  3. A little help with my first ever MySensors (and Arduido) sketch: Rotary Angle Sensor (knob) + Nano + esp8266 gateway
14 Posts 2 Posters 2.9k Views 2 Watching
  • vadimbzV Offline
    vadimbzV Offline
    vadimbz
    wrote on last edited by vadimbz
    UPD: I forgot to paste the important part, this:
    #error No forward link or gateway feature activated. This means nowhere to send messages! Pretty pointless.
    I want to show angular value (0-300) upstream to Home Assistant as a sensor, and lockstep to it from there to control home assistant services - volume control, scene selector, media seek, etc.
    Mysensors 2.11 in arduino, gateway is still 2.0. This is the sensor, not the same as encoder evidently:
    http://wiki.seeed.cc/Grove-Rotary_Angle_Sensor/
    and the code. Thanks!
    #include <GroveEncoder.h>
    #include <MyConfig.h>
    #define ROTARY_ANGLE_SENSOR A0
    #define ADC_REF 5//reference voltage of ADC is 5v.If the Vcc switch on the seeeduino
                     //board switches to 3V3, the ADC_REF should be 3.3
    #define VCC 5//VCC of the grove interface is normally 5v
    #define FULL_ANGLE 300//full value of the rotary angle is 300 degrees
    #define SN "RotaryAngleSensor"
    #define SV "1.0"
    #define CHILD_ID
    unsigned long SLEEP_TIME = 100
    Rotary Angle Sensor;
    MyMessage msg(CHILD_ID, V_VAR1);
    int lastDegrees;
        Serial.begin(9600);
        pinsInit();
        sendSketchInfo(SN, SV);
        present(CHILD_ID, S_CUSTOM);
        int degrees;
        degrees = getDegree();
        Serial.println(degrees);
        if (degrees != lastDegrees) {
            send(msg.set(degrees));
            lastDegrees = degrees;
        sleep(SLEEP_TIME);
    void pinsInit()
        pinMode(ROTARY_ANGLE_SENSOR, INPUT);
    /*Function: Get the angle between the mark and the starting position    */
    /*Parameter:-void                                                       */
    /*Return:   -int,the range of degrees is 0~300                          */
    int getDegree()
        int sensor_value = analogRead(ROTARY_ANGLE_SENSOR);
        float voltage;
        voltage = (float)sensor_value*ADC_REF/1023;
        float degrees = (voltage*FULL_ANGLE)/VCC;
        return degrees;
    • vadimbzV vadimbz
      #define SV "1.0"
      #define CHILD_ID
      int lastDegrees;
          Serial.begin(9600);
          pinsInit();
          int degrees;
          sleep(SLEEP_TIME);
      void pinsInit()
      int getDegree()
          float voltage;
          return degrees;
      Welcome to the MySensors community @vadimbz
      Remove #include <MyConfig.h> and move #include <MySensors.h> to after the lines starting with #define
      • vadimbzV Offline
        vadimbzV Offline
        vadimbz
        New error. Also is it normal that IDE recognizes nano board, but not its port?
        WARNING: library GroveEncoder claims to run on [arc32] architecture(s) and may be incompatible with your current board which runs on [avr] architecture(s).
        encoderTest:22: error: 'Rotary' does not name a type
        encoderTest:24: error: expected primary-expression before ',' token
        C:\Users\Vadim\Documents\Arduino\encoderTest\encoderTest.ino: In function 'void setup()':
        encoderTest:32: error: expected primary-expression before ',' token
        exit status 1
        • vadimbzV vadimbz
          exit status 1
          @vadimbz seems like the GroveEncoder library doesn't support avr (which is what Arduino Nano and Pro Mini uses). You'll need to find another library.
          • vadimbzV Offline
            vadimbzV Offline
            vadimbz
            It was never used in fact, and it wasn't used in a reference sketch either. removing it killed only the top error message.
            • vadimbzV vadimbz
              @vadimbz could you post your current sketch?
              • vadimbzV Offline
                vadimbzV Offline
                vadimbz
                Rotary... line before mymessage is causing problems. I think I misunderstood its meaning
                #define SV "1.0"
                #define CHILD_ID
                unsigned long SLEEP_TIME = 100;
                int lastDegrees;
                    Serial.begin(9600);
                    pinsInit();
                    int degrees;
                    sleep(SLEEP_TIME);
                void pinsInit()
                int getDegree()
                    float voltage;
                    return degrees;
                • vadimbzV vadimbz
                  #define SV "1.0"
                  #define CHILD_ID
                  int lastDegrees;
                      Serial.begin(9600);
                      pinsInit();
                      int degrees;
                      sleep(SLEEP_TIME);
                  void pinsInit()
                  int getDegree()
                      float voltage;
                      return degrees;
                  @vadimbz just remove it?
                  • vadimbzV Offline
                    vadimbzV Offline
                    vadimbz
                    Cascading errors (
                    It seems that I needencoderTest:21: error: expected primary-expression before ',' token
                    encoderTest:29: error: expected primary-expression before ',' token
                    exit status 1
                    • vadimbzV Offline
                      vadimbzV Offline
                      vadimbz
                      Sketch notations were updated between 2.0 and 2.1.1, weren't they?
                      • vadimbzV vadimbz
                        Cascading errors (
                        exit status 1
                        @vadimbz change
                        #define CHILD_ID
                        to something like
                        #define CHILD_ID 1
                        • vadimbzV Offline
                          vadimbzV Offline
                          vadimbz
                          YES, that's it, compiled and flashed... at which point the board started acting out, but I can bounce from here J
                          While we're still here, is there a way to connect 3-pin sensors (with one signal pin) to digisparks along with radio? 3-pin radio connection scheme is not an option at the moment unfortunately...
                          ...and I feel like an idiot with a handful of those -)
                          • vadimbzV vadimbz
                            @vadimbz could you explain what a 3-pin sensor is? Many of the MySensors examples use sensors with multiple pins so that shouldn't be a problem.
                            • vadimbzV Offline
                              vadimbzV Offline
                              vadimbz
                              I nwas about talking about digispark (attiny85) board that would be a good match for rolling out mysensors if only had a couple more pins:
                              I was asking if it's possible to use them after all one way or another, at least for basic sensors with 3 pins (GND, Vcc, Signal) from which we need only Signal.
                              I also mentioned this as known, but unwated solution:
                              https://www.hackster.io/arjun/nrf24l01-with-attiny85-3-pins-74a1f2
                              11.8k
                              113.2k
