  3. OpenHAB
  4. openHAB 2.0 binding
openHAB 2.0 binding
534 Posts 88 Posters 676.7k Views 99 Watching
  • carlylerC
    carlylerC
    carlyler
    wrote on last edited by carlyler
    #448
    I am trying to make use of the customSensor using org.openhab.binding.mysensors-2.1.0-SNAPSHOT.jar I see the node 12 var4 message arrive but it is not being assigned to my item; am I doing something wrong? I have tried both string and number item types.
    10:37:37.879 [DEBUG] [rsAbstractConnection$MySensorsReader] - 12;0;1;0;27;1023
    10:37:37.880 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 12 found in gateway
    10:37:37.881 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 0 found in node 12
    10:37:37.882 [DEBUG] [ensors.handler.MySensorsThingHandler] - Updating channel: var4(27) value to: 1023
    10:37:37.896 [DEBUG] [ensors.handler.MySensorsThingHandler] - Setting last update for node/child 12/0 to 2017-06-03T10:37:37.000-0400
    10:37:37.901 [DEBUG] [rsAbstractConnection$MySensorsReader] - 12;255;3;0;22;63464
    10:37:37.912 [INFO ] [marthome.event.ItemStateChangedEvent] - Sensor12LastUpdate changed from 2017-06-03T10:37:26.000-0400 to 2017-06-03T10:37:37.000-0400
    10:37:37.925 [INFO ] [marthome.event.ItemStateChangedEvent] - mySMsg01 changed from 1;4;1;0;1;64.2 to 12;0;1;0;27;1023
    10:37:37.935 [INFO ] [marthome.event.ItemStateChangedEvent] - mySMsg01 changed from 12;0;1;0;27;1023 to 12;255;3;0;22;63464
    10:37:41.974 [DEBUG] [rsAbstractConnection$MySensorsReader] - 2;0;1;0;17;544
    10:37:41.975 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 2 found in gateway
    10:37:41.976 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 0 found in node 2
    10:37:41.976 [DEBUG] [ensors.handler.MySensorsThingHandler] - Updating channel: watt(17) value to: 544
    10:37:41.984 [DEBUG] [ensors.handler.MySensorsThingHandler] - Setting last update for node/child 2/0 to 2017-06-03T10:37:41.000-0400
    10:37:41.995 [INFO ] [marthome.event.ItemStateChangedEvent] - watt01 changed from 547 to 544
    10:37:42.005 [DEBUG] [rsAbstractConnection$MySensorsReader] - 2;0;1;0;24;1138982
    10:37:42.006 [INFO ] [marthome.event.ItemStateChangedEvent] - Sensor02LastUpdate changed from 2017-06-03T10:37:27.000-0400 to 2017-06-03
    Things
    Bridge mysensors:bridge-eth:ethGatewayPi [ ipAddress="127.0.0.1", tcpPort=5003, sendDelay=200 ]
       humidity         hum01       [ nodeId="1", childId="0" ]
       temperature      temp01      [ nodeId="1", childId="1" ]
       humidity         hum02       [ nodeId="1", childId="2" ]
       temperature      temp02      [ nodeId="1", childId="3" ]
       humidity         hum03       [ nodeId="1", childId="4" ]
       temperature      temp03      [ nodeId="1", childId="5" ]
       power            power01     [ nodeId="2", childId="0" ]
       rgbLight         rgb02       [ nodeId="6", childId="0", requestAck=true ]
       light            relay01     [ nodeId="7", childId="0", requestAck=true ]
       motion           motion01    [ nodeId="8", childId="0", requestAck=true ]
       motion           motion02    [ nodeId="9", childId="0", requestAck=true ]
       light            relay02     [ nodeId="9", childId="1", requestAck=true ]
       cover            cover03     [ nodeId="10", childId="0", requestAck=true, smartSleep=true ]
       cover            cover02     [ nodeId="11", childId="0", requestAck=true, smartSleep=true ]
       customSensor     blind01     [ nodeId="12", childId="0", requestAck=true, smartSleep=true ]
    items:
    String blind1BatReading	    "Blind#1 Battery A/D Reading"  	<battery>			{ channel="mysensors:customSensor:ethGatewayPi:blind01:var4" }
    DateTime Sensor12LastUpdate "Last seen Nd12 [%1$ta %1$tT]"       <clock>    	{ channel="mysensors:customSensor:ethGatewayPi:blind01:lastupdate" }
    edit 6/7: I stand corrected, the variables are being updated. I was fooled by the log. For some reason the log does not show the change the way it did it binding 2.0.0. I placed debug messages in my rules and they're updating.
    • T TimO
      @RVMRVM could you give this one a try?
      https://github.com/tobof/openhab2-addons/issues/76
      It is not yet integrated into the main branch. If you could test it and give me some feedback I would be very grateful. :)
      matt shepherd
      @TimO is it possible to configure using paper ui?
      cheers
      Matt
      • T TimO
        @the-trung This thread is OpenHAB and MySensors binding related. Better ask here: https://community.openhab.org
        In your case I suppose you need to switch chmod with chown. :)
        the trung
        @TimO
        I follow your guid and it's ok, then i checks karaf and see there 0_1496630110147_karaf2.png
        is this mean i installed my binding?
        and i have question
        did you fix error : Unable to install bundle openhab-transport-serial
        thanks you so much
        • M matt shepherd
          cheers
          Matt
          TimO
          @matt-shepherd yes!
          • carlylerC carlyler
            Things
            items:
            TimO
            @carlyler thank you for filing an issue, I'll look into it.
            • T the trung
              @TimO
              and i have question
              thanks you so much
              TimO
              @the-trung yes, the binding seems to be installed. Serial transport is needed for MySensors. I'm not able to answer questions about mcp binding.
              RVMRVMR 2 Replies Last reply
              • T TimO
                RVMRVMR
                RVMRVMR
                RVMRVM
                @TimO Hey Tim, before i start test , i have installed OH2.1 build #925 on 2 new W8 pc's.
                download the org.openhab.binding.mysensors-2.1.0-SNAPSHOT.jar file and put it in the addons folder.
                result:
                2017-06-10 15:01:27.812 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at /start
                2017-06-10 15:01:27.922 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
                2017-06-10 15:01:28.031 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
                2017-06-10 15:01:28.250 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
                2017-06-10 15:01:28.281 [ERROR] [org.openhab.binding.mysensors ] - FrameworkEvent ERROR - org.openhab.binding.mysensors
                org.osgi.framework.BundleException: Could not resolve module: org.openhab.binding.mysensors [182]
                at org.eclipse.osgi.container.Module.start(Module.java:434)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
                at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1582)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
                at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1562)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
                at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1533)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
                at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1476)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
                at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
                at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
                at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
                i cannot start the mysensors binding ...
                i have installed it on 3 diff pc's, same result , can you help mee with this, i'am stucked ..
                thanks in advance
                kind regards
                andreacioniA 1 Reply Last reply
                • RVMRVMR RVMRVM
                  result:
                  thanks in advance
                  kind regards
                  andreacioniA
                  andreacioniA
                  andreacioni
                  @RVMRVM
                  Did you run feature:install openhab-transport-serial, on OH console?
                  • RVMRVMR
                    RVMRVMR
                    RVMRVM
                    Oh yes, i dit not, that was the problem, now i can start to test the RGB-RGBW , hope that i can run this
                    thanks for the quit reaction
                    Roger
                    • T TimO
                      RVMRVMR
                      RVMRVMR
                      RVMRVM
                      wrote on last edited by RVMRVM
                      #457
                      @TimO Hello, i tried the RGB & RGBW , it looks ok but there are no commands that been send to the node and this for every item, a'im new in the openHab world, so that will be the problem.
                      the result is the same for RGB & RGBW
                      my .things file:
                      Bridge mysensors:bridge-eth:gateway [ ipAddress="192.168.2.190", tcpPort=5003, sendDelay=200 ] {
                      light:RGBW_23_Status [ nodeId="23", childId="0", requestAck=false]
                      rgbwLight:RGBW_23_Color [ nodeId="23", childId="1", requestAck=false ]
                      dimmer:RGBW_23_Dimmer [ nodeId="23", childId="2", requestAck=false ]
                      my .items file:
                      Group GF_Living "Living Room" <video> (gGF)
                      /* Indoor Temperatures */
                      //Number Temperature_GF_Living "Temperature [%.1f °C]" <temperature> (Temperature, GF_Living)
                      Switch RGBW_23_Status "Living" (GF_Living, Lights) { channel="mysensors:bridge-eth:gateway:RGBW_23_Status"}
                      Dimmer RGBW_23_Dimmer "Living" <slider> (GF_Living, Lights) ["Lighting"] { channel="mysensors:bridge-eth:gateway:RGBW_23_Dimmer"}
                      Color RGBW_23_Color "RGBW Light" <colorwheel> {channel = "mysensors:bridge-eth:gateway:RGBW_23_Color"}
                      and my .sitemap file
                      sitemap rvms label="test rvms"
                      Frame label="RGBW Living" {
                      Switch item=RGBW_23_Status label="Button Switch" mappings=[ON="on",OFF="off"]
                      Slider item=RGBW_23_Dimmer switchSupport
                      Colorpicker item=RGBW_23_Color
                      as result we have:
                      0_1497172964239_upload-df31d06d-cc9b-47df-9583-831a701cdeed
                      and in the paperUI:
                      0_1497173108301_upload-088cd943-2a85-4ad4-9197-b76b075f4ffe
                      this is what the log-file shows:
                      2017-06-11 09:50:48.187 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at /start
                      2017-06-11 09:50:51.161 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'rvms.items'
                      2017-06-11 09:50:52.088 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'rvms.sitemap'
                      2017-06-11 09:50:52.187 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'rvms.things'
                      2017-06-11 09:50:52.978 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
                      2017-06-11 09:50:53.006 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
                      2017-06-11 09:50:53.073 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
                      2017-06-11 09:50:53.404 [INFO ] [assic.internal.servlet.WebAppServlet] - Started Classic UI at /classicui/app
                      2017-06-11 09:50:53.555 [WARN ] [.discovery.MySensorsDiscoveryService] - Cannot automatic discover thing node: 0, child: 255 please insert it manually
                      2017-06-11 09:50:53.558 [INFO ] [al.protocol.ip.MySensorsIpConnection] - Successfully connected to MySensors Bridge.
                      2017-06-11 09:55:56.976 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'rvms.things'
                      2017-06-11 09:55:56.988 [WARN ] [rsAbstractConnection$MySensorsWriter] - Interrupted MySensorsWriter
                      2017-06-11 09:55:56.989 [WARN ] [rsAbstractConnection$MySensorsReader] - Interrupted MySensorsReader
                      2017-06-11 09:55:58.010 [WARN ] [.discovery.MySensorsDiscoveryService] - Cannot automatic discover thing node: 0, child: 255 please insert it manually
                      2017-06-11 09:55:58.020 [INFO ] [al.protocol.ip.MySensorsIpConnection] - Successfully connected to MySensors Bridge.
                      2017-06-11 10:08:57.483 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'rvms.sitemap'
                      so what is wrong here ?
                      thanks in advance
                      Roger
                      • FusedHe3F
                        FusedHe3F
                        FusedHe3
                        Hi @TimO,
                        I also tried the RGB Light and it seems to be working! (I am using Maghac's RGB LED strip sketch)
                        Auto discovery worked instantly. I did have to work with the .items file to get the color picker instead of a text input. I also get these two errors every time I send a command:
                        16:57:36.770 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'rgbLight01' received command 124,89,100
                        16:57:36.809 [INFO ] [marthome.event.ItemStateChangedEvent] - rgbLight01 changed from 359,91,100 to 124,89,100
                        16:57:37.117 [WARN ] [rs.internal.gateway.MySensorsGateway] - Variable 2 not present
                        16:57:37.222 [WARN ] [rs.internal.gateway.MySensorsGateway] - Variable 3 not present
                        As I'm relatively new to MySensors, I was wondering if it is normal that the RGB Light Sensor channel is used for this. Or is this just temporary until an actual RGB channel is made?
                          matt shepherd
                          I've been trying to figure this out for a while. For me openhab discovers 4 things Red, Green, Blue and Status. These are all dimmers and I can't get them all to work together as 1 colour wheel? They all work really well independently but that's as far as I got. I've also tried the .items file but with no luck.
                          carlylerC 1 Reply Last reply
                          • D
                            doctor64
                            Hello!
                            I just started to play with OpenHab2 and new binding? thank you for great work.
                            But, i discover some strange behavior:
                            Openhab2, ethernet gateway, 3 mysensor nodes, all nodes sucessfully detected and configured in PaperUI, but some data looks like not updated. Looking to log i note some suspicious lines like:
                            00:28:47.077 [DEBUG] [rsAbstractConnection$MySensorsReader] - 3;1;1;0;0;24.6
                            00:28:47.078 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 3 found in gateway
                            00:28:47.078 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 1 found in node 3
                            00:28:47.078 [WARN ] [rs.internal.gateway.MySensorsGateway] - Variable 0 not present
                            Sorry, i don't know how to dump OpenHab configuration, but item configured.
                            Any suggestions?
                            • M matt shepherd
                              carlylerC
                              carlylerC
                              carlyler
                              @matt-shepherd What works for me :
                              items - just used 1 channel, V_VAR1, but you could keep them separate
                              String neoPixelRgb           "RGB LED string"                           (grpLighting)  { channel="mysensors:rgbLight:ethGateway:rgb01:var1" }
                              Color neoPixelColor         "RGB LED string"            <colorwheel>    (grpLighting)
                              rule
                              rule "Set RGB value NeoPixelStrip"
                              when
                                  Item neoPixelColor changed
                              then
                                  val hsbValue = neoPixelColor.state as HSBType
                                  val brightness = hsbValue.brightness.intValue
                                  val redValue = ((((hsbValue.red.intValue * 255) / 100) * brightness) / 100)
                                  val grnValue = ((((hsbValue.green.intValue * 255) / 100) * brightness) / 100)
                                  val bluValue = ((((hsbValue.blue.intValue * 255) / 100) * brightness) / 100)
                                  val rgbHexString = String::format("%02X%02X%02X", redValue, grnValue, bluValue)
                                  sendCommand(neoPixelRgb, rgbHexString)
                              end
                              parsed in node
                                if (message.type == V_VAR1)
                                  Serial.print(", New status, V_RGB: ");
                                  // starting to process the hex code
                                  String hexstring = message.getString(); //here goes the hex color code coming from through MySensors (like FF9A00)
                                  long number = (long) strtol( &hexstring[0], NULL, 16);
                                  RGB_values[0] = number >> 16;
                                  RGB_values[1] = number >> 8 & 0xFF;
                                  RGB_values[2] = number & 0xFF;
                                  colorWipe(strip.Color(RGB_values[0], RGB_values[1], RGB_values[2]), 50);
                              • T TimO
                                RVMRVMR
                                RVMRVMR
                                RVMRVM
                                #462
                                @TimO Hey all, looks everything seems to work now, but now i have defined the bindings by the paper UI, and work with the rule definition as show by 'doctor64' ....
                                thanks for the help
                                Roger
                                • FusedHe3F FusedHe3
                                  Hi @TimO,
                                  TimO
                                  @FusedHe3 Thank you for testing and your input!
                                  The sketch you are using is representing itself as a RGB sensor and the log you've posted looks good.
                                  About the fiddling with the .items file and the color picker: Thank you! That should'nt be needed anymore, I've changed it here: RGB-Test-Binding
                                  FusedHe3F 2 Replies Last reply
                                  • RVMRVMR RVMRVM
                                    thanks for the help
                                    Roger
                                    TimO
                                    @RVMRVM The definitions carlyler posted looks fine and I've tried to implement this logic into the binding so you won't need the rule anymore. Feel free to test my binding or stay with the rule. Hopefully both would lead to the same result. :)
                                    RVMRVMR 1 Reply Last reply
                                    • D doctor64
                                      Hello!
                                      Any suggestions?
                                      TimO
                                      Hey @doctor64 !
                                      Please open a new topic. This one is getting really huge. :-)
                                      Please check if the temperature channel is linked. In PaperUI you may do this by moving to "Configuration" -> "Things" and click on the sensor data.
                                      D 1 Reply Last reply
                                      • T TimO
                                        FusedHe3F
                                        FusedHe3F
                                        FusedHe3
                                        @TimO No problem, glad to help!
                                        I'll try to alter the sketch and use the new version of the binding as soon as I have my LED strip running again.
                                        • T TimO
                                          RVMRVMR
                                          RVMRVMR
                                          RVMRVM
                                          #467
                                          @TimO Perfect, is OK for RGB & RGBW... but now the datastring you send is a decimal string, not a HEX-string as they used normal, it is not a big problem to change this feature in the node script, if you want to have a decimal string.
                                          How do you handle the white color, becaus this is not included in the datastring info. maybe by a switch and a other variable .
                                          something like this:
                                          0_1497272329084_upload-bc139de4-29ff-4760-ac5e-7746249546fc
                                          Roger
