  3. A little help with my first ever MySensors (and Arduido) sketch: Rotary Angle Sensor (knob) + Nano + esp8266 gateway
14 Posts 2 Posters 3.6k Views 2 Watching
  • vadimbzV vadimbz
    UPD: I forgot to paste the important part, this:
    #error No forward link or gateway feature activated. This means nowhere to send messages! Pretty pointless.
    I want to show angular value (0-300) upstream to Home Assistant as a sensor, and lockstep to it from there to control home assistant services - volume control, scene selector, media seek, etc.
    Mysensors 2.11 in arduino, gateway is still 2.0. This is the sensor, not the same as encoder evidently:
    http://wiki.seeed.cc/Grove-Rotary_Angle_Sensor/
    and the code. Thanks!
    #include <GroveEncoder.h>
    #include <MyConfig.h>
    #define ROTARY_ANGLE_SENSOR A0
    #define ADC_REF 5//reference voltage of ADC is 5v.If the Vcc switch on the seeeduino
                     //board switches to 3V3, the ADC_REF should be 3.3
    #define VCC 5//VCC of the grove interface is normally 5v
    #define FULL_ANGLE 300//full value of the rotary angle is 300 degrees
    #define SN "RotaryAngleSensor"
    #define SV "1.0"
    #define CHILD_ID
    unsigned long SLEEP_TIME = 100
    Rotary Angle Sensor;
    MyMessage msg(CHILD_ID, V_VAR1);
    int lastDegrees;
        Serial.begin(9600);
        pinsInit();
        sendSketchInfo(SN, SV);
        present(CHILD_ID, S_CUSTOM);
        int degrees;
        degrees = getDegree();
        Serial.println(degrees);
        if (degrees != lastDegrees) {
            send(msg.set(degrees));
            lastDegrees = degrees;
        sleep(SLEEP_TIME);
    void pinsInit()
        pinMode(ROTARY_ANGLE_SENSOR, INPUT);
    /*Function: Get the angle between the mark and the starting position    */
    /*Parameter:-void                                                       */
    /*Return:   -int,the range of degrees is 0~300                          */
    int getDegree()
        int sensor_value = analogRead(ROTARY_ANGLE_SENSOR);
        float voltage;
        voltage = (float)sensor_value*ADC_REF/1023;
        float degrees = (voltage*FULL_ANGLE)/VCC;
        return degrees;
    Welcome to the MySensors community @vadimbz
    Remove #include <MyConfig.h> and move #include <MySensors.h> to after the lines starting with #define
    • vadimbzV
      vadimbzV
      vadimbz
      New error. Also is it normal that IDE recognizes nano board, but not its port?
      WARNING: library GroveEncoder claims to run on [arc32] architecture(s) and may be incompatible with your current board which runs on [avr] architecture(s).
      encoderTest:22: error: 'Rotary' does not name a type
      encoderTest:24: error: expected primary-expression before ',' token
      C:\Users\Vadim\Documents\Arduino\encoderTest\encoderTest.ino: In function 'void setup()':
      encoderTest:32: error: expected primary-expression before ',' token
      exit status 1
      • vadimbzV vadimbz
        exit status 1
        @vadimbz seems like the GroveEncoder library doesn't support avr (which is what Arduino Nano and Pro Mini uses). You'll need to find another library.
        • vadimbzV
          vadimbzV
          vadimbz
          It was never used in fact, and it wasn't used in a reference sketch either. removing it killed only the top error message.
          • vadimbzV vadimbz
            @vadimbz could you post your current sketch?
            • vadimbzV
              vadimbzV
              vadimbz
              Rotary... line before mymessage is causing problems. I think I misunderstood its meaning
              #define SV "1.0"
              #define CHILD_ID
              unsigned long SLEEP_TIME = 100;
              int lastDegrees;
                  Serial.begin(9600);
                  pinsInit();
                  int degrees;
                  sleep(SLEEP_TIME);
              void pinsInit()
              int getDegree()
                  float voltage;
                  return degrees;
              • vadimbzV vadimbz
                #define SV "1.0"
                #define CHILD_ID
                int lastDegrees;
                    Serial.begin(9600);
                    pinsInit();
                    int degrees;
                    sleep(SLEEP_TIME);
                void pinsInit()
                int getDegree()
                    float voltage;
                    return degrees;
                @vadimbz just remove it?
                • vadimbzV
                  vadimbzV
                  vadimbz
                  Cascading errors (
                  It seems that I needencoderTest:21: error: expected primary-expression before ',' token
                  encoderTest:29: error: expected primary-expression before ',' token
                  exit status 1
                  • vadimbzV
                    vadimbzV
                    vadimbz
                    Sketch notations were updated between 2.0 and 2.1.1, weren't they?
                    • vadimbzV vadimbz
                      Cascading errors (
                      exit status 1
                      @vadimbz change
                      #define CHILD_ID
                      to something like
                      #define CHILD_ID 1
                      • vadimbzV
                        vadimbzV
                        vadimbz
                        YES, that's it, compiled and flashed... at which point the board started acting out, but I can bounce from here J
                        While we're still here, is there a way to connect 3-pin sensors (with one signal pin) to digisparks along with radio? 3-pin radio connection scheme is not an option at the moment unfortunately...
                        ...and I feel like an idiot with a handful of those -)
                        • vadimbzV vadimbz
                          @vadimbz could you explain what a 3-pin sensor is? Many of the MySensors examples use sensors with multiple pins so that shouldn't be a problem.
                          • vadimbzV
                            vadimbzV
                            vadimbz
                            wrote on last edited by vadimbz
                            I nwas about talking about digispark (attiny85) board that would be a good match for rolling out mysensors if only had a couple more pins:
                            I was asking if it's possible to use them after all one way or another, at least for basic sensors with 3 pins (GND, Vcc, Signal) from which we need only Signal.
                            I also mentioned this as known, but unwated solution:
                            https://www.hackster.io/arjun/nrf24l01-with-attiny85-3-pins-74a1f2
