  3. My Sensor node "motherboard" (MySensorsNode)
72 Posts 13 Posters 45.7k Views 21 Watching
  • AnticimexA
    AnticimexA
    Anticimex
    I have not used dualoptiboot. But there should not be need for a special variant of it. It is a board that takes a standard arduino pro mini so a bootloader designed for that arduino should work just fine. Just make sure to configure the proper JEDEC ID for the flash.
    • B
      B
      bilbolodz
      I've took bootloader from: https://github.com/LowPowerLab/DualOptiboot
      What JEDEC ID is correct for AT25DF512C?
      AnticimexA 1 Reply Last reply
      • B bilbolodz
        AnticimexA
        AnticimexA
        Anticimex
        #58
        @bilbolodz that is stated in the datasheet of the device. Table 12.2. Manufacturer ID is 1Fh and Device ID part 1 is 65h. So you need to define MY_OTA_FLASH_JDECID to 0x1F65 (which is default I believe).
        I don't know if you need to reconfigure DualOptiboot if you took it from LowPowerLab. Perhaps.
        • B
          B
          bilbolodz
          I've got it working BUT I've very strange "solution". I'll write it down maybe someone be able to explain me what's going on:
          I've 3 versions of "test program" 1.0, 1.1, 1.2 (actually the only difference is sketch number).
          1. I'm uploading manually with avrdude DualOptiboot from "Mysensors board package" (uploading using gui not working - gives strange error about fuses).
          2. I'm uploading (using USBasp and Arduino GUI) program version 1.0: program is working but "Reboot" command send from MYSController gets arduin into endless loop during "boot"
          0 MCO:BGN:INIT REPEATER,CP=RNORAA-,VER=2.1.1
          4 TSM:INIT
          4 TSF:WUR:MS=0
          12 TSM:INIT:TSP OK
          14 TSF:0 MCO:BGN:INIT REPEATER,CP=RNORAA-,VER=2.1.1
          4 TSM:INIT
          4 TSF:WUR:MS=0
          12 TSM:INIT:TSP OK
          1. Physical reset of board and OTA update to v 1.1 using MYSControler. OTA update is finished but at the end "endless loop"
          133398 OTA:FWP:RECV B=0000
          133400 OTA:FWP:FW END
          136038 OTA:CRC:B=05A8,C=6506,F=6506
          136040 OTA:FWP:CRC OK
          4 TSM:INIT
          4 TSF:WUR:MS=0
          12 TSM:INIT:TSP OK
          14 TSF:�0 MCO:BGN:INIT REPEATER,CP=RNORAA-,VER=2.1.1
          4 TSM:INIT
          4 TSF:WUR:MS=0
          12 TSM:INIT:TSP OK
          1. Physical reset of board: still version 1.0 present and running, reboot NOT working
          2. One again I program bootloader using command:
          avrdude -c usbasp -p m328p -u -U flash:w:optiboot_atmega328_pro_8MHz.hex
          1. Surprise, surprise: version 1.1 present and running, reboot command WORKING!
          2. After these I can program freely (using OTA) other versions of program (e.x. 1.2 or even "start version" 1.0)
          I'm making some STUPID mistake but I can't find it......
          AnticimexA rozpruwaczR 2 Replies Last reply
          • B bilbolodz
            4 TSM:INIT
            4 TSF:WUR:MS=0
            12 TSM:INIT:TSP OK
            4 TSM:INIT
            4 TSF:WUR:MS=0
            12 TSM:INIT:TSP OK
            4 TSM:INIT
            4 TSF:WUR:MS=0
            12 TSM:INIT:TSP OK
            4 TSM:INIT
            4 TSF:WUR:MS=0
            12 TSM:INIT:TSP OK
            AnticimexA
            AnticimexA
            Anticimex
            @bilbolodz hm, sorry. Can't really help there. The board should be SenseBender compatible so what ever flow is described for that board (and bootloader designed for that board) should work on this. But perhaps the fact that this one has a pro mini and not just a vanilla atmega cause it to behave differently in some way.
            • B bilbolodz
              4 TSM:INIT
              4 TSF:WUR:MS=0
              12 TSM:INIT:TSP OK
              4 TSM:INIT
              4 TSF:WUR:MS=0
              12 TSM:INIT:TSP OK
              4 TSM:INIT
              4 TSF:WUR:MS=0
              12 TSM:INIT:TSP OK
              4 TSM:INIT
              4 TSF:WUR:MS=0
              12 TSM:INIT:TSP OK
              rozpruwaczR
              rozpruwaczR
              rozpruwacz
              @bilbolodz I had also problems with DualOptiboot and OTA. It is very poorly documented. As I understand how it works, If you burn the bootloader first and then the program You actually erasing the bootloader that you burned before (thats why it is in "endless loop"). The bootloader must be burned after the program is already on the external flash, so it can load that program into the internal memory. To do that:
              1. upload the program to the board
              2. fire the ota update to write the same program to the external flash
              3. program the bootloader
              after that you will have the bootloader and OTA working.
              B 1 Reply Last reply
              • rozpruwaczR rozpruwacz
                B
                B
                bilbolodz
                @rozpruwacz
                I've made some test. It looks that bootloader is "damaged" ONLY if sketch is loaded using programmer (USBASP in my case). If sketch is loaded via serial and bootloader all is fine. So correct usage should be:
                1. Program DualOptiboot bootloader using programmer
                2. Upload sketch using serial port and DualOptiboot bootloader
                • B bilbolodz
                  @rozpruwacz
                  rozpruwaczR
                  rozpruwaczR
                  rozpruwacz
                  @bilbolodz LOL, You are absolutely right :D thats why it is called "Dual" :P because it can also boot from the serial port ... thanks !!
                  • AnticimexA Anticimex
                    EDIT: BOMs are now uploaded as well. I have to inspect the gerbers one more time but it is close to manufacture now :)
                    B
                    B
                    bilbolodz
                    @Anticimex
                    Could you please:
                    1. Point me to drop in replacement for DMP3056L-7? It's hard to get in my area...
                    2. Tell where can I buy SI7021 chip?
                    • B bilbolodz
                      @Anticimex
                      Could you please:
                      AnticimexA
                      AnticimexA
                      Anticimex
                      @bilbolodz you find all sourcing information I have on github
                      • B bilbolodz
                        @Anticimex
                        Could you please:
                        rozpruwaczR
                        rozpruwaczR
                        rozpruwacz
                        @bilbolodz said in My Sensor node "motherboard" (MySensorsNode):
                        SI7021
                        fo the transistor search for P-CHANNEL MOSFET with Low On-Resistance (the lower the better, the DMP3056L has 500mOhms) and the transistor must be rated for voltage grater than your power supply (Drain-Source Voltage parameter in datasheet, which is negative value but think of it as it would be positive)
                          B
                          B
                          bilbolodz
                          @Anticimex I've checked it but in most cases all sources you've mentioned have very expensive shipment to Poland.
                          How about DMP3056L-7 replacement? I've found it on aliexpres but shipment are twice such expensive as 35 pieces of transistor.
                          • B bilbolodz
                            rozpruwaczR
                            rozpruwaczR
                            rozpruwacz
                            @bilbolodz You can buy an SI7021 module and desolder it :D https://botland.com.pl/czujniki-temperatury/6554-si7021-czujniki-temperatury-i-wilgotnosci-i2c-sparkfun.html
                            • B
                              B
                              bilbolodz
                              @rozpruwacz said in My Sensor node "motherboard" (MySensorsNode):
                              SI7021
                              Found it on ebay:
                              http://www.ebay.com/itm/SI7021-A10-GM1R-Digital-Temperature-and-Humidity-Sensor-Module-F-Arduino-Si7021-/132179773960?hash=item1ec6874a08:g:oL0AAOSw~y9ZCf9o
                              Still looking for good source of DMP3056L-7 or replecement
                              • AnticimexA
                                AnticimexA
                                Anticimex
                                I cannot help on country specific sourcing alternatives. It would be impossible for me to create a list for the cheapest sourcing alternatives for every country. You have all part information in the BOM. So it should be relatively easy for you to search the parts. And if you want alternatives, do a parametric search at your preferred suppliers.
                                • B
                                  B
                                  bilbolodz
                                  Do you have suggestion how to mount RFM69 radio module? "Standard" 2.54 gold pin won't fit....
                                  • B bilbolodz
                                    AnticimexA
                                    AnticimexA
                                    Anticimex
                                    @bilbolodz well, no it is 2mm pitch.
