  3. Easy/Newbie PCB for MySensors
257 Posts 37 Posters 180.4k Views 38 Watching
  • A achurak1
    @sundberg84 - correct, the 5v booster looks exactly like the 3.3v booster. I have another sensor I've built manually and it works exactly like that, arduino/temp/hum/radio all work from 3.3v and pir works from 5v. I power it all with two rechargeable batteries (so ~2.6 max charged, not even 3) and it's been running good for several months already and still shows 2.45-2.50.
    @achurak1 do you know you could modify the pir sensor to work directly from batteries by removing the regulator?
    A 1 Reply Last reply
      achurak1
      @gohan - I tried to connect the 3.3v to one of the three pins where you'd usually put a jumper (H, L pads) as I've seen people discussing it on this forum and it just didn't work for me, the sensor did work, but very unstable, would fire up every time radio sends or receives something.
        Because you need to add an extra AA battery to increase voltage to around 4,5v just for the pir sensor
          achurak1
          wrote on last edited by achurak1
          #123
          @gohan - not sure how exactly it answers my question? I thought you meant I could run the pir from 3.3v. I could plug everything to an outlet and don't worry about the batteries at all. The pir works perfectly from two batteries and the 5v booster, so why would I want to add more batteries and make the whole thing much bigger?
            I was just saying that without regulators/boosters you can still make a working sensor and get a better battery life. If you don't mind battery life or you can make an outlet powered sensor, of course it makes not much sense.
            • sundberg84S
              sundberg84S
              #125
              Im doing a new revision here with RFM69 support.
              I never used the RFM69 though - is there anything I should take in mind?
              • Is it the same with IRQ as Nrf24l01+ - not used, but good to have ie. should i have a jumper so the user can connect IRQ ?
              • The antenna, is it enough with a jumper/hole so the user can solder a antenna of their own? Or is the trace/trace-length also included as the antenna?
                The problem with rfm69 is that they work on 3 different frequencies, so you have to choose which frequency you want to support. I'm not sure if the correct length for the 433mhz is good also for the 866mhz. Let's hope somebody more expert shows up 😀
                  sundberg84S
                  sundberg84S
                  @gohan - You mean with the antenna? (But the footprint is the same?)
                  Well, if the trace isnt added to the lenght of the antenna and I add a through-hole the user can just add what kind of lenght they want?
                    The trace adds up to the antenna lengths for what I have seen so far, so I'd say to play safe and leave a hole where to solder the wire antenna or even better if it's near the edge of the pcb you could design a place to mount a sma connector for a real antenna. What do you think?
                      sundberg84S
                      sundberg84S
                      @gohan - the problem is then if you buy a antenna from ebay with the right length. Added to the PCB trace the length will not match. I have to make the antenna hole as close as possible to the module then.
                        by looking around at other PCBs with sma connectors, they are close to radio module, but still a few millimeters away so I'd say you should be ok
                          sundberg84S
                          sundberg84S
                          @gohan - notised that as well. I have asked scalz over PM about this, I saw he made alot of RFM projects.
                          • sundberg84S
                            sundberg84S
                            Sneak-peak at upcoming RFM edition.
                            All input appreciated as usual.
                            • I couldnt fit a SMA connector at this point for external antenna because I dont want to remodel the PCB completley.
                              I want it to be as close looking to the original as possible to make it easier for newbies.
                            • I went with the HW/W version. I talked to scalz and the CW is smaller and better for low power but HW/W is the one at MySensors website/tutorial/shop and preffered at 5v...
                            Thoughts?
                              I thought the SMA connector could fit on the side of the PCB... oh well....
                              Btw, is the CW really smaller? I thought it was only a different pinout
                                sundberg84S
                                sundberg84S
                                @gohan - Could be - never used them :S I just checked this image and they look smaller: https://www.google.se/search?q=RFM69H&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjdzPDD2OTTAhWqK5oKHW5RCboQ_AUICygC&biw=1920&bih=941#tbm=isch&q=RFM69H+pinout&imgrc=c_R-Nh2VtBGlRM:
                                Im giving it a second try with the SMA tonight... I will rotate it 180dgr and maybe I can fit it there...
                                • S shabba
                                  What is the purpose of the Raw connection under the radio connection? Designed for a jumper to supply RAW to MYSX connection?
                                  Also any other caveats to be aware of when using RAW and a 3.3 mini and skipping the regulator?
                                  dbemowskD
                                  dbemowskD
                                  @shabba the purpose is to keep the raw power away from the 16 pin breakout header if it is not needed. If you connect the jumper, you will have raw power available on pin 1 of the header.
                                  • dbemowskD
                                    dbemowskD
                                    I was working on a project last night and was using an old REV 8 board for it. After wiring it up I needed to check some things with the pins on the breakout header. When I looked at the site, which showed the REV 9 board, I noticed that the breakout header is quite different between the REV 8 and REV 9 boards. I figured that it was worth noting to people here to watch what diagram you are looking at compared to what REV of the board you are using.
                                    • dbemowskD dbemowsk
                                      sundberg84S
                                      sundberg84S
                                      #137
                                      @dbemowsk - thank you for pointing this out!
                                      Rev 8 is MysX 1.X and one of the reasons I upgraded to Rev 9 is because MysX 2.X came out. The pins are a bit changed but much better in MysX 2.X. For more details can study the changes.txt as well in the project.
                                      I will add this to Q&A for EasyPCB so other users dont miss it!
                                      Thanks again!
                                        Markus.
                                        Hi All,
                                        I have a lot of these PCBs in Rev.9 running as battery powered sensors. Also some with regulated power. They are running currentl with a NRF24L01. But i need to use on some sensors a RFM69 868 Radio. I have few breakout boards to use a RFM69 on a NRF24L01 connector. Is it possilbe just to replace the Radios on my EasyPBCs NRF to use RFM69 Radios? Think from power perspective should this be working. Well I know I have to Change also the Radio type in the Sketch. But is there anything more to do? Like cabling or specific Settings in the Sketch?
                                        Many Thanks
                                        Markus
                                        korttomaK gohanG 2 Replies Last reply
                                        • M Markus.
                                          Hi All,
                                          Many Thanks
                                          Markus
                                          korttomaK
                                          korttomaK
                                          korttoma
                                          @Markus. Keep in mind that the RFM69 radio pins are not 5V tolerable so use them only with 3.3V Pro mini. And like you said change the radio type in sketch.
                                          • Tomas
                                          12.5k
