  2. Announcements
  3. 💬 Rain Gauge
💬 Rain Gauge
61 Posts 17 Posters 28.9k Views 16 Watching
  • dbemowskD dbemowsk
    @Enfeet What type of sensor did you use for the tipping bucket? Reed switch? Hall effect sensor?
    EnfeetE
    EnfeetE
    Enfeet
    @dbemowsk
    20mm magnetic contact like this:
    SY
    Enfeet
    dbemowskD 1 Reply Last reply
    • EnfeetE Enfeet
      @dbemowsk
      SY
      Enfeet
      dbemowskD
      dbemowskD
      @Enfeet Thanks, it was hard to tell from your pics. It almost looked like a hall sensor. I too am using a reed switch. I have some reed switch boards that I salvaged from some old laptops. They were the sensors for closing the LCD.
      • EnfeetE Enfeet
        Hi friends,
        here is my replica of Rain Guage MySensors project
        photos:
        https://goo.gl/photos/4kA7T4d8SsDBRrrS7
        The sketch is adopted for 'Adafruit Unified Sensor by Adafruit' + 'DHT sensor library' just uncomment both DHT_ON and DHT_ADAFRUIT
        and last version of Arduino IDE 1.8.3
        ...and Yes, I'm using rfm69hw radio with encryption enabled ;-)
        #define MY_RFM69_ENABLE_ENCRYPTION
         Arduino Tipping Bucket Rain Gauge
         April 26, 2015
         Version 2.0
         Utilizing a tipping bucket sensor, your Vera home automation controller and the MySensors.org
         gateway you can measure and sense local rain.  This sketch will create two devices on your
         Vera controller.  One will display your total precipitation for the last 5 days.  The other,
         a sensor that changes state if there is recent rain (up to last 120 hours)  above a threshold.
         Both these settings are user definable.
         There is a build overview video here: https://youtu.be/1eMfKQaLROo
         * Allows you to set the rain threshold in mm
         * Allows you to determine the tripped indicator window up to 120 hours.
         * Displays the last 5 days of rain in Variable1 through Variable5
           of the Rain Sensor device
         * Configuration changes to Sensor device updated every hour
         * Should run on any Arduino
         * Will retain Tripped/Not Tripped status and data in a power interruption, saving small amount
           of data to EEPROM (Circular Buffer to maximize life of EEPROM)
         * LED status indicator
         * Optional Temp/Humidity (DHT-22 or DHT-11) and Light LUX (BH1750) sensors. To use, uncomment
           #define DHT_ON  and/or #define LUX_ON
         * Optionally send total accumulation of each day's rainfall or send only individual days rainfall totals.
           Uncomment #define USE_DAILY to display individual daily rainfall.  If it is commented out it will display
           a cumulative total rainfall (day4 = day1+day2+day3+day4 etc)
         by @BulldogLowell and @PeteWill for free public use
        //#define MY_DEBUG_VERBOSE
        #define MY_NODE_ID AUTO
        //#define MY_RADIO_NRF24
        #define MY_RADIO_RFM69
        #define MY_IS_RFM69HW
        #define MY_RFM69_TX_POWER 31
        #include <math.h>
        #include <TimeLib.h>
        #define SKETCH_NAME "Rain Gauge"
        #define SKETCH_VERSION "2.0"
        #define DWELL_TIME 40  // this allows for radio to come back to power after a transmission, ideally 0
        //#define DEBUG_ON  // Rain gauge specific debug messages.
        #define DHT_ON // uncomment out this line to enable DHT sensor
        // 20170621 by Enfeet
        #define DHT_ADAFRUIT // uncomment out this line to enable DHT with 'Adafruit Unified Sensor by Adafruit' + 'DHT sensor library'
        //#define DHTTYPE           DHT11     // DHT 11
        #define DHTTYPE           DHT22     // DHT 22 (AM2302)
        //#define DHTTYPE           DHT21     // DHT 21 (AM2301)
        // /20170621 by Enfeet
        //#define LUX_ON // uncomment out this line to enable BH1750 sensor
        //#define USE_DAILY // Uncomment to display individual daily rainfall totals in the variables sent to your controller. If it's commented it will add each day to the next for a cumulative total.
        #define TIP_SENSOR_PIN 3
        //d=112 mm
        //11689.863832 mm2 =  116,89863832 cm2
        //42,77209787776081 mm
        //88 89 91 91 90 = 89,8
        //0,4763039852757329
        #define CALIBRATE_FACTOR 48 // amount of rain per rain bucket tip e.g. 5 is .05mm
        #define DHT_LUX_DELAY 300000  //Delay in milliseconds that the DHT and LUX sensors will wait before sending data
        #define CHILD_ID_RAIN_LOG 3  // Keeps track of accumulated rainfall
        #define CHILD_ID_TRIPPED_INDICATOR 4  // Indicates Tripped when rain detected
        #define EEPROM_BUFFER_LOCATION 0  // location of the EEPROM circular buffer
        #define E_BUFFER_LENGTH 240
        #define RAIN_BUCKET_SIZE 120
          #ifdef  DEBUG_ON
            #define M_DEBUG_PRINT(x)   Serial.print(x)
            #define M_DEBUG_PRINTLN(x) Serial.println(x)
        MyMessage msgRainRate(CHILD_ID_RAIN_LOG, V_RAINRATE);
        MyMessage msgRain(CHILD_ID_RAIN_LOG, V_RAIN);
        MyMessage msgRainVAR1(CHILD_ID_RAIN_LOG, V_VAR1);
        MyMessage msgRainVAR2(CHILD_ID_RAIN_LOG, V_VAR2);
        MyMessage msgRainVAR3(CHILD_ID_RAIN_LOG, V_VAR3);
        MyMessage msgRainVAR4(CHILD_ID_RAIN_LOG, V_VAR4);
        MyMessage msgRainVAR5(CHILD_ID_RAIN_LOG, V_VAR5);
        MyMessage msgTripped(CHILD_ID_TRIPPED_INDICATOR, V_TRIPPED);
        MyMessage msgTrippedVar1(CHILD_ID_TRIPPED_INDICATOR, V_VAR1);
        MyMessage msgTrippedVar2(CHILD_ID_TRIPPED_INDICATOR, V_VAR2);
        #ifdef DHT_ON
          #ifdef DHT_ADAFRUIT
          #include <Adafruit_Sensor.h>
          #include <DHT_U.h>
          #define CHILD_ID_HUM 0
          #define CHILD_ID_TEMP 1
          #define HUMIDITY_SENSOR_DIGITAL_PIN 8
          #ifndef DHT_ADAFRUIT // 20170621 by Enfeet
            DHT dht;
            DHT_Unified dht(HUMIDITY_SENSOR_DIGITAL_PIN, DHTTYPE);
            sensors_event_t event;
          #endif // /20170621 by Enfeet
          float lastTemp;
          float lastHum;
          bool metric = true;
        #ifdef LUX_ON
          //BH1750 is connected to SCL (analog input A5) and SDA (analog input A4)
          #include <BH1750.h>
          #define CHILD_ID_LIGHT 2
          BH1750 lightSensor;
          unsigned int lastlux;
          uint8_t heartbeat = 10; //Used to send the light lux to gateway as soon as the device is restarted and after the DHT_LUX_DELAY has happened 10 times
        unsigned long sensorPreviousMillis;
        int eepromIndex;
        int tipSensorPin = 3; // Pin the tipping bucket is connected to. Must be interrupt capable pin
        int ledPin = 5; // Pin the LED is connected to.  PWM capable pin required
        #ifdef DEBUG_ON
        unsigned long dataMillis;
        unsigned long serialInterval = 600000UL;
        const unsigned long oneHour = 3600000UL;
        unsigned long lastTipTime;
        unsigned long lastRainTime; //Used for rainRate calculation
        unsigned int rainBucket [RAIN_BUCKET_SIZE] ; /* 24 hours x 5 Days = 120 hours */
        unsigned int rainRate = 0;
        uint8_t rainWindow = 72;         //default rain window in hours.  Will be overwritten with msgTrippedVar1.
        volatile int wasTippedBuffer = 0;
        int rainSensorThreshold = 50; //default rain sensor sensitivity in hundredths.  Will be overwritten with msgTrippedVar2.
        uint8_t state = 0;
        uint8_t oldState = 2; //Setting the default to something other than 1 or 0
        unsigned int lastRainRate = 0;
        int lastMeasure = 0;
        bool gotTime = false;
        uint8_t lastHour;
        uint8_t currentHour;
        void presentation()  {
          wait(DWELL_TIME);
          present(CHILD_ID_RAIN_LOG, S_RAIN);
          wait(DWELL_TIME);
          present(CHILD_ID_TRIPPED_INDICATOR, S_MOTION);
          wait(DWELL_TIME);
        #ifdef DHT_ON
          present(CHILD_ID_HUM, S_HUM);
          wait(DWELL_TIME);
          wait(DWELL_TIME);
        #ifdef LUX_ON
          M_DEBUG_PRINTLN(F("Sensor Presentation Complete"));
          #ifndef MY_DEBUG
          SERIAL_START(115200);  //Start serial if MySensors debugging isn't enabled
          // Set up the IO
          pinMode(TIP_SENSOR_PIN, INPUT);
          attachInterrupt (digitalPinToInterrupt(TIP_SENSOR_PIN), sensorTipped, FALLING);  // depending on location of the hall effect sensor may need CHANGE
          pinMode(ledPin, OUTPUT);
          digitalWrite(ledPin, HIGH);
          //Sync time with the server
          unsigned long functionTimeout = millis();
          while (timeStatus() == timeNotSet && millis() - functionTimeout < 30000UL)
            requestTime();
            M_DEBUG_PRINTLN(F("Getting Time"));
            wait(1000); // call once per second
            M_DEBUG_PRINTLN(F("."));
          currentHour = hour();
          lastHour = hour();
          //retrieve from EEPROM stored values on a power cycle.
          bool isDataOnEeprom = false;
          for (int i = 0; i < E_BUFFER_LENGTH; i++)
            uint8_t locator = loadState(EEPROM_BUFFER_LOCATION + i);
            if (locator == 0xFE)  // found the EEPROM circular buffer index
              eepromIndex = EEPROM_BUFFER_LOCATION + i;
              M_DEBUG_PRINT(F("EEPROM Index "));
              M_DEBUG_PRINTLN(eepromIndex);
              //Now that we have the buffer index let's populate the rainBucket[] with data from eeprom
              loadRainArray(eepromIndex);
              isDataOnEeprom = true;
          if (!isDataOnEeprom) // Added for the first time it is run on a new Arduino
            M_DEBUG_PRINTLN(F("I didn't find valid EEPROM Index, so I'm writing one to location 0"));
            eepromIndex = EEPROM_BUFFER_LOCATION;
            saveState(eepromIndex, 0xFE);
            saveState(eepromIndex + 1, 0xFE);
            //then I will clear out any bad data
            for (int i = 2; i <= E_BUFFER_LENGTH; i++)
              saveState(i, 0x00);
          #ifdef DEBUG_ON
          dataMillis = millis();
          lastTipTime = millis();
          request(CHILD_ID_TRIPPED_INDICATOR, V_VAR1);
          wait(DWELL_TIME);
          request(CHILD_ID_TRIPPED_INDICATOR, V_VAR2);
          wait(DWELL_TIME);
        #ifdef DHT_ON
            dht.begin();
          wait(DWELL_TIME);
        #ifdef LUX_ON
          lightSensor.begin();
          transmitRainData(); //Setup complete send any data loaded from eeprom to gateway
          if (state)
            prettyFade();  // breathe if tripped
            slowFlash();   // blink if not tripped
        #ifdef DEBUG_ON  // Serial Debug Block
          if ( (millis() - dataMillis) >= serialInterval)
            for (int i = 24; i <= 120; i = i + 24)
              updateSerialData(i);
          // let's constantly check to see if the rain in the past rainWindow hours is greater than rainSensorThreshold
          int measure = 0; // Check to see if we need to show sensor tripped in this block
          for (int i = 0; i < rainWindow; i++)
            measure += rainBucket [i];
            if (measure != lastMeasure)
              //      M_DEBUG_PRINT(F("measure value (total rainBucket within rainWindow): "));
              //      M_DEBUG_PRINTLN(measure);
              lastMeasure = measure;
          state = (measure >= (rainSensorThreshold * 100));
          if (state != oldState)
            send(msgTripped.set(state));
            wait(DWELL_TIME);
            M_DEBUG_PRINT(F("New Sensor State... Sensor: "));
            M_DEBUG_PRINTLN(state ? "Tripped" : "Not Tripped");
            oldState = state;
          unsigned long tipDelay = millis() - lastRainTime;
          if (wasTippedBuffer) // if was tipped, then update the 24hour total and transmit to Vera
            M_DEBUG_PRINTLN(F("Sensor Tipped"));
            M_DEBUG_PRINT(F("rainBucket [0] value: "));
            M_DEBUG_PRINTLN(rainBucket [0]);
            send(msgRain.set((float)rainTotal(currentHour) / 100, 1)); //Calculate the total rain for the day
            wait(DWELL_TIME);
            wasTippedBuffer--;
            rainRate = ((oneHour) / tipDelay);
            if (rainRate != lastRainRate)
              send(msgRainRate.set(rainRate, 1));
              wait(DWELL_TIME);
              M_DEBUG_PRINT(F("RainRate= "));
              M_DEBUG_PRINTLN(rainRate);
              lastRainRate = rainRate;
            lastRainTime = lastTipTime;
          if (currentHour != lastHour)
            M_DEBUG_PRINTLN(F("One hour elapsed."));
            send(msgRain.set((float)rainTotal(currentHour) / 100, 1)); // send today's rainfall
            wait(DWELL_TIME);
            saveState(eepromIndex, highByte(rainBucket[0]));
            saveState(eepromIndex + 1, lowByte(rainBucket[0]));
            M_DEBUG_PRINT(F("Saving rainBucket[0] to eeprom. rainBucket[0] = "));
            M_DEBUG_PRINTLN(rainBucket[0]);
            for (int i = RAIN_BUCKET_SIZE - 1; i >= 0; i--)//cascade an hour of values back into the array
              rainBucket [i + 1] = rainBucket [i];
            wait(DWELL_TIME);
            wait(DWELL_TIME);
            rainBucket[0] = 0;
            eepromIndex = eepromIndex + 2;
            if (eepromIndex > EEPROM_BUFFER_LOCATION + E_BUFFER_LENGTH)
            M_DEBUG_PRINT(F("Writing to EEPROM.  Index: "));
            requestTime(); // sync the time every hour
            wait(DWELL_TIME);
            transmitRainData();
            rainRate = 0;
            wait(DWELL_TIME);
            M_DEBUG_PRINTLN(F("Sending rainRate is 0 to controller"));
            lastHour = hour();
          if (millis() - sensorPreviousMillis > DHT_LUX_DELAY)
            #ifdef DHT_ON  //DHT Code
              doDHT();
            #ifdef LUX_ON
              doLUX();
            sensorPreviousMillis = millis();
        #ifdef DHT_ON
        void doDHT(void)
            if (isnan(temperature))
            dht.temperature().getEvent(&event);
            float temperature = event.temperature;
            if (isnan(event.temperature))
              M_DEBUG_PRINTLN(F("Failed reading temperature from DHT"));
            } else if (temperature != lastTemp)
              lastTemp = temperature;
                if (!metric)
              wait(DWELL_TIME);
              M_DEBUG_PRINT(F("Temperature is: "));
              M_DEBUG_PRINTLN(temperature);
            float humidity = dht.getHumidity();;
            if (isnan(humidity))
            dht.humidity().getEvent(&event);
            float humidity = event.relative_humidity;
            if (isnan(event.relative_humidity))
              M_DEBUG_PRINTLN(F("Failed reading humidity from DHT"));
            } else if (humidity != lastHum)
              lastHum = humidity;
              wait(DWELL_TIME);
              M_DEBUG_PRINT(F("Humidity is: "));
              M_DEBUG_PRINTLN(humidity);
        #ifdef LUX_ON
        void doLUX(void)
          unsigned int lux = lightSensor.readLightLevel();// Get Lux value
          M_DEBUG_PRINT(F("Current LUX Level: "));
          M_DEBUG_PRINTLN(lux);
          heartbeat++;
          if (lux != lastlux || heartbeat > 10)
            send(msg.set(lux));
            lastlux = lux;
          if (heartbeat > 10)
            heartbeat = 0;
        void sensorTipped()
          unsigned long thisTipTime = millis();
          if (thisTipTime - lastTipTime > 100UL)
            rainBucket[0] += CALIBRATE_FACTOR; // adds CALIBRATE_FACTOR hundredths of unit each tip
            wasTippedBuffer++;
          lastTipTime = thisTipTime;
        int rainTotal(int hours)
          int total = 0;
          for ( int i = 0; i <= hours; i++)
            total += rainBucket [i];
          return total;
        #ifdef DEBUG_ON
        void updateSerialData(int x)
          M_DEBUG_PRINT(F("Rain last "));
          M_DEBUG_PRINT(x);
          M_DEBUG_PRINTLN(F(" hours: "));
          float tipCount = 0;
          for (int i = 0; i < x; i++)
            tipCount = tipCount + rainBucket [i];
          tipCount = tipCount / 100;
          M_DEBUG_PRINTLN(tipCount);
        void loadRainArray(int eValue) // retrieve stored rain array from EEPROM on powerup
          for (int i = 1; i < RAIN_BUCKET_SIZE; i++)
            eValue = eValue - 2;
            if (eValue < EEPROM_BUFFER_LOCATION)
              eValue = EEPROM_BUFFER_LOCATION + E_BUFFER_LENGTH;
            M_DEBUG_PRINT(F("EEPROM location: "));
            M_DEBUG_PRINTLN(eValue);
            uint8_t rainValueHigh = loadState(eValue);
            uint8_t rainValueLow = loadState(eValue + 1);
            unsigned int rainValue = rainValueHigh << 8;
            rainValue |= rainValueLow;
            rainBucket[i] = rainValue;
            M_DEBUG_PRINT(F("rainBucket[ value: "));
            M_DEBUG_PRINT(i);
            M_DEBUG_PRINT(F("] value: "));
            M_DEBUG_PRINTLN(rainBucket[i]);
        void transmitRainData(void)
          M_DEBUG_PRINT(F("In transmitRainData. currentHour = "));
          M_DEBUG_PRINTLN(currentHour);
          int rainUpdateTotal = 0;
          for (int i = currentHour; i >= 0; i--)
            rainUpdateTotal += rainBucket[i];
            M_DEBUG_PRINT(F("Adding rainBucket["));
            M_DEBUG_PRINT(i);
            M_DEBUG_PRINTLN(F("] to rainUpdateTotal."));
          M_DEBUG_PRINT(F("TX Day 1: rainUpdateTotal = "));
          M_DEBUG_PRINTLN((float)rainUpdateTotal / 100.0);
          send(msgRainVAR1.set((float)rainUpdateTotal / 100.0, 1)); //Send current day rain totals (resets at midnight)
          wait(DWELL_TIME);
        #ifdef USE_DAILY
          for (int i = currentHour + 24; i > currentHour; i--)
            M_DEBUG_PRINT(i);
          M_DEBUG_PRINT(F("TX Day 2: rainUpdateTotal = "));
          send(msgRainVAR2.set((float)rainUpdateTotal / 100.0, 1));
          wait(DWELL_TIME);
        #ifdef USE_DAILY
          for (int i = currentHour + 48; i > currentHour + 24; i--)
            M_DEBUG_PRINT(i);
          M_DEBUG_PRINT(F("TX Day 3: rainUpdateTotal = "));
          send(msgRainVAR3.set((float)rainUpdateTotal / 100.0, 1));
          wait(DWELL_TIME);
        #ifdef USE_DAILY
          for (int i = currentHour + 72; i > currentHour + 48; i--)
            M_DEBUG_PRINT(i);
          M_DEBUG_PRINT(F("TX Day 4: rainUpdateTotal = "));
          send(msgRainVAR4.set((float)rainUpdateTotal / 100.0, 1));
          wait(DWELL_TIME);
        #ifdef USE_DAILY
          for (int i = currentHour + 96; i > currentHour + 72; i--)
            M_DEBUG_PRINT(i);
          M_DEBUG_PRINT(F("TX Day 5: rainUpdateTotal = "));
          send(msgRainVAR5.set((float)rainUpdateTotal / 100.0, 1));
          wait(DWELL_TIME);
          if (message.sensor == CHILD_ID_RAIN_LOG)
            // nothing to do here
          else if (message.sensor == CHILD_ID_TRIPPED_INDICATOR)
            if (message.type == V_VAR1)
              rainWindow = atoi(message.data);
              if (rainWindow > 120)
                rainWindow = 120;
              else if (rainWindow < 1)
                rainWindow = 1;
              if (rainWindow != atoi(message.data))   // if I changed the value back inside the boundries, push that number back to Vera
                send(msgTrippedVar1.set(rainWindow));
              rainSensorThreshold = atoi(message.data);
              if (rainSensorThreshold > 10000)
                rainSensorThreshold = 10000;
              else if (rainSensorThreshold < 1)
                rainSensorThreshold = 1;
              if (rainSensorThreshold != atoi(message.data))  // if I changed the value back inside the boundries, push that number back to Vera
                send(msgTrippedVar2.set(rainSensorThreshold));
        void prettyFade(void)
          float val = (exp(sin(millis() / 2000.0 * PI)) - 0.36787944) * 108.0;
          analogWrite(ledPin, val);
        void slowFlash(void)
          static bool ledState = true;
          static unsigned long pulseStart = millis();
          if (millis() - pulseStart < 100UL)
            digitalWrite(ledPin, !ledState);
        void receiveTime(unsigned long newTime)
          M_DEBUG_PRINTLN(F("Time received..."));
          setTime(newTime);
          char theTime[6];
          sprintf(theTime, "%d:%2d", hour(), minute());
          M_DEBUG_PRINTLN(theTime);
        i take an original .stl files from the link provided: https://drive.google.com/drive/folders/0B3KGTJHUgpw1fkwtM3RreEF2QWg4eUdsUHdSQjl6UWx2Q3dPS19WSGdqd0pZQ3hhQk1TMkE
        but in order to save a support material recreate and split it a little ;-)
        The result are visible on photos
        here is an .scad code of my modifications on top of original files, also i print them up side down ;-)
        $fn=300;
        difference(){
        translate([35,0,0])
        import("Can.stl");
        cube([210,150,150],center=true);
        translate([62,0,0])
        rotate([0,90,0])
        difference(){
        cylinder(d=10,h=3,center=true);
        cylinder(d=4,h=6,center=true);
        difference(){
        translate([-88,0,0])
        sphere(d=300);
        translate([-90,0,0])
        sphere(d=300);
        translate([61,0,0])
        rotate([0,90,0])
        cylinder(d=4,h=4,center=true);
        rotate([0,90,0])
        difference(){
        cylinder(d=310,h=208,center=true);
        cylinder(d=122.5+4,h=310,center=true);
        translate([54,0,0])
        rotate([0,90,0])
        difference(){
        cylinder(d=122.5+4,h=108,center=true);
        cylinder(d=122.5,h=310,center=true);
        $fn=300;
        difference(){
        translate([35,0,0])
        import("Can.stl");
        translate([62,0,0])
        rotate([0,90,0])
        difference(){
        difference(){
        sphere(d=300);
        sphere(d=300);
        translate([61,0,0])
        rotate([0,90,0])
        rotate([0,90,0])
        difference(){
        translate([54,0,0])
        rotate([0,90,0])
        difference(){
        cylinder(d=122.5+4,h=40
           ,center=true);
        translate([32,0,0])
        rotate([0,90,0])
        difference(){
        cylinder(d=122.5+4+4,h=8
           ,center=true);
        cylinder(d=122.5+4,h=9,center=true);
        SY
        Enfeet
        dbemowskD
        dbemowskD
        @Enfeet I was checking out your sketch and was confused on some of the numbers you had commented into your sketch. I am gathering that they are numbers you used to figure out your CALIBRATE_FACTOR number, but I am trying to understand them. These are the numbers I am referring to:
        //d=112 mm
        I am assuming that 112 mm is the diameter of your catchment funnel. I cannot however figure out your next number 11689.863832 mm2. What formula did you use to come up with that number? Knowing that may help me understand the rest of the numbers.
        EnfeetE 1 Reply Last reply
          //d=112 mm
          EnfeetE
          EnfeetE
          Enfeet
          @dbemowsk i use first found online calculator http://onlinemschool.com/math/assistance/figures_area/circle/
          and... strange.... it gives other result ;-) So my calculations are incorrect ;-(
          A = 1 4 π d2 = 1 4 π 1122 = 3136 π ≈ 9852.032512
          SY
          Sergey
          EnfeetE dbemowskD 2 Replies Last reply
          • EnfeetE Enfeet
            SY
            Sergey
            EnfeetE
            EnfeetE
            Enfeet
            @Enfeet o! d=122 not 112... uff correct ;-)
            • EnfeetE Enfeet
              SY
              Sergey
              dbemowskD
              dbemowskD
              @Enfeet I have been trying to wrap my head around the formulas for this. I have been basing numbers off of the formulas on this instructables page and after looking at his numbers, I think he has them wrong too. He states :
              rainfall height = volume of rain collected / catchment area
              In my rain collector, the length and breadth were 11 cm by 5 cm respectively giving a catchment area of 55 sq.cm. So a collection of 9 milliliters of rain would mean 9 cc/55 sq.cm = 0.16363... cm = 1.6363... mm = 0.394 inches.
              9cc/55 is 0.16363 cm, but 1.6363 mm does not equal 0.394 inches as stated in the article. According to the conversion I did it is 0.064421. Did I do a calculation wrong?
                EnfeetE
                EnfeetE
                Enfeet
                @dbemowsk I think it's time to look in a book ;-) "The amount of precipitation is expressed in millimeters of a layer of water that would be formed from the precipitation, if they did not evaporate, did not seep into the soil and would not drain. Numerically, the amount of precipitation in millimeters is equal to the amount of kilograms of water left on the site in 1 sq.meter, i.e. 1 mm = 1 kg / 1 m2.
                • EnfeetE Enfeet
                  EnfeetE
                  EnfeetE
                  Enfeet
                  @Enfeet Precipitation intensity
                  "Strong" is called rain, if it drops from 15 to 49 mm in 12 hours. Precipitation is also "very strong" when it falls from 50 mm in 12 hours.
                  "Strong snow" - the amount of precipitation from 7 to 19 mm for 12 hours. "Very heavy snow," when its amount exceeds 20 mm in 12 hours.
                  • EnfeetE Enfeet
                    dbemowskD
                    dbemowskD
                    @Enfeet I understand that, my point was I guess more that it gets confusing when the person that wrote the article gets the numbers wrong. The other part that can get a little confusing in this at times is the units of measure and the conversions. When you talk about mm (length) vs mm2 (area) vs mm3 (volume) and you start mixing these together in the calculations. I am in the US, so I work with imperial measures, so then there is the conversions from metric to imperial on top of that. The thing that I think the guy that wrote the article got wrong was his conversion to imperial measure (inches of rainfall). That is more what I was trying to wrap my head around.
                      EnfeetE
                      EnfeetE
                      Enfeet
                      @dbemowsk Sorry, i m living in metric units ;-) But, i think it can be calculated logically. Just look at a DIY project: https://www.education.com/science-fair/article/DIY-rain-gauge/ The logic is to attach a scale to a bottle and measure the mm or inches of rain occured. Our goal is recalculate the number of impulses to the amount of precipitation depending on square of our bucket. So it's possible to take a bottle with the same square like our bucket, attach a scale (inches or mm does not matter) and let collect all water out of our measuring gauge i.e. take a litter or half flow it to a gauge and collect after. And finally just divide measured level of collected water to the number of impulses counted....
                      Sorry if method is not clear... ;-) I can draw an idea in a pictures ;-)
                      • EnfeetE
                        EnfeetE
                        Enfeet
                        Ups! After 3 days.....
                          schmucke
                          What kind of powersupply is a good one, if i have errors with bouncing/fakerain?
                          • S schmucke
                            EnfeetE
                            EnfeetE
                            Enfeet
                            @schmucke I'm using 5V 1Amp from tiny mobile charger https://www.thingiverse.com/thing:2171813
                              schmucke
                              I have the following problem:
                              Every Time, if a normal switch with a led bulb is switching, the arduino is count one up...
                              • mfalkviddM
                                Sounds like the hardware debouncing described in the troubleshooting section might be needed.
                                  schmucke
                                  I have just one build, but i use 300ohm. I think, thats to small :/
                                  • kotzerK
                                    kotzerK
                                    kotzer
                                    nice idea, nice project, nice documentation, nice result :+1: :heart: :heart:
                                    but i've a problem with the led. this is only HIGH when the arduino boots up for ~2 secs. then set to 0 (LOW).
                                    i adjusted some debugging message to find out, what exactly happens, but am stucking here.. in the loop it goes into slowFlash(), but there nothing is called against the led_pin (because of if (millis() - pulseStart < 100UL))
                                    what am i doing wrong?
                                    why is the led only fired at startup, but not when trapped (manually closed the reed switch for short time to simulate some rain)?
                                    what was the intension of the led? (nothing could be found in description & video of pete)
                                    @petewill I don't see the led in your vid... where is it?
                                    • I
                                      I
                                      itbeyond
                                      Folks, A question of interest. I have had my gauge working great for several months but it has just started to play up. It seems to crash after a few hours. I have not plugged in a debug/console or anything as yet but decided to have a good look at the code and I have noticed that every hour the system cycles through updating EPROM values to cascade the rain rates. I have also noted with interest a comment in the API that mentions some 300K updates as max for the EPROM - I just looked at the Ardunio documentation and it states 100K read/write cycles till EPROM failure. If I am reading this right then maybe my problems are related to dead EPROM storage caused after months of hourly write cycles - Is this a possibility and if yes should we not look at another method of update management for the gauge - I do not want to have to trash an Arduino every few months, I am looking at the code and need more time to get a full handle on it however there appears to be write cycles every hour even if the values have not changed. Is this something to investigate? Is there a way to know if an Arduino EPROM has failed due to excessive write cycles?
                                      • I itbeyond
                                        #55
                                        @itbeyond there are 8,760 hours in a year, so 100,000 writes should last more than 10 years.
                                        MySensors does not re-write the same data if the data has not changed, so a save call does not always result in a write.
                                        The code uses a ring buffer to lessen the risk of writing too much to a single eeprom position.
                                        So eeprom writes should not be a problem. But maybe Arduino clones can't handle 100,000 writes?
                                        I guess an alternative could be to store the data in ram and send it to the controller periodically so the data can be fetched when the Arduino (re)boots. Or do the aggregation on the controller, where ram and storage is plentiful.
                                        The best way I know to detect eeprom failures is to repeatedly read and measure time for each read. On esp8266 I've seen reads that take more than 100x normal time when the eeprom was damaged.
                                        I 1 Reply Last reply
                                          I
                                          I
                                          itbeyond
                                          @mfalkvidd thanks for the important info on the saveState - I have not looked at the API code in this respect and if it does not write same data this is a very good. I have also looked into the code some more there are 4 possible writes per hour which using your maths is 35k write per year so it still should be good for a few years (clones well yes who knows). I may have another problem but I am not sure what - if I reboot it is runs fine for several hours and randomly seems to stop sending data however even if the EPROM is stuffed it should not affect the temp, hum and light level sensors. I may be seeing some funny humid reading so the DHT could be faulty also - I may replace this firstly and see what the result is. Thanks for the response.
                                          petewillP 1 Reply Last reply
