  3. 💬 RFM69 Livolo 1 channel 1 way EU switch(VL-C700X-1_Ver_C2)
mysensorslivolo
8 Posts 4 Posters 3.4k Views 2 Watching
  • O Offline
    O Offline
    openhardware.io
    https://www.openhardware.io/view/387/RFM69-Livolo-1-channel-1-way-EU-switchVL-C700X-1_Ver_C2
    • mtiutiuM Offline
      mtiutiuM Offline
      mtiutiu
      And...here comes the 1 channel variant for the classic Livolo switch front plate. Work in progress for both projects(1 and 2 channels)...
      • T Offline
        T Offline
        Toyman
        Am I right that Livolo needs just L wire, and not both L and L wires? Is it the same when Livolo front panel is replaced with yours? If yes, then it would significantly simplify the install process
        mtiutiuM 1 Reply Last reply
        • T Toyman
          mtiutiuM Offline
          mtiutiuM Offline
          mtiutiu
          @Toyman
          Yes you're right. And regarding the second question - the functionality is the same but you have Mysensors features on top.
          • T Offline
            T Offline
            Toyman
            Thx! I mean "when replaced with yours still needs just one wire", but it's clear now!
            • T Toyman
              mtiutiuM Offline
              mtiutiuM Offline
              mtiutiu
              @Toyman
              Yes I know what you meant. It's L(live) wire only powered. But in order to work it still needs a capacitor across the light bulb as I mentioned in the other project(https://www.openhardware.io/view/306/Livolo-2-channels-1-way-EU-switchVL-C700X-1-Ver-B8) and some modifications on the power board but this time without the 12V line wiring as it's already provided now in the new version by the Livolo manufacturer.
              • mtiutiuM Offline
                mtiutiuM Offline
                mtiutiu
                I wired the relay channels inputs in parallel on the 2x7 connector as this variant has one relay/channel only but I don't know to which of the ULN2003 IC outputs the relay is connected to on the power/relays board. So basically two of the current buffers from the ULN2003 IC have the inputs tied in parallel which I don't see to be a problem as this IC is designed to have buffers put in parallel(both inputs and outputs).
                Hope that the above makes sense.
                jirmJ 1 Reply Last reply
                • mtiutiuM mtiutiu
                  jirmJ Offline
                  jirmJ Offline
                  jirm
                  @mtiutiu
                  Wooow Wooow Wooow ! Here they are !
                  This one gang you designed will be my 1st Livolo hack
                  So many many thanks @mtiutiu
                  Best regards
