  3. How to connect QUIP300 to Domoticz
31 Posts 3 Posters 8.2k Views 3 Watching
    Just copy the code from motion sensor sketch, assign a child ID to the pir sensor, present it and in code just check pin status with digitalread() and send value changed from last send
    • M Offline
      M Offline
      mckenzi
      Hey gohan, thanks - basic sketch will do the job.
      I faced another problem. Now i've conected one of the PIR via WemosD1 mini with ESP Easy.0_1497208049084_DSC_0864.JPG
      And works very well.
      But i would like to connect 3 more sensors.
      Power supply for PIR and Wemos is different and there is only one GND pin .
      Any idea how to make it?
        3 more sensor to the same wemos?
        • M Offline
          M Offline
          mckenzi
          wrote on last edited by mckenzi
          Yes. Possible?
            With mysensors it is possible, with esp easy I don't know.
            • M Offline
              M Offline
              mckenzi
              I can swich to MySensors- no problem.
              • M Offline
                M Offline
                mckenzi
                Hi Gohan, please see my set up i more details.
                Each of PIR is conected to old/not used alarm control panel.
                Now it is used as power supply. I've just ordered Arduino Nano + nRF24L01 to conect all motion sensors. I would like to use one of free port to power my node (thru voltage step down : 12V->5V)
                How should i conect sensors to node?
                  wrote on last edited by gohan
                  Do you want to put the nano in that panel?
                  • M Offline
                    M Offline
                    mckenzi
                    Hi, panel will be use as a power supply only.
                      Ok, but if you put the nano in that location you will have the yellow cables coming back from the PIR sensors and you would have to use those to connect to digital pins of the arduino, the problem is that you need to check what is the voltage that most likely will be over 5V and you would need to find a way to lower it.
                      • M Offline
                        M Offline
                        mckenzi
                        Yellow cable is connected to PIR's relay. And this cable i'm going to conect to digital input of arduino.
                        Second cable from PIR's relay will be connnected to arduino's GND pin. ( not shown on this photo).
                        There is no voltage on PIR's relay ( works as simple switch).
                        Is my understanding correct ?
                          If it is just a relay ok, I thought you were using the output of the pir sensor, but always check before connecting to the Arduino
                          • M Offline
                            M Offline
                            mckenzi
                            So how to connect 4 PIRs to one node to be able to see in Domoticz which was acivated ?
                              Connect each one on a different digital pin and create a different child id for each pir sensor and present all of them, it is just replicating 4 times the code of the motion sensor sketch.
                              • M Offline
                                M Offline
                                mckenzi
                                Last question: one pin of each PIR's relay must be connected to common Arduino GND pin, right ?
                                  it depends, you could also wire it to the 5V and detect when the digital pin goes high you have movement.
                                  • M Offline
                                    M Offline
                                    mckenzi
                                    THank you Gohan. Now everything is more clearer. :-) Will try today to wire everything.
                                    • M Offline
                                      M Offline
                                      mckenzi
                                      Hi GOHAN,
                                      Finally i've build my serial gateway ( Arduino UNO + nRF24) + node (Arduino Nano + nRF24) but i failed with PIR conection to my NODE. How should i connect PIR's relay to Nano ? ( digital input + GND ) ?
                                      Now i know that relay is normally closed ( 0, 1 state, no power on it)
                                      I was trying to connect this way and it was working for few second ( i saw in the serial monitor , 1 , 0) but after some time NODE was sending weird data to GW.
                                      How connect it corectlly and how to mod the sketch for more sensors? (4 pcs). ```
                                      This is the way ?
                                      #define DIGITAL_INPUT_SENSOR 4   // The digital input you attached your motion sensor.  (Only 2 and 3 generates interrupt!)
                                      #define CHILD_ID 2   // Id of the sensor child```
                                        IF the pir sensor has a normally closed relay you need to use the 5v output of the arduino to one pin of the relay and the other to the digital input and use the code to send TRIPPED true message when pin goes LOW and TRIPPED false when pin is high
                                        • M Offline
                                          M Offline
                                          mckenzi
                                          Hi Gohan,
                                          This is the way i should follow ?:
                                          	// Read digital motion value
                                            if(digitalRead(DIGITAL_INPUT_SENSOR) == HIGH){
                                              tripped = true;
                                              tripped = false;
                                          Not so easy to set :-)
