  3. How to connect QUIP300 to Domoticz
31 Posts 3 Posters 8.2k Views 3 Watching
  • M Offline
    M Offline
    mckenzi
    Thank you Nca78 & gohan.
    Sensor is working very well conected to Wemos D1 mini under Domoticz control. Not i'm testing with 9V battery .
    I faced some problems with conection to Arduino . Basic sketch for motion sensor not working for my setup.
    Any clues how to modify my current sketch ? (for relays)
    0_1497042712762_GatewaySerialWired.ino
    Thank you.
      I can't see your sketch. What problem are you having exactly?
      • M Offline
        M Offline
        mckenzi
        Hello Gohan ,
        Here is my sketch. Arduino is conected via uSB cable to my QNAP.
        And there is few relays conected to Arduino. I would like to avoid wireless conection.
        Now i would like to add PIRs to this sketch.
        //#define MY_RADIO_NRF24
        // Enable serial gateway
        #define MY_GATEWAY_SERIAL
        #if F_CPU == 8000000L
        #define MY_BAUD_RATE 38400
        // Flash leds on rx/tx/err
        // #define MY_LEDS_BLINKING_FEATURE
        // Set blinking period
        // #define MY_DEFAULT_LED_BLINK_PERIOD 300
        // #define MY_WITH_LEDS_BLINKING_INVERSE
        // Enable inclusion mode
        #define MY_REPEATER_FEATURE
        #define RELAY_1  4  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
        #define BUTTON_PIN A1
        void before() {
            pinMode(pin, OUTPUT);
        Bounce debouncer = Bounce();
          delay(10000);
           // Setup the button.
          pinMode(BUTTON_PIN, INPUT_PULLUP);
          // After setting up the button, setup debouncer.
          debouncer.attach(BUTTON_PIN);
          debouncer.interval(5);
          //presentation();
          sendSketchInfo("Relay", "1.0");
            present(sensor, S_LIGHT);
        MyMessage msg(1, V_LIGHT);
          if (debouncer.update()) {
            // Get the update value.
            int value = debouncer.read();
            // Send in the new value.
            if(value == LOW){
                 saveState(1, !loadState(1));
                 digitalWrite(RELAY_1, loadState(1)?RELAY_ON:RELAY_OFF);
                 send(msg.set(loadState(1)));
          if (message.type==V_LIGHT) {
             // Change relay state
             // Store state in eeprom
        How to make it ? I'm newbie - sorry.
        Regards.
          Just copy the code from motion sensor sketch, assign a child ID to the pir sensor, present it and in code just check pin status with digitalread() and send value changed from last send
          • M Offline
            M Offline
            mckenzi
            Hey gohan, thanks - basic sketch will do the job.
            I faced another problem. Now i've conected one of the PIR via WemosD1 mini with ESP Easy.0_1497208049084_DSC_0864.JPG
            And works very well.
            But i would like to connect 3 more sensors.
            Power supply for PIR and Wemos is different and there is only one GND pin .
            Any idea how to make it?
              3 more sensor to the same wemos?
              • M Offline
                M Offline
                mckenzi
                wrote on last edited by mckenzi
                Yes. Possible?
                  With mysensors it is possible, with esp easy I don't know.
                  • M Offline
                    M Offline
                    mckenzi
                    I can swich to MySensors- no problem.
                    • M Offline
                      M Offline
                      mckenzi
                      Hi Gohan, please see my set up i more details.
                      Each of PIR is conected to old/not used alarm control panel.
                      Now it is used as power supply. I've just ordered Arduino Nano + nRF24L01 to conect all motion sensors. I would like to use one of free port to power my node (thru voltage step down : 12V->5V)
                      How should i conect sensors to node?
                        wrote on last edited by gohan
                        Do you want to put the nano in that panel?
                        • M Offline
                          M Offline
                          mckenzi
                          Hi, panel will be use as a power supply only.
                            Ok, but if you put the nano in that location you will have the yellow cables coming back from the PIR sensors and you would have to use those to connect to digital pins of the arduino, the problem is that you need to check what is the voltage that most likely will be over 5V and you would need to find a way to lower it.
                            • M Offline
                              M Offline
                              mckenzi
                              Yellow cable is connected to PIR's relay. And this cable i'm going to conect to digital input of arduino.
                              Second cable from PIR's relay will be connnected to arduino's GND pin. ( not shown on this photo).
                              There is no voltage on PIR's relay ( works as simple switch).
                              Is my understanding correct ?
                                If it is just a relay ok, I thought you were using the output of the pir sensor, but always check before connecting to the Arduino
                                • M Offline
                                  M Offline
                                  mckenzi
                                  So how to connect 4 PIRs to one node to be able to see in Domoticz which was acivated ?
                                    Connect each one on a different digital pin and create a different child id for each pir sensor and present all of them, it is just replicating 4 times the code of the motion sensor sketch.
                                    • M Offline
                                      M Offline
                                      mckenzi
                                      Last question: one pin of each PIR's relay must be connected to common Arduino GND pin, right ?
                                        it depends, you could also wire it to the 5V and detect when the digital pin goes high you have movement.
                                        • M Offline
                                          M Offline
                                          mckenzi
                                          THank you Gohan. Now everything is more clearer. :-) Will try today to wire everything.
