  3. Combine airquality, temperature code and send to the ethernet gateway
9 Posts 3 Posters 2.5k Views 3 Watching
  • T
    Tommas
    wrote on last edited by Tommas
    Dear All!
    My project: Node + EthernetGW + openhab2
    I try to combine the two example sketch codes (I would like to trigger the MQ2 sensor for smoke) , but it seems that the node sends the MQ2 sensors values, but
    -the gateway dont read that, and
    -i think that the node send the data more frequently than it should do.
    GW
    0;255;3;0;9;TSF:MSG:FPAR REQ,ID=1
    0;255;3;0;9;TSF:PNG:SEND,TO=0
    0;255;3;0;9;TSF:CKU:OK
    0;255;3;0;9;TSF:MSG:GWL OK
    0;255;3;0;9;TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
    0;255;3;0;9;TSF:MSG:READ,1-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
    0;255;3;0;9;TSF:MSG:PINGED,ID=1,HP=1
    0;255;3;0;9;TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
    0;255;3;0;9;TSF:MSG:READ,1-1-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
    0;255;3;0;9;TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
    0;255;3;0;9;TSF:MSG:READ,1-1-0,s=255,c=0,t=17,pt=0,l=5,sg=0:2.1.1
    0;255;3;0;9;TSF:MSG:READ,1-1-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
    0;255;3;0;9;TSF:MSG:READ,1-1-0,s=255,c=3,t=11,pt=0,l=22,sg=0:TemperatureAndHumidity
    0;255;3;0;9;TSF:MSG:READ,1-1-0,s=255,c=3,t=12,pt=0,l=3,sg=0:1.1
    0;255;3;0;9;TSF:MSG:READ,1-1-0,s=255,c=3,t=11,pt=0,l=18,sg=0:Air Quality Sensor
    0;255;3;0;9;TSF:MSG:READ,1-1-0,s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
    0;255;3;0;9;TSF:MSG:READ,1-1-0,s=0,c=0,t=7,pt=0,l=0,sg=0:
    0;255;3;0;9;TSF:MSG:READ,1-1-0,s=1,c=0,t=6,pt=0,l=0,sg=0:
    0;255;3;0;9;TSF:MSG:READ,1-1-0,s=2,c=0,t=22,pt=0,l=0,sg=0:
    0;255;3;0;9;TSF:MSG:READ,1-1-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
    0;255;3;0;9;TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
    0;255;3;0;9;TSF:MSG:READ,1-1-0,s=1,c=1,t=0,pt=7,l=5,sg=0:26.0
    0;255;3;0;9;TSF:MSG:READ,1-1-0,s=0,c=1,t=1,pt=7,l=5,sg=0:46.0
    0;255;3;0;9;TSF:MSG:READ,1-1-0,s=0,c=1,t=1,pt=7,l=5,sg=0:45.0
    NODE
    3 TSM:INIT
    4 TSF:WUR:MS=0
    11 TSM:INIT:TSP OK
    13 TSM:INIT:STATID=1
    15 TSF:SID:OK,ID=1
    16 TSM:FPAR
    53 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    875 TSF:MSG:READ,0-0-1,s=255,c=3,t=8,pt=1,l=1,sg=0:0
    880 TSF:MSG:FPAR OK,ID=0,D=1
    2060 TSM:FPAR:OK
    2061 TSM:ID
    2062 TSM:ID:OK
    2064 TSM:UPL
    2067 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
    2076 TSF:MSG:READ,0-0-1,s=255,c=3,t=25,pt=1,l=1,sg=0:1
    2081 TSF:MSG:PONG RECV,HP=1
    2084 TSM:UPL:OK
    2085 TSM:READY:ID=1,PAR=0,DIS=1
    2091 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
    2098 TSF:MSG:READ,0-0-1,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
    2105 TSF:MSG:SEND,1-1-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.1.1
    2113 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
    4121 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=11,pt=0,l=22,sg=0,ft=0,st=OK:TemperatureAndHumidity
    4131 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.1
    4141 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=11,pt=0,l=18,sg=0,ft=0,st=OK:Air Quality Sensor
    4150 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.0
    4158 TSF:MSG:SEND,1-1-0-0,s=0,c=0,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    4166 TSF:MSG:SEND,1-1-0-0,s=1,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=OK:
    4173 TSF:MSG:SEND,1-1-0-0,s=2,c=0,t=22,pt=0,l=0,sg=0,ft=0,st=OK:
    4179 MCO:REG:REQ
    4183 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
    4190 TSF:MSG:READ,0-0-1,s=255,c=3,t=27,pt=1,l=1,sg=0:1
    4195 MCO:PIM:NODE REG=1
    4197 MCO:BGN:STP
    4199 MCO:SLP:MS=1000,SMS=0,I1=255,M1=255,I2=255,M2=255
    4204 MCO:SLP:TPD
    4206 MCO:SLP:WUP=-1
    4208 MCO:BGN:INIT OK,TSP=1
    4235 TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:26.0
    T: 26.00
    4243 TSF:MSG:SEND,1-1-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:46.0
    H: 46.00
    LPG:0ppm    CO:0ppm    SMOKE:0ppm
    5257 MCO:SLP:MS=5000,SMS=0,I1=255,M1=255,I2=255,M2=255
    5262 MCO:SLP:TPD
    5263 MCO:SLP:WUP=-1
    6294 MCO:SLP:MS=5000,SMS=0,I1=255,M1=255,I2=255,M2=255
    6299 MCO:SLP:TPD```
    **Combined Node Sketch**
    Im attach the sketch of the node.0_1500791513747_DHT_MQ2_uj.ino
    Another question will be, that is this code OK for openhab:
    The temp and humidity works as expect, everything is OK. but the new manually entered code seems isnot recognized , but the openhab automatic search find the new child sensor but the values are zero.
    ~# cat /etc/openhab2/things/demo.things
    Bridge mysensors:bridge-eth:gateway [ ipAddress="100.100.6.41", tcpPort=5003, sendDelay=200, startupCheckEnabled=false,networkSanCheckEnabled=false ] {
            humidity                hum01   [ nodeId=1, childId=0 ]
            temperature             temp01  [ nodeId=1, childId=1 ]
            AirQuality              airq01  [ nodeId=1, childId=2 ]
    cat /etc/openhab2/items/demo.items
    Number hum01      "Humidity" { channel="mysensors:humidity:gateway:hum01:hum" }
    Number temp01     "Temperature" { channel="mysensors:temperature:gateway:temp01:temp" }
    Number airq01     "AirQuality" { channel="mysensors:airQuality:gateway:airq01:level" }
    cat /etc/openhab2/sitemaps/demo.sitemap
      sitemap demo label="Main Menu" {
            Frame {
                    Text item=hum01
                    Text item=temp01
                    Text item=airq01
    Thank you your help!
    Best regards,
      Can you post the code of the node? Otherwise it's difficult to give an answer for the first question. I can't help for Openhab.
        Tommas
        @gohan
        Hi Gohan!
        Thank you again for your help:)
        I have uploaded already but i see that the link dont work.
        I added comments to the MQ2 sections
        Code
         * Version 1.0: Henrik EKblad
         * sensor using a DHT11/DHT-22.
        #define MY_NODE_ID 1
        // Enable debug prints
        //#define MY_RS485
        /* TemperatureAndHumidity */
        #define DHT_DATA_PIN 3
        #define SENSOR_TEMP_OFFSET 0
        static const uint64_t UPDATE_INTERVAL = 5000;
        #define CHILD_ID_HUM 0
        #define CHILD_ID_TEMP 1
        float lastTemp;
        float lastHum;
        uint8_t nNoUpdatesTemp;
        uint8_t nNoUpdatesHum;
        bool metric = true;
        /*---------------------------------MQ2---------------------------------------------------------*/
        #define   CHILD_ID_MQ                   2
        /************************Hardware Related Macros************************************/
        #define   MQ_SENSOR_ANALOG_PIN         (0)  //define which analog input channel you are going to use
        #define         RL_VALUE                     (5)     //define the load resistance on the board, in kilo ohms
        #define         RO_CLEAN_AIR_FACTOR          (9.83)  //RO_CLEAR_AIR_FACTOR=(Sensor resistance in clean air)/RO,
        //which is derived from the chart in datasheet
        /***********************Software Related Macros************************************/
        #define         CALIBARAION_SAMPLE_TIMES     (50)    //define how many samples you are going to take in the calibration phase
        #define         CALIBRATION_SAMPLE_INTERVAL  (500)   //define the time interal(in milisecond) between each samples in the
        //cablibration phase
        #define         READ_SAMPLE_INTERVAL         (50)    //define how many samples you are going to take in normal operation
        #define         READ_SAMPLE_TIMES            (5)     //define the time interal(in milisecond) between each samples in
        //normal operation
        /**********************Application Related Macros**********************************/
        #define         GAS_LPG                      (0)
        #define         GAS_CO                       (1)
        #define         GAS_SMOKE                    (2)
        /*****************************Globals***********************************************/
        //VARIABLES
        float Ro = 10000.0;    // this has to be tuned 10K Ohm
        int val = 0;           // variable to store the value coming from the sensor
        float valMQ =0.0;
        float lastMQ =0.0;
        float           LPGCurve[3]  =  {2.3,0.21,-0.47};   //two points are taken from the curve.
        //with these two points, a line is formed which is "approximately equivalent"
        //to the original curve.
        //data format:{ x, y, slope}; point1: (lg200, 0.21), point2: (lg10000, -0.59)
        float           COCurve[3]  =  {2.3,0.72,-0.34};    //two points are taken from the curve.
        //data format:{ x, y, slope}; point1: (lg200, 0.72), point2: (lg10000,  0.15)
        float           SmokeCurve[3] = {2.3,0.53,-0.44};   //two points are taken from the curve.
        //data format:{ x, y, slope}; point1: (lg200, 0.53), point2:(lg10000,-0.22)
        /*--------------------MQ2 end---------------------------------*/
        DHT dht;
        MyMessage msg(CHILD_ID_MQ, V_LEVEL);
          sendSketchInfo("TemperatureAndHumidity", "1.1");
          sendSketchInfo("Air Quality Sensor", "1.0"); /*MQ2*/
          present(CHILD_ID_HUM, S_HUM);
          present(CHILD_ID_MQ, S_AIR_QUALITY); /*MQ2*/
        /*---MQ2---------------------------------------------------------*/
          Ro = MQCalibration(
                   MQ_SENSOR_ANALOG_PIN);         //Calibrating the sensor. Please make sure the sensor is in clean air
          dht.readSensor(true);
          if (isnan(temperature)) {
            lastTemp = temperature;
            if (!metric) {
            // Reset no updates counter
            nNoUpdatesTemp = 0;
            #ifdef MY_DEBUG
            Serial.print("T: ");
            nNoUpdatesTemp++;
          if (isnan(humidity)) {
            lastHum = humidity;
            nNoUpdatesHum = 0;
            #ifdef MY_DEBUG
            Serial.print("H: ");
            Serial.println(humidity);
            nNoUpdatesHum++;
        /*----MQ2----*/
        uint16_t valMQ = MQGetGasPercentage(MQRead(MQ_SENSOR_ANALOG_PIN)/Ro,GAS_CO);
          Serial.println(val);
          Serial.print("LPG:");
          Serial.print(MQGetGasPercentage(MQRead(MQ_SENSOR_ANALOG_PIN)/Ro,GAS_LPG) );
          Serial.print( "ppm" );
          Serial.print("    ");
          Serial.print("CO:");
          Serial.print(MQGetGasPercentage(MQRead(MQ_SENSOR_ANALOG_PIN)/Ro,GAS_CO) );
          Serial.print("    ");
          Serial.print("SMOKE:");
          Serial.print(MQGetGasPercentage(MQRead(MQ_SENSOR_ANALOG_PIN)/Ro,GAS_SMOKE) );
          Serial.print("\n");
          if (valMQ != lastMQ) {
            send(msg.set((int16_t)ceil(valMQ)));
            lastMQ = ceil(valMQ);
          sleep(UPDATE_INTERVAL);
        /*----MQ2----*/
        /****************** MQResistanceCalculation ****************************************
        Input:   raw_adc - raw value read from adc, which represents the voltage
        Output:  the calculated sensor resistance
        Remarks: The sensor and the load resistor forms a voltage divider. Given the voltage
                 across the load resistor and its resistance, the resistance of the sensor
                 could be derived.
        float MQResistanceCalculation(int raw_adc)
          return ( ((float)RL_VALUE*(1023-raw_adc)/raw_adc));
        /***************************** MQCalibration ****************************************
        Input:   mq_pin - analog channel
        Output:  Ro of the sensor
        Remarks: This function assumes that the sensor is in clean air. It use
                 MQResistanceCalculation to calculates the sensor resistance in clean air
                 and then divides it with RO_CLEAN_AIR_FACTOR. RO_CLEAN_AIR_FACTOR is about
                 10, which differs slightly between different sensors.
        float MQCalibration(int mq_pin)
          int i;
          float val=0;
          for (i=0; i<CALIBARAION_SAMPLE_TIMES; i++) {          //take multiple samples
            val += MQResistanceCalculation(analogRead(mq_pin));
            delay(CALIBRATION_SAMPLE_INTERVAL);
          val = val/CALIBARAION_SAMPLE_TIMES;                   //calculate the average value
          val = val/RO_CLEAN_AIR_FACTOR;                        //divided by RO_CLEAN_AIR_FACTOR yields the Ro
          //according to the chart in the datasheet
          return val;
        /*****************************  MQRead *********************************************
        Output:  Rs of the sensor
        Remarks: This function use MQResistanceCalculation to caculate the sensor resistenc (Rs).
                 The Rs changes as the sensor is in the different consentration of the target
                 gas. The sample times and the time interval between samples could be configured
                 by changing the definition of the macros.
        float MQRead(int mq_pin)
          int i;
          float rs=0;
          for (i=0; i<READ_SAMPLE_TIMES; i++) {
            rs += MQResistanceCalculation(analogRead(mq_pin));
            delay(READ_SAMPLE_INTERVAL);
          rs = rs/READ_SAMPLE_TIMES;
          return rs;
        /*****************************  MQGetGasPercentage **********************************
        Input:   rs_ro_ratio - Rs divided by Ro
                 gas_id      - target gas type
        Output:  ppm of the target gas
        Remarks: This function passes different curves to the MQGetPercentage function which
                 calculates the ppm (parts per million) of the target gas.
        int MQGetGasPercentage(float rs_ro_ratio, int gas_id)
          if ( gas_id == GAS_LPG ) {
            return MQGetPercentage(rs_ro_ratio,LPGCurve);
          } else if ( gas_id == GAS_CO ) {
            return MQGetPercentage(rs_ro_ratio,COCurve);
          } else if ( gas_id == GAS_SMOKE ) {
            return MQGetPercentage(rs_ro_ratio,SmokeCurve);
          return 0;
        /*****************************  MQGetPercentage **********************************
                 pcurve      - pointer to the curve of the target gas
        Remarks: By using the slope and a point of the line. The x(logarithmic value of ppm)
                 of the line could be derived if y(rs_ro_ratio) is provided. As it is a
                 logarithmic coordinate, power of 10 is used to convert the result to non-logarithmic
                 value.
        int  MQGetPercentage(float rs_ro_ratio, float *pcurve)
          return (pow(10,( ((log(rs_ro_ratio)-pcurve[1])/pcurve[2]) + pcurve[0])));
        /*----MQ2----*/
        Best regards,
          mickecarlsson
          There are two errors:
          The serious one:
            Ro = MQCalibration(MQ_SENSOR_ANALOG_PIN); //Calibrating the sensor. Please make sure the sensor is in clean air
          If you look at where you have put your initializing code you will realize that the code is never run unless you make the UPDATE_INTERVAL so small that it is less than dht.getMinimumSamplingPeriod
          Change the setup() to this instead:
          The second one is this:
          You should only have one entry:
            sendSketchInfo("Temperature, Humidity and Gas", "1.1");
          • M mickecarlsson
            The serious one:
            Tommas
            @mickecarlsson
            Thank you very much guys!
            I had to modify things for openhab, it is better now. But...
            in openhab2 i get this in the log:
            2017-07-24 19:23:36.497 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 2 found in node 1
            2017-07-24 19:23:36.498 [WARN ] [rs.internal.gateway.MySensorsGateway] - Variable V_LEVEL not present
            Does someone know what i missed?
            Good afternoon!
              the first is just a debug message, the other I don't know what level is actually expecting
              T 2 Replies Last reply
                Tommas
                @gohan
                Dear Gohan!
                OK!
                I paste the new code again:
                //#define MY_RS485
                float lastTemp;
                float lastHum;
                bool metric = true;
                //normal operation
                #define         GAS_LPG                      (0)
                #define         GAS_CO                       (1)
                //unsigned long SLEEP_TIME = 30000; // Sleep time between reads (in milliseconds)
                unsigned long SLEEP_TIME = 5000; // Sleep time between reads (in milliseconds)
                //VARIABLES
                float valMQ =0.0;
                float lastMQ =0.0;
                DHT dht;
                  // sendSketchInfo("TemperatureAndHumidity", "1.1");
                  sendSketchInfo("Temperature, Humidity and Gas", "1.1"); /*MQ2*/
                  //present(CHILD_ID_MQ, S_SMOKE); /*MQ2*/
                    if (!metric) {
                    nNoUpdatesTemp = 0;
                    #ifdef MY_DEBUG
                    nNoUpdatesTemp++;
                    lastHum = humidity;
                    nNoUpdatesHum = 0;
                    #ifdef MY_DEBUG
                    nNoUpdatesHum++;
                /*----MQ2----*/
                  Serial.print("    ");
                  Serial.print("    ");
                  Serial.print("\n");
                /*----MQ2----*/
                         could be derived.
                  int i;
                  float val=0;
                  return val;
                  int i;
                  float rs=0;
                  return rs;
                  return 0;
                         value.
                /*----MQ2----*/```
                  Tommas
                  @gohan
                  Dear Gohan!
                  I realized that I can not transfer the gas sensors calculated value through the V_LEVEL variable used in the sketch, because on the openhab side i should use tripped type value i think...
                  So i think there is a missconfiguration between openhab item/sitemap configuration and the sketch.
                  The goal would be to display the mq2 sensor's calculated value, which i can use for alarm in the future, but now i will be happy about the value:)
                  Have a good day
                    For alarm you need to create a rule in Openhab that when value goes over a certain value it sets of the alarm
