  3. Secure 5-button keyfob with enclosure (was: 8-button keyfob)
72 Posts 5 Posters 25.7k Views 7 Watching
  • MiKaM
    MiKaM
    MiKa
    V 1.1 of pcb should have really bigger side pads for battery holder, I already destroyed one pcb pads when I put in coin battery, probably reason is overheating this small pads during soldering the battery holder :angry:
    E 1 Reply Last reply
    • E
      E
      elcaron
      Thanks, I'll change that.
      BTW, I found another reason against adding a serial programming interface: To safe power, brownout detection should be disabled. If the battery runs low, erratic behavior may occur, which includes jumping to arbitrary addresses in flash. If a bootloader is still there, there is code to write to the flash, which might damage the programming. On the other hand, I highly doubt that a failing mcu will manage to go through the full process of sending an authenticated button pres, especially since high current RF tasks are involved.
      So it is probably generally advisable to not have the Arduino bootloader on there.
      • MiKaM MiKa
        E
        E
        elcaron
        wrote on last edited by elcaron
        #37
        @MiKa I have made a big new push to the repository. Here are the changes from the commit:
        • Doubled size of battery pads.
        • Added HT7333 to allow for LIR2032 lithium coin cell (Bridge pads for CR2032).
        • Changed A7 to A2 to make LED work.
        • Added SMD contacts for TX and GND for debug output (interface with pogo pins).
          (Getting TX out was hard enough, RX just wasn't worth it, I thing we really do not need to send anything to a keyfob :))
        I would have liked to put a step-up converter on there, but I have not found a possibility for one that does not need an inductor that is too bit to fit on there.
        AnticimexA 1 Reply Last reply
        • E elcaron
          AnticimexA
          AnticimexA
          Anticimex
          @elcaron you will need at least TX from your board in order to personalize the atsha204a. Lest you personalize it before you solder it on the board. The personalizer can operate without TX.
          • AnticimexA Anticimex
            E
            E
            elcaron
            @Anticimex Why? I thought there is SKIP_UART_CONFIRMATION. I have to set USER_KEY, but isn't that generated once for the whole network? I figure it doesn't have to be the keyfob node that does that ...
            • E elcaron
              AnticimexA
              AnticimexA
              Anticimex
              @elcaron yes, but how would you obtain the atsha204a serial if you want to be able to whitelist your keyfob?
              • MiKaM
                MiKaM
                MiKa
                Wow, good progress! :)
                Finnaly I start up sketch, but with USBasp is not possible to upload firmware to atmega when the radio is connected :angry: I put temporary radio via pin socket and I need to remove radio during programming :open_mouth: , maybe RFM69HCW need to have connected RESET pin or some pull-up is missing.
                From sleep mode Im able to wake up node just via SW5 wchich is conneted to pin D3 (INT1), Its possible to wake up from some sleep mode also via another pins (except D2 which is INT0)?
                E 2 Replies Last reply
                  E
                  E
                  elcaron
                  @Anticimex Ok, I see ...
                  Well, good that we have TX now :) If my current version works, I'll personalize the ATSHA outside of the board. It's really easy to solder with a hot air gun.
                  • E elcaron
                    AnticimexA
                    AnticimexA
                    Anticimex
                    @elcaron sure, that works. Just remember to take a note of the serial. Or use the TX pad you just made and run the personalizer again :)
                    • MiKaM MiKa
                      E
                      E
                      elcaron
                      @MiKa What? Unsoldering the radio is terrible ... I really don't see a reason for that, it should be SPI and the radio should do nothing ... maybe we need to pull CS low to make sure the radio is not selected? Someone here should know that ...
                      Regarding wake up: Yes, THAT I know about :) All the button pins are on PCINT1_vect: https://playground.arduino.cc/Main/PinChangeInterrupt
                      Consider setting a mask to limit it to the 5 button pins.
                        E
                        E
                        elcaron
                        @Anticimex If the personalizer can read it indefinitely, can't I just send it out over the radio?
                        • E elcaron
                          AnticimexA
                          AnticimexA
                          Anticimex
                          @elcaron no. Never. Then it can be sniffed. And made pointless.
                          • MiKaM MiKa
                            E
                            E
                            elcaron
                            @MiKa BTW, thanksfor testing. I have very little time right now, so I am glad I don't have to do the tests AND update the PCB. I still haven't finished my adapter from my 10 pin usbAVR to the 6 pin ISCP header ...
                              E
                              E
                              elcaron
                              #48
                              @Anticimex
                              1. How can it be sniffed if the transmission is AES encrypted by the RFM69?
                              2. How is it pointless if it could be read by a bad guy from a lost keyfob? I thought it was the point of the ATSHA that it can be safely lost.
                              I thought security was given because a badguy cannot change the ATSHA id and also cannot extract the PSK. SO the id doesn't seem private.
                              • MiKaM
                                MiKaM
                                MiKa
                                @elcaron No problem, I playing with it when I have time :) I will play now with interrupt changing :)
                                btw. LIR was an good idea, I have for test now CR2023 which have cca 2,75V and working distance from the gateway is really low. :)
                                • MiKaM MiKa
                                  E
                                  E
                                  elcaron
                                  #50
                                  @MiKa The LIR2032 have much smaller capacity, tough. The 4uA quiescent current of the HT7333 alone will suck them dry in about a year. Probably even destroy them, due the lack of undervoltage protection :(
                                  The solution is far from optimal.
                                  What tantalum cap capacity did you use? How low is the range?
                                  MiKaM 1 Reply Last reply
                                  • E elcaron
                                    MiKaM
                                    MiKaM
                                    MiKa
                                    @elcaron I using 10u/10V, I didnt measure distance exactly,but is "visible" difference when is node powered from USBasp(3.3V) or from 2.7 V :)
                                    • MiKaM MiKa
                                      E
                                      E
                                      elcaron
                                      #52
                                      @MiKa That is very low. I am not an expert for tantalums, but I guess 6.3V should be save, shouldn't it? You get 100uF at that size and voltage. I even managed to stack 2 of them. It might even be possible to squeeze an 220uF 3528 in there, not sure.
                                      Perhaps I should use the space on the back of the battery opposite of the HT7333 for an array of big tantalum caps.
                                      Could you maybe test the range with a strong external supply at 2.7V?
                                      • E elcaron
                                        @Anticimex
                                        AnticimexA
                                        AnticimexA
                                        Anticimex
                                        @elcaron
                                        I don't want signing security to be dependent on encryption. Especially when the sw AES encryption used for nrf24 does not use IV:a and therefore is easy to crack.
                                        And suppose you use whitelisting in your network, and the serials was exchanged OTA. So someone could figure out the serial of all secure nodes in your network.
                                        Then they could take your keyfob which has a valid hmac key stored. They cant read the key but they don't have to since they still can use it.
                                        And they also know the serial of other nodes, so they can spoof any secure node you have and you wouldn't notice.
                                        If they don't know the serial they would at least have to guess a valid node id and serial pair to be able to fake that node. And they can obtain the serial of the stolen device but if you use whitelisting you can just remove your lost node from your gw whitelist and they would not be able to use it.
                                          @elcaron
                                          E
                                          E
                                          elcaron
                                          #54
                                          @Anticimex Ok, let's take encryption out of the equation. I still don't get it.
                                          As long as the PSK is not transmitted, I don't see how HMAC could be broken. If a soft-signing device is lost, the PSK could be read. But if an ATSHA device is lost, the PSK cannot be read. An attacker could only use the PSK in combination with the fixed ID of that ATSHA; that could be un-whitelisted or blacklisted (I really would like to see blacklisting because of that, I think.)
                                          Can you sketch a valid attack with a known Id, but without a leaked PSK, or a way how my PSK could leak if I generally only expose ATSHA devices?
