  3. MyController.org
  4. Remote Access
Remote Access
Scheduled Pinned Locked Moved MyController.org
13 Posts 5 Posters 5.4k Views 4 Watching
  • C Offline
    C Offline
    cjm4909
    Is there an easy way to access the MyController web interface from outside my local network?
    • N Offline
      N Offline
      niccodemi
      @cjm4909 it is very easy if you just open the port of your Mycontroller web address (default 8443) on your router. If you've got dynamic IP from your ISP you can always apply for ddns provider.
      • C Offline
        C Offline
        cjm4909
        Thank you I will take a look
        • Velo17V Offline
          Velo17V Offline
          Velo17
          I have sort of the same question, but the easy way to give access to my Raspberry thru my router by using a DDNS service is not working for me, as I have a crippled dual stack lite IPv6 implementation.
          So I am more or less left to rely on the other way round: Push data from the home server into the internet. Is there a recommended way of doing this with mycontroller or more general mysensors? I am not using MQTT so far, just an ethernet gateway. For example Domoticz have this my.domoticz service which enables just this very easily.
          N 1 Reply Last reply
          • Velo17V Velo17
            N Offline
            N Offline
            niccodemi
            @Velo17 One of my linux servers is also behind double NAT network but I can still use DDNS service however update client has to be installed / configured on the server itself not on the router.
            Other option (if you are running Raspbian) would be Teamviewer.
            Velo17V 1 Reply Last reply
            • N niccodemi
              Velo17V Offline
              Velo17V Offline
              Velo17
              @niccodemi It's been already a couple of years ago when I last tried to get this running like you describe - actually in the IPv4 days. But that client I used doesnt work with IPv6 anymore. Can you tell me which client and maybe DDNS service you are using? And yes, I'm running Raspbian. True, last option would be Teamviewer.
              Thank you and greetings from Germany!
              • Velo17V Velo17
                N Offline
                N Offline
                niccodemi
                @Velo17 I am still on IPv4. I use DDClient as an update agent. I think it works with majority of providers such as NO-IP and DYNU.
                • Mitja BlazinsekM Offline
                  Mitja Blazinsek
                  any idea why i can't acess mycontroler from internet i was opening port 8443 for computer on which controller are running but still not open browser said ERR_INVALID_HTTP_RESPONSE, i was try to run domoticz controller and have no problem to accessing it from internet
                  • Mitja BlazinsekM Mitja Blazinsek
                    @Mitja-Blazinsek are you using https:// before the ip/host name? Which browsers have you tried and is the result the same in all of them?
                      Mitja Blazinsek
                      i try with and without https, i'm using chrome but also try explorer as i said domoticz work fine
                        N Offline
                        N Offline
                        niccodemi
                        @Mitja-Blazinsek I had similar issue. I found the cause was port 8443 itself. When I changed Mycontroller config to use another port (8442 or 8444) and opened it, I was able to access Mycontroller from external networks.
                          Mitja Blazinsek
                          still no success try chane the ports, shoul i chane anything else in config file like bind ip my settings in config file is:
                          mcc.web.bind.address=0.0.0.0
                          mcc.web.enable.https=true
                          mcc.web.http.port=8181
                          mcc.web.file.location=../www/
                          mcc.web.ssl.keystore.file=../conf/keystore.jks
                          mcc.web.ssl.keystore.password=mycontroller
                          mcc.web.ssl.keystore.type=JKS
                            Mitja Blazinsek
                            it works now i disabled https, and it works fine thanks folks for help :)
