  3. 💬 4-channel switcher/dimmer
contest2017mysensorsdimmer
28 Posts 10 Posters 11.7k Views 9 Watching
  • Andrea BoarinoA
    Andrea BoarinoA
    Andrea Boarino
    HouseIOTH 1 Reply Last reply
    • HouseIOTH HouseIOT
      @tbowmo said in 💬 4-channel switcher/dimmer:
      Would you mind adding the schematics as a PDF file
      Yes, I add it soon.
      hhaliboH
      hhaliboH
      hhalibo
      wrote on last edited by hhalibo
      @HouseIOT As a newbie, I did a board completely following you schematics. But unfortunately,not working...
      I use the MYsensores-bootloader(8Mhz,V1.5.4!), and I flashed your source ino-code into the board.
      I can see the dimmer in the MYSController(as picture show), but there's no output from the X1.
      My gateway is a esp8266 wifi gateway, version is 2.1.1 and it works fine.
      PS: After testing job, the circuits of low voltage seems work well, shortcuts x5 and x2, the indicator led show lightness change(OFF, 30 & 100). The problem maybe in the Hi-voltage parts.
      PLS help, THANKS a lot !
      • hhaliboH hhalibo
        HouseIOTH
        HouseIOTH
        HouseIOT
        @hhalibo
        Check for neutral and phase connected right. I can see only one wire of load connected to X1. Other one must be connected to neutral if on X4.1 is phase. Otherwise try to reduce down to zero R5,7,9,11. May be not open the optocouplers.
        hhaliboH 1 Reply Last reply
        • Andrea BoarinoA Andrea Boarino
          [[topic:post-is-deleted]]
          HouseIOTH
          HouseIOTH
          HouseIOT
          @Andrea-Boarino
          Hi! It is Sanhe enclosure. I have bought it in Ukraine.
            @hhalibo
            hhaliboH
            hhaliboH
            hhalibo
            @HouseIOT THANKS for rapid reply!
            I changed the resistor(r5) to 0 as pitcture shown, no function...
            • hhaliboH hhalibo
              HouseIOTH
              HouseIOTH
              HouseIOT
              @hhalibo
              What supply voltage? 3.3V?..
              Usually if properly assembled, there should be no problems.
              hhaliboH 2 Replies Last reply
                @hhalibo
                hhaliboH
                hhaliboH
                hhalibo
                @HouseIOT supply voltage is 220v.
                  @hhalibo
                  hhaliboH
                  hhaliboH
                  hhalibo
                  @HouseIOT Hi,in your schematics, the D1 is a DIODE, but in your BOM, D1 is nothing. Maybe the problem is here?
                  • hhaliboH hhalibo
                    HouseIOTH
                    HouseIOTH
                    HouseIOT
                    @hhalibo said in 💬 4-channel switcher/dimmer:
                    is 220v
                    My English not so good, sorry. I say about low voltage on Atmega. There should be not less than 3.3v. If it is less then may not be enough current to open the optocoupler.
                    D1 i not problem. The zero crossing detect works correctly. You see it on LEDs.
                      is 220v
                      hhaliboH
                      hhaliboH
                      hhalibo
                      #26
                      @HouseIOT The voltage output from the AMS1117-3.3 is 3.29v, and the voltage of the JP1 (VCC & GND) is 3.29v.
                      And when the V_PERCENTAGE is 100, the voltage input of the pin1&2 with OK2(3,4,5) is 0.825V.
                      when V_PERCENTAGE is 30, the voltage input of the pin1&2 with OK2(3,4,5) is 0.25V.
                      except the voltage input of OK(2,3,4,5) is definitely low,others seems OK.
                      • hhaliboH
                        hhaliboH
                        hhalibo
                        #27
                        @HouseIOT
                        I replaced the led1 with a 0Ω resistor, YEAH! Works!:laughing:
                        and I will replace the led 2,3,4
                        • hhaliboH
                          hhaliboH
                          hhalibo
                          #28
                          @HouseIOT Sorry to trouble you, i use a mysensors-wifi-gateway with protocol 2.1.1 , and my homeautomation is home-assistant. I can't use your dimmer in my system.
                          After read the reference, there need to add V-percentage and V-status in the code, as a newbie , I can't do it myself. So I wondered,can you do me a favor?
                          Thanks a lot.
