  3. 💬 RFM69(H)W Arduino Mini Pro Shield
rfm69arduino pro minishieldrfm69hw
27 Posts 8 Posters 11.6k Views 5 Watching
  • O Offline
    O Offline
    openhardware.io
    https://www.openhardware.io/view/388/RFM69HW-Arduino-Mini-Pro-Shield
    • N Offline
      N Offline
      Interesting design. Are all those holes for cooling, or for better connection to the ground plane? How much of a difference do they make?
      Also, you may be interested in this:
      https://www.openhardware.io/view/268/RFM69HW-interstitial-board-for-Pro-Mini-Temp-Humidity-sensor
      S 1 Reply Last reply
      • J Offline
        J Offline
        jlaraujo
        They are for a better connection to the ground plane, in theory to reduce noise. They were added in the spirit of "it can't hurt".
        Thanks for sharing the interstitial board, i'm currently thinking in improving the design to overlap more of the board with the Mini Pro, i'll post some pictures of the current version already soldered tomorrow.
        Domoticz, mysensors 2.3.1, RFM69 and RF24 sensors
        • N NeverDie
          @NeverDie - Its called "Via Stitching" http://techdocs.altium.com/display/ADOH/Via+Stitching#
          Could the author add design files as well (not only gerber?).
          Im interested in the RFM antenna design. Do you have any library used for the RFM module as well?
          J N 2 Replies Last reply
            how does it connect to the Arduino? Does it sticks out or fits just completely over the mini pro?
            • S sundberg84
              J Offline
              J Offline
              jlaraujo
              @sundberg84 Well, it has no antenna, it uses a PCB SMA plug mouted horizontally, also allows a wire antenna to be connected to the SMD pad for flexibility. The library for DesignSpark is here https://github.com/NeuroRoboticTech/NRTDesignSparkLibraries.
              Unfortunately, I don't seem to be able to export the DesignSpark pcb to other format, humm, will have to think if DesignSpark is the way to go forwardm don't want to get stuck on a single platform.
              Anyway, here is the PCB file:0_1494349092804_RFM69H.pcb
              • S sundberg84
                N Offline
                N Offline
                @sundberg84 said in 💬 RFM69(H)W Arduino Mini Pro Shield:
                When it comes to RF, it seems like there are competing theories floating around. I guess via stitching is one theory. Another theory is that you want the ground plane to be as uninterrupted as possible. I've also seen a theory that says you want to have only one point of connection between nets. I'm not sure how to resolve all that, except by experimentation. That's why I'm glad the OP machine gunned his board with via's: it's something new to try for a compare/contrast. Since it doesn't add to cost, I'd be delighted if it turns out to be beneficial.
                • N NeverDie
                  @NeverDie said in 💬 RFM69(H)W Arduino Mini Pro Shield:
                  not competing, i would say complementary :)
                  • J Offline
                    J Offline
                    jlaraujo
                    Updated the project with two pictures, i'm also posting them here.
                    Regarding the performance, i haven't done many tests yet, with the limited tests that i have done i suspect that is is better now than just connecting the wires to the Arduino.
                    • S Offline
                      stevebus
                      Neat project. This will really make for much cleaner projects for me.
                      I ordered a few to play with and I'm trying to understand the connections. I soldered the RFM69 module on, no problem, and the antenna. I'll do the capacitor next.
                      However, I'm trying to figure out the GND, VCC, and IRQ connections. Are the pads the only option for connection, or do the holes next to them work too (hole a lot easier to solder than pad :-)) ? I don't see any kind of etching connecting the two visible on either the top or the bottom. I assume the intent is to connect a wire to them and then run that wire "underneath" the mini to connect to GND, VSS, and D2 respectively?
                      Sorry if that's a stupid question, as I don't have tools to via the design files.
                      --Steve
                      Vera Edge/UI7; mysensors; Arduino's and RPIs; data posted to Azure for an IoT 'dashboard' of my house
                      Opinions expressed here are my own and do not necessarily reflect Microsoft's feelings on a given topic :-)
                      J 1 Reply Last reply
                      • S stevebus
                        --Steve
                        J Offline
                        J Offline
                        jlaraujo
                        Glad the project seems interesting, the possibility to it being useful to someone else is the main reason for sharing.
                        Regarding the connections, for GND, you can connect to any of the blue dots, for VCC to the red dot, IRQ has no option other than the pad.
                        0_1496187001732_upload-f023faee-04de-4454-9623-144db56da374
                        My idea in using the pads was to make the board easier to slide below the mini, exactly like you state.
                        If you want, i can create a custom board for you with hole instead of pad, i used designspark PCB which is easy(er) to use but does not allow to export to other PCB software formats :-(.
                        • S Offline
                          stevebus
                          Thanks for the quick reply. No need for special build for IRQ (although that might be a good addition for a future rev to have that option). I can solder to a pad, it's just trickier as my E.E. training, skills, steadier hands, and better eyesight were 20+ years ago :-)
                          For the holes, out of curiosity, I see the VCC hole connection trace on the board, but I can't see how the pins are all connected to GND (i.e. can't see any traces). Is it between the layers of the board? Or am I just going blind?
                          Thanks again for the contribution as this is a very nice project.
                          • S stevebus
                            J Offline
                            J Offline
                            jlaraujo
                            @stevebus you are going blind :-D (like me probably) all those pins are in the ground plane, trying to provide a uniform ground to see if it improves the performance of the radio (by reducing outside interference). You can see that clearly on the gnd of the capacitor or in the gnd pad.
                            gohanG 1 Reply Last reply
                            • S Offline
                              stevebus
                              Ah! I see! (said the blind man :-) ).
                              I had never really paid attention to PCB design, so didn't realize there were often "planes" for some widespread connections (like ground)... makes perfect sense.
                              Thx again for the quick responses. I'll be soldering up the rest of the connections tomorrow so I'll be able to give it a test.
                              • J jlaraujo
                                @jlaraujo I am about to order sma connectors, is there anything to look for or anyone would do?
                                  @gohan - use the same size on the connector as you have when you order the boards ;)
                                    If you can find the size let me know, I looked on aliexpress and none are showing what is the supported pcb size. So either it is like standard for 1.6mm pcbs or I have no idea
                                    J S 2 Replies Last reply
                                    • S Offline
                                      stevebus
                                      Was able to finish up the soldering, and just playing with the mocksensor sketch... works great! (not sure why my pics are sideways, they are straight on my machine :-) )
                                      Looking at the RSSI data, this sensor seems to be about the same signal strength as my other sensors (maybe even slightly better, probably due to the shorter and more solid connections). So it seems that the performance of the radio is pretty good.
                                      sensor1
                                      sensor2
                                        J Offline
                                        J Offline
                                        jlaraujo
                                        @gohan It seems to be a standard sma size the 1.6mm distance between the legs, anyway if it is bigger you can solder only the top layer, if it is shorter, you can cut some legs.
                                        Not the best but it should work.
                                        • S stevebus
                                          sensor1
                                          sensor2
                                          J Offline
                                          J Offline
                                          jlaraujo
                                          @stevebus glad it is working i have an updated version of the pcb in the first production run, that will not need any extra wiring, i'll keep you guys updated on the progress.
                                          12.2k
