  3. help needed with multiple temp sensor data logging project
37 Posts 4 Posters 13.6k Views 5 Watching
  • wallyllamaW
    wallyllamaW
    wallyllama
    Other answers. 1 resistor per 1-wire network.
    I believe you can still get a/d converter chips, they could probably be used to read an orp or ph sensor. Water level could possibly be read with a capacative sensor, but you are going run into your power problems again.
      MasterCATZ
      Ok that's what I wanted to know as I did read here
      http://www.jon00.me.uk/onewireintro.shtml
      50mm was as long as you could go
      however, how does that work if the probe wire is long?
      would I be better off making my own probe's with 6 wires with
      In / Out ? that then links to the next part of the daisy chain ?
      wallyllamaW 1 Reply Last reply
      • M MasterCATZ
        wallyllamaW
        wallyllamaW
        wallyllama
        The ds2450 adc is out of production. The ds2438 battery monitor is ehat you'd have to use.
        This person was going to use the adc, but ill bet the batter monitor could be made to work.
        Reefcentral
        For connections, a 3 port rj11 might work, in from previous tank, out to next, and one to the tank sensor. I think if you keep the line to the tank under 1meter you are ok, but i have never built a network as long as you are proposing.
        • wallyllamaW
          wallyllamaW
          wallyllama
          Maximintegrated
          Read this, there is a formula for what they call weight, and they talk about stubs. That would be the part from the main bus wires to the sensor.
          • M MasterCATZ
            what is your recommendation for the wireless hardware
            "Serial WiFi Module ESP8266 module ESP01"
            are what I have tried in the past with poor results
            I have been thinking I could make a wireless module, disconnect the sensor from 1 wire and I could plug the probes into wifi when I need to?
            how do I go about Daisy chaining the probes
            are there any simple splice crimp connector out their?
            ( might use telephone cables or ribbon cables as I don't think I should use RJ45 just incase someone mistakes as a LAN port )
            I did come across this
            http://www.ebay.com.au/itm/DS18B20-Waterproof-Digital-Temperature-Sensor-With-Adapter-Module-for-Arduino-WS-/182526807558?hash=item2a7f720e06:g:lW4AAOSw-itXp~d7
            but to me, it just looks like its purpose is just to add the pull-down resistor?
            does every probe need the resistor or is only 1x needed?
            also any probes for PH that work using 1-wire? or water level sensor?
            zboblamontZ
            zboblamontZ
            zboblamont
            @MasterCATZ
            I have no experience of the daisy chaining of sensors but as wallyllama has explained, this is pretty much my understanding of the technique, and I'm sure I read recently about the difference between parasitic power connection and normal fairly recently in a post.
            Radio
            MySensors was originally built around the NRF24 2.4 GHz transceivers as I understand it, but there has been considerable interest and development with the RFM69 series transceivers which have better range in the 433MHz area. I suggest you look at Moteino and the Whisper Node I mentioned earlier as they are well thought out designs, radio module incorporated, low power consumption, compact, etc. and seem reliable. There are multiple alternatives folk here have utilised in the uhf bands varying from the ultra cheap chinese no-name to almost professional grade transceivers, it rather depends whether you want off the shelf units with loads of support or want to experiment with fine soldering. I didn't, as too old and shaky for that, so went Whisper Nodes, and just building them and playing with them now in advance of the Gateway arriving.
            Some things you may wish to consider are temperature transients in the tank so you can establish the ideal sense point, how often you want the data updated (hourly, every ten minutes, every four seconds) as this may need a RTC, collision management for data coming in, and whether the node needs physically protected against the environment.
              MasterCATZ
              RFM69 does look promising even if
              I have to power it
                MasterCATZ
                looks like I will have to make my own sensors that Daisy chain directly off the sensor
                https://edwardmallon.wordpress.com/2015/03/01/using-ds18b20-sensors-to-make-a-diy-thermistor-string-pt-1-the-build/
                  MasterCATZ
                  wrote on last edited by MasterCATZ
                  #23
                  so what I think I will do is
                  use a trimpot at the start so resistance can be adjusted as sensors/length are altered
                  cat5 wiring
                  Dry end has 2x rj11 ends
                  *example
                  rj11 (in) pins 1,2,3,4
                  rj11 (out) pins 5,6,7,8
                  Pin 1 (White/Green) - Power return or ground
                  Pin 2 (Green) - +5V
                  Pin 3 (White/Orange) - Power return or ground
                  Pin 4 (Blue) - DQ (data in)
                  Pin 5 (White/Blue) - 1-Wire return or ground
                  Pin 6 (Orange) - +5V
                  Pin 7 (White/Brown) Power return or ground
                  Pin 8 (Brown) - DQ (data out)
                  all wires join onto the DS18B20 and waterproofed
                  then up at the dry end use rj11 joiners, they can be pulled apart and have resistors added if needed and if I need to take a sensor out of the daisy chain, it is just a matter of bypassing a joiner
                  http://www.ebay.com.au/itm/RJ11-6P4C-Female-Modular-Telephone-Cable-Wire-Straight-Coupler-Joiner-White-/111725356245?hash=item1a0359a4d5:g:miQAAOSwWxNY2l0I
                  or I just do the STUBS thing 100-150Ω resistor inside a 3 way splitter and have a normal premade waterproofed sensor used with rj11 connector
                  http://www.ebay.com.au/itm/10pcs-RJ-11-RJ-14-Phone-Line-Cable-Coupler-3-Way-Splitter-Connector-Adapter-/290986642163?hash=item43c027caf3:g:LD4AAOxySy9SRSLm
                  either should work in the fish room tanks are on racks stacked to each other
                  so how would I go about doing a 1-wire breakout, as each rack would be pushing the length and I have 14x racks ~3m long 4 tiers
                  I might be possible to do the daisy chain per 2 racks
                  is their a way to do it without using multiple Arduino , is there some hardware that would allow multiple runs of 1-wire ?
                    MasterCATZ
                    another thing does anyone know if putting capacitors in the daisy chain will cause any issues?
                    I figured haveing a capacitor near a sensor would help keep the power stable?
                    • wallyllamaW
                      wallyllamaW
                      wallyllama
                      There are 1wire "hubs" that would help, they basically turn on or off parts of the network, so each run could be the max distance.
                      Each network would need only 1 digital pin and resistor, i think you could define multiple pins and do a onewire.begin for each (using different names each of course) i think you would run out of memory or clock cycles before you ran out of pins even with a pro mini.
                      Using a dedicated 5v line is probably better than a capacitor and parasitic power, especially with long runs and lots of sensors. Unless you can live with really slow polling times. With the complexity you are talking about, I wouldn't be surprised if takes a couple of minutes to poll everything reliably with parasitic power. If it works (i havent tried it) using several pins on the arduino, each controlling a 1wire network might help out considerably. You could service 1 network, while the others are being "charged".
                      • wallyllamaW
                        wallyllamaW
                        wallyllama
                        If you search "1-wire hub", there are premade options, and diy.
                          MasterCATZ
                          #27
                          thanks for your guidance
                          parts arrived yesterday and just got the probes reading
                          how ever I could not get OWFS to work,
                          https://www.domoticz.com/wiki/1Wire
                          sudo i2cdetect -y 1
                          0 1 2 3 4 5 6 7 8 9 a b c d e f
                          00: -- -- -- -- -- -- -- -- -- -- -- -- --
                          10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
                          20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
                          30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
                          40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
                          50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
                          60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
                          70: -- -- -- -- -- -- -- --
                          but using /sys/bus/w1/devices
                          they are there
                          cat w1_slave
                          a2 01 4b 46 7f ff 0c 10 49 : crc=49 YES
                          a2 01 4b 46 7f ff 0c 10 49 t=26125
                          edit
                          actually quite happy, using 5v and daisy chained a heap of cat5 cables together for testing, over 100m all working good
                          • M MasterCATZ
                            sudo i2cdetect -y 1
                            they are there
                            cat w1_slave
                            edit
                            wallyllamaW
                            wallyllamaW
                            wallyllama
                            @MasterCATZ :smiley_cat:
                            • M MasterCATZ
                              zboblamontZ
                              zboblamontZ
                              zboblamont
                              @MasterCATZ I'm following this with interest as looking at a WAY smaller scale use with the small 3 legged 18B20 to give individual room temperatures in the house, 4 upstairs, 6 downstairs.
                              Had originally considered individual room nodes, but this seems a slightly simpler solution (other than lifting parts of the upstairs floor).
                              • zboblamontZ zboblamont
                                MasterCATZ
                                #30
                                @zboblamont I will be able to test the lengths today, making another 20x temperature sockets and I have a heap of 20m cat5 cables to chain from
                                I am using a trim pot to adjust at the breadboard, so far still 4.7
                                if I was going to do it again would use a 5 or 10k high precision the 5% pot too dodgy
                                still yet to use resistors on each drop and I have a 10v 1000uf capacitor on each ground / vcc, no idea if it helps or not
                                you could also run a 100mbs LAN plus temp probes each using 4x of the 8 cat5 pins
                                http://www.108relays.ca/dl/1_Wire_Design_Guide_v1.0.pdf
                                edit
                                it looks like you have to keep the lengths and probe numbers equal if your splitting them off like a tree
                                if I had 1 side 6m longer with more probes than the other side a probe read 0 deg
                                added more probes on the other side and they read fine again
                                ( touch wood )
                                I have placed a probe at the end with no capacitor, can not get it to connect
                                when I make more probes tomorrow will try that spot again with a capacitor
                                for now will try the one with out capacitor at the first split near the pi to see what happens, it's pitch black now time for bed :P
                                strange thing just tried another stock probe with no capacitor and can not get that to work either and I was running these ones inside all day
                                for some reason voltmeter reads neg millivolts
                                now I just want to build another cap probe to see whats going on
                                edit , either I wired something backwards or maybe i just hit the limits adjusting trim pot now as even the DS18B20 on the bread board stopped responding
                                edit, somethings not right pulled the main link and its receiving 0 deg from sensors not even plugged in.
                                new probe and bread board temps working tho
                                set @ 4k , tried adding another probe at 1st split all died again,
                                I'd say at my limits without the 100~150 resistors trying to push 6x 20m cables
                                voltage still 4+
                                but I am sus as to why a probe felt warm where a cap was done, unsure if it was still from the soldering heat or not so I might have something miss wired as I was running as the day light was dropping fast
                                ( this setup is for monitoring tanks in my polytunnels no lights apart from the flash light in my mouth )
                                the goal was 3 x 20m on each side split at the breadboard with ~5m long branches running of each join with 2x probes about every 1 m with 1m long lengths approx 60x DS18B20 and about 210m of cable
                                unfortunately, I was 1 section short the 5th section would not work
                                so 50 probes 175m cable
                                I'll try again in a daisy chain formation later on
                                currently using raspberry pi 2 B and domoticz
                                I ended up doing rj45 as they worked out cheaper than the rj11/14
                                I paid $20 for 100 , also why I did not add the capacitor inside like I was going to so they could be used in other areas for LAN, hopefully, no one tries to plug a laptop into them
                                http://www.ebay.com.au/itm/CS-5X-US-10x-Practical-3-Way-RJ45-LAN-Network-Ethernet-Splitter-Connector-Beige/201963874318
                                  MasterCATZ
                                  might be best to NOT buy the ones I got , just discovered 1x port of just about all of them was not working correctly
                                  ( pins on slight angle off setting alignment )
                                  causing the probes to be in parasitic mode
                                  • M MasterCATZ
                                    zboblamontZ
                                    zboblamontZ
                                    zboblamont
                                    @MasterCATZ I should not have the same issues as the scale in my case is small, but will set up a test with the devices individually just in case before installing. This is the type on it's way (not from this supplier), I can only hope they are genuine components. link text
                                    I will also have to read the guide again as the devices placement and harmonics were a bit of a puzzle, and on one hand they recommended Cat5e yet went on to say twisted pair was better.
                                      MasterCATZ
                                      #33
                                      anyone know the correct way I should be using an external power source
                                      I powered them up directly with + - still running to the pi and blew the external 2a 5v power pack ( it also powered up the pi and I believe back-feeding this way removes surge protection )
                                      then I tried with the GND and DQ connected with the pi doing the pull up , external PSU ( 30A rated 5v rail 450w 3.3v 12v 5v ) looked like it was shorting out dropping .2v per probe and changing sound as tho it was under load how ever I am currently using its 3A port
                                      I then tried with just the DQ connected not much luck
                                      then I moved the bread board over the PSU and had the 4.7k pull up on its end and DQ / GND connected to the pi , I seem to have some connections, but getting a lot of unknown vendor type errors
                                      but PSU does not seem to be under load
                                      http://datasheets.maximintegrated.com/en/ds/DS2482-100.pdf
                                      I might get one of these I2C one wire bridge that can adjust the strength of the pull-up dynamically as the network grows
                                      http://videos.cctvcamerapros.com/voltage-drop-calculator
                                      has got me thinking I might double up on the strands 24 gauge has too much voltage drop @ 5v
                                      should I just treat each pair as a wire or should I have ground on each twist ?
                                      ie
                                      ( p1,p2 GND) Green pair
                                      ( p3,p4 VCC ) Blue pair
                                      (p5.p6 DQ ) Orange pair
                                      ( p6,p7 GND ) Brown pair
                                      or
                                      (p1 ground p2 VCC ) Green pair
                                      (p3,ground p4 VCC ) Blue pair
                                      (p5,ground,p6 DQ ) Orange pair
                                      (p7,ground,p8 DQ ) Brown pair
                                      or any other combo, I would rather use a 2amp PSU than a 30 amp .. but thats so far the only way to keep these things powered up in a daisy chain
                                      https://forum.allaboutcircuits.com/threads/24-gauge-wire-if-you-double-up-strands-what-equivalence-gauge.108649/
                                      • wallyllamaW
                                        wallyllamaW
                                        wallyllama
                                        It looks like the standard for power over ethernet uses a twisted pair as a "single wire". So blue/blue-white is + and brown/brown-white is -
                                        Seems like a reasonable way to do it, even though you arent wiring ethernet.
                                        • M MasterCATZ
                                          ie
                                          or
                                          zboblamontZ
                                          zboblamontZ
                                          zboblamont
                                          @MasterCATZ Perhaps you are expecting too much of the network you wish to monitor, which to be fair is not small. Splitting the network into smaller more controllable and manageable segments may be counter intuitive, but can be efficient even if you derive a solution beyond your own pre-determinations.
                                          12.5k
