  3. OpenHAB
  4. openHAB 2.0 binding
openHAB 2.0 binding
534 Posts 88 Posters 676.7k Views 99 Watching
  • L
    L
    LastSamurai
    @RVMRVM Sorry I haven't had the time to test anything yet (was working on another project). Might take me a while to get to.
    • P patrick schaerer
      @TimO said:
      @bentrik said:
      I managed to find an addons directory in /usr/share/openhab2/addons, but I can´t find a way to copy the .jar file there, as I get permission denied both through WinSCP in sudo mode and terminal ssh. The folder has permission 0775.
      That is the correct directory if you installed OH2 via .deb. Seems like you are using a user in WinSCP that is not allowed to write to the directory above. To circumvent this:
      1. Copy the binding jar to /tmp.
      2. Login via ssh and execute:
      sudo cp /tmp/org.openhab.binding.mysensors-2.0.0-SNAPSHOT.jar /usr/share/openhab2/addons/
      and
      sudo chmod openhab.openhab /usr/share/openhab2/addons/org.openhab.binding.mysensors-2.0.0-SNAPSHOT.jar
      OH2 is started/stopped/restarted with
      service openhab2 start/stop/restart
      To log into the karaf console do:
      ssh openhab@localhost -p 8101
      Password is: habopen
      Follow the guide/wiki from:
      In the console enter feature:install openhab-transport-serial
      I have installed openhab with the openhabian image. I could start the mysensors gateway too.
      I followed the github-openhab2 installation instructions.
      To this point
      I read a lot of posts on this thread but on get this error:
      openhab> install openhab-transport-serial
      Bundle IDs:
      Error executing command: Error installing bundles:
      	Unable to install bundle openhab-transport-serial
      the chmod line posted above doesn't work neither. chmod does not accept openhab.openhab
      I dont have any clue how to install the binding for openhab2 ... why isn't that possible from paperui :-(
      the trung
      @patrick-schaerer
      hi patrick
      i follow your guide with command to install MPC23017 Binding on openhab2
      sudo chmod openhab.openhab /usr/share/openhab2/addons/org.openhab.binding.mcp23017-1.9.0.jar
      but it not work and has information" chmod: invalid mode: ‘openhab.openhab’
      then i take ":" instead of "." into account like
      sudo chmod openhab:openhab /usr/share/openhab2/addons/org.openhab.binding.mcp23017-1.9.0.jar
      but it same error
      0_1496478264776_upload-ff8c1fc1-81fa-4e92-9e2d-46d4d7ca3f33
      can you help me, please.
      thanks you
      • T the trung
        @patrick-schaerer
        hi patrick
        but it same error
        thanks you
        TimO
        @the-trung This thread is OpenHAB and MySensors binding related. Better ask here: https://community.openhab.org
        In your case I suppose you need to switch chmod with chown. :)
        • carlylerC
          carlylerC
          carlyler
          wrote on last edited by carlyler
          #448
          I am trying to make use of the customSensor using org.openhab.binding.mysensors-2.1.0-SNAPSHOT.jar I see the node 12 var4 message arrive but it is not being assigned to my item; am I doing something wrong? I have tried both string and number item types.
          10:37:37.879 [DEBUG] [rsAbstractConnection$MySensorsReader] - 12;0;1;0;27;1023
          10:37:37.880 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 12 found in gateway
          10:37:37.881 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 0 found in node 12
          10:37:37.882 [DEBUG] [ensors.handler.MySensorsThingHandler] - Updating channel: var4(27) value to: 1023
          10:37:37.896 [DEBUG] [ensors.handler.MySensorsThingHandler] - Setting last update for node/child 12/0 to 2017-06-03T10:37:37.000-0400
          10:37:37.901 [DEBUG] [rsAbstractConnection$MySensorsReader] - 12;255;3;0;22;63464
          10:37:37.912 [INFO ] [marthome.event.ItemStateChangedEvent] - Sensor12LastUpdate changed from 2017-06-03T10:37:26.000-0400 to 2017-06-03T10:37:37.000-0400
          10:37:37.925 [INFO ] [marthome.event.ItemStateChangedEvent] - mySMsg01 changed from 1;4;1;0;1;64.2 to 12;0;1;0;27;1023
          10:37:37.935 [INFO ] [marthome.event.ItemStateChangedEvent] - mySMsg01 changed from 12;0;1;0;27;1023 to 12;255;3;0;22;63464
          10:37:41.974 [DEBUG] [rsAbstractConnection$MySensorsReader] - 2;0;1;0;17;544
          10:37:41.975 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 2 found in gateway
          10:37:41.976 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 0 found in node 2
          10:37:41.976 [DEBUG] [ensors.handler.MySensorsThingHandler] - Updating channel: watt(17) value to: 544
          10:37:41.984 [DEBUG] [ensors.handler.MySensorsThingHandler] - Setting last update for node/child 2/0 to 2017-06-03T10:37:41.000-0400
          10:37:41.995 [INFO ] [marthome.event.ItemStateChangedEvent] - watt01 changed from 547 to 544
          10:37:42.005 [DEBUG] [rsAbstractConnection$MySensorsReader] - 2;0;1;0;24;1138982
          10:37:42.006 [INFO ] [marthome.event.ItemStateChangedEvent] - Sensor02LastUpdate changed from 2017-06-03T10:37:27.000-0400 to 2017-06-03
          Things
          Bridge mysensors:bridge-eth:ethGatewayPi [ ipAddress="127.0.0.1", tcpPort=5003, sendDelay=200 ]
             humidity         hum01       [ nodeId="1", childId="0" ]
             temperature      temp01      [ nodeId="1", childId="1" ]
             humidity         hum02       [ nodeId="1", childId="2" ]
             temperature      temp02      [ nodeId="1", childId="3" ]
             humidity         hum03       [ nodeId="1", childId="4" ]
             temperature      temp03      [ nodeId="1", childId="5" ]
             power            power01     [ nodeId="2", childId="0" ]
             rgbLight         rgb02       [ nodeId="6", childId="0", requestAck=true ]
             light            relay01     [ nodeId="7", childId="0", requestAck=true ]
             motion           motion01    [ nodeId="8", childId="0", requestAck=true ]
             motion           motion02    [ nodeId="9", childId="0", requestAck=true ]
             light            relay02     [ nodeId="9", childId="1", requestAck=true ]
             cover            cover03     [ nodeId="10", childId="0", requestAck=true, smartSleep=true ]
             cover            cover02     [ nodeId="11", childId="0", requestAck=true, smartSleep=true ]
             customSensor     blind01     [ nodeId="12", childId="0", requestAck=true, smartSleep=true ]
          items:
          String blind1BatReading	    "Blind#1 Battery A/D Reading"  	<battery>			{ channel="mysensors:customSensor:ethGatewayPi:blind01:var4" }
          DateTime Sensor12LastUpdate "Last seen Nd12 [%1$ta %1$tT]"       <clock>    	{ channel="mysensors:customSensor:ethGatewayPi:blind01:lastupdate" }
          edit 6/7: I stand corrected, the variables are being updated. I was fooled by the log. For some reason the log does not show the change the way it did it binding 2.0.0. I placed debug messages in my rules and they're updating.
          • T TimO
            @RVMRVM could you give this one a try?
            https://github.com/tobof/openhab2-addons/issues/76
            It is not yet integrated into the main branch. If you could test it and give me some feedback I would be very grateful. :)
            matt shepherd
            @TimO is it possible to configure using paper ui?
            cheers
            Matt
            • T TimO
              the trung
              @TimO
              I follow your guid and it's ok, then i checks karaf and see there 0_1496630110147_karaf2.png
              is this mean i installed my binding?
              and i have question
              did you fix error : Unable to install bundle openhab-transport-serial
              thanks you so much
              • M matt shepherd
                cheers
                Matt
                TimO
                @matt-shepherd yes!
                • carlylerC carlyler
                  Things
                  items:
                  TimO
                  @carlyler thank you for filing an issue, I'll look into it.
                  • T the trung
                    @TimO
                    and i have question
                    thanks you so much
                    TimO
                    @the-trung yes, the binding seems to be installed. Serial transport is needed for MySensors. I'm not able to answer questions about mcp binding.
                    RVMRVMR 2 Replies Last reply
                    • T TimO
                      RVMRVMR
                      RVMRVMR
                      RVMRVM
                      @TimO Hey Tim, before i start test , i have installed OH2.1 build #925 on 2 new W8 pc's.
                      download the org.openhab.binding.mysensors-2.1.0-SNAPSHOT.jar file and put it in the addons folder.
                      result:
                      2017-06-10 15:01:27.812 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at /start
                      2017-06-10 15:01:27.922 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
                      2017-06-10 15:01:28.031 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
                      2017-06-10 15:01:28.250 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
                      2017-06-10 15:01:28.281 [ERROR] [org.openhab.binding.mysensors ] - FrameworkEvent ERROR - org.openhab.binding.mysensors
                      org.osgi.framework.BundleException: Could not resolve module: org.openhab.binding.mysensors [182]
                      at org.eclipse.osgi.container.Module.start(Module.java:434)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
                      at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1582)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
                      at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1562)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
                      at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1533)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
                      at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1476)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
                      at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
                      at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
                      at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
                      i cannot start the mysensors binding ...
                      i have installed it on 3 diff pc's, same result , can you help mee with this, i'am stucked ..
                      thanks in advance
                      kind regards
                      andreacioniA 1 Reply Last reply
                      • RVMRVMR RVMRVM
                        result:
                        thanks in advance
                        kind regards
                        andreacioniA
                        andreacioniA
                        andreacioni
                        @RVMRVM
                        Did you run feature:install openhab-transport-serial, on OH console?
                        • RVMRVMR
                          RVMRVMR
                          RVMRVM
                          Oh yes, i dit not, that was the problem, now i can start to test the RGB-RGBW , hope that i can run this
                          thanks for the quit reaction
                          Roger
                          • T TimO
                            RVMRVMR
                            RVMRVMR
                            RVMRVM
                            wrote on last edited by RVMRVM
                            #457
                            @TimO Hello, i tried the RGB & RGBW , it looks ok but there are no commands that been send to the node and this for every item, a'im new in the openHab world, so that will be the problem.
                            the result is the same for RGB & RGBW
                            my .things file:
                            Bridge mysensors:bridge-eth:gateway [ ipAddress="192.168.2.190", tcpPort=5003, sendDelay=200 ] {
                            light:RGBW_23_Status [ nodeId="23", childId="0", requestAck=false]
                            rgbwLight:RGBW_23_Color [ nodeId="23", childId="1", requestAck=false ]
                            dimmer:RGBW_23_Dimmer [ nodeId="23", childId="2", requestAck=false ]
                            my .items file:
                            Group GF_Living "Living Room" <video> (gGF)
                            /* Indoor Temperatures */
                            //Number Temperature_GF_Living "Temperature [%.1f °C]" <temperature> (Temperature, GF_Living)
                            Switch RGBW_23_Status "Living" (GF_Living, Lights) { channel="mysensors:bridge-eth:gateway:RGBW_23_Status"}
                            Dimmer RGBW_23_Dimmer "Living" <slider> (GF_Living, Lights) ["Lighting"] { channel="mysensors:bridge-eth:gateway:RGBW_23_Dimmer"}
                            Color RGBW_23_Color "RGBW Light" <colorwheel> {channel = "mysensors:bridge-eth:gateway:RGBW_23_Color"}
                            and my .sitemap file
                            sitemap rvms label="test rvms"
                            Frame label="RGBW Living" {
                            Switch item=RGBW_23_Status label="Button Switch" mappings=[ON="on",OFF="off"]
                            Slider item=RGBW_23_Dimmer switchSupport
                            Colorpicker item=RGBW_23_Color
                            as result we have:
                            0_1497172964239_upload-df31d06d-cc9b-47df-9583-831a701cdeed
                            and in the paperUI:
                            0_1497173108301_upload-088cd943-2a85-4ad4-9197-b76b075f4ffe
                            this is what the log-file shows:
                            2017-06-11 09:50:48.187 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at /start
                            2017-06-11 09:50:51.161 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'rvms.items'
                            2017-06-11 09:50:52.088 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'rvms.sitemap'
                            2017-06-11 09:50:52.187 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'rvms.things'
                            2017-06-11 09:50:52.978 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
                            2017-06-11 09:50:53.006 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
                            2017-06-11 09:50:53.073 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
                            2017-06-11 09:50:53.404 [INFO ] [assic.internal.servlet.WebAppServlet] - Started Classic UI at /classicui/app
                            2017-06-11 09:50:53.555 [WARN ] [.discovery.MySensorsDiscoveryService] - Cannot automatic discover thing node: 0, child: 255 please insert it manually
                            2017-06-11 09:50:53.558 [INFO ] [al.protocol.ip.MySensorsIpConnection] - Successfully connected to MySensors Bridge.
                            2017-06-11 09:55:56.976 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'rvms.things'
                            2017-06-11 09:55:56.988 [WARN ] [rsAbstractConnection$MySensorsWriter] - Interrupted MySensorsWriter
                            2017-06-11 09:55:56.989 [WARN ] [rsAbstractConnection$MySensorsReader] - Interrupted MySensorsReader
                            2017-06-11 09:55:58.010 [WARN ] [.discovery.MySensorsDiscoveryService] - Cannot automatic discover thing node: 0, child: 255 please insert it manually
                            2017-06-11 09:55:58.020 [INFO ] [al.protocol.ip.MySensorsIpConnection] - Successfully connected to MySensors Bridge.
                            2017-06-11 10:08:57.483 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'rvms.sitemap'
                            so what is wrong here ?
                            thanks in advance
                            Roger
                            • FusedHe3F
                              FusedHe3F
                              FusedHe3
                              Hi @TimO,
                              I also tried the RGB Light and it seems to be working! (I am using Maghac's RGB LED strip sketch)
                              Auto discovery worked instantly. I did have to work with the .items file to get the color picker instead of a text input. I also get these two errors every time I send a command:
                              16:57:36.770 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'rgbLight01' received command 124,89,100
                              16:57:36.809 [INFO ] [marthome.event.ItemStateChangedEvent] - rgbLight01 changed from 359,91,100 to 124,89,100
                              16:57:37.117 [WARN ] [rs.internal.gateway.MySensorsGateway] - Variable 2 not present
                              16:57:37.222 [WARN ] [rs.internal.gateway.MySensorsGateway] - Variable 3 not present
                              As I'm relatively new to MySensors, I was wondering if it is normal that the RGB Light Sensor channel is used for this. Or is this just temporary until an actual RGB channel is made?
                                matt shepherd
                                I've been trying to figure this out for a while. For me openhab discovers 4 things Red, Green, Blue and Status. These are all dimmers and I can't get them all to work together as 1 colour wheel? They all work really well independently but that's as far as I got. I've also tried the .items file but with no luck.
                                carlylerC 1 Reply Last reply
                                • D
                                  doctor64
                                  Hello!
                                  I just started to play with OpenHab2 and new binding? thank you for great work.
                                  But, i discover some strange behavior:
                                  Openhab2, ethernet gateway, 3 mysensor nodes, all nodes sucessfully detected and configured in PaperUI, but some data looks like not updated. Looking to log i note some suspicious lines like:
                                  00:28:47.077 [DEBUG] [rsAbstractConnection$MySensorsReader] - 3;1;1;0;0;24.6
                                  00:28:47.078 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 3 found in gateway
                                  00:28:47.078 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 1 found in node 3
                                  00:28:47.078 [WARN ] [rs.internal.gateway.MySensorsGateway] - Variable 0 not present
                                  Sorry, i don't know how to dump OpenHab configuration, but item configured.
                                  Any suggestions?
                                  • M matt shepherd
                                    carlylerC
                                    carlylerC
                                    carlyler
                                    @matt-shepherd What works for me :
                                    items - just used 1 channel, V_VAR1, but you could keep them separate
                                    String neoPixelRgb           "RGB LED string"                           (grpLighting)  { channel="mysensors:rgbLight:ethGateway:rgb01:var1" }
                                    Color neoPixelColor         "RGB LED string"            <colorwheel>    (grpLighting)
                                    rule
                                    rule "Set RGB value NeoPixelStrip"
                                    when
                                        Item neoPixelColor changed
                                    then
                                        val hsbValue = neoPixelColor.state as HSBType
                                        val brightness = hsbValue.brightness.intValue
                                        val redValue = ((((hsbValue.red.intValue * 255) / 100) * brightness) / 100)
                                        val grnValue = ((((hsbValue.green.intValue * 255) / 100) * brightness) / 100)
                                        val bluValue = ((((hsbValue.blue.intValue * 255) / 100) * brightness) / 100)
                                        val rgbHexString = String::format("%02X%02X%02X", redValue, grnValue, bluValue)
                                        sendCommand(neoPixelRgb, rgbHexString)
                                    end
                                    parsed in node
                                      if (message.type == V_VAR1)
                                        Serial.print(", New status, V_RGB: ");
                                        // starting to process the hex code
                                        String hexstring = message.getString(); //here goes the hex color code coming from through MySensors (like FF9A00)
                                        long number = (long) strtol( &hexstring[0], NULL, 16);
                                        RGB_values[0] = number >> 16;
                                        RGB_values[1] = number >> 8 & 0xFF;
                                        RGB_values[2] = number & 0xFF;
                                        colorWipe(strip.Color(RGB_values[0], RGB_values[1], RGB_values[2]), 50);
                                    • T TimO
                                      RVMRVMR
                                      RVMRVMR
                                      RVMRVM
                                      #462
                                      @TimO Hey all, looks everything seems to work now, but now i have defined the bindings by the paper UI, and work with the rule definition as show by 'doctor64' ....
                                      thanks for the help
                                      Roger
                                      • FusedHe3F FusedHe3
                                        Hi @TimO,
                                        TimO
                                        @FusedHe3 Thank you for testing and your input!
                                        The sketch you are using is representing itself as a RGB sensor and the log you've posted looks good.
                                        About the fiddling with the .items file and the color picker: Thank you! That should'nt be needed anymore, I've changed it here: RGB-Test-Binding
                                        FusedHe3F 2 Replies Last reply
                                        • RVMRVMR RVMRVM
                                          thanks for the help
                                          Roger
                                          TimO
                                          @RVMRVM The definitions carlyler posted looks fine and I've tried to implement this logic into the binding so you won't need the rule anymore. Feel free to test my binding or stay with the rule. Hopefully both would lead to the same result. :)
                                          RVMRVMR 1 Reply Last reply
