  3. Raspberry Pi 3 as Gateway using RS485
10 Posts 3 Posters 8.2k Views 5 Watching
  • M Offline
    M Offline
    matz
    wrote on last edited by matz
    Hi all,
    Radio is not working between my node and my Raspberry gateway, because they are too far. When I put the node in the same room as the RPI3 it is ok but when i put the node where it should stand, it can not find parent anymore. The configuration was totally OK on RPI3 side and Node side and they can communicate, the only problem is the distance.
    I decided to switch to wired network with rs485 using MAX485 modules like this one because I have wires between them. I followed the guide on the site but it seems it lacks some info for rs485 to work. I read a lot the forum and found a lot of useful info, but node still can not find parent.
    I think my problem is on RPI3 side and the conf of RS485. What i have done :
    1. Wiring on RPI3
    I followed the 1st schema on this thread as Luc3as said he could make it worked after having set the NODE_ID. So :
    2. Wiring on Arduino Node
    I followed the same schema, so :
    3. Configuration on RPI3
    I installed everything like on the guide of the site. And configure like this :
    ./configure --my-transport=rs485
    ./configure --my-gateway=ethernet --my-port=5003
    make
    sudo ./bin/mysgw -d
    No errors doing that. On RPI3 console after launching gw in debug mode, no error message.
    4. Arduino code
    On arduino codfe side, i specified the node as it seems to help on a rs485 configuration like said
    here and lhere :
    #define MY_NODE_ID 23
    5. Result
    On Arduino, parent not found.
    I tried to change the DE pin as it seems to be 2 as default and in the first schema it seems to be 26 :
    ./configure --my-rs485-de-pin=26
    make
    sudo ./bin/mysgw -d
    Still no parent found.
    I googled a bit and i specified a serial :
    ./configure --my-rs485-serial-port=serial1
    make
    sudo ./bin/mysgw -d
    Still no parent found. I tried serial2 not better. I tried just 1 or 2, same thing. I tried also those values for serial with the DE pin set back to 2, same problem.
    Where am i wrong ? Can you help me ?
    Regards
    Matz
    mfalkviddM M 2 Replies Last reply
    • M matz
      Hi all,
      1. Wiring on RPI3
      make
      sudo ./bin/mysgw -d
      4. Arduino code
      here and lhere :
      5. Result
      make
      sudo ./bin/mysgw -d
      make
      sudo ./bin/mysgw -d
      Regards
      Matz
      @matz this might be totally wrong, but I thought all parameters had to be added at the same time to the configure script. Does it help if you run everything in one go, like this?
      ./configure --my-rs485-serial-port=serial1 --my-rs485-de-pin=26 --my-gateway=ethernet --my-port=5003 --my-transport=rs485
      • M matz
        Hi all,
        1. Wiring on RPI3
        make
        sudo ./bin/mysgw -d
        4. Arduino code
        here and lhere :
        5. Result
        make
        sudo ./bin/mysgw -d
        make
        sudo ./bin/mysgw -d
        Regards
        Matz
        M Offline
        M Offline
        matz
        I add that i di not change the baud rate on RPI side so it is 9600 and i specified it correctly on Arduino side :
        //Enable RS485 transport layer
        #define MY_RS485
        // Define this to enables DE-pin management on defined pin
        #define MY_RS485_DE_PIN 2
        // Set RS485 baud rate to use
          M Offline
          M Offline
          matz
          @mfalkvidd it seems you're right, because after doing that, do a new make and launch the gw, i have this error
          mysgw: Starting gateway...
          mysgw: MCO:BGN:INIT GW,CP=RSNG---,VER=2.1.1
          mysgw: TSF:LRT:OK
          mysgw: TSM:INIT
          mysgw: TSF:WUR:MS=0
          mysgw: Unable to open the serial port serial1
          mysgw: Failed to open serial port.
          What can i do ?
          • M matz
            mysgw: TSF:LRT:OK
            mysgw: TSM:INIT
            mysgw: TSF:WUR:MS=0
            What can i do ?
            M Offline
            M Offline
            matz
            After some search there seem to be a problem on serial on RPI3. I disabled bluetooth and done the recommendation in this link https://raspberrypi.stackexchange.com/questions/45570/how-do-i-make-serial-work-on-the-raspberry-pi3. Rebooted. But same problem even if i change the config to point to serial0 or serial1. Each time i have
            Any idea ?
            • M matz
              Any idea ?
              M Offline
              M Offline
              matz
              Ok i found the problem : serial must be set with full path : /dev/serial0
              Config is then like this :
              ./configure --my-rs485-serial-port=/dev/serial0 --my-gateway=ethernet --my-port=5003 --my-transport=rs485 --my-rs485-baudrate=9600 --my-rs485-de-pin=26
              I do another "make" to have everything taken into account.
              Also, serial on RPI3 need some attention. I followed instructions here. I have not disabled the bluetooth. I then run
              sudo ./bin/mysgw -d
              And i have :
              mysgw: TSF:LRT:OK
              mysgw: TSM:INIT
              mysgw: TSF:WUR:MS=0
              mysgw: TSM:INIT:TSP OK
              mysgw: TSM:INIT:GW MODE
              mysgw: MCO:REG:NOT NEEDED
              mysgw: MCO:BGN:STP
              mysgw: MCO:BGN:INIT OK,TSP=1
              :clap:
              But my problem is that node can not find parent... I don't understand why. Maybe the GPIO 26 on which i attach the DE ? Should i use anything else ?
              Here is what i have on node side :
              0 MCO:BGN:INIT NODE,CP=RSNNA--,VER=2.1.1
              3 MCO:BGN:BFR
              215 TSM:INIT
              216 TSF:WUR:MS=0
              218 TSM:INIT:TSP OK
              220 TSM:INIT:STATID=23
              222 TSF:SID:OK,ID=23
              223 TSM:FPAR
              241 TSF:MSG:SEND,23-23-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
              2248 !TSM:FPAR:NO REPLY
              2250 TSM:FPAR
              2268 TSF:MSG:SEND,23-23-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
              4276 !TSM:FPAR:NO REPLY
              4278 TSM:FPAR
              4295 TSF:MSG:SEND,23-23-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
              6303 !TSM:FPAR:NO REPLY
              6305 TSM:FPAR
              6323 TSF:MSG:SEND,23-23-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
              8331 !TSM:FPAR:FAIL
              8332 TSM:FAIL:CNT=1
              8334 TSM:FAIL:PDT
              18337 TSM:FAIL:RE-INIT
              18339 TSM:INIT
              18340 TSM:INIT:TSP OK
              18342 TSM:INIT:STATID=23
              18344 TSF:SID:OK,ID=23
              18348 TSM:FPAR
              18365 TSF:MSG:SEND,23-23-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
              20373 !TSM:FPAR:NO REPLY
              • M matz
                sudo ./bin/mysgw -d
                And i have :
                mysgw: TSF:LRT:OK
                mysgw: TSM:INIT
                mysgw: TSF:WUR:MS=0
                mysgw: MCO:BGN:STP
                :clap:
                3 MCO:BGN:BFR
                215 TSM:INIT
                216 TSF:WUR:MS=0
                218 TSM:INIT:TSP OK
                223 TSM:FPAR
                2250 TSM:FPAR
                4278 TSM:FPAR
                6305 TSM:FPAR
                8331 !TSM:FPAR:FAIL
                8332 TSM:FAIL:CNT=1
                8334 TSM:FAIL:PDT
                18339 TSM:INIT
                18348 TSM:FPAR
                M Offline
                M Offline
                matz
                Hello
                I found the problem : the config is waiting for the pin number, it is obvious as it is called my-rs485-de-pin, and not the GPIO number... So GPIO 26 is pin number 37. I put 37 in the config and it is now ok :)
                • M matz
                  Hello
                  Great work @matz ! Thanks for sharing the solution.
                    M Offline
                    M Offline
                    matz
                    @mfalkvidd i hope i will help somebody, we must admit that the page on the site is not really detailed on the rs485 transport mode for the raspberry pi gateway :)
                    • J Offline
                      J Offline
                      Jstoaks
                      Hi All,
                      Following along this thread for RS485, I'm having a difficult time getting any communication to be received from another RS485 Node. I've tried both the Master and Development Branchs on RPI A.
                      In Compiling the configuration in either case, I see alot of Compiler Warning during the make process.
                      Has there been any more movement regarding this repo since the last dated response in this thread. AS of June 6th 2017 - Like 5 Years AGO???
