  2. Announcements
  3. 💬 Motion Sensor
💬 Motion Sensor
63 Posts 30 Posters 34.7k Views 31 Watching
  • Patrik SöderströmP
    Patrik SöderströmP
    Patrik Söderström
    Do you have an example sketch of connecting two PIRs to one Arduino? Would really need that in my setup.
    Random_nut1R 1 Reply Last reply
    • Patrik SöderströmP Patrik Söderström
      Random_nut1R
      Random_nut1R
      Random_nut1
      And so do I. Have tried to accomplish this as my first mysensors project, but coming up short... :-(
      • ben999B
        ben999B
        ben999
        wrote on last edited by ben999
        Hi all
        I have build a node with this setup.
        It is an Arduino Pro Mini with a SR501 and a RFL01. Arduino and sensor converted to 3.3V.
        Motion is detected like it should, no trouble.
        But everytime my arduino hits this :
        the node returns a "high"... meaning there's motion (where there is not actually)
        So my notification board gets a new entry every two minutes...
        Is this normal beahaviour ? (Hope not!!! ;) )
        GrahamG 1 Reply Last reply
        • bgunnarbB
          bgunnarbB
          bgunnarb
          Hi ben999
          I don't know what your sketch looks like but in my implementation I catch the movement in a boolean variable called tripped which I use to set the message sent to the controller.
          // Read digital motion value
          send(msgm.set(tripped?"1":"0"));  // Send tripped value to gw
          Then I do some other stuff based on tripped being true or false.
          Before the node goes to sleep I reset tripped. Otherwise I will get the old value back next time the node wakes up after SLEEP_TIME regardless if there is movement or not.
          // Sleep until interrupt comes in on motion sensor but send update every minute.
            tripped = false;  //reset tripped
            sleep(INTERRUPT,CHANGE, SLEEP_TIME);
          It goes without saying that SLEEP_TIME will have to be longer than the reset time of the sensor itself. My sensor element resets in about 20 seconds, which puts a lower limit to SLEEP_TIME.
          I have never been so busy since I retired!
          ben999B 1 Reply Last reply
          • ben999B ben999
            Hi all
            GrahamG
            GrahamG
            Graham
            The SLEEP_TIME define tells your board to wake up every two minutes regardless of whether there is an interrupt. If you want longer, increase this value. I think you can also set it to 0 to only wake on interrupts.
            • bgunnarbB bgunnarb
              Hi ben999
              ben999B
              ben999B
              ben999
              @bgunnarb
              Thank you very much for your message
              I added tripped = false; to my sketch but that didn't change the general behaviour : sensor still give false trigger when coming out of sleep period...
              @Graham
              Thank you very much for your message as well
              I might not have described my problem precisely enough :
              Motion sensor will be used as part of an house alarm
              I have set up a very simple rule for now (home.rules) stating that
              when sensor changed from CLOSED to OPEN
                 then sendBroadcastNotification(to me)
              This works fine and node comes out of sleep when motion triggers the interrupt. All fine.
              Trouble is when we get to the end of the sleeptime... node comes out of sleep and i get a "tripped" that sends me a notification (or later on will set the siren on!!!)
              @Graham 's idea is pretty good: keep node asleep forever until interrupt kicks in...
              But nodes do have temperature, humidity and battery statuses to share...
              I tried to load the basic sketch (ignoring temp, hum and batt) but node still behaves the same... :(
              Does it not do the same at yours ?
              unsigned long SLEEP_TIME = 120000;
              #define DIGITAL_INPUT_SENSOR 3
              #define CHILD_ID 1
                  pinMode(DIGITAL_INPUT_SENSOR, INPUT);
                  present(CHILD_ID, S_MOTION);
                  bool tripped = digitalRead(DIGITAL_INPUT_SENSOR) == HIGH;
                  send(msg.set(tripped?"1":"0"));
              Thanks a lot for your help
              • ben999B ben999
                @bgunnarb
                @Graham
                #define CHILD_ID 1
                GrahamG
                GrahamG
                Graham
                @ben999 The sketch you have will report the state of the pin every 2 minutes as well as when interrupted by motion.
                If the SR501 is still within its timeout after the last motion detected, the pin will still be high. Eventually, (the maximum length of time is about 10 minutes) the pin should go low. If it doesn't, there is a fault with the SR501.
                The timeout can be adjusted by one of the dials (see http://henrysbench.capnfatz.com/henrys-bench/arduino-sensors-and-input/arduino-hc-sr501-motion-sensor-tutorial/#Time_Delay_Adjustment). I'm not sure what the shortest period is, but it is probably less than two minutes, which would send 0 in the next message.
                You would, however, get another interrupt if more motion occurred before the two minutes are up.
                • ben999B
                  ben999B
                  ben999
                  @Graham Thank you for your reply
                  SR501 seem to work fine on two fronts:
                  • the arduino IDE serial monitor shows the SR501 going ON then OFF after 5s (as per dial)
                  • same serial monitor shows that sensor gets motion when it occurs...
                  I'll have a go with another node just to be sure
                  Thanks again for your help (both of you :) )
                  EfflonE 1 Reply Last reply
                  • Cliff KarlssonC
                    Cliff KarlssonC
                    Cliff Karlsson
                    If I wanted to add two PIRs to one sensor-node would this sketch work?
                     * Version 1.0 - Henrik Ekblad
                    // Enable debug prints
                    // #define MY_DEBUG
                    #define DIGITAL_INPUT_SENSOR_1 2
                    #define DIGITAL_INPUT_SENSOR_2 3  // The digital input you attached your motion sensor.  (Only 2 and 3 generates interrupt!)
                    #define CHILD_ID_1 1   // Id of the sensor child
                    #define CHILD_ID_2 2   // Id of the sensor child
                    // Initialize motion message
                    MyMessage msg(CHILD_ID_1, V_TRIPPED);
                        pinMode(DIGITAL_INPUT_SENSOR_1, INPUT);      // sets the motion sensor digital pin as input
                        pinMode(DIGITAL_INPUT_SENSOR_2, INPUT);      // sets the motion sensor digital pin as input
                        sendSketchInfo("Motion Sensor_Dual", "1.0");
                        present(CHILD_ID_1, S_MOTION);
                        present(CHILD_ID_2, S_MOTION);
                        bool tripped_1 = digitalRead(DIGITAL_INPUT_SENSOR_1) == HIGH;
                        bool tripped_2 = digitalRead(DIGITAL_INPUT_SENSOR_2) == HIGH;
                        Serial.println(tripped_1 || tripped_2);
                        if(tripped_1){
                        send(msg.set(tripped_1?"1":"0"));  // Send tripped value to gw
                        if(tripped_2){
                        send(msg.set(tripped_2?"1":"0"));  // Send tripped value to gw
                        sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR_1 || DIGITAL_INPUT_SENSOR_1), CHANGE, SLEEP_TIME);
                    I know PIN 2 is supposed to be connected to the radio but I read somewhere that it is not used.
                    sellierS 1 Reply Last reply
                    • ben999B ben999
                      EfflonE
                      EfflonE
                      Efflon
                      @ben999 Did you get your sensor sorted? I have the same issue with the sensor reporting tripped after going out of sleep, same goes for wait. Putting the exact same logic in a sketch without MYS and I have no issues... going crazy soon
                      • miroM
                        miroM
                        miro
                        wrote on last edited by miro
                        #24
                        Does anyone know why my sensor only reacts when I move my hand just in front of it. From a distance it does not work. Has tested with different HC-SR501 PIR and adjusted also and various radio but all gave the same result.
                        // #define MY_DEBUG
                        void presentation()  {
                          Serial.println(tripped);
                        gohanG 1 Reply Last reply
                        • miroM miro
                          // #define MY_DEBUG
                          @miro
                          have you tried to power he sensor with external 5v instead of 5v pin from arduino?
                            A Former User
                            Hi all,
                            The motion sensor project is my first using Arduino and MySensors! I've managed to get the Gateway all up and running and the motion sensor to communicate with it (using the standard ino file from the project page), but I seem to have a couple of issues:
                            • Despite the default sleep time it seems to be communicating with the Gateway constantly.
                            • Permanently displayed as in an 'On' state in Domoticz.
                            I've tried adjusting the sensitivity and time but it doesn't seem to make a difference.
                            I don't know which bit is supposed to contain the values which I can decipher with the serial protocol guide so apologies if the answer is staring me in the face!
                            Gateway received
                            0;255;3;0;9;TSF:MSG:READ,1-1-0,s=1,c=1,t=16,pt=0,l=1,sg=0:1
                            1;1;1;0;16;1
                            Node sent
                            1383086 TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=16,pt=0,l=1,sg=0,ft=0,st=OK:0
                            1383106 MCO:SLP:MS=120000,SMS=0,I1=1,M1=1,I2=255,M2=255
                            1383120 MCO:SLP:TPD
                            1383127 MCO:SLP:WUP=1
                            Any help would be appreciated :)
                            ? 1 Reply Last reply
                              try to use a 10uF or bigger capacitor on the 5v and GND, I had issues with mine triggering randomly and after using a stable 5v supply it got back to normal: in fact later on when I added the capacitor to help the NRF24 radio it also stabilized the 5V for the sensor and it is now working fine.
                              Did you try to use just a sleep(2000) without the interrupt? Just to check if it is going to sleep correctly
                              • D
                                Daanozz
                                i'm trying to get my motionsensor working, but i see only 0 in the terminal what send to the gateway. Does anyone know why i only see that 0 and not a 1? I'm asuming that 1 is a movement.
                                • bgunnarbB
                                  bgunnarbB
                                  bgunnarb
                                  I have found in my experiments with the PIR motion sensor that at least the type that I am using is extremely sensitive to ripple in the Vcc voltage.
                                  First of all, it is unstable as the feed voltage approaches 5V and then it triggers spontaneously again and again. I then tried to rise the voltage to around 11V which is the voltage that the battery eliminator gives. But that voltage has a ripple of 0.1 volt amplitude so this triggers the sensor again and again also since the arduino introduces small changes in the voltage when it processes the script.
                                  The solution was to install a LM317 voltage regulator to bring down the voltage to 8V which is then ripple free and stable. Now the PIR works very well and does not give false triggers.
                                  The arduino is fed from a separate voltage regulator giving 5V. I tried to connect the battery eliminator directly to RAW but that released the smoke from the on-board voltage regulator and as you know, when you let the smoke out from components, they no longer work. :grinning:
                                  Apparently the battery eliminator also produces some voltage spikes that are not healthy.
                                    I solved my random pir triggers with a Capacitor on the 5v pin.
                                    • ? A Former User
                                      Hi all,
                                      Gateway received
                                      1;1;1;0;16;1
                                      Node sent
                                      1383120 MCO:SLP:TPD
                                      A Former User
                                      @Kieren-Perry said in 💬 Motion Sensor:
                                      Hi all,
                                      Gateway received
                                      1;1;1;0;16;1
                                      Node sent
                                      1383120 MCO:SLP:TPD
                                      Thanks for all your comments! Tried the capacitor route but no dice. In the end, connected a 9v battery to the jack and the PIR to the VIN as the voltage from the 5v pin and USB was a little below what it should have been.
                                      • Cliff KarlssonC
                                        Cliff KarlssonC
                                        Cliff Karlsson
                                        If I want something to run for 10 seconds after a motion have been detected, how would I make this happend?
                                          Set a timer in the code, that's shouldn't be very hard to do.
