  3. OpenHAB
  4. openHAB 2.0 binding
openHAB 2.0 binding
534 Posts 88 Posters 677.3k Views 99 Watching
  • carlylerC carlyler
    I am trying to make use of the customSensor using org.openhab.binding.mysensors-2.1.0-SNAPSHOT.jar I see the node 12 var4 message arrive but it is not being assigned to my item; am I doing something wrong? I have tried both string and number item types.
    10:37:37.879 [DEBUG] [rsAbstractConnection$MySensorsReader] - 12;0;1;0;27;1023
    10:37:37.880 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 12 found in gateway
    10:37:37.881 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 0 found in node 12
    10:37:37.882 [DEBUG] [ensors.handler.MySensorsThingHandler] - Updating channel: var4(27) value to: 1023
    10:37:37.896 [DEBUG] [ensors.handler.MySensorsThingHandler] - Setting last update for node/child 12/0 to 2017-06-03T10:37:37.000-0400
    10:37:37.901 [DEBUG] [rsAbstractConnection$MySensorsReader] - 12;255;3;0;22;63464
    10:37:37.912 [INFO ] [marthome.event.ItemStateChangedEvent] - Sensor12LastUpdate changed from 2017-06-03T10:37:26.000-0400 to 2017-06-03T10:37:37.000-0400
    10:37:37.925 [INFO ] [marthome.event.ItemStateChangedEvent] - mySMsg01 changed from 1;4;1;0;1;64.2 to 12;0;1;0;27;1023
    10:37:37.935 [INFO ] [marthome.event.ItemStateChangedEvent] - mySMsg01 changed from 12;0;1;0;27;1023 to 12;255;3;0;22;63464
    10:37:41.974 [DEBUG] [rsAbstractConnection$MySensorsReader] - 2;0;1;0;17;544
    10:37:41.975 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 2 found in gateway
    10:37:41.976 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 0 found in node 2
    10:37:41.976 [DEBUG] [ensors.handler.MySensorsThingHandler] - Updating channel: watt(17) value to: 544
    10:37:41.984 [DEBUG] [ensors.handler.MySensorsThingHandler] - Setting last update for node/child 2/0 to 2017-06-03T10:37:41.000-0400
    10:37:41.995 [INFO ] [marthome.event.ItemStateChangedEvent] - watt01 changed from 547 to 544
    10:37:42.005 [DEBUG] [rsAbstractConnection$MySensorsReader] - 2;0;1;0;24;1138982
    10:37:42.006 [INFO ] [marthome.event.ItemStateChangedEvent] - Sensor02LastUpdate changed from 2017-06-03T10:37:27.000-0400 to 2017-06-03
    Things
    Bridge mysensors:bridge-eth:ethGatewayPi [ ipAddress="127.0.0.1", tcpPort=5003, sendDelay=200 ]
       humidity         hum01       [ nodeId="1", childId="0" ]
       temperature      temp01      [ nodeId="1", childId="1" ]
       humidity         hum02       [ nodeId="1", childId="2" ]
       temperature      temp02      [ nodeId="1", childId="3" ]
       humidity         hum03       [ nodeId="1", childId="4" ]
       temperature      temp03      [ nodeId="1", childId="5" ]
       power            power01     [ nodeId="2", childId="0" ]
       rgbLight         rgb02       [ nodeId="6", childId="0", requestAck=true ]
       light            relay01     [ nodeId="7", childId="0", requestAck=true ]
       motion           motion01    [ nodeId="8", childId="0", requestAck=true ]
       motion           motion02    [ nodeId="9", childId="0", requestAck=true ]
       light            relay02     [ nodeId="9", childId="1", requestAck=true ]
       cover            cover03     [ nodeId="10", childId="0", requestAck=true, smartSleep=true ]
       cover            cover02     [ nodeId="11", childId="0", requestAck=true, smartSleep=true ]
       customSensor     blind01     [ nodeId="12", childId="0", requestAck=true, smartSleep=true ]
    items:
    String blind1BatReading	    "Blind#1 Battery A/D Reading"  	<battery>			{ channel="mysensors:customSensor:ethGatewayPi:blind01:var4" }
    DateTime Sensor12LastUpdate "Last seen Nd12 [%1$ta %1$tT]"       <clock>    	{ channel="mysensors:customSensor:ethGatewayPi:blind01:lastupdate" }
    edit 6/7: I stand corrected, the variables are being updated. I was fooled by the log. For some reason the log does not show the change the way it did it binding 2.0.0. I placed debug messages in my rules and they're updating.
    TimO
    @carlyler thank you for filing an issue, I'll look into it.
    • T the trung
      @TimO
      I follow your guid and it's ok, then i checks karaf and see there 0_1496630110147_karaf2.png
      is this mean i installed my binding?
      and i have question
      did you fix error : Unable to install bundle openhab-transport-serial
      thanks you so much
      TimO
      @the-trung yes, the binding seems to be installed. Serial transport is needed for MySensors. I'm not able to answer questions about mcp binding.
      RVMRVMR 2 Replies Last reply
      • T TimO
        @RVMRVM could you give this one a try?
        https://github.com/tobof/openhab2-addons/issues/76
        It is not yet integrated into the main branch. If you could test it and give me some feedback I would be very grateful. :)
        RVMRVMR
        RVMRVMR
        RVMRVM
        @TimO Hey Tim, before i start test , i have installed OH2.1 build #925 on 2 new W8 pc's.
        download the org.openhab.binding.mysensors-2.1.0-SNAPSHOT.jar file and put it in the addons folder.
        result:
        2017-06-10 15:01:27.812 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at /start
        2017-06-10 15:01:27.922 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
        2017-06-10 15:01:28.031 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
        2017-06-10 15:01:28.250 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
        2017-06-10 15:01:28.281 [ERROR] [org.openhab.binding.mysensors ] - FrameworkEvent ERROR - org.openhab.binding.mysensors
        org.osgi.framework.BundleException: Could not resolve module: org.openhab.binding.mysensors [182]
        at org.eclipse.osgi.container.Module.start(Module.java:434)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
        at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1582)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
        at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1562)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
        at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1533)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
        at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1476)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
        at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
        at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
        at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
        i cannot start the mysensors binding ...
        i have installed it on 3 diff pc's, same result , can you help mee with this, i'am stucked ..
        thanks in advance
        kind regards
        andreacioniA 1 Reply Last reply
        • RVMRVMR RVMRVM
          result:
          thanks in advance
          kind regards
          andreacioniA
          andreacioniA
          andreacioni
          @RVMRVM
          Did you run feature:install openhab-transport-serial, on OH console?
          • RVMRVMR
            RVMRVMR
            RVMRVM
            Oh yes, i dit not, that was the problem, now i can start to test the RGB-RGBW , hope that i can run this
            thanks for the quit reaction
            Roger
            • T TimO
              RVMRVMR
              RVMRVMR
              RVMRVM
              wrote on last edited by RVMRVM
              #457
              @TimO Hello, i tried the RGB & RGBW , it looks ok but there are no commands that been send to the node and this for every item, a'im new in the openHab world, so that will be the problem.
              the result is the same for RGB & RGBW
              my .things file:
              Bridge mysensors:bridge-eth:gateway [ ipAddress="192.168.2.190", tcpPort=5003, sendDelay=200 ] {
              light:RGBW_23_Status [ nodeId="23", childId="0", requestAck=false]
              rgbwLight:RGBW_23_Color [ nodeId="23", childId="1", requestAck=false ]
              dimmer:RGBW_23_Dimmer [ nodeId="23", childId="2", requestAck=false ]
              my .items file:
              Group GF_Living "Living Room" <video> (gGF)
              /* Indoor Temperatures */
              //Number Temperature_GF_Living "Temperature [%.1f °C]" <temperature> (Temperature, GF_Living)
              Switch RGBW_23_Status "Living" (GF_Living, Lights) { channel="mysensors:bridge-eth:gateway:RGBW_23_Status"}
              Dimmer RGBW_23_Dimmer "Living" <slider> (GF_Living, Lights) ["Lighting"] { channel="mysensors:bridge-eth:gateway:RGBW_23_Dimmer"}
              Color RGBW_23_Color "RGBW Light" <colorwheel> {channel = "mysensors:bridge-eth:gateway:RGBW_23_Color"}
              and my .sitemap file
              sitemap rvms label="test rvms"
              Frame label="RGBW Living" {
              Switch item=RGBW_23_Status label="Button Switch" mappings=[ON="on",OFF="off"]
              Slider item=RGBW_23_Dimmer switchSupport
              Colorpicker item=RGBW_23_Color
              as result we have:
              0_1497172964239_upload-df31d06d-cc9b-47df-9583-831a701cdeed
              and in the paperUI:
              0_1497173108301_upload-088cd943-2a85-4ad4-9197-b76b075f4ffe
              this is what the log-file shows:
              2017-06-11 09:50:48.187 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at /start
              2017-06-11 09:50:51.161 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'rvms.items'
              2017-06-11 09:50:52.088 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'rvms.sitemap'
              2017-06-11 09:50:52.187 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'rvms.things'
              2017-06-11 09:50:52.978 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
              2017-06-11 09:50:53.006 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
              2017-06-11 09:50:53.073 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
              2017-06-11 09:50:53.404 [INFO ] [assic.internal.servlet.WebAppServlet] - Started Classic UI at /classicui/app
              2017-06-11 09:50:53.555 [WARN ] [.discovery.MySensorsDiscoveryService] - Cannot automatic discover thing node: 0, child: 255 please insert it manually
              2017-06-11 09:50:53.558 [INFO ] [al.protocol.ip.MySensorsIpConnection] - Successfully connected to MySensors Bridge.
              2017-06-11 09:55:56.976 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'rvms.things'
              2017-06-11 09:55:56.988 [WARN ] [rsAbstractConnection$MySensorsWriter] - Interrupted MySensorsWriter
              2017-06-11 09:55:56.989 [WARN ] [rsAbstractConnection$MySensorsReader] - Interrupted MySensorsReader
              2017-06-11 09:55:58.010 [WARN ] [.discovery.MySensorsDiscoveryService] - Cannot automatic discover thing node: 0, child: 255 please insert it manually
              2017-06-11 09:55:58.020 [INFO ] [al.protocol.ip.MySensorsIpConnection] - Successfully connected to MySensors Bridge.
              2017-06-11 10:08:57.483 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'rvms.sitemap'
              so what is wrong here ?
              thanks in advance
              Roger
              • FusedHe3F
                FusedHe3F
                FusedHe3
                Hi @TimO,
                I also tried the RGB Light and it seems to be working! (I am using Maghac's RGB LED strip sketch)
                Auto discovery worked instantly. I did have to work with the .items file to get the color picker instead of a text input. I also get these two errors every time I send a command:
                16:57:36.770 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'rgbLight01' received command 124,89,100
                16:57:36.809 [INFO ] [marthome.event.ItemStateChangedEvent] - rgbLight01 changed from 359,91,100 to 124,89,100
                16:57:37.117 [WARN ] [rs.internal.gateway.MySensorsGateway] - Variable 2 not present
                16:57:37.222 [WARN ] [rs.internal.gateway.MySensorsGateway] - Variable 3 not present
                As I'm relatively new to MySensors, I was wondering if it is normal that the RGB Light Sensor channel is used for this. Or is this just temporary until an actual RGB channel is made?
                  matt shepherd
                  I've been trying to figure this out for a while. For me openhab discovers 4 things Red, Green, Blue and Status. These are all dimmers and I can't get them all to work together as 1 colour wheel? They all work really well independently but that's as far as I got. I've also tried the .items file but with no luck.
                  carlylerC 1 Reply Last reply
                  • D
                    doctor64
                    Hello!
                    I just started to play with OpenHab2 and new binding? thank you for great work.
                    But, i discover some strange behavior:
                    Openhab2, ethernet gateway, 3 mysensor nodes, all nodes sucessfully detected and configured in PaperUI, but some data looks like not updated. Looking to log i note some suspicious lines like:
                    00:28:47.077 [DEBUG] [rsAbstractConnection$MySensorsReader] - 3;1;1;0;0;24.6
                    00:28:47.078 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 3 found in gateway
                    00:28:47.078 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 1 found in node 3
                    00:28:47.078 [WARN ] [rs.internal.gateway.MySensorsGateway] - Variable 0 not present
                    Sorry, i don't know how to dump OpenHab configuration, but item configured.
                    Any suggestions?
                    • M matt shepherd
                      carlylerC
                      carlylerC
                      carlyler
                      @matt-shepherd What works for me :
                      items - just used 1 channel, V_VAR1, but you could keep them separate
                      String neoPixelRgb           "RGB LED string"                           (grpLighting)  { channel="mysensors:rgbLight:ethGateway:rgb01:var1" }
                      Color neoPixelColor         "RGB LED string"            <colorwheel>    (grpLighting)
                      rule
                      rule "Set RGB value NeoPixelStrip"
                      when
                          Item neoPixelColor changed
                      then
                          val hsbValue = neoPixelColor.state as HSBType
                          val brightness = hsbValue.brightness.intValue
                          val redValue = ((((hsbValue.red.intValue * 255) / 100) * brightness) / 100)
                          val grnValue = ((((hsbValue.green.intValue * 255) / 100) * brightness) / 100)
                          val bluValue = ((((hsbValue.blue.intValue * 255) / 100) * brightness) / 100)
                          val rgbHexString = String::format("%02X%02X%02X", redValue, grnValue, bluValue)
                          sendCommand(neoPixelRgb, rgbHexString)
                      end
                      parsed in node
                        if (message.type == V_VAR1)
                          Serial.print(", New status, V_RGB: ");
                          // starting to process the hex code
                          String hexstring = message.getString(); //here goes the hex color code coming from through MySensors (like FF9A00)
                          long number = (long) strtol( &hexstring[0], NULL, 16);
                          RGB_values[0] = number >> 16;
                          RGB_values[1] = number >> 8 & 0xFF;
                          RGB_values[2] = number & 0xFF;
                          colorWipe(strip.Color(RGB_values[0], RGB_values[1], RGB_values[2]), 50);
                      • T TimO
                        RVMRVMR
                        RVMRVMR
                        RVMRVM
                        #462
                        @TimO Hey all, looks everything seems to work now, but now i have defined the bindings by the paper UI, and work with the rule definition as show by 'doctor64' ....
                        thanks for the help
                        Roger
                        • FusedHe3F FusedHe3
                          Hi @TimO,
                          TimO
                          @FusedHe3 Thank you for testing and your input!
                          The sketch you are using is representing itself as a RGB sensor and the log you've posted looks good.
                          About the fiddling with the .items file and the color picker: Thank you! That should'nt be needed anymore, I've changed it here: RGB-Test-Binding
                          FusedHe3F 2 Replies Last reply
                          • RVMRVMR RVMRVM
                            thanks for the help
                            Roger
                            TimO
                            @RVMRVM The definitions carlyler posted looks fine and I've tried to implement this logic into the binding so you won't need the rule anymore. Feel free to test my binding or stay with the rule. Hopefully both would lead to the same result. :)
                            RVMRVMR 1 Reply Last reply
                            • D doctor64
                              Hello!
                              Any suggestions?
                              TimO
                              Hey @doctor64 !
                              Please open a new topic. This one is getting really huge. :-)
                              Please check if the temperature channel is linked. In PaperUI you may do this by moving to "Configuration" -> "Things" and click on the sensor data.
                              D 1 Reply Last reply
                              • T TimO
                                FusedHe3F
                                FusedHe3F
                                FusedHe3
                                @TimO No problem, glad to help!
                                I'll try to alter the sketch and use the new version of the binding as soon as I have my LED strip running again.
                                • T TimO
                                  RVMRVMR
                                  RVMRVMR
                                  RVMRVM
                                  #467
                                  @TimO Perfect, is OK for RGB & RGBW... but now the datastring you send is a decimal string, not a HEX-string as they used normal, it is not a big problem to change this feature in the node script, if you want to have a decimal string.
                                  How do you handle the white color, becaus this is not included in the datastring info. maybe by a switch and a other variable .
                                  something like this:
                                  0_1497272329084_upload-bc139de4-29ff-4760-ac5e-7746249546fc
                                  Roger
                                  • RVMRVMR RVMRVM
                                    Roger
                                    TimO
                                    @RVMRVM Interesting. Do you have a corresponding log for me?
                                    Here's my test:
                                    [INFO ] [arthome.event.ItemCommandEvent:43   ] - Item 'mysensors_rgbLight_8a7ca179_rgblight_199_0_rgb' received command 71,46,91
                                    [DEBUG] [.c.thing.internal.ThingManager:366  ] - Delegating command '71,46,91' for item 'mysensors_rgbLight_8a7ca179_rgblight_199_0_rgb' to handler for channel 'mysensors:rgbLight:8a7ca179:rgblight_199_0:rgb'
                                    [DEBUG] [.m.c.MySensorsRGBTypeConverter:63   ] - Converting RGB Int to Hex: R d4, G e8, B 7d
                                    [DEBUG] [b.m.i.gateway.MySensorsGateway:563  ] - Node 199 found in gateway
                                    [DEBUG] [b.m.i.gateway.MySensorsGateway:567  ] - Child 0 found in node 199
                                    [DEBUG] [ractConnection$MySensorsWriter:524  ] - Sending to MySensors: 199;0;1;0;40;d4e87d
                                    • T TimO
                                      Here's my test:
                                      RVMRVMR
                                      RVMRVMR
                                      RVMRVM
                                      #469
                                      @TimO this is the log of the node:
                                      15:33:19.326> 15054 TSF:MSG:READ,0-0-23,s=1,c=1,t=26,pt=0,l=10,sg=0:231,81,100
                                      this is the result from the rule routine:
                                      15:39:17.479> 10919 TSF:MSG:READ,0-0-23,s=1,c=1,t=26,pt=0,l=6,sg=0:FF5E28
                                      • T TimO
                                        Hey @doctor64 !
                                        doctor64
                                        Hello @TimO !
                                        I delete all things and items (btw, seems like items not deleted completely, and re-apperas after item re-create), create things again and not see error anymore. Some black magic in action, looks like.
                                        I will create separate topic if this issue appears again. Thank you!
                                        • T TimO
                                          FusedHe3F
                                          FusedHe3F
                                          FusedHe3
                                          @TimO Just tried the changes you made. Color picker now worked straight away! :smile:
                                            sendSketchInfo(SN, SV);
