensor to communicate with it (using the standard ino file from the project page), but I seem to have a couple of issues:
          • Despite the default sleep time it seems to be communicating with the Gateway constantly.
          • Permanently displayed as in an 'On' state in Domoticz.
          I've tried adjusting the sensitivity and time but it doesn't seem to make a difference.
          I don't know which bit is supposed to contain the values which I can decipher with the serial protocol guide so apologies if the answer is staring me in the face!
          Gateway received
          0;255;3;0;9;TSF:MSG:READ,1-1-0,s=1,c=1,t=16,pt=0,l=1,sg=0:1
          1;1;1;0;16;1
          Node sent
          1383086 TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=16,pt=0,l=1,sg=0,ft=0,st=OK:0
          1383106 MCO:SLP:MS=120000,SMS=0,I1=1,M1=1,I2=255,M2=255
          1383120 MCO:SLP:TPD
          1383127 MCO:SLP:WUP=1
          Any help would be appreciated :)
          ? 1 Reply Last reply
            try to use a 10uF or bigger capacitor on the 5v and GND, I had issues with mine triggering randomly and after using a stable 5v supply it got back to normal: in fact later on when I added the capacitor to help the NRF24 radio it also stabilized the 5V for the sensor and it is now working fine.
            Did you try to use just a sleep(2000) without the interrupt? Just to check if it is going to sleep correctly
            • D
              Daanozz
              i'm trying to get my motionsensor working, but i see only 0 in the terminal what send to the gateway. Does anyone know why i only see that 0 and not a 1? I'm asuming that 1 is a movement.
              • bgunnarbB
                bgunnarbB
                bgunnarb
                I have found in my experiments with the PIR motion sensor that at least the type that I am using is extremely sensitive to ripple in the Vcc voltage.
                First of all, it is unstable as the feed voltage approaches 5V and then it triggers spontaneously again and again. I then tried to rise the voltage to around 11V which is the voltage that the battery eliminator gives. But that voltage has a ripple of 0.1 volt amplitude so this triggers the sensor again and again also since the arduino introduces small changes in the voltage when it processes the script.
                The solution was to install a LM317 voltage regulator to bring down the voltage to 8V which is then ripple free and stable. Now the PIR works very well and does not give false triggers.
                The arduino is fed from a separate voltage regulator giving 5V. I tried to connect the battery eliminator directly to RAW but that released the smoke from the on-board voltage regulator and as you know, when you let the smoke out from components, they no longer work. :grinning:
                Apparently the battery eliminator also produces some voltage spikes that are not healthy.
                I have never been so busy since I retired!
                  I solved my random pir triggers with a Capacitor on the 5v pin.
                  • ? A Former User
                    Hi all,
                    Gateway received
                    1;1;1;0;16;1
                    Node sent
                    1383120 MCO:SLP:TPD
                    A Former User
                    @Kieren-Perry said in 💬 Motion Sensor:
                    Hi all,
                    Gateway received
                    1;1;1;0;16;1
                    Node sent
                    1383120 MCO:SLP:TPD
                    Thanks for all your comments! Tried the capacitor route but no dice. In the end, connected a 9v battery to the jack and the PIR to the VIN as the voltage from the 5v pin and USB was a little below what it should have been.
                    • Cliff KarlssonC
                      Cliff KarlssonC
                      Cliff Karlsson
                      If I want something to run for 10 seconds after a motion have been detected, how would I make this happend?
                        Set a timer in the code, that's shouldn't be very hard to do.
                        • Cliff KarlssonC
                          Cliff KarlssonC
                          Cliff Karlsson
                          I have never used timers but I looked at the blink without delay sketch from the arduino website. Do I replace the if -statement with a while loop?
                          const int ledPin =  LED_BUILTIN;// the number of the LED pin
                          // Variables will change :
                          int ledState = LOW;             // ledState used to set the LED
                          // Generally, you should use "unsigned long" for variables that hold time
                          // The value will quickly become too large for an int to store
                          unsigned long previousMillis = 0;        // will store last time LED was updated
                          // constants won't change :
                          const long interval = 1000;           // interval at which to blink (milliseconds)
                            // set the digital pin as output:
                            pinMode(ledPin, OUTPUT);
                            // here is where you'd put code that needs to be running all the time.
                            // check to see if it's time to blink the LED; that is, if the
                            // difference between the current time and last time you blinked
                            // the LED is bigger than the interval at which you want to
                            // blink the LED.
                            if (currentMillis - previousMillis >= interval) {
                              // save the last time you blinked the LED
                              // if the LED is off turn it on and vice-versa:
                              if (ledState == LOW) {
                                ledState = HIGH;
                                ledState = LOW;
                              // set the LED with the ledState of the variable:
                              digitalWrite(ledPin, ledState);
                            Just leave it as it is, just put a condition that will trigger the if statement only once the pir sensor got triggered
                            • L
                              L
                              LastSamurai
                              I would actually not do this in a node but in the controller (at least if I get what you are trying to do right). I have done that with some scripting in domoticz. I have lights that that are switched on for 5 minutes when motion is detected and shut down 5 minutes after the last motion stopped. Motion sensor and rgbw controller are different mysensor nodes. Much more versatile then hardcoding this in you node's code.
                              ben999B 1 Reply Last reply
                              • L LastSamurai
                                ben999B
                                ben999B
                                ben999
                                @LastSamurai
                                Would you do that through "rules" ?
                                • ben999B ben999
                                  @LastSamurai
                                  @ben999 yes.
                                  @LastSamurai I know that hardcoding is less flexible, but at least it can work even if controller is down or disconnected, of course it depends how critical is the actuator.
                                  • maghacM
                                    maghacM
                                    maghac
                                    So, I notice that the HC-SR501 has a 7133-1 voltage regulator on-board which I guess means that the logic is actually driven with 3.3V and not 5V.
                                    Is it possible to bypass the regulator and power the sensor directly with the 3.3V I am using to power my nano with?
                                    maghacM 1 Reply Last reply
                                    • maghacM maghac
                                      maghacM
                                      maghacM
                                      maghac
                                      @maghac Aha, guess I should read old posts first :)
                                        Just make sure the power source is stable otherwise you will end up with random triggers from pir sensor
                                          ben999B
                                          ben999B
                                          ben999
                                          @gohan @maghac
                                          From my little experience : when running from 2 AA batteries with sketch as it is I got random triggers continuousely
                                          Adding a delay() before entering sleep() sorted things out (something like 3 sec is necessary to get power stable again)
                                          Not sure it's the smartest way of doing it, but it works...
                                          Any comment on the security side of it? Could my node miss some action during these 3 sec ? Or the interrupt pin would still listen to the PIR sensor pin ?
