  2. Announcements
  3. 💬 Distance Sensor
💬 Distance Sensor
92 Posts 18 Posters 51.2k Views 18 Watching
  • Boots33B Boots33
    @zboblamont It will be good to see the final results of both yours and @jjk
    zboblamontZ
    zboblamontZ
    zboblamont
    @Boots33 Well, finally I got some positive results, but not quite as expected...
    The JSN-SR04T-2.0 nor the DYP-ME007Y I could get to work on all six variations of sketches tried. Still not sure why neither would work using this 3v3 board even with 5v to the ultrasonic board and dropper resistors on the echo. Allegedly the ping from 3.3v should work.
    So, bought and finished today trialling a 5v/16MHz Pro-Mini ;
    The JSN version 2.0 nor the DYP would not respond to NewPing, simply churning out zeroes.
    Other sketches would turn out fixed numbers and zeroes which did not alter irrespective of the transducer/object distance.
    The JSN finally got working with a simple PulseIn calculation loop with a 500 delay. First reading was always Zero, all the rest consistent and rock solid.
    The DYP unexpectedly responded only to the SoftwareSerial method originally found to work from a Russian site. The readings are spot on from the start.
    Now that they work, I need to figure out if there is a workaround for the 3.3v transceiver node....
    Phew....
    Boots33B 1 Reply Last reply
    • zboblamontZ zboblamont
      Phew....
      Boots33B
      Boots33B
      Boots33
      @zboblamont it certainly has been a bumpy road for you. good to see you making some headway.
      • ben999B
        ben999B
        ben999
        wrote on last edited by ben999
        #52
        I've been fighting with DYP-ME007Y myself for the last few days...
        Originally i wanted to monitor the level of a water tank with an SR04 ; as it is not waterproof i assumed that it would die fairly quickly.
        So i ordered a DYP-ME007... but the last letter ("Y") means that it uses serial communication, so the ping Library doesn't apply.
        Bouncing from site to site i found the following code that @zboblamont refers to :
        #include <SoftwareSerial.h>
        SoftwareSerial mySerial =  SoftwareSerial(10,11);
        #define echoPin 10
        #define trigPin 11
        unsigned int reading;
        byte readByte;
        byte read_buffer[4];
        byte crcCalc;
        word distance;
        String outText;
          mySerial.begin (9600);
          Serial.println("start");
          for (byte loopstep = 0; loopstep <= 3; loopstep++) {
            read_buffer[loopstep] = 0;
          if (mySerial.available() < 1) {
            return;
          readByte = mySerial.read();
          for (byte loopstep = 0; loopstep <= 2; loopstep++) {
            read_buffer[loopstep] = read_buffer[loopstep + 01];
          read_buffer[03] = readByte;
          if (read_buffer[00] != 0xff) {
            return;
          crcCalc = read_buffer[00] + read_buffer[01] + read_buffer[02];
          if (read_buffer[03] != crcCalc) {
            return;
          distance = (read_buffer[01] * 0xff) + read_buffer[02];
          outText = "bytes: ";
          outText = String(outText + read_buffer[00]);
          outText = String(outText + "+");
          outText = String(outText + read_buffer[01]);
          outText = String(outText + read_buffer[02]);
          outText = String(outText + read_buffer[03]);
          outText = String(outText + " = ");
          outText = String(outText + distance);
          outText = String(outText + " mm");
          Serial.println(outText);
          delay(1000);
          while (mySerial.available() > 0) {
        Worked first shot
        • ben999B ben999
          #define echoPin 10
          #define trigPin 11
          byte readByte;
          byte crcCalc;
          word distance;
          String outText;
              return;
              return;
              return;
            delay(1000);
          Worked first shot
          zboblamontZ
          zboblamontZ
          zboblamont
          @ben999 So glad it worked, I tormented myself as a newbie in Arduinoworld. I didn't realise that the 'Y' was significant though, I recall others saying it fitted NewPing like a glove...
          I don't think it helps when there are so many conflicting model numbers for completely (physically) different devices...
          Hey ho....
          • jjkJ
            jjkJ
            jjk
            hi folks, received my DYP-ME007Y finally, tried it and got the same inconsistent readings with the old sketch that @zboblamont and others reported. I was excited to see the code that @ben999 found and tested successfully - but I don't even get past the "start" print out in the serial monitor. the LED on the DYP board is flashing eagerly, but it doesn't look like it gets any readings... Have you guys changed anything else to get it t work?
            • jjkJ
              jjkJ
              jjk
              update: we're getting there... after a bit a tweaking and trying different angles, I'm now getting readings. The good news: in one position, when readings come in, they are consistent. The bad news: as soon as I move the sensor head, it's a gamble, in some cases the readings are o.k., in other cases it drops to 0mm... Anybody has seen a similar effect?
              ben999B zboblamontZ 2 Replies Last reply
              • jjkJ jjk
                ben999B
                ben999B
                ben999
                @jjk sensor head need to be perpendicular to surface being measured?
                • jjkJ jjk
                  zboblamontZ
                  zboblamontZ
                  zboblamont
                  @jjk If the readings you ARE getting are accurate when moved to new positions, it could as @ben999 said be inaccurate alignment to the reflective surface, or as was commented somewhere else, the plug/socket on the board being loose.
                  With a 3/4 to 1/2 reducer on a 1/2 pipe ready here for final installation, I sat transducer the socket to take out movement or alignment issues, it drifts off quite readily if angle is wrong. The code Ben refers to for this DYP gave me a slightly lower but not silly first reading then consistent results thereafter, no zeroes.
                  Please note that I had tried all 6 sketch variants on the 3.3v device with a 5v DYP supply and got nonsense. Using the 3.3v Trig with drop resistors on the Echo neither the JSN nor the DYP worked properly despite the 5v power from the separate booster supply to them.
                  I only found consistency using a 5v pro-mini, with the DYP power supplied from logic pins, which leads me to think Trig and/or Echo are also 5v sensitive, contradicting previous advice and complicating my layout.
                  Have not yet got round to trialling a logic converter from the 3.3v pro-mini for Trig and Echo with the original 5v supply, which is the next step, will report back once I get some time to test.
                  • jjkJ
                    jjkJ
                    jjk
                    @ben999 and @zboblamont thanks for the swift feedback and advice. I think you are right, the DYP seems to be VERY sensitive to alignment. The tests I did were "handheld" and readings jumped arbitrarily btw zeroes, accurate, and off values. I've done a few tests now with the sensor head fixed and more aligned to the target surface and that seems to work out much better now. I also found that readings get less accurate above 1m, though?!
                    • jjkJ
                      jjkJ
                      jjk
                      btw. I'm using a pro mini 5V to power and trigger the DYP at the moment. Have played with an external 5V supply, but that didn't seem to make a noticeable difference.
                      • jjkJ jjk
                        zboblamontZ
                        zboblamontZ
                        zboblamont
                        @jjk Sounds like you're getting there, it should be no problem with the 5v pro-mini, the only variables should be alignment and sketches.
                        To clarify, I only got a 5v pro-mini to figure out whether the DYP and JSN devices would work, which they did after trying different sketches. Those same sketches had retrieved garbage on the 3.3v pro-mini, despite a separate 5v supply to the DYP, running contrary to experience of others. That supply was unnecessary with the 5v pro-mini.
                        As the 3.3v is the intended battery powered radio node, I need the DYP to work with it, hence the logic level converter being the next attempt to get the DYP to work with the node.
                        • ben999B
                          ben999B
                          ben999
                          #61
                          DYP measuring range starts at 30cm -ish
                          When water tank is full-up, water level is near the top of the cistern...
                          So to achieve the minimum reading distance I used a big PVC pipe placed vertically on top of cistern (about 30cm) through a hole...
                          I went from 5cm to 8cm but no luck : I guess there must be some "echo" in the pipe that fools the reading...
                          I will end-up with a plastic bucket (dia 30cm height 30cm) on top of cistern opening (not tested yet)
                          Final word : be aware of confined spaces, that sensor is kind of claustrophobic ;)
                          • ben999B
                            ben999B
                            ben999
                            #62
                            I don't quite like the idea of the DYP board being powered full-time...
                            It "ticks" every one second and i only need a few updates of water level per day.
                            I would like to power it via a transistor (itself being triggered by arduino)
                            What would be your thoughts on that ?
                            • powering that board say 4 times a day for 10 seconds would be more deadly than being powered on all the time ?
                            • looks like the serial "conversation" kicks-in as soon as power is applied to the board... could it damage either board if serial link is cut anytime ?
                            • DYP board uses on average less than 15mA. What transistor would be a good contender for that job ?
                            Thanks again for reading and thanks even more for your input :)
                            zboblamontZ 3 Replies Last reply
                            • ben999B ben999
                              zboblamontZ
                              zboblamontZ
                              zboblamont
                              @ben999 Surprised if you are getting echoes in a pipe, there are no surfaces to reflect the signal. Both the tanks I am looking to monitor are quite big, I might have to use a pipe in the water tank as it is a plastic moulding which has vertical facing flats on the ribs. Will report back once tested in place.
                              I looked at transistor switching the device due to RTC and radio occupying all but 4 analogue lines on the node, but there were reportedly some issues with switching ground, so I settled on the latching dpdt relay I posted further up the thread. It needs two pins to open or close by changing outputs from high to low. It opened or closed in less than 30ms, about 33mA from memory, zero consumption once latched.
                              In my own case the node is 3.3v, the 5v boosted line for the DYP power was originally controlled by the relay.
                              Having established now that the DYP requires a 5v trig/echo, the relay is being reworked so one contact switches the 3.3v the other the 5v to power both the DYP and the level switcher, hopefully resolving earlier failures.
                              • N
                                N
                                Newzwaver
                                Hi Everyone,
                                Just trying to get everything set back up correctly and I def have something wrong, my distance sensors show Zero.
                                3 TSM:INIT
                                4 TSF:WUR:MS=0
                                11 TSM:INIT:TSP OK
                                13 TSF:SID:OK,ID=254
                                15 TSM:FPAR
                                51 TSF:MSG:SEND,254-254-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                2059 !TSM:FPAR:NO REPLY
                                2061 TSM:FPAR
                                2097 TSF:MSG:SEND,254-254-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                2615 TSF:MSG:READ,0-0-254,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                                2620 TSF:MSG:FPAR OK,ID=0,D=1
                                4105 TSM:FPAR:OK
                                4106 TSM:ID
                                4107 TSM:ID:OK
                                4109 TSM:UPL
                                4118 TSF:MSG:SEND,254-254-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                                4128 TSF:MSG:READ,0-0-254,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                                4133 TSF:MSG:PONG RECV,HP=1
                                4136 TSM:UPL:OK
                                4137 TSM:READY:ID=254,PAR=0,DIS=1
                                4150 TSF:MSG:SEND,254-254-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                                4157 TSF:MSG:READ,0-0-254,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                4166 TSF:MSG:SEND,254-254-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.1.1
                                4177 TSF:MSG:SEND,254-254-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                                4211 TSF:MSG:READ,0-0-254,s=255,c=3,t=6,pt=0,l=1,sg=0:M
                                4234 TSF:MSG:SEND,254-254-0-0,s=255,c=3,t=11,pt=0,l=15,sg=0,ft=0,st=OK:Distance Sensor
                                4246 TSF:MSG:SEND,254-254-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.0
                                4265 TSF:MSG:SEND,254-254-0-0,s=1,c=0,t=15,pt=0,l=0,sg=0,ft=0,st=OK:
                                4272 MCO:REG:REQ
                                4282 TSF:MSG:SEND,254-254-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                                4289 TSF:MSG:READ,0-0-254,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                                4294 MCO:PIM:NODE REG=1
                                4296 MCO:BGN:STP
                                4298 MCO:BGN:INIT OK,TSP=1
                                Ping: 0 cm
                                4336 MCO:SLP:MS=5000,SMS=0,I1=255,M1=255,I2=255,M2=255
                                4341 MCO:SLP:TPD
                                4343 MCO:SLP:WUP=-1
                                Ping: 0 cm
                                4380 MCO:SLP:MS=5000,SMS=0,I1=255,M1=255,I2=255,M2=255
                                4386 MCO:SLP:TPD
                                4387 MCO:SLP:WUP=-1
                                Ping: 0 cm
                                4425 MCO:SLP:MS=5000,SMS=0,I1=255,M1=255,I2=255,M2=255
                                4430 MCO:SLP:TPD
                                Any idea why? Pins are set correctly 5 and 6.
                                ben999B 1 Reply Last reply
                                • N Newzwaver
                                  Hi Everyone,
                                  3 TSM:INIT
                                  4 TSF:WUR:MS=0
                                  11 TSM:INIT:TSP OK
                                  15 TSM:FPAR
                                  2061 TSM:FPAR
                                  4105 TSM:FPAR:OK
                                  4106 TSM:ID
                                  4107 TSM:ID:OK
                                  4109 TSM:UPL
                                  4136 TSM:UPL:OK
                                  4272 MCO:REG:REQ
                                  4296 MCO:BGN:STP
                                  Ping: 0 cm
                                  4341 MCO:SLP:TPD
                                  4343 MCO:SLP:WUP=-1
                                  Ping: 0 cm
                                  4386 MCO:SLP:TPD
                                  4387 MCO:SLP:WUP=-1
                                  Ping: 0 cm
                                  4430 MCO:SLP:TPD
                                  ben999B
                                  ben999B
                                  ben999
                                  @Newzwaver which sensor are you using? And which library?
                                  • N
                                    N
                                    Newzwaver
                                    Thanks for the reply, I am using the HC SR04
                                    • ben999B ben999
                                      zboblamontZ
                                      zboblamontZ
                                      zboblamont
                                      @ben999 Finally good news at least on getting the DYP-SR04T-2.0 to behave with the 3.3v Pro Mini, currently arrangement like wire spaghetti. How it all fits in the weatherproof box is another day's work, as is coding it up to send hourly data back to the Gateway.
                                      Earlier trials using the 5v Mini worked perfectly, so ended up with latching relay and booster on separate battery pack, unfortunately I did not realise the complications of using a single coil latching relay on the Arduino.
                                      Needed to get some work done on the house, so delayed getting back to until last week.
                                      So the working hardware is now 10k resistor to DIODES DMG6968U-7 switching a NEC EE2-3TNU double coil relay, a level converter for trig/echo, and a 5v booster to power the ultrasonic. Works fine now even though the first reading is still always a Zero.
                                      Relay switch on and switch off is less than 10ms- Arduino and low current..
                                      • ben999B ben999
                                        zboblamontZ
                                        zboblamontZ
                                        zboblamont
                                        @ben999 As a postscript to the above, I puzzled over how quickly I could get a valid result before being able to power down the secondary circuit of relay, booster, level converter etc...
                                        I looked at the results coming in (in this case from the JSN sensor) and read up on median analysis and gave up pretty quickly on that level of sophistication, as I realised only the first result was incorrect, that puzzling zero, all the rest were consistent and repetitive.
                                        Inserting a while statement in the Void Setup (instead of the forever version in the Void Loop) checking the time duration < 1, I got a valid result immediately after the first ping, and the secondary circuit could be shut down.
                                        As I only need one valid result to switch the relay off and radio the reading in once and hour, this seems to satisfy my requirements while limiting power drain on the secondary circuit.
                                        • P
                                          P
                                          peerv
                                          I had to add some lines to the sample sketch to get console printouts:
                                          and in the void setup():
                                          Is everybody so specialized that they see immediately this omission? :-)
