  2. Announcements
  3. 💬 Rain Gauge
💬 Rain Gauge
62 Posts 18 Posters 29.3k Views 17 Watching
  • U user2684
    @itbeyond I can say it is working perfectly now, thanks! Always 0.00 during the night, I force two triggers this morning and I had the correct equivalent of rain.
    @petewill I'd add this as a note on https://www.mysensors.org/build/rain, even if it is not a common issue, at least for those who will experience it can have a solution ready to use.
    So if I understand correctly (which rarely happens), in a no rain situation it is like the bucket is unplugged and the pin is connected to Vcc through the 1k resistor (to limit the current right?) and also charging the capacitor. When it rains, it is like the bucket would connect the input pin to ground and I guess the capacitor and 330R resistor would smooth this so to actually debounce the signal. Is it the case? Thanks
    I
    I
    itbeyond
    @user2684 That is great news - your understanding is basically correct. When no rain the 1K is providing the pull up to 3.3/5v and charging the cap at the same time (current limit is really for when you go to ground not to hold the pin up). When the bucket tips the cap is discharged via the resistor to ground (bucket switch) and thus the pin goes low. Yes - simple and effective pull up and debounce system which works every time - in fact I use this on all interrupt triggered pins for all my projects.
    @petewill it would be good to include something like this on most of the projects, would have saved me a lot of early angst in having faulty triggered interrupts. I suspect different cloned Arduino boards have different to zero internal pull ups (3 different ones I have tried seem to have none) and to be 100% sure it is much better to document an external arrangement. It will really help the beginners to get it right first time and keep some hair regardless of the quality of the board they are using. I needed this on my irrigation controller also - same problem with a 10cm cable to a push button.
    U petewillP 2 Replies Last reply
    • I itbeyond
      U
      U
      user2684
      @itbeyond thanks for the explanation! Last question even if not necessarily mysensors related: how did you size the cap the resistors? Thanks!
      • I itbeyond
        petewillP
        petewillP
        petewill
        wrote on last edited by petewill
        #34
        @itbeyond said in 💬 Rain Gauge:
        Interesting. I haven't experienced this behavior with any of my devices yet. I do power most of my sensors with my whole house power supply though so I guess that would explain it.
        I will update the rain gauge page and also add this info to the troubleshooting section. Thanks for your help with this!
        If anyone needs a visual of what @itbeyond described above here is the wiring diagram.
        • EnfeetE
          EnfeetE
          Enfeet
          Hi friends,
          here is my replica of Rain Guage MySensors project
          photos:
          https://goo.gl/photos/4kA7T4d8SsDBRrrS7
          The sketch is adopted for 'Adafruit Unified Sensor by Adafruit' + 'DHT sensor library' just uncomment both DHT_ON and DHT_ADAFRUIT
          and last version of Arduino IDE 1.8.3
          ...and Yes, I'm using rfm69hw radio with encryption enabled ;-)
          #define MY_RFM69_ENABLE_ENCRYPTION
           Arduino Tipping Bucket Rain Gauge
           April 26, 2015
           Version 2.0
           Utilizing a tipping bucket sensor, your Vera home automation controller and the MySensors.org
           gateway you can measure and sense local rain.  This sketch will create two devices on your
           Vera controller.  One will display your total precipitation for the last 5 days.  The other,
           a sensor that changes state if there is recent rain (up to last 120 hours)  above a threshold.
           Both these settings are user definable.
           There is a build overview video here: https://youtu.be/1eMfKQaLROo
           * Allows you to set the rain threshold in mm
           * Allows you to determine the tripped indicator window up to 120 hours.
           * Displays the last 5 days of rain in Variable1 through Variable5
             of the Rain Sensor device
           * Configuration changes to Sensor device updated every hour
           * Should run on any Arduino
           * Will retain Tripped/Not Tripped status and data in a power interruption, saving small amount
             of data to EEPROM (Circular Buffer to maximize life of EEPROM)
           * LED status indicator
           * Optional Temp/Humidity (DHT-22 or DHT-11) and Light LUX (BH1750) sensors. To use, uncomment
             #define DHT_ON  and/or #define LUX_ON
           * Optionally send total accumulation of each day's rainfall or send only individual days rainfall totals.
             Uncomment #define USE_DAILY to display individual daily rainfall.  If it is commented out it will display
             a cumulative total rainfall (day4 = day1+day2+day3+day4 etc)
           by @BulldogLowell and @PeteWill for free public use
          //#define MY_DEBUG_VERBOSE
          #define MY_NODE_ID AUTO
          //#define MY_RADIO_NRF24
          #define MY_RADIO_RFM69
          #define MY_IS_RFM69HW
          #define MY_RFM69_TX_POWER 31
          #include <math.h>
          #include <TimeLib.h>
          #define SKETCH_NAME "Rain Gauge"
          #define SKETCH_VERSION "2.0"
          #define DWELL_TIME 40  // this allows for radio to come back to power after a transmission, ideally 0
          //#define DEBUG_ON  // Rain gauge specific debug messages.
          #define DHT_ON // uncomment out this line to enable DHT sensor
          // 20170621 by Enfeet
          #define DHT_ADAFRUIT // uncomment out this line to enable DHT with 'Adafruit Unified Sensor by Adafruit' + 'DHT sensor library'
          //#define DHTTYPE           DHT11     // DHT 11
          #define DHTTYPE           DHT22     // DHT 22 (AM2302)
          //#define DHTTYPE           DHT21     // DHT 21 (AM2301)
          // /20170621 by Enfeet
          //#define LUX_ON // uncomment out this line to enable BH1750 sensor
          //#define USE_DAILY // Uncomment to display individual daily rainfall totals in the variables sent to your controller. If it's commented it will add each day to the next for a cumulative total.
          #define TIP_SENSOR_PIN 3
          //d=112 mm
          //11689.863832 mm2 =  116,89863832 cm2
          //42,77209787776081 mm
          //88 89 91 91 90 = 89,8
          //0,4763039852757329
          #define CALIBRATE_FACTOR 48 // amount of rain per rain bucket tip e.g. 5 is .05mm
          #define DHT_LUX_DELAY 300000  //Delay in milliseconds that the DHT and LUX sensors will wait before sending data
          #define CHILD_ID_RAIN_LOG 3  // Keeps track of accumulated rainfall
          #define CHILD_ID_TRIPPED_INDICATOR 4  // Indicates Tripped when rain detected
          #define EEPROM_BUFFER_LOCATION 0  // location of the EEPROM circular buffer
          #define E_BUFFER_LENGTH 240
          #define RAIN_BUCKET_SIZE 120
            #ifdef  DEBUG_ON
              #define M_DEBUG_PRINT(x)   Serial.print(x)
              #define M_DEBUG_PRINTLN(x) Serial.println(x)
          MyMessage msgRainRate(CHILD_ID_RAIN_LOG, V_RAINRATE);
          MyMessage msgRain(CHILD_ID_RAIN_LOG, V_RAIN);
          MyMessage msgRainVAR1(CHILD_ID_RAIN_LOG, V_VAR1);
          MyMessage msgRainVAR2(CHILD_ID_RAIN_LOG, V_VAR2);
          MyMessage msgRainVAR3(CHILD_ID_RAIN_LOG, V_VAR3);
          MyMessage msgRainVAR4(CHILD_ID_RAIN_LOG, V_VAR4);
          MyMessage msgRainVAR5(CHILD_ID_RAIN_LOG, V_VAR5);
          MyMessage msgTripped(CHILD_ID_TRIPPED_INDICATOR, V_TRIPPED);
          MyMessage msgTrippedVar1(CHILD_ID_TRIPPED_INDICATOR, V_VAR1);
          MyMessage msgTrippedVar2(CHILD_ID_TRIPPED_INDICATOR, V_VAR2);
          #ifdef DHT_ON
            #ifdef DHT_ADAFRUIT
            #include <Adafruit_Sensor.h>
            #include <DHT_U.h>
            #define CHILD_ID_HUM 0
            #define CHILD_ID_TEMP 1
            #define HUMIDITY_SENSOR_DIGITAL_PIN 8
            #ifndef DHT_ADAFRUIT // 20170621 by Enfeet
              DHT dht;
              DHT_Unified dht(HUMIDITY_SENSOR_DIGITAL_PIN, DHTTYPE);
              sensors_event_t event;
            #endif // /20170621 by Enfeet
            float lastTemp;
            float lastHum;
            bool metric = true;
          #ifdef LUX_ON
            //BH1750 is connected to SCL (analog input A5) and SDA (analog input A4)
            #include <BH1750.h>
            #define CHILD_ID_LIGHT 2
            BH1750 lightSensor;
            unsigned int lastlux;
            uint8_t heartbeat = 10; //Used to send the light lux to gateway as soon as the device is restarted and after the DHT_LUX_DELAY has happened 10 times
          unsigned long sensorPreviousMillis;
          int eepromIndex;
          int tipSensorPin = 3; // Pin the tipping bucket is connected to. Must be interrupt capable pin
          int ledPin = 5; // Pin the LED is connected to.  PWM capable pin required
          #ifdef DEBUG_ON
          unsigned long dataMillis;
          unsigned long serialInterval = 600000UL;
          const unsigned long oneHour = 3600000UL;
          unsigned long lastTipTime;
          unsigned long lastRainTime; //Used for rainRate calculation
          unsigned int rainBucket [RAIN_BUCKET_SIZE] ; /* 24 hours x 5 Days = 120 hours */
          unsigned int rainRate = 0;
          uint8_t rainWindow = 72;         //default rain window in hours.  Will be overwritten with msgTrippedVar1.
          volatile int wasTippedBuffer = 0;
          int rainSensorThreshold = 50; //default rain sensor sensitivity in hundredths.  Will be overwritten with msgTrippedVar2.
          uint8_t state = 0;
          uint8_t oldState = 2; //Setting the default to something other than 1 or 0
          unsigned int lastRainRate = 0;
          int lastMeasure = 0;
          bool gotTime = false;
          uint8_t lastHour;
          uint8_t currentHour;
          void presentation()  {
            wait(DWELL_TIME);
            present(CHILD_ID_RAIN_LOG, S_RAIN);
            wait(DWELL_TIME);
            present(CHILD_ID_TRIPPED_INDICATOR, S_MOTION);
            wait(DWELL_TIME);
          #ifdef DHT_ON
            present(CHILD_ID_HUM, S_HUM);
            wait(DWELL_TIME);
            wait(DWELL_TIME);
          #ifdef LUX_ON
            M_DEBUG_PRINTLN(F("Sensor Presentation Complete"));
            #ifndef MY_DEBUG
            SERIAL_START(115200);  //Start serial if MySensors debugging isn't enabled
            // Set up the IO
            pinMode(TIP_SENSOR_PIN, INPUT);
            attachInterrupt (digitalPinToInterrupt(TIP_SENSOR_PIN), sensorTipped, FALLING);  // depending on location of the hall effect sensor may need CHANGE
            pinMode(ledPin, OUTPUT);
            digitalWrite(ledPin, HIGH);
            //Sync time with the server
            unsigned long functionTimeout = millis();
            while (timeStatus() == timeNotSet && millis() - functionTimeout < 30000UL)
              requestTime();
              M_DEBUG_PRINTLN(F("Getting Time"));
              wait(1000); // call once per second
              M_DEBUG_PRINTLN(F("."));
            currentHour = hour();
            lastHour = hour();
            //retrieve from EEPROM stored values on a power cycle.
            bool isDataOnEeprom = false;
            for (int i = 0; i < E_BUFFER_LENGTH; i++)
              uint8_t locator = loadState(EEPROM_BUFFER_LOCATION + i);
              if (locator == 0xFE)  // found the EEPROM circular buffer index
                eepromIndex = EEPROM_BUFFER_LOCATION + i;
                M_DEBUG_PRINT(F("EEPROM Index "));
                M_DEBUG_PRINTLN(eepromIndex);
                //Now that we have the buffer index let's populate the rainBucket[] with data from eeprom
                loadRainArray(eepromIndex);
                isDataOnEeprom = true;
            if (!isDataOnEeprom) // Added for the first time it is run on a new Arduino
              M_DEBUG_PRINTLN(F("I didn't find valid EEPROM Index, so I'm writing one to location 0"));
              eepromIndex = EEPROM_BUFFER_LOCATION;
              saveState(eepromIndex, 0xFE);
              saveState(eepromIndex + 1, 0xFE);
              //then I will clear out any bad data
              for (int i = 2; i <= E_BUFFER_LENGTH; i++)
                saveState(i, 0x00);
            #ifdef DEBUG_ON
            dataMillis = millis();
            lastTipTime = millis();
            request(CHILD_ID_TRIPPED_INDICATOR, V_VAR1);
            wait(DWELL_TIME);
            request(CHILD_ID_TRIPPED_INDICATOR, V_VAR2);
            wait(DWELL_TIME);
          #ifdef DHT_ON
              dht.begin();
            wait(DWELL_TIME);
          #ifdef LUX_ON
            lightSensor.begin();
            transmitRainData(); //Setup complete send any data loaded from eeprom to gateway
            if (state)
              prettyFade();  // breathe if tripped
              slowFlash();   // blink if not tripped
          #ifdef DEBUG_ON  // Serial Debug Block
            if ( (millis() - dataMillis) >= serialInterval)
              for (int i = 24; i <= 120; i = i + 24)
                updateSerialData(i);
            // let's constantly check to see if the rain in the past rainWindow hours is greater than rainSensorThreshold
            int measure = 0; // Check to see if we need to show sensor tripped in this block
            for (int i = 0; i < rainWindow; i++)
              measure += rainBucket [i];
              if (measure != lastMeasure)
                //      M_DEBUG_PRINT(F("measure value (total rainBucket within rainWindow): "));
                //      M_DEBUG_PRINTLN(measure);
                lastMeasure = measure;
            state = (measure >= (rainSensorThreshold * 100));
            if (state != oldState)
              send(msgTripped.set(state));
              wait(DWELL_TIME);
              M_DEBUG_PRINT(F("New Sensor State... Sensor: "));
              M_DEBUG_PRINTLN(state ? "Tripped" : "Not Tripped");
              oldState = state;
            unsigned long tipDelay = millis() - lastRainTime;
            if (wasTippedBuffer) // if was tipped, then update the 24hour total and transmit to Vera
              M_DEBUG_PRINTLN(F("Sensor Tipped"));
              M_DEBUG_PRINT(F("rainBucket [0] value: "));
              M_DEBUG_PRINTLN(rainBucket [0]);
              send(msgRain.set((float)rainTotal(currentHour) / 100, 1)); //Calculate the total rain for the day
              wait(DWELL_TIME);
              wasTippedBuffer--;
              rainRate = ((oneHour) / tipDelay);
              if (rainRate != lastRainRate)
                send(msgRainRate.set(rainRate, 1));
                wait(DWELL_TIME);
                M_DEBUG_PRINT(F("RainRate= "));
                M_DEBUG_PRINTLN(rainRate);
                lastRainRate = rainRate;
              lastRainTime = lastTipTime;
            if (currentHour != lastHour)
              M_DEBUG_PRINTLN(F("One hour elapsed."));
              send(msgRain.set((float)rainTotal(currentHour) / 100, 1)); // send today's rainfall
              wait(DWELL_TIME);
              saveState(eepromIndex, highByte(rainBucket[0]));
              saveState(eepromIndex + 1, lowByte(rainBucket[0]));
              M_DEBUG_PRINT(F("Saving rainBucket[0] to eeprom. rainBucket[0] = "));
              M_DEBUG_PRINTLN(rainBucket[0]);
              for (int i = RAIN_BUCKET_SIZE - 1; i >= 0; i--)//cascade an hour of values back into the array
                rainBucket [i + 1] = rainBucket [i];
              wait(DWELL_TIME);
              wait(DWELL_TIME);
              rainBucket[0] = 0;
              eepromIndex = eepromIndex + 2;
              if (eepromIndex > EEPROM_BUFFER_LOCATION + E_BUFFER_LENGTH)
              M_DEBUG_PRINT(F("Writing to EEPROM.  Index: "));
              requestTime(); // sync the time every hour
              wait(DWELL_TIME);
              transmitRainData();
              rainRate = 0;
              wait(DWELL_TIME);
              M_DEBUG_PRINTLN(F("Sending rainRate is 0 to controller"));
              lastHour = hour();
            if (millis() - sensorPreviousMillis > DHT_LUX_DELAY)
              #ifdef DHT_ON  //DHT Code
                doDHT();
              #ifdef LUX_ON
                doLUX();
              sensorPreviousMillis = millis();
          #ifdef DHT_ON
          void doDHT(void)
              if (isnan(temperature))
              dht.temperature().getEvent(&event);
              float temperature = event.temperature;
              if (isnan(event.temperature))
                M_DEBUG_PRINTLN(F("Failed reading temperature from DHT"));
              } else if (temperature != lastTemp)
                lastTemp = temperature;
                  if (!metric)
                wait(DWELL_TIME);
                M_DEBUG_PRINT(F("Temperature is: "));
                M_DEBUG_PRINTLN(temperature);
              float humidity = dht.getHumidity();;
              if (isnan(humidity))
              dht.humidity().getEvent(&event);
              float humidity = event.relative_humidity;
              if (isnan(event.relative_humidity))
                M_DEBUG_PRINTLN(F("Failed reading humidity from DHT"));
              } else if (humidity != lastHum)
                lastHum = humidity;
                wait(DWELL_TIME);
                M_DEBUG_PRINT(F("Humidity is: "));
                M_DEBUG_PRINTLN(humidity);
          #ifdef LUX_ON
          void doLUX(void)
            unsigned int lux = lightSensor.readLightLevel();// Get Lux value
            M_DEBUG_PRINT(F("Current LUX Level: "));
            M_DEBUG_PRINTLN(lux);
            heartbeat++;
            if (lux != lastlux || heartbeat > 10)
              send(msg.set(lux));
              lastlux = lux;
            if (heartbeat > 10)
              heartbeat = 0;
          void sensorTipped()
            unsigned long thisTipTime = millis();
            if (thisTipTime - lastTipTime > 100UL)
              rainBucket[0] += CALIBRATE_FACTOR; // adds CALIBRATE_FACTOR hundredths of unit each tip
              wasTippedBuffer++;
            lastTipTime = thisTipTime;
          int rainTotal(int hours)
            int total = 0;
            for ( int i = 0; i <= hours; i++)
              total += rainBucket [i];
            return total;
          #ifdef DEBUG_ON
          void updateSerialData(int x)
            M_DEBUG_PRINT(F("Rain last "));
            M_DEBUG_PRINT(x);
            M_DEBUG_PRINTLN(F(" hours: "));
            float tipCount = 0;
            for (int i = 0; i < x; i++)
              tipCount = tipCount + rainBucket [i];
            tipCount = tipCount / 100;
            M_DEBUG_PRINTLN(tipCount);
          void loadRainArray(int eValue) // retrieve stored rain array from EEPROM on powerup
            for (int i = 1; i < RAIN_BUCKET_SIZE; i++)
              eValue = eValue - 2;
              if (eValue < EEPROM_BUFFER_LOCATION)
                eValue = EEPROM_BUFFER_LOCATION + E_BUFFER_LENGTH;
              M_DEBUG_PRINT(F("EEPROM location: "));
              M_DEBUG_PRINTLN(eValue);
              uint8_t rainValueHigh = loadState(eValue);
              uint8_t rainValueLow = loadState(eValue + 1);
              unsigned int rainValue = rainValueHigh << 8;
              rainValue |= rainValueLow;
              rainBucket[i] = rainValue;
              M_DEBUG_PRINT(F("rainBucket[ value: "));
              M_DEBUG_PRINT(i);
              M_DEBUG_PRINT(F("] value: "));
              M_DEBUG_PRINTLN(rainBucket[i]);
          void transmitRainData(void)
            M_DEBUG_PRINT(F("In transmitRainData. currentHour = "));
            M_DEBUG_PRINTLN(currentHour);
            int rainUpdateTotal = 0;
            for (int i = currentHour; i >= 0; i--)
              rainUpdateTotal += rainBucket[i];
              M_DEBUG_PRINT(F("Adding rainBucket["));
              M_DEBUG_PRINT(i);
              M_DEBUG_PRINTLN(F("] to rainUpdateTotal."));
            M_DEBUG_PRINT(F("TX Day 1: rainUpdateTotal = "));
            M_DEBUG_PRINTLN((float)rainUpdateTotal / 100.0);
            send(msgRainVAR1.set((float)rainUpdateTotal / 100.0, 1)); //Send current day rain totals (resets at midnight)
            wait(DWELL_TIME);
          #ifdef USE_DAILY
            for (int i = currentHour + 24; i > currentHour; i--)
              M_DEBUG_PRINT(i);
            M_DEBUG_PRINT(F("TX Day 2: rainUpdateTotal = "));
            send(msgRainVAR2.set((float)rainUpdateTotal / 100.0, 1));
            wait(DWELL_TIME);
          #ifdef USE_DAILY
            for (int i = currentHour + 48; i > currentHour + 24; i--)
              M_DEBUG_PRINT(i);
            M_DEBUG_PRINT(F("TX Day 3: rainUpdateTotal = "));
            send(msgRainVAR3.set((float)rainUpdateTotal / 100.0, 1));
            wait(DWELL_TIME);
          #ifdef USE_DAILY
            for (int i = currentHour + 72; i > currentHour + 48; i--)
              M_DEBUG_PRINT(i);
            M_DEBUG_PRINT(F("TX Day 4: rainUpdateTotal = "));
            send(msgRainVAR4.set((float)rainUpdateTotal / 100.0, 1));
            wait(DWELL_TIME);
          #ifdef USE_DAILY
            for (int i = currentHour + 96; i > currentHour + 72; i--)
              M_DEBUG_PRINT(i);
            M_DEBUG_PRINT(F("TX Day 5: rainUpdateTotal = "));
            send(msgRainVAR5.set((float)rainUpdateTotal / 100.0, 1));
            wait(DWELL_TIME);
            if (message.sensor == CHILD_ID_RAIN_LOG)
              // nothing to do here
            else if (message.sensor == CHILD_ID_TRIPPED_INDICATOR)
              if (message.type == V_VAR1)
                rainWindow = atoi(message.data);
                if (rainWindow > 120)
                  rainWindow = 120;
                else if (rainWindow < 1)
                  rainWindow = 1;
                if (rainWindow != atoi(message.data))   // if I changed the value back inside the boundries, push that number back to Vera
                  send(msgTrippedVar1.set(rainWindow));
                rainSensorThreshold = atoi(message.data);
                if (rainSensorThreshold > 10000)
                  rainSensorThreshold = 10000;
                else if (rainSensorThreshold < 1)
                  rainSensorThreshold = 1;
                if (rainSensorThreshold != atoi(message.data))  // if I changed the value back inside the boundries, push that number back to Vera
                  send(msgTrippedVar2.set(rainSensorThreshold));
          void prettyFade(void)
            float val = (exp(sin(millis() / 2000.0 * PI)) - 0.36787944) * 108.0;
            analogWrite(ledPin, val);
          void slowFlash(void)
            static bool ledState = true;
            static unsigned long pulseStart = millis();
            if (millis() - pulseStart < 100UL)
              digitalWrite(ledPin, !ledState);
          void receiveTime(unsigned long newTime)
            M_DEBUG_PRINTLN(F("Time received..."));
            setTime(newTime);
            char theTime[6];
            sprintf(theTime, "%d:%2d", hour(), minute());
            M_DEBUG_PRINTLN(theTime);
          i take an original .stl files from the link provided: https://drive.google.com/drive/folders/0B3KGTJHUgpw1fkwtM3RreEF2QWg4eUdsUHdSQjl6UWx2Q3dPS19WSGdqd0pZQ3hhQk1TMkE
          but in order to save a support material recreate and split it a little ;-)
          The result are visible on photos
          here is an .scad code of my modifications on top of original files, also i print them up side down ;-)
          $fn=300;
          difference(){
          translate([35,0,0])
          import("Can.stl");
          cube([210,150,150],center=true);
          translate([62,0,0])
          rotate([0,90,0])
          difference(){
          cylinder(d=10,h=3,center=true);
          cylinder(d=4,h=6,center=true);
          difference(){
          translate([-88,0,0])
          sphere(d=300);
          translate([-90,0,0])
          sphere(d=300);
          translate([61,0,0])
          rotate([0,90,0])
          cylinder(d=4,h=4,center=true);
          rotate([0,90,0])
          difference(){
          cylinder(d=310,h=208,center=true);
          cylinder(d=122.5+4,h=310,center=true);
          translate([54,0,0])
          rotate([0,90,0])
          difference(){
          cylinder(d=122.5+4,h=108,center=true);
          cylinder(d=122.5,h=310,center=true);
          $fn=300;
          difference(){
          translate([35,0,0])
          import("Can.stl");
          translate([62,0,0])
          rotate([0,90,0])
          difference(){
          difference(){
          sphere(d=300);
          sphere(d=300);
          translate([61,0,0])
          rotate([0,90,0])
          rotate([0,90,0])
          difference(){
          translate([54,0,0])
          rotate([0,90,0])
          difference(){
          cylinder(d=122.5+4,h=40
             ,center=true);
          translate([32,0,0])
          rotate([0,90,0])
          difference(){
          cylinder(d=122.5+4+4,h=8
             ,center=true);
          cylinder(d=122.5+4,h=9,center=true);
          SY
          Enfeet
          dbemowskD 2 Replies Last reply
          • EnfeetE Enfeet
            Hi friends,
            photos:
             April 26, 2015
             Version 2.0
            #include <math.h>
            //d=112 mm
              #ifdef  DEBUG_ON
            #ifdef DHT_ON
              #ifdef DHT_ADAFRUIT
              #include <DHT_U.h>
                DHT dht;
              float lastTemp;
              float lastHum;
              bool metric = true;
            #ifdef LUX_ON
              #include <BH1750.h>
              BH1750 lightSensor;
            int eepromIndex;
            #ifdef DEBUG_ON
            uint8_t state = 0;
            uint8_t lastHour;
              wait(DWELL_TIME);
              wait(DWELL_TIME);
              wait(DWELL_TIME);
            #ifdef DHT_ON
              wait(DWELL_TIME);
              wait(DWELL_TIME);
            #ifdef LUX_ON
              #ifndef MY_DEBUG
              // Set up the IO
                requestTime();
              lastHour = hour();
                  saveState(i, 0x00);
              #ifdef DEBUG_ON
              wait(DWELL_TIME);
              wait(DWELL_TIME);
            #ifdef DHT_ON
                dht.begin();
              wait(DWELL_TIME);
            #ifdef LUX_ON
              if (state)
                wait(DWELL_TIME);
                oldState = state;
                wait(DWELL_TIME);
                wasTippedBuffer--;
                  wait(DWELL_TIME);
                wait(DWELL_TIME);
                wait(DWELL_TIME);
                wait(DWELL_TIME);
                rainBucket[0] = 0;
                wait(DWELL_TIME);
                transmitRainData();
                rainRate = 0;
                wait(DWELL_TIME);
                lastHour = hour();
                  doDHT();
                #ifdef LUX_ON
                  doLUX();
            #ifdef DHT_ON
            void doDHT(void)
                    if (!metric)
                  wait(DWELL_TIME);
                  lastHum = humidity;
                  wait(DWELL_TIME);
            #ifdef LUX_ON
            void doLUX(void)
              heartbeat++;
                send(msg.set(lux));
                lastlux = lux;
              if (heartbeat > 10)
                heartbeat = 0;
            void sensorTipped()
                wasTippedBuffer++;
              int total = 0;
              return total;
            #ifdef DEBUG_ON
              M_DEBUG_PRINT(x);
              float tipCount = 0;
                M_DEBUG_PRINT(i);
                M_DEBUG_PRINT(i);
              wait(DWELL_TIME);
            #ifdef USE_DAILY
                M_DEBUG_PRINT(i);
              wait(DWELL_TIME);
            #ifdef USE_DAILY
                M_DEBUG_PRINT(i);
              wait(DWELL_TIME);
            #ifdef USE_DAILY
                M_DEBUG_PRINT(i);
              wait(DWELL_TIME);
            #ifdef USE_DAILY
                M_DEBUG_PRINT(i);
              wait(DWELL_TIME);
                    rainWindow = 120;
                    rainWindow = 1;
              setTime(newTime);
              char theTime[6];
            $fn=300;
            difference(){
            translate([35,0,0])
            import("Can.stl");
            translate([62,0,0])
            rotate([0,90,0])
            difference(){
            difference(){
            sphere(d=300);
            sphere(d=300);
            translate([61,0,0])
            rotate([0,90,0])
            rotate([0,90,0])
            difference(){
            translate([54,0,0])
            rotate([0,90,0])
            difference(){
            $fn=300;
            difference(){
            translate([35,0,0])
            import("Can.stl");
            translate([62,0,0])
            rotate([0,90,0])
            difference(){
            difference(){
            sphere(d=300);
            sphere(d=300);
            translate([61,0,0])
            rotate([0,90,0])
            rotate([0,90,0])
            difference(){
            translate([54,0,0])
            rotate([0,90,0])
            difference(){
               ,center=true);
            translate([32,0,0])
            rotate([0,90,0])
            difference(){
               ,center=true);
            SY
            Enfeet
            dbemowskD
            dbemowskD
            @Enfeet What type of sensor did you use for the tipping bucket? Reed switch? Hall effect sensor?
            EnfeetE 1 Reply Last reply
            • dbemowskD dbemowsk
              EnfeetE
              EnfeetE
              Enfeet
              @dbemowsk
              20mm magnetic contact like this:
              SY
              Enfeet
              dbemowskD 1 Reply Last reply
              • EnfeetE Enfeet
                @dbemowsk
                SY
                Enfeet
                dbemowskD
                dbemowskD
                @Enfeet Thanks, it was hard to tell from your pics. It almost looked like a hall sensor. I too am using a reed switch. I have some reed switch boards that I salvaged from some old laptops. They were the sensors for closing the LCD.
                • EnfeetE Enfeet
                  Hi friends,
                  photos:
                   April 26, 2015
                   Version 2.0
                  #include <math.h>
                  //d=112 mm
                    #ifdef  DEBUG_ON
                  #ifdef DHT_ON
                    #ifdef DHT_ADAFRUIT
                    #include <DHT_U.h>
                      DHT dht;
                    float lastTemp;
                    float lastHum;
                    bool metric = true;
                  #ifdef LUX_ON
                    #include <BH1750.h>
                    BH1750 lightSensor;
                  int eepromIndex;
                  #ifdef DEBUG_ON
                  uint8_t state = 0;
                  uint8_t lastHour;
                    wait(DWELL_TIME);
                    wait(DWELL_TIME);
                    wait(DWELL_TIME);
                  #ifdef DHT_ON
                    wait(DWELL_TIME);
                    wait(DWELL_TIME);
                  #ifdef LUX_ON
                    #ifndef MY_DEBUG
                    // Set up the IO
                      requestTime();
                    lastHour = hour();
                        saveState(i, 0x00);
                    #ifdef DEBUG_ON
                    wait(DWELL_TIME);
                    wait(DWELL_TIME);
                  #ifdef DHT_ON
                      dht.begin();
                    wait(DWELL_TIME);
                  #ifdef LUX_ON
                    if (state)
                      wait(DWELL_TIME);
                      oldState = state;
                      wait(DWELL_TIME);
                      wasTippedBuffer--;
                        wait(DWELL_TIME);
                      wait(DWELL_TIME);
                      wait(DWELL_TIME);
                      wait(DWELL_TIME);
                      rainBucket[0] = 0;
                      wait(DWELL_TIME);
                      transmitRainData();
                      rainRate = 0;
                      wait(DWELL_TIME);
                      lastHour = hour();
                        doDHT();
                      #ifdef LUX_ON
                        doLUX();
                  #ifdef DHT_ON
                  void doDHT(void)
                          if (!metric)
                        wait(DWELL_TIME);
                        lastHum = humidity;
                        wait(DWELL_TIME);
                  #ifdef LUX_ON
                  void doLUX(void)
                    heartbeat++;
                      send(msg.set(lux));
                      lastlux = lux;
                    if (heartbeat > 10)
                      heartbeat = 0;
                  void sensorTipped()
                      wasTippedBuffer++;
                    int total = 0;
                    return total;
                  #ifdef DEBUG_ON
                    M_DEBUG_PRINT(x);
                    float tipCount = 0;
                      M_DEBUG_PRINT(i);
                      M_DEBUG_PRINT(i);
                    wait(DWELL_TIME);
                  #ifdef USE_DAILY
                      M_DEBUG_PRINT(i);
                    wait(DWELL_TIME);
                  #ifdef USE_DAILY
                      M_DEBUG_PRINT(i);
                    wait(DWELL_TIME);
                  #ifdef USE_DAILY
                      M_DEBUG_PRINT(i);
                    wait(DWELL_TIME);
                  #ifdef USE_DAILY
                      M_DEBUG_PRINT(i);
                    wait(DWELL_TIME);
                          rainWindow = 120;
                          rainWindow = 1;
                    setTime(newTime);
                    char theTime[6];
                  $fn=300;
                  difference(){
                  translate([35,0,0])
                  import("Can.stl");
                  translate([62,0,0])
                  rotate([0,90,0])
                  difference(){
                  difference(){
                  sphere(d=300);
                  sphere(d=300);
                  translate([61,0,0])
                  rotate([0,90,0])
                  rotate([0,90,0])
                  difference(){
                  translate([54,0,0])
                  rotate([0,90,0])
                  difference(){
                  $fn=300;
                  difference(){
                  translate([35,0,0])
                  import("Can.stl");
                  translate([62,0,0])
                  rotate([0,90,0])
                  difference(){
                  difference(){
                  sphere(d=300);
                  sphere(d=300);
                  translate([61,0,0])
                  rotate([0,90,0])
                  rotate([0,90,0])
                  difference(){
                  translate([54,0,0])
                  rotate([0,90,0])
                  difference(){
                     ,center=true);
                  translate([32,0,0])
                  rotate([0,90,0])
                  difference(){
                     ,center=true);
                  SY
                  Enfeet
                  dbemowskD
                  dbemowskD
                  @Enfeet I was checking out your sketch and was confused on some of the numbers you had commented into your sketch. I am gathering that they are numbers you used to figure out your CALIBRATE_FACTOR number, but I am trying to understand them. These are the numbers I am referring to:
                  //d=112 mm
                  I am assuming that 112 mm is the diameter of your catchment funnel. I cannot however figure out your next number 11689.863832 mm2. What formula did you use to come up with that number? Knowing that may help me understand the rest of the numbers.
                    //d=112 mm
                    EnfeetE
                    EnfeetE
                    Enfeet
                    @dbemowsk i use first found online calculator http://onlinemschool.com/math/assistance/figures_area/circle/
                    and... strange.... it gives other result ;-) So my calculations are incorrect ;-(
                    A = 1 4 π d2 = 1 4 π 1122 = 3136 π ≈ 9852.032512
                    SY
                    Sergey
                    EnfeetE dbemowskD 2 Replies Last reply
                    • EnfeetE Enfeet
                      SY
                      Sergey
                      EnfeetE
                      EnfeetE
                      Enfeet
                      @Enfeet o! d=122 not 112... uff correct ;-)
                      • EnfeetE Enfeet
                        SY
                        Sergey
                        dbemowskD
                        dbemowskD
                        @Enfeet I have been trying to wrap my head around the formulas for this. I have been basing numbers off of the formulas on this instructables page and after looking at his numbers, I think he has them wrong too. He states :
                        rainfall height = volume of rain collected / catchment area
                        In my rain collector, the length and breadth were 11 cm by 5 cm respectively giving a catchment area of 55 sq.cm. So a collection of 9 milliliters of rain would mean 9 cc/55 sq.cm = 0.16363... cm = 1.6363... mm = 0.394 inches.
                        9cc/55 is 0.16363 cm, but 1.6363 mm does not equal 0.394 inches as stated in the article. According to the conversion I did it is 0.064421. Did I do a calculation wrong?
                          EnfeetE
                          EnfeetE
                          Enfeet
                          @dbemowsk I think it's time to look in a book ;-) "The amount of precipitation is expressed in millimeters of a layer of water that would be formed from the precipitation, if they did not evaporate, did not seep into the soil and would not drain. Numerically, the amount of precipitation in millimeters is equal to the amount of kilograms of water left on the site in 1 sq.meter, i.e. 1 mm = 1 kg / 1 m2.
                          • EnfeetE Enfeet
                            EnfeetE
                            EnfeetE
                            Enfeet
                            @Enfeet Precipitation intensity
                            "Strong" is called rain, if it drops from 15 to 49 mm in 12 hours. Precipitation is also "very strong" when it falls from 50 mm in 12 hours.
                            "Strong snow" - the amount of precipitation from 7 to 19 mm for 12 hours. "Very heavy snow," when its amount exceeds 20 mm in 12 hours.
                            • EnfeetE Enfeet
                              dbemowskD
                              dbemowskD
                              @Enfeet I understand that, my point was I guess more that it gets confusing when the person that wrote the article gets the numbers wrong. The other part that can get a little confusing in this at times is the units of measure and the conversions. When you talk about mm (length) vs mm2 (area) vs mm3 (volume) and you start mixing these together in the calculations. I am in the US, so I work with imperial measures, so then there is the conversions from metric to imperial on top of that. The thing that I think the guy that wrote the article got wrong was his conversion to imperial measure (inches of rainfall). That is more what I was trying to wrap my head around.
                                EnfeetE
                                EnfeetE
                                Enfeet
                                @dbemowsk Sorry, i m living in metric units ;-) But, i think it can be calculated logically. Just look at a DIY project: https://www.education.com/science-fair/article/DIY-rain-gauge/ The logic is to attach a scale to a bottle and measure the mm or inches of rain occured. Our goal is recalculate the number of impulses to the amount of precipitation depending on square of our bucket. So it's possible to take a bottle with the same square like our bucket, attach a scale (inches or mm does not matter) and let collect all water out of our measuring gauge i.e. take a litter or half flow it to a gauge and collect after. And finally just divide measured level of collected water to the number of impulses counted....
                                Sorry if method is not clear... ;-) I can draw an idea in a pictures ;-)
                                • EnfeetE
                                  EnfeetE
                                  Enfeet
                                  Ups! After 3 days.....
                                    schmucke
                                    What kind of powersupply is a good one, if i have errors with bouncing/fakerain?
                                    • S schmucke
                                      EnfeetE
                                      EnfeetE
                                      Enfeet
                                      @schmucke I'm using 5V 1Amp from tiny mobile charger https://www.thingiverse.com/thing:2171813
                                        schmucke
                                        I have the following problem:
                                        Every Time, if a normal switch with a led bulb is switching, the arduino is count one up...
                                        • mfalkviddM
                                          Sounds like the hardware debouncing described in the troubleshooting section might be needed.
                                          12.5k
