  3. 💬 nRF52 Development Board
nrf52 arduino
13 Posts 7 Posters 4.7k Views 7 Watching
    @onehorse
    How did you solder it? I know that using solder stencils and reflow oven are a popular approach, but how did you even accurately align and place the parts before soldering it? That's the part that frustrates me when the pin pitch and even the parts themselves are so tiny. I feel as though I would need some kind of jig or something to asist me to really dial it in.
    gohanG mtiutiuM 2 Replies Last reply
    • YveauxY
      @onehorse Please add all development files for this board to the project, as that's the whole idea about open hardware!
        @onehorse
        @NeverDie in theory the surface tension of molten tin should pull the pieces into place, that's what I have seen even if I never done it myself 😅
          @onehorse
          mtiutiuM
          mtiutiuM
          mtiutiu
          I've done this kind of soldering myself and it works with no problems thanks to the laws of physics which @gohan already explained. You just need a little bit more patience when first aligning the component but it doesn't need to be perfectly aligned - the surface tension of the liquid solder will take care of it - just not use too much solder or solder paste though.
          • mtiutiuM mtiutiu
            @mtiutiu said in 💬 nRF52 Development Board:
            Well, just how close to perfect does it need to be? No one seems to talk about that.
            Nca78N mtiutiuM 2 Replies Last reply
              @NeverDie said in 💬 nRF52 Development Board:
              I've seen it a few times, can be impressive like this one:
              https://www.youtube.com/watch?v=_5lksMvmqQc
                mtiutiuM
                mtiutiuM
                mtiutiu
                I did it like this guy here: qfn soldering and it worked like a charm. Just be careful not to put too much solder on the pads. But if you use stencils and solder paste it should be much more easier.
                I don't have a oven and I don't use stencils.
                Nca78N NeverDieN 2 Replies Last reply
                • mtiutiuM mtiutiu
                  @mtiutiu wow thank you for the link I didn't know it was possible like that :o
                  I'll sure test it as soon as possible, I'm restraining from ordering QFN at the moment, for fear of not beeing able to solder them. But this could change the deal.
                  • mtiutiuM mtiutiu
                    @mtiutiu
                    Which flux do you like to use best? The guy in the video says he used Multicore X32-10I
                    I unexpectedly got five free "bonus" nRF52832 chips with my nRF52832 DK, so I might as well give it a try. If the OP would post his gerber files, I could try it on his board. Otherwise, I might try it on sparkfun's board.
                    Do you get better results from pre-heating the board from underneath with a re-work heater? I don't yet have one of those, but maybe now is the time to get one....
                    mtiutiuM 1 Reply Last reply
                      @mtiutiu
                      mtiutiuM
                      mtiutiuM
                      mtiutiu
                      I used flux paste like this one:
                      http://s.aliexpress.com/f67bIZb2
                      And I didn't used preheating because I don't have such a tool. I did just like that guy explained in that video. That's how I soldered the mega328p qfn32 package on my serial gw from here: https://www.openhardware.io/view/316/MySensors-RFM69W-serial-GWATMEGA328P
                      It's not hard trust me.. just a little bit of patience and after that by practicing a little bit you'll gain experience and see that's just a piece of cake.
                        @onehorse
                        Thanks for posting your gerber files. Do you have a BOM as well?
