  2. Announcements
  3. 💬 Building an Ethernet Gateway
133 Posts 42 Posters 102.4k Views 35 Watching
    sorry, but that is not the complete code.
    • H hiddenuser
      I am not sure where I went wrong the below code hangs half way through. I am using ENC28J60
      https://www.aliexpress.com/item/Mini-ENC28J60-Webserver-module-Ethernet-Shield-board-for-Arduino-Nano-v3-0/2037927977.html?spm=2114.40010208.4.8.mUp9p8
      #ifndef config_h
      #define config_h
      #include <stdint.h>
         MySensors configuration
      //#define MY_BAUD_RATE 9600
      //#define MY_BAUD_RATE 38400
      //#define MY_BAUD_RATE 115200
      //#define MY_NODE_ID 100
      #define MY_GATEWAY_ENC28J60
      //#define MY_GATEWAY_W5100
      //#define MY_REPEATER_FEATURE
      // The ENC28J60 ethernet module seems to have a hard time co-operate with
      // radio on the same spi bus.
      #define MY_SOFTSPI
      // When ENC28J60 is connected we have to move CE/CSN pins for NRF radio
      #ifndef MY_RF24_CE_PIN
      #define MY_RF24_CE_PIN 5
      #ifndef MY_RF24_CS_PIN
      #define MY_RF24_CS_PIN 6
      // Gateway IP address
      #define MY_IP_ADDRESS 192,168,0,66
      #define MY_PORT 5003
      //#define MY_CONTROLLER_IP_ADDRESS 192, 168, 0, 55
      #define MY_MAC_ADDRESS 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xFE
      // Flash leds on rx/tx/err
      //#define MY_LEDS_BLINKING_FEATURE
      // Set blinking period
      // Enable inclusion mode
      #define MY_DEFAULT_ERR_LED_PIN 7  // Error led pin
      #define MY_DEFAULT_RX_LED_PIN  8  // Receive led pin
      #define MY_DEFAULT_TX_LED_PIN  9  // the PCB, on board LED
      //#define MY_DISABLED_SERIAL
      #ifdef MY_DISABLED_SERIAL
      #undef MY_DEBUG
      *  Gateway config
      #define MY_GATEWAY_MAX_RECEIVE_LENGTH (100u)
      #define MY_GATEWAY_MAX_SEND_LENGTH (120u)
       * @def MY_GATEWAY_MAX_CLIENTS
      #define MY_GATEWAY_MAX_CLIENTS (1u)
      * @def MY_RX_MESSAGE_BUFFER_FEATURE
      * @brief This enabled the receiving buffer feature.
      * This feature is currently not supported for RFM69 and RS485, for RF24 MY_RF24_IRQ_PIN has to be defined.
      //#define MY_RX_MESSAGE_BUFFER_FEATURE
       * @def MY_RX_MESSAGE_BUFFER_SIZE
       * @brief Declare the amount of incoming messages that can be buffered.
      #ifdef MY_RX_MESSAGE_BUFFER_FEATURE
      #ifndef MY_RX_MESSAGE_BUFFER_SIZE
      #define MY_RX_MESSAGE_BUFFER_SIZE  (20)
       * @def MY_RF24_PA_LEVEL
      #ifndef MY_RF24_PA_LEVEL
       * @def MY_RF24_CHANNEL
      #ifndef MY_RF24_CHANNEL
      #define MY_RF24_CHANNEL  76
       * @def MY_RF24_DATARATE
      #ifndef MY_RF24_DATARATE
      #include "config.h"
      #include <UIPEthernet.h>
      Output:
      0;255;3;0;9;TSM:INIT
      0;255;3;0;9;TSF:WUR:MS=0
      0;255;3;0;9;TSM:INIT:TSP OK
      0;255;3;0;9;TSM:INIT:GW MODE
      IP: 192.168.0.66
      0;255;3;0;9;MCO:BGN:STP
      0;255;3;0;9;Eth: connect
      0;255;3;0;9;Eth: 0;0;3;0;2;
      0;255;3;0;9;Eth: 0;0;3;0;2;Get Version
      0;255;3;0;9;Eth: 0;0;3;0;18;PING
      0;255;3;0;9;TSF:MSG:READ,1-1-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
      0;255;3;0;9;TSF:MSG:BC
      0;255;3;0;9;TSF:MSG:FPAR REQ,ID=1
      0;255;3;0;9;TSF:PNG:SEND,TO=0
      0;255;3;0;9;TSF:CKU:OK
      0;255;3;0;9;TSF:MSG:GWL OK
      ketch uses 26,232 bytes (85%) of program storage space. Maximum is 30,720 bytes.
      Global variables use 1,286 bytes (62%) of dynamic memory, leaving 762 bytes for local variables. Maximum is 2,048 bytes.
      E
      E
      Ed1500
      wrote on last edited by Ed1500
      #61
      @hiddenuser That is too bad.
      I must say I find your sketch somewhat confusing. What is the purpose of the ifndef confif_h followed by a config_h?
      your config.h seems to just define the configuration. Why not just do an #include "config.h"
      The large amount of ifdefs make the sketch a little bit hard to read.
      If you are a beginner (we all have been) and make a sketch primarily for yourself, many of those ifdes are not really necessary and at least you are not losing track.
      Anyway, not trying to criticize you, but error tracking also for yrself would be easier.
      Also... you are using a soft SPI. For the ENC28J60 that is not really necessary. (not necessary for w5100 either with a little adaptation).
      So... I am afraid that at this point I cant say anything sensible about yr sketch, but I can say the ENC28J60 works, even with a shared SPI bus.
      Have you tried a working W5100 sketch with simply changing Ethernet.h into UIPEthernet.h?
      • H
        H
        hiddenuser
        @Ed1500 Thanks for you feedback. I have switched over to using W5100. However I have noticed that for some reason I am missing a data which is sent over nrf24. The gaps in the data are random and I can't seem to figure out why this is happening. BTW I am using domoticz on a pi to get the data. Initially I was using mysensor over usb to get the data and used to work fine. In order to get the update OTA I am trying to switch to ethernet Gateway and does not seem to work :(
        #define MY_SOFTSPI
        #define MY_IP_ADDRESS 192,168,0,66   // If this is disabled, DHCP is used to retrieve address
        #define MY_DEFAULT_RX_LED_PIN  7  // Receive led pin
        #define MY_DEFAULT_TX_LED_PIN  7  // Transmit led pin
        #include <Ethernet.h>
        void setup(){
          delay(10000);
        void loop(){
        E 1 Reply Last reply
          Are you running domoticz on a raspberry? If so, you could skip the arduino and connect the radio on the rpi directly.
          • H hiddenuser
            #define MY_SOFTSPI
            void setup(){
              delay(10000);
            void loop(){
            E
            E
            Ed1500
            @hiddenuser Your code seems OK apart from the fact it doesnt seem to do anything. Randomly missing data when using an nrf24 could be due to data just not arriving over the link although with shot distance that is rare. Nevertheless you could disconnect the w5100 and check a serial.print for a while to see if data is still missing.
            I dont have much experience using the soft spi, only using hardware SPI. You may want to consider Gohan' s suggestion
            H 1 Reply Last reply
            • E Ed1500
              H
              H
              hiddenuser
              wrote on last edited by hiddenuser
              #65
              @Ed1500 @gohan Thanks. I am trying to create an ehternet gateway so I can do OTAs.
              • H hiddenuser
                E
                E
                Ed1500
                @hiddenuser I understand. Not sure if that is possible through a W5100/arduino, I guess it is but might not be easy :-)
                  Ethernet gateway works either way, it is only a matter of personal taste. Personally I did go for the raspberry gw because I have less stuff around and I save an arduino board.
                  • Jonathan CaesJ
                    Jonathan CaesJ
                    Jonathan Caes
                    Hi everyone,
                    Is it possible to build an ethernet gateway with a RFM69 radio module?
                    Because I tried this a while ago and that didn't work because of a software problem in the library's. Is that already solved or not?
                      With development branch it should be solved, but I still have to try
                      • Jonathan CaesJ Jonathan Caes
                        Hi everyone,
                        E
                        E
                        Ed1500
                        @Jonathan-Caes I did, with an RFM69HW an arduino pro mini and a funduino Ethernetmodule. Used the setup from computourist in github https://github.com/computourist/RFM69-MQTT-client
                        • Toni RamosT
                          Toni RamosT
                          Toni Ramos
                          hello @Ed1500, i have the same problem as @Mitja-Blazinsek. i have a w5100 module (funduino), arduino pro mini and nrf24 radio. i try to use your tip, including a delay in setup() but it doen't work yet, the gateway isn't reached using ping. is necesary another change? did you move the setup() function in the program? thanks!!
                          • Toni RamosT Toni Ramos
                            E
                            E
                            Ed1500
                            #72
                            @Toni-Ramos Sorry to hear that. Are you using Soft SPI or hardware SPI for both?
                            Can you get any connection if you just use it as webserver without the NRF24?
                            • Toni RamosT
                              Toni RamosT
                              Toni Ramos
                              @Ed1500 i'm using softSPI as the example. I can see ping works correctly if i comment "#define MY_RADIO_NRF24". If not, the gateway shows the following messages continuosly:
                              0;255;3;0;9;TSM:FAIL:CNT=1
                              0;255;3;0;9;TSM:FAIL:PDT
                              0;255;3;0;9;TSM:FAIL:RE-INIT
                              • Toni RamosT
                                Toni RamosT
                                Toni Ramos
                                @Ed1500 after tests with different versions of the library i discovered a bad welded pin in the nrf24. It seens to work fine now,i'll conect a node to the gateway and check all
                                  E
                                  E
                                  Ed1500
                                  @Toni-Ramos Glad you got it solved. apologies I had not seen yr earlier reply yet, but thats no longer relevant.
                                  Always good to check the joints :-)
                                    What is the best way to make the gateway wait for ip address (it's set to use dhcp) when power goes down? I noticed that the gateway starts faster than the router and doesn't get the ip address so I had to push the reset button to get it to work.
                                      @gohan maybe add a wait call in before()? Not sure if before() is run early enough, but it might be worth a try.
                                      Maybe the library can be modified to try for a longer time before giving up.
                                        Maybe I could make a check if there is no client connected I could reset the board, but I was wondering if there is any was to know if the system has a valid ip
                                        • Mitja BlazinsekM
                                          Mitja BlazinsekM
                                          Mitja Blazinsek
                                          hi after long time i finaly get new w5100 module now the test sketch from arduino ide for ethernet like web server are working fine bur still don't work as a gateway in domoticz or mycontroler. i just open example gatewayw5100 from my sensor libary and upload to mega bard bit status in my controler is always down af course i set the gateway in my controler :Enabled
                                          Enabled
                                          Type
                                          Ethernet
                                          Network type
                                          MySensors
                                          Connection details
                                          Host:192.168.178.66, Port:5003
                                          Status
                                          Down
                                          Status since
                                          7 minutes ago
                                          Status message
                                          ERROR: connect timed out
