  3. first battery powered DHT lux
10 Posts 2 Posters 2.3k Views 1 Watching
  • markjgabbM Offline
    markjgabbM Offline
    markjgabb
    hi guys so im trying to build my first sensor from scratch, its using the easyPCB @sundberg84 (CHEERS)!
    im having issues combining it all for the DHT
    i keep getting dht was not declared
    so its a battery sensor with a DHT 22 and a photo resistor for lux
    here is my code
    anyone with advice would be greatly appreciated
    // Enable debug prints
    #define MY_NODE_ID 3
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    #define CHILD_ID_LIGHT 2
    #define LIGHT_SENSOR_ANALOG_PIN A1
    unsigned long SLEEP_TIME = 600000; // Sleep time between reads (in milliseconds)
    #define SKETCH_NAME "loungeroom living sensor #1"        // Change to a fancy name you like
    #define SKETCH_VERSION "1"                    // Your version
    float lastTemp;
    float lastHum;
    boolean metric = true;
    int LightLevel = 0;
    int lastLightLevel;
    MyMessage LightMsg(CHILD_ID_LIGHT, V_LIGHT_LEVEL);
      present(CHILD_ID_HUM, S_HUM);
      present(CHILD_ID_LIGHTLEVEL, S_LIGHT_LEVEL);
      if (isnan(temperature)) {
        lastTemp = temperature;
        Serial.print("T: ");
        Serial.println(temprature);
      if (isnan(humidity)) {
          lastHum = humidity;
          Serial.print("H: ");
          Serial.println(humidity);
    int lightLevel = (1023-analogRead(LIGHT_SENSOR_ANALOG_PIN))/10.23;
      Serial.println(lightLevel);
          send(LightMsg.set(lightLevel));
          lastLightLevel = lightLevel;
      batM();
       delay(500);
       // Battery monitoring reading
       delay(500);
       // Calculate the battery in %
       if (batLoop > 2) {
       if (batteryPcnt > 100) {
         batteryPcnt=100;
           batLoop = 0;
         batLoop++;
    S 1 Reply Last reply
    • markjgabbM markjgabb
      here is my code
      float lastTemp;
      float lastHum;
      int LightLevel = 0;
      int lastLightLevel;
            lastHum = humidity;
        batM();
         delay(500);
         delay(500);
         if (batLoop > 2) {
           batteryPcnt=100;
             batLoop = 0;
           batLoop++;
      @markjgabb you need to install the external dht22 library and you forgot to declare dht. (DHT dht;)
      See my sketch https://github.com/sundberg84/MySensors2.0.0/blob/master/NorrHumAs/NorrHumAs.ino
        markjgabbM Offline
        markjgabb
        @sundberg84
        i copied your github one directly....
        but when i try to verify i get the following error
        exit status 1
        no matching function for call to 'DHT::DHT()'
          @sundberg84
          exit status 1
          @markjgabb did you install the library?
            markjgabbM Offline
            markjgabb
            i did install DHT library...but mine seems to be diffrent, if i manually include it i get dht_U.h
              markjgabbM Offline
              markjgabb
              wrote on last edited by markjgabb
              dht sensor library by adafruit installed version 1.3.0
                markjgabbM Offline
                markjgabb
                @sundberg84 copied a dht library from another computer i used last time i did mysensors work...now ive got that base sketch working....now to add the photo resistor
                  markjgabbM Offline
                  markjgabb
                  @sundberg84 champion and here is completed sketch which compiles without errors
                  #define MY_NODE_ID 14
                  #define MY_PARENT_NODE_ID 100
                  unsigned long SLEEP_TIME = 120000; // Sleep time between reads (in milliseconds)
                  DHT dht;
                  float lastTemp;
                  float lastHum;
                  int LightLevel = 0;
                  int lastLightLevel;
                        lastHum = humidity;
                    batM();
                     delay(500);
                     delay(500);
                     if (batLoop > 2) {
                       batteryPcnt=100;
                         batLoop = 0;
                       batLoop++;
                    DHT dht;
                    float lastTemp;
                    float lastHum;
                    int LightLevel = 0;
                    int lastLightLevel;
                          lastHum = humidity;
                      batM();
                       delay(500);
                       delay(500);
                       if (batLoop > 2) {
                         batteryPcnt=100;
                           batLoop = 0;
                         batLoop++;
                    @markjgabb - nice to hear!
                    I always use the librarys in the ext. MySensors folder: https://github.com/mysensors/MySensorsArduinoExamples/tree/master/libraries since they are known to work with the sketches in the build section.
                    Also note that you have fixed the ID and parent node now... you might want to remove those lines
                    atleast the parent_node_id because that is a repeater in my setup... so unless you have a repeater woth 100 as id this will not work.
                    If you have flashed this to the node, it might be a good idea to clear the eeprom before flashing the new sketch without the parent_node_id feature.
                      markjgabbM Offline
                      markjgabb
                      @sundberg84 nah just prrof of build at the moment...ill fix them with my proper node ID's when it's build time....waiting on step up's at the moment..... they seem to take a while when you find them cheaper
                      12.2k
